Members Mockingbird Posted May 3, 2017 Members Report Posted May 3, 2017 What's your preferred screwdrivers for machine maintenance? I have to replace a hook and base for a cylinder machine, and all my screwdrivers are too long to access the screws with enough clearance. I've seen right angle ratchet types and just using mini screwdrivers on youtube videos being used. For those that have been through a few, what did you settle on? Quote
Members gottaknow Posted May 3, 2017 Members Report Posted May 3, 2017 All of my screwdrivers are SnapOn brand. The tips are hardened which work nicely on hardened screws. For tight spots, I prefer 1/4" insert bits. I apply torque with a box end 1/4" wrench. If need be, I wedge a screwdriver on top of the insert bit for downward pressure. I also use SnapOn insert bits, they last the longest. I've also built many custom tools where nothing is available for a specific task. Regards, Eric Quote
Members JD62 Posted May 3, 2017 Members Report Posted May 3, 2017 Gottaknow said almost word for word what I was thinking! Howd you do that? Quote One day at a time my friends John
Contributing Member fredk Posted May 3, 2017 Contributing Member Report Posted May 3, 2017 Never be afraid to cut or file a tool to suit the job. Most tools are made for general purpose use. Just cut one down & re-handle to suit your job. I have a vintage racing car; most of the tools I need are no longer available so I just cut, file and weld up tools to do the work Quote Al speling misteaks aer all mi own werk..
Members dikman Posted May 3, 2017 Members Report Posted May 3, 2017 A long time ago I bought a small ratchet handle that takes 1/4" bits and found it very useful on sewing machines. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
bikermutt07 Posted May 3, 2017 Report Posted May 3, 2017 Wiha has some really well made screw driver sets. Top quality stuff. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members trash treasure Posted May 3, 2017 Members Report Posted May 3, 2017 Get a set of Chapman gunsmith screwdrivers - Wouldn't be without them : https://chapmanmfg.com/collections/slotted-flathead-sets/products/8900-standard-set-12-slotted-bits Quote The model number giveth, and the subclass taketh away ......... Sometimes
Members Mockingbird Posted May 3, 2017 Author Members Report Posted May 3, 2017 On 5/3/2017 at 11:05 AM, trash treasure said: Get a set of Chapman gunsmith screwdrivers - Wouldn't be without them : https://chapmanmfg.com/collections/slotted-flathead-sets/products/8900-standard-set-12-slotted-bits Expand "Great for firearms, weapons, dental and lab equipment, sewing machines and fishing reels" ...and it comes in pink! Thanks for the suggestions, mini ratchet with lots of bits worked out well. Quote
Members gottaknow Posted May 3, 2017 Members Report Posted May 3, 2017 This is about half of my SnapOn screwdrivers. I keep a duplicate set in our Seattle factory so when I fly over to help out or teach, I don't have to put my tools into checked baggage. Saves a ton of time at airports. In the old days, (pre 911) I would just carry them on in an attaché. Some of the handles in the picture have been around since the 80's, with the blades being replaced when they begin too get dull. I always start out an apprentice mechanic with a set as well. I like their electronic series because they are not flared out at the blade tip. There are a lot of places on machines where the taper won't fit down a set screw hole. I buy those in 1/16", 1/8" and 3/16" blade width. The larger screwdrivers have a hex built in just below the handle. You can use a box end wrench to apply some serious torque to pop a stubborn screw loose. Regards, Eric Quote
Members SolarLeatherMachines Posted May 3, 2017 Members Report Posted May 3, 2017 When I was living in Europe, and learning to wrench over there, I was introduced to Beta tools. All German made, and super nice. I really line the grips and the quality is second to none. Dealers are hard to find, but they have a tool for dang near everything. http://www.peerless-betatools.com/products/details/1294-3X100-SCREWDRIVERS-HEADLESS-SLOTTED Quote Alexander
Members Yetibelle Posted May 3, 2017 Members Report Posted May 3, 2017 The old off-set screw drivers work really well, I have torqued on some of those flat head screws and they don't move, then I tried the off-set and they come right out. I wish I could find them in every size Don't forget the magnet tray, they are so handy. Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Members brmax Posted May 3, 2017 Members Report Posted May 3, 2017 This is my best choice for this work, i have found different bits available in this set that really! fit The 15 series jukis i work on and also a singer have why i dont know, several different screw heads. It is surprising that this kit mentioned is way beyond the standard drivers. https://www.amazon.com/Wheeler-89-Piece-Deluxe-Gunsmithing-Screwdriver/dp/B001C63M7O In the shop i keep a standard set of snap on screw drivers. I always have liked the ability to use a wrench with these in stabilizing and putting some extra torque for removal. I never had any nice x-long drivers, but do agree the electric series offer some of interest for special work. The craftsman black handle drivers i always liked as the blasted tips i thought were spot on for fit in most standard screws. The handles i liked better than the old clear, red and blue. This brand was my only purchase for service truck and shop box before retiring. I had an apprentice box in 80 with snap on drivers and traded it with new job position that required a service truck. Since then for pro money use i used craftsman for drivers and snap on tools for everthing else. I did work in a set of matco torx drivers for lite work and the handles were pretty darn nice. All things considered i really wish i had invested in the wheeler set for special work long ago, really just needed at the home for special work. When your setting there with a parker or a beretta you should have a proper tool before movin ahead. Good day Floyd Quote
