Members Mungo Posted April 7, 2022 Members Report Posted April 7, 2022 Sometimes after I’ve sewn my leather work the threads pick up the dye and appear dirty. Is there a way to clean them to make them nice and white again? Quote
Members Bert03241 Posted April 7, 2022 Members Report Posted April 7, 2022 throw them in the washing machine No seriously I don't see how, any attempt to wash the stitch line would risk getting more dye on them I would think. Quote
Members Mungo Posted April 7, 2022 Author Members Report Posted April 7, 2022 I tried using wet cotton swabs. It helped a little, but not enough. Quote
Members Eager2Learn Posted April 7, 2022 Members Report Posted April 7, 2022 Saddle soap. Soap makes things clean. Quote
CFM tsunkasapa Posted April 7, 2022 CFM Report Posted April 7, 2022 1 hour ago, Eager2Learn said: Saddle soap. Soap makes things clean. Soap will not get dye out of thread. Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
Members Tugadude Posted April 7, 2022 Members Report Posted April 7, 2022 3 hours ago, Mungo said: Sometimes after I’ve sewn my leather work the threads pick up the dye and appear dirty. Is there a way to clean them to make them nice and white again? Is the thread waxed? If so it could be on the surface and may rub off with a clean cloth. That’s one good reason to wax thread. Quote
Members chiefjason Posted April 7, 2022 Members Report Posted April 7, 2022 (edited) Let the leather dry thoroughly. Usually a few hours. Pull off extra thread, the ends get most of the transfer Keep the needles close to the ends, the thread at the needle gets a lot of dye. If your thread is soft look for a hard bonded nylon thread, The bonded coating does not pick up as much. Edited April 7, 2022 by chiefjason Quote
Members JayEhl Posted April 7, 2022 Members Report Posted April 7, 2022 I've read how some use a natural color thread and then dye after you sew. Not sure if its an option but just thought I'd throw that out there. Quote
Members Zonker1972 Posted April 7, 2022 Members Report Posted April 7, 2022 send a sacrificial piece of thread about a foot long on a needle through the holes and then throw it away. now stitch up and hopefully have cleaner thread holding the project together. Quote
Members JayEhl Posted April 7, 2022 Members Report Posted April 7, 2022 That's a good idea @Zonker1972 Quote
PastorBob Posted April 7, 2022 Report Posted April 7, 2022 7 hours ago, chiefjason said: Let the leather dry thoroughly. Usually a few hours. Pull off extra thread, the ends get most of the transfer Keep the needles close to the ends, the thread at the needle gets a lot of dye. If your thread is soft look for a hard bonded nylon thread, The bonded coating does not pick up as much. +1. I normally measure the distance I am stitching, multiply that by 4, then add a bit for thread length. I use .8mm thread and saddle stitch. Most of the dye transfer is on the ends which are cut off when done. Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
Contributing Member fredk Posted April 7, 2022 Contributing Member Report Posted April 7, 2022 1 hour ago, PastorBob said: +1. I normally measure the distance I am stitching, multiply that by 4, then add a bit for thread length. I use .8mm thread and saddle stitch. Most of the dye transfer is on the ends which are cut off when done. Quote Al speling misteaks aer all mi own werk..
Contributing Member fredk Posted April 7, 2022 Contributing Member Report Posted April 7, 2022 btw, on the odd occasion when I reckoned a thread was too grubby, I pulled the thread out and re-stitched with new clean thread Thread is cheap. You'll spend / waste more time trying to clean a length of thread worth less than 0.1c than its worth. Pull it out and re-stitch and be done with it. Also trying various solutions on the thread to try to clean it may damage the leather or its finish, and that bit is ultimately worth more Quote Al speling misteaks aer all mi own werk..
Members TomE Posted April 7, 2022 Members Report Posted April 7, 2022 17 hours ago, Mungo said: Sometimes after I’ve sewn my leather work the threads pick up the dye and appear dirty. Is there a way to clean them to make them nice and white again? I assume you follow the usual practices to minimize dye ruboff. Fiebings Pro Dye and Fenice Colorfast dye produce less ruboff than other dyes I've tried. Prior to sewing, buff the work with a soft cloth until there's no more dye rubbing off. I quit using Tan Kote as a finish after sewing because it works like a dye solvent and discolors even bonded nylon thread. Then there's the failsafe - use dark colored thread. Quote
Members Mungo Posted April 8, 2022 Author Members Report Posted April 8, 2022 Thanks for the replies. I’ll be using those suggestions in the future. Quote
PastorBob Posted April 8, 2022 Report Posted April 8, 2022 10 hours ago, Mungo said: Thanks for the replies. I’ll be using those suggestions in the future. Also, are you punching your holes before or after dyeing? After is much better, dye can't sit in the holes then. Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
