Members gw21 Posted January 21, 2025 Members Report Posted January 21, 2025 I'm a beginner and currently using a wooden cutting board made of oak for cutting leather with a head knife. I have a feeling that that cutting on wood makes the knife dull. So, can you please recommend some natural materials for cutting boards. I dislike using polymer/plastic products. What is the traditional surface for cutting leather with a head knife? Thanks. Quote
Members DieselTech Posted January 21, 2025 Members Report Posted January 21, 2025 I would just buy a plastic uhmw cutting board. Lmao if your worried about plastic, then you probably don't want to know what is in your leather. Quote
CFM chuck123wapati Posted January 21, 2025 CFM Report Posted January 21, 2025 2 hours ago, gw21 said: I'm a beginner and currently using a wooden cutting board made of oak for cutting leather with a head knife. I have a feeling that that cutting on wood makes the knife dull. So, can you please recommend some natural materials for cutting boards. I dislike using polymer/plastic products. What is the traditional surface for cutting leather with a head knife? Thanks. wood is fine leather doesn't know the difference. th board is to protect your blades and wooden Cutting boards are as old as knives. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Northmount Posted January 21, 2025 Report Posted January 21, 2025 3 hours ago, gw21 said: using a wooden cutting board made of oak for cutting leather with a head knife. Depending on how you are cutting, sometimes the knife wants to follow the wood grain. Self healing cutting mats are nice as they are all marked out in measured squares making it easier to layout and cut straight lines with a guide rule. Quote
Members TonyV Posted January 21, 2025 Members Report Posted January 21, 2025 (edited) Yes, wood contributes to your knife getting dull. Just think of all the opportunity you have to get really good at sharpening and stropping! If you're determined to avoid plastic surfaces, try a softer wood surface, such as plywood, which you would be able to easily replace when needed. But really, the best cutting surfaces are made of plastic. Many of them are made of recycled plastic, if that helps. Edited January 21, 2025 by TonyV Quote
Members nylonRigging Posted January 21, 2025 Members Report Posted January 21, 2025 1 hour ago, TonyV said: Yes, wood contributes to your knife getting dull. Just think of all the opportunity you have to get really good at sharpening and stropping! If you're determined to avoid plastic surfaces, try a softer wood surface, such as plywood, which you would be able to easily replace when needed. But really, the best cutting surfaces are made of plastic. Many of them are made of recycled plastic, if that helps. Soft cutting boards really sucks the sharpness edge off the blades, I use a lot of the Poly. cutting boards and razor knife everyday. from what I understand the #1 Best Cutting Board materials is .. Acetel Copolymer . Delrin is another but more expensive. . Quote
Members TomE Posted January 21, 2025 Members Report Posted January 21, 2025 I covered my work table with white HDPE (https://www.menards.com/main/building-materials/panel-products/plastic-utility-panels/1-4-x-4-x-8-hdpe-panel/whtkhdpe48x96x220/p-1561703293086-c-14048.htm). Less drag = much easier to control the knife, compared to plywood or the self-healing mat that I previously used. The white color brightens up my workshop and helps me see the work. Quote
Members jcuk Posted January 22, 2025 Members Report Posted January 22, 2025 I use MDF no drag and does not dull the edge once its to cut up on one side turn it over, just remember to only use it for cutting because it will scratch your work. Hope this helps JCUK Quote
Contributing Member fredk Posted January 22, 2025 Contributing Member Report Posted January 22, 2025 For rough-out cutting I use one of these hook blades. It doesn't cut into any board. With care it can be use to cut right on the pattern line For finish cutting I either use shears/scissors or a knife on a self-healing cutting mat Quote Al speling misteaks aer all mi own werk..
Northmount Posted January 23, 2025 Report Posted January 23, 2025 17 hours ago, jcuk said: I use MDF I've seen bits of metal embedded in MDF. Fine for stropping since you're not cutting into it, really smooth. Quote
