Members BoogieMan2718 Posted November 2, 2022 Members Report Posted November 2, 2022 Hello, I am still relatively new to leatherwork as a hobby and I have bought all of the basic tools I need and made a few tools as well. I would love to have a set of good oblong punches but they are quite pricey! So, in your experience, if you could only have one size of oblong punch to do as much different punching as possible what width and length would it be? I have already considered making sure it is short because I can always step it forward to lengthen the punched area. Also, I have been looking at C.S. Osborne, but does anyone have any other good brand recommendations? Quote
CFM chuck123wapati Posted November 2, 2022 CFM Report Posted November 2, 2022 what do you make the most of? Quote
Doc Reaper Posted November 2, 2022 Report Posted November 2, 2022 (edited) I have need for only one and it is a 3/16th, it is used for belts to make the tounge lie down better. I’m sure a round hole, the same size, would do just as well but the oval looks better I also have bag punches purchased at different times that measure 3/4 of an inch up to 2 1/4 inches please be just a bit clearer on its use, I started out using 1 inch oblong and moved up to a 1 1/4 inch oblong to make the tounge slot on belts and straps Edited November 2, 2022 by Doc Reaper Clear statement Quote
Members doubleh Posted November 2, 2022 Members Report Posted November 2, 2022 I have never owned one. I use the size hole punch I want on each end and cut the sides out with the appropriate sized wood chisel. When I started this long ago I had the wood chisels and not much money. It worked and I have stuck with it. Quote
Members BlackDragon Posted November 2, 2022 Members Report Posted November 2, 2022 I needed a couple of oblong punches but really didnt want to spend big money on them because I saw a few bad reviews on the big name brands. They stated the punches were dull and didnt hold up well. I took the chance on a set of cheap punches. There were 7 sizes in the set and only needed 2 of them, for $13 it wouldn't have be a big loss if they were junk. Once I got them they went right to my sharpening stones. They work great! They go right through 10oz leather and so far they're holding their edges. Quote
Members Tugadude Posted November 2, 2022 Members Report Posted November 2, 2022 Unless you use them a lot, just become proficient using round hole punches for the ends and then cut straight lines connecting them. If I made a ton of belts, I'm probably invest in one. If you are new, and you insist on having them, maybe look for some el cheapo imports for the time being. I know the old saying "buy once, cry once" as a reason to invest in quality, but if you are only going to use them a couple times a year is it really wise? If you use them regularly, then sure, buy a good set. Use your resources to invest in higher quality versions of what you DO use regularly. That's my free advice, and worth every penny! Quote
Members Burkhardt Posted November 3, 2022 Members Report Posted November 3, 2022 Check out @Oak Grove Leather Works he's selling all his tools and might have what you're looking for. Quote
Moderator bruce johnson Posted November 3, 2022 Moderator Report Posted November 3, 2022 I assume you are talking about slot or bag punches because some places do call them oblong punches. If not, ignore this. There is a general recommendation floating around to make the slot for a buckle the width of the strap. I don't like that. On a 1/2 strap that may not be enough or too much depending on thickness or buckle length. On a 1-1/2" it may be sloppy. On my smaller stuff usually a 5/8" was good. On a belt 7/8" was usually good. One horse gear with thick leather up to a 1-1/2 for back cinch buckles. Disclaimer - I deal in leather tools and have some opinions on makers/styles and generally they are wrong according to some email replies and phone messages I get. Feel free to contact me privately and we can discuss my opinions. Easiest way is through my website and there should be a link below. Quote
Members dannyd Posted November 4, 2022 Members Report Posted November 4, 2022 On 11/2/2022 at 1:02 PM, doubleh said: I have never owned one. I use the size hole punch I want on each end and cut the sides out with the appropriate sized wood chisel. When I started this long ago I had the wood chisels and not much money. It worked and I have stuck with it. That is an excellent idea I have a old Stanley set from 50 years ago 1/8 to 2". Quote
Members Gezzer Posted November 4, 2022 Members Report Posted November 4, 2022 I finally broke down and bought a cheap 3/4 " oblong , I used it twice and went back to hole punch and cutting to connect the dots . But if I did a lot of that type stuff , I could see dropping some $ on a good set . Quote
Members Matt S Posted November 4, 2022 Members Report Posted November 4, 2022 My strategy with tools is thus. It's partially based on having a small workshop: (1) Unless you luck into a ridiculously good bargain or something usually unobtainable, only buy tools as you need them not as you find them. There's not much sense in having money and space tied up with "just in case" tools that you never use, except for emergency/safety stuff. I'm glad to have that fire extinguisher on the wall and would be happy if I never have to use it, but I don't see it as a waste of money or space. I don't know why I have 3 different sets of loop sewing jaws when none of them fit my sewing clams. (2) If you're confident that a tool will help you, buy they best quality tool you can afford -- a good quality tool will last longer, be repairable/serviceable, will retain more value if you decide to sell it on, will help you work faster/easier/cleaner and will be cheaper in the long run ("cost per use") over