MtlBiker Posted March 28, 2024 Report Posted March 28, 2024 I just saw the latest Sailrite how-to project... just a simple waxed canvas and cordura dopp bag, with leather accents. For all the leather accents they said to apply Neatsfoot oil BEFORE the Fiebings Dye. That surprised me as I'd always thought you apply the oil (if not using a different product) after dying the leather. Is doing it their way common? Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Members billybopp Posted March 28, 2024 Members Report Posted March 28, 2024 12 minutes ago, MtlBiker said: I just saw the latest Sailrite how-to project... just a simple waxed canvas and cordura dopp bag, with leather accents. For all the leather accents they said to apply Neatsfoot oil BEFORE the Fiebings Dye. That surprised me as I'd always thought you apply the oil (if not using a different product) after dying the leather. Is doing it their way common? It's not uncommon to add a very light coat of NFO before dying. Folks say that it helps even out the dye when applied. Some will even mix NFO and dye. I haven't tried either and can't attest to whether it works or not. - Bill Quote
Northmount Posted March 28, 2024 Report Posted March 28, 2024 Moved to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners. Quote
kgg Posted March 28, 2024 Report Posted March 28, 2024 (edited) 51 minutes ago, MtlBiker said: For all the leather accents they said to apply Neatsfoot oil BEFORE the Fiebings Dye. My limited experience is using a spray gun for dying. First we dyed allowing it to penetrate into the leather then oiling. Once you get it to the shade you want let it dry and then oil. Oiling first I think would only provide another barrier to the dye. Just my experience, kgg Edited March 28, 2024 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Dwight Posted March 29, 2024 Members Report Posted March 29, 2024 A few years back I was having trouble with my light tan dyes . . . not being even . . . especially saddle tan. I don't recall the impetus that moved me to try oiling first . . . I did . . . have NEVER had another problem like that since. I use a cheap pig hair brush from Harbor freight . . . put on a very light coat . . . just enough to make it look wet . . . Let it "dry" for 24 hours . . . the dye goes on perfect . . . every time. I don't always oil for black . . . it depends on the leather . . . But if it is anything other than black . . . it ALWAYS gets oiled first. That is for all my holsters . . . belts . . . sheaths . . . and gun cases . . . which is mainly what I do. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members bladegrinder Posted March 29, 2024 Members Report Posted March 29, 2024 18 minutes ago, Dwight said: A few years back I was having trouble with my light tan dyes . . . not being even . . . especially saddle tan. I don't recall the impetus that moved me to try oiling first . . . I did . . . have NEVER had another problem like that since. I use a cheap pig hair brush from Harbor freight . . . put on a very light coat . . . just enough to make it look wet . . . Let it "dry" for 24 hours . . . the dye goes on perfect . . . every time. I don't always oil for black . . . it depends on the leather . . . But if it is anything other than black . . . it ALWAYS gets oiled first. That is for all my holsters . . . belts . . . sheaths . . . and gun cases . . . which is mainly what I do. May God bless, Dwight Same here, I always use oil. I put it on then dye the next day. Quote
MtlBiker Posted March 29, 2024 Author Report Posted March 29, 2024 @kgg @Dwight and @bladegrinder - Thanks for your comments. I forgot to check last night when I got home, what the product is that I've been using for leather prep before applying dye, but it was some commercial product. Used to de-glaze the leather and remove contaminants. Until now, I never thought of using NFO before dyeing. I'm going to have to give it a try. Thank you all. Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Members Dwight Posted March 30, 2024 Members Report Posted March 30, 2024 10 hours ago, MtlBiker said: @kgg @Dwight and @bladegrinder - Thanks for your comments. I forgot to check last night when I got home, what the product is that I've been using for leather prep before applying dye, but it was some commercial product. Used to de-glaze the leather and remove contaminants. Until now, I never thought of using NFO before dyeing. I'm going to have to give it a try. Thank you all. Just one quick note . . . when you go for example to Tandy's or other leather shops . . . the cheap stuff will be Neatsfoot oil "compound" . . . which is a conglomerate of oils. Buy the pure neatsfoot oil . . . it's a bit more expensive . . . but it's the good stuff . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members GatoGordo Posted March 30, 2024 Members Report Posted March 30, 2024 Just a reminder. If you do use neatsfoot oil, check at your local feed store. They also sell Fiebing's 100% Pure Neatsfoot Oil, but often at a lower price than the leather supply store. Quote
Members Chipster99 Posted March 31, 2024 Members Report Posted March 31, 2024 I buy Fiebings 100% Pure Neatsfoot Oil at Tractor Supply. Olive oil also works fine and you can get that at any grocery store. And I also agree with Dwight - oil then dye. Quote
