Members Norwegian Posted June 30, 2022 Members Report Posted June 30, 2022 Would it be possible to make a presser foot somehow? It's hopeless to find feet for a Singer 45K58. Would 3d plastic be too soft/get worn out too fast? Quote
Members Constabulary Posted June 30, 2022 Members Report Posted June 30, 2022 (edited) Adler 4, 104, 5, 105 (jump foot versions) used similar feet but they are as rare as the Singer 45K feet. I had 20 or so different feet (Singer and Adler) but sold most of them some weeks ago cause I never used them. I have 5 left but I have no chance to check if they suit the 45K58 in particular cause some feet require certain feed dogs. I have two I could part with but said said not sure if they fit the 45K58. a left and right toe foot - kind of. Edited June 30, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted June 30, 2022 Members Report Posted June 30, 2022 I have feet for 45 K machines for sale. Will be posting pics of them next week. glenn Quote
Members Norwegian Posted June 30, 2022 Author Members Report Posted June 30, 2022 27 minutes ago, Constabulary said: Adler 4, 104, 5, 105 (jump foot versions) used similar feet but they are as rare as the Singer 45K feet. I had 20 or so different feet (Singer and Adler) but sold most of them some weeks ago cause I never used them. I have 5 left but I have no chance to check if they suit the 45K58 in particular cause some feet require certain feed dogs. I have two I could part with but said said not sure if they fit the 45K58. a left and right toe foot - kind of. Thank you! I'm not sure I should try, will need some changes.. Let me get some measurements tomorrow. Quote
Members Norwegian Posted June 30, 2022 Author Members Report Posted June 30, 2022 9 minutes ago, shoepatcher said: I have feet for 45 K machines for sale. Will be posting pics of them next week. glenn Glenn, thank you! Like the ones in my picture? There are different feet for different 45K models. Quote
Members dikman Posted June 30, 2022 Members Report Posted June 30, 2022 In answer to your question, no, 3D plastic feet would not last long! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Michiel Posted July 1, 2022 Members Report Posted July 1, 2022 I made a “new” foot for a a machine with a rare seize by cutting off the upper part off a more standard foot and doing some welding and grinding (in my case i made a combination of the upper part from one foot and the lower part of another one) It did not look very appealing because i did not bother grinding of the weld but it worked perfect (I did not take a photo and do not have it here at the moment) Quote
Members chrisash Posted July 1, 2022 Members Report Posted July 1, 2022 (edited) You could make them in 3D using nylon Taulman 230 on most printers, should last much longer than PLA or ABS, and hopefully take more stress, nothing to loose and easy to replace if they wear out https://www.amazon.co.uk/Taulman-Nylon-Printing-Filament-Black/dp/B01MTK1JAG Edited July 1, 2022 by chrisash Quote Mi omputer is ot ood at speeling , it's not me
RockyAussie Posted July 1, 2022 Report Posted July 1, 2022 I ran into a similar problem on my 331 pfaff awhile back. I ground too much off the right side of the foot and it broke so I made one up using a bit of flat metal off some machine that felt like it had a bit better than mild steel carbon to it. The piece was just a tad thicker than the foot and wide enough to do the job. This was all done using a drill for the slot hole end, a thin disc in an angle grinder, a Dremel thin cutting disc and a bit off polishing on a rag wheel with some Tripoly polishing compound. The Pfaff foot on the right has the broken foot at the back Cutting out the straight part here was the hardest part to do because you have to be careful not to go over deep. You can see here where I have made the right side thin to get my guide up closer to the needle than the standard foot allowed Here you can see it mounted on my machine. This allows me to stitch with the guide within 2.5mm from the edge. Time taken just over 2 hours but I have done a few before this one as well at other times. (Wear safety glasses) Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Norwegian Posted July 1, 2022 Author Members Report Posted July 1, 2022 6 hours ago, RockyAussie said: I ran into a similar problem on my 331 pfaff awhile back. I ground too much off the right side of the foot and it broke so I made one up using a bit of flat metal off some machine that felt like it had a bit better than mild steel carbon to it. The piece was just a tad thicker than the foot and wide enough to do the job. This was all done using a drill for the slot hole end, a thin disc in an angle grinder, a Dremel thin cutting disc and a bit off polishing on a rag wheel with some Tripoly polishing compound. The Pfaff foot on the right has the broken foot at the back Cutting out the straight part here was the hardest part to do because you have to be careful not to go over deep. You can see here where I have made the right side thin to get my guide up closer to the needle than the standard foot allowed Here you can see it mounted on my machine. This allows me to stitch with the guide within 2.5mm from the edge. Time taken just over 2 hours but I have done a few before this one as well at other times. (Wear safety glasses) Wow! Nice! Quote
