JamesR
Everything posted by JamesR
Small briefcase, cobra buckle, archery inspired.
JamesR posted a gallery image in Gallery- Our Leatherwork
From the album: Current work
This small case is made of black and burgundy latigo. I went to 6 spi from 5 spi. I think the 6 looks better but I am not sure about the strength? I tried to use an archery design element to secure the buckle, not sure if i was successful. -
New Year, New Challenge!
JamesR replied to FaireLeatherFriend's topic in Special Events, Contests and Classes
I like it, thanks -
Thor, That is a great looking case but I am having trouble understanding how it works? When the phone is inside does the semi circle flap hold it in? Do you remove the flap to get the phone out? Jim -
Is it possible to burnish the edges of bison leather? The samples I have are too soft and flexible.
http://www.dotfasteners.com/index.html They make different length posts. I use the Press-n-snap tool, it works great.
I know in Stolhman's book on stitching he advises that the stitch line be the same distance as the total thickness of the sewn parts. I can see how this might not look right on some sheaths or holsters. I guess my question really has to do with the strength of the stitchline. Depending on the cord size,spi and awl size how much leather does one need to the edge for strength. I imagine the grain of the leather might also be relevant.
Smokeypoint, Thank you for another way of looking at this. .4" seems like a lot but it looks good in you photo. How heavy was the cord you used?
George, Just briefcases and shoulder bags, no hard cases. Last piece I had was 8 oz. I will drop down to 6 oz. and see what it is like. Thanks again Jim
Thanks to both of you. I guess I will stick with bridle. I was looking for something that might be more flexible for the same weight as bridle. W&C will "stake" the leather to soften it. Do you think staking makes it harder to burnish an edge?
George3, I like W&C bridle too. It is what I have been using. I was wondering how different their harness would be. When you say water proof do you mean the harness leather has more oil or wax?
I want to try some russet colored harness leather for a briefcase. Would this be a good choice or should I stick with bridle leather? How do they differ?
Thanks again!
- 19 replies
- briefcase
- laptop bag
(and 5 more)
Thanks for the tip on the glue. I never would have considered the heat issue. One more thing, I know I can cut the metal with carbide saw blades but can you profile it with routers? Thanks again.
- 19 replies
- briefcase
- laptop bag
(and 5 more)
Seeing such masterful work like this from you and others on this site is a reality check for me. It shows me how far away from it I am. About the hardware. What are you using to attach the brass and wood together with? I am mainly a woodworker so using wood and brass really interests me. Does brass work as easily as aluminum? Thanks Jim
- 19 replies
- briefcase
- laptop bag
(and 5 more)
Axe Sheath - Copper Rivet Intro
JamesR replied to eby's topic in Gun Holsters, Rifle Slings and Knife Sheathes
This green corrosion concerns me. I thought it only happened with chrome tanned not veg tanned leather? -
Thick latigo briefcase with quick release buckle
I wanted to do something rugged with some thick latigo (about 10 oz.) I had. I used these very high quality and very strong buckles. Should last a while. -
Thanks to both. I like the look of that seam ripper.
Lets say you need to remove a stitch line without damaging the leather surface. What tools and methods do you use?
OLDNSLOW Yes this is an old thread. In addition to the different lengths I have found you can use the cap portion as a backing for the turn button.
I made this a number of years ago. It uses the metal screw from a Jorgensen woodworking clamp. It is made of ash with maple jaws.I have it mounted on a low bench which doubles as a seat. It is set up for a lefty. The extended handle on the left is far enough away to prevent the cord from getting tangled. The throat depth is about 12 1/2" to the top of the jaws. (Wish I had made it deeper)