a lower quality one. Generally price correlates with quality. A few years ago I needed a 1.5" crew/oblong punch and bought an Ivan (cheap, from Taiwan) for £25. It crumpled on the second hole. I bought a replacement from Osborne (made in USA) at double the price and it's many times the value to me in terms of a clean and consistent cut, reliability, and ease of use. Inflation also means that, were I to sell it tomorrow, I would probably break even on what I paid for it as well as the the value of what I made with it. That Ivan brand steel pretzel now has almost zero value. (3) If you're not sure whether a tool will help you evaluate its utility by borrowing one or buying the cheapest version that will function for your intended use. If it's useful use it until it wears out or holds you back and replace it with the best quality version you can find. (4) Every so often, declutter by putting everything you haven't used in a while into a box. Put that box somewhere a bit inconvenient, so if you suddenly need to use it you can get it. If you haven't used that tool for a while you probably don't use it and can sell it or give it away. Again, this doesn't apply to the fire extinguisher or a tool that you genuinely use for an occasional specific job. (5) At the risk of echoing rule #1: if you're not a collector you don't need every tool. If you're happy making a crew slot with a round punch and a knife, keep doing it! Quote
Members BoogieMan2718 Posted November 7, 2022 Author Members Report Posted November 7, 2022 On 11/2/2022 at 1:02 PM, doubleh said: I have never owned one. I use the size hole punch I want on each end and cut the sides out with the appropriate sized wood chisel. When I started this long ago I had the wood chisels and not much money. It worked and I have stuck with it. This is what I have been doing minus using a wood chisel to connect the dots. That is brilliant and I think I will give that a try first. I am thinking you can probably get really clean slots with this method. Do you have any good tricks for round ends and English points? On 11/4/2022 at 12:20 PM, Matt S said: My strategy with tools is thus. It's partially based on having a small workshop: (1) Unless you luck into a ridiculously good bargain or something usually unobtainable, only buy tools as you need them not as you find them. There's not much sense in having money and space tied up with "just in case" tools that you never use, except for emergency/safety stuff. I'm glad to have that fire extinguisher on the wall and would be happy if I never have to use it, but I don't see it as a waste of money or space. I don't know why I have 3 different sets of loop sewing jaws when none of them fit my sewing clams. (2) If you're confident that a tool will help you, buy they best quality tool you can afford -- a good quality tool will last longer, be repairable/serviceable, will retain more value if you decide to sell it on, will help you work faster/easier/cleaner and will be cheaper in the long run ("cost per use") over a lower quality one. Generally price correlates with quality. A few years ago I needed a 1.5" crew/oblong punch and bought an Ivan (cheap, from Taiwan) for £25. It crumpled on the second hole. I bought a replacement from Osborne (made in USA) at double the price and it's many times the value to me in terms of a clean and consistent cut, reliability, and ease of use. Inflation also means that, were I to sell it tomorrow, I would probably break even on what I paid for it as well as the the value of what I made with it. That Ivan brand steel pretzel now has almost zero value. (3) If you're not sure whether a tool will help you evaluate its utility by borrowing one or buying the cheapest version that will function for your intended use. If it's useful use it until it wears out or holds you back and replace it with the best quality version you can find. (4) Every so often, declutter by putting everything you haven't used in a while into a box. Put that box somewhere a bit inconvenient, so if you suddenly need to use it you can get it. If you haven't used that tool for a while you probably don't use it and can sell it or give it away. Again, this doesn't apply to the fire extinguisher or a tool that you genuinely use for an occasional specific job. (5) At the risk of echoing rule #1: if you're not a collector you don't need every tool. If you're happy making a crew slot with a round punch and a knife, keep doing it! Very good points you have made here. I am trying to keep the tools at a minimum and find ways to use individual tools for multiple uses. Also, I have become a believer in the "buy once cry once" line of thinking for tools that get a lot of use. Thanks for the input. Quote
Members doubleh Posted November 8, 2022 Members Report Posted November 8, 2022 For round and pointed ends I just cut them with a knife and sand to shape with a drum sander in my drill press. Slow I know, but I did this in my selling days because of the little money thing and I devised ways to use tools I already had. No need for speed now. Quote
stelmackr Posted November 8, 2022 Report Posted November 8, 2022 On 11/4/2022 at 9:20 AM, Matt S said: (4) Every so often, declutter by putting everything you haven't used in a while into a box. Put that box somewhere a bit inconvenient, so if you suddenly need to use it you can get it. If you haven't used that tool for a while you probably don't use it and can sell it or give it away. Again, this doesn't apply to the fire extinguisher or a tool that you genuinely use for an occasional specific job. Wish I had this advice 30-years ago. ;-) Quote
Members seabee Posted November 8, 2022 Members Report Posted November 8, 2022 Hi, all I use round hole punches and sharp woodworking chisels for the side, no need for bag punches. Howard Quote