Members Gregg From Keystone Sewing Posted May 3, 2017 Members Report Posted May 3, 2017 These are some of the best darn, tried and true screwdrivers I can find, and I've tried a lot of 'em. Don't want to drop brand names, but I can attest to the fact that they were made here in USA. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Darren Brosowski Posted May 5, 2017 Members Report Posted May 5, 2017 I use my trusty electrical screwdrivers but have a variety of older types that have been ground to shape for various jobs. Quote
Members Stuggi Posted May 6, 2017 Members Report Posted May 6, 2017 (edited) Wera makes nice screwdrivers, and with the most common from Wera and an assortment of older random brand stubby ones I usually get by. Flat blade screwdrivers are a bit odd in that regard that you need a lot more of them than the Phillips and Pozidrive ones. If you want to get really picky, you should pick up a bits set for gunsmithing, they usually have a huge array of different width and thickness of flathead bits. Never used this one on a sewing machine, but it has saved me from tearing down hours of work to get to a single screw so many times when working on equipment in datacenters; it's a small ratchet bit driver that fits in the palm of your hand. https://www.amazon.co.uk/d/4bo/innovative-profile-squat-stubby-ratcheting-screwdriver-engineer/B002L6HJ82/ref=sr_1_2?ie=UTF8&qid=1494054383&sr=8-2&keywords=ratchet+palm+bits Edited May 6, 2017 by Stuggi Quote Pfaff 335-H3-39/21-BSN
480volt Posted May 7, 2017 Report Posted May 7, 2017 Second on the Wiha. I use insulated ones for energized work and I have never broken or worn out the tip on one. The rest of mine are Klein. Quote
garypl Posted May 7, 2017 Report Posted May 7, 2017 On 5/3/2017 at 11:05 AM, trash treasure said: Get a set of Chapman gunsmith screwdrivers - Wouldn't be without them : https://chapmanmfg.com/collections/slotted-flathead-sets/products/8900-standard-set-12-slotted-bits Expand I agree about the Chapman screwdrivers - I have been using a set of Chapman screwdrivers with the ratchet wrench for over 30 years and have never broken or twisted any of the bits - top quality! Quote Cowboy 4500, Consew 206RB-4
Members ChapmanMFG Posted May 17, 2018 Members Report Posted May 17, 2018 On 5/7/2017 at 12:28 PM, garypl said: I agree about the Chapman screwdrivers - I have been using a set of Chapman screwdrivers with the ratchet wrench for over 30 years and have never broken or twisted any of the bits - top quality! Expand Thanks so much for recommending our tools! We work hard to produce precision, quality bits and I'm so happy to hear that our tools have served the 3 of you well. Our tools have been used on sewing machines for a long time because our hollow ground bits fit the full depth and width of slotted screws unlike typical tapered screwdrivers. Also our bits are engineered to bend/break before damaging the screw. We've been in business since 1936 and have grown to about 15 people. Most of our new customers are referrals from other customers as we do not have a large marketing budget. Is there anything that you need that we don't currently make? Thanks again, Joel - Chapman MFG joel@chapmanmfg.com Quote
garypl Posted May 17, 2018 Report Posted May 17, 2018 On 5/17/2018 at 1:42 PM, ChapmanMFG said: Thanks so much for recommending our tools! We work hard to produce precision, quality bits and I'm so happy to hear that our tools have served the 3 of you well. Our tools have been used on sewing machines for a long time because our hollow ground bits fit the full depth and width of slotted screws unlike typical tapered screwdrivers. Also our bits are engineered to bend/break before damaging the screw. We've been in business since 1936 and have grown to about 15 people. Most of our new customers are referrals from other customers as we do not have a large marketing budget. Is there anything that you need that we don't currently make? Thanks again, Joel - Chapman MFG joel@chapmanmfg.com Expand Hi Joel, I think a collection of bits specifically aimed at sewing machine usage would be a good seller for you. The set I bought has a few bits that I will not use. I can’t speak for every type of machine out there, but I can provide you with a list of the bits I use on my CB4500, so you know what many leather craftsmen have to use on their equipment. Maybe others on this forum can add commonly used bits they use on other machines and you can assemble a set based on this input. I will post a list when I get home tonight. Gary Quote Cowboy 4500, Consew 206RB-4
JJN Posted May 18, 2018 Report Posted May 18, 2018 On 5/17/2018 at 1:42 PM, ChapmanMFG said: Thanks so much for recommending our tools! We work hard to produce precision, quality bits and I'm so happy to hear that our tools have served the 3 of you well. Our tools have been used on sewing machines for a long time because our hollow ground bits fit the full depth and width of slotted screws unlike typical tapered screwdrivers. Also our bits are engineered to bend/break before damaging the screw. We've been in business since 1936 and have grown to about 15 people. Most of our new customers are referrals from other customers as we do not have a large marketing budget. Is there anything that you need that we don't currently make? Thanks again, Joel - Chapman MFG joel@chapmanmfg.com Expand I've been using Chapman Mfg. screwdrivers for a couple years now. They are American made and top quality. Here is a suggestion. Spend about $100 and get the Master Set. You will use it for everything, guns, auto, home repairs and more. I made a list the tool bits that fit specific screw heads I turn on my sewing machines and made a custom set for each machine. You can easily order just the bits you need ($1.50 +/-) and additional ratchets. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
DonInReno Posted May 18, 2018 Report Posted May 18, 2018 Gunsmiths deal with a lot of hardened screws and numerous sizes of slotted screws. Brownells and numerous others sell great sets with hard bits - no gunsmith stays in business if they don't have good screwdrivers that don't slip. Off the shelf at Home Depot or lowes Klien electrical screw drivers are pretty hard. Stanley bits appear hard, but it's overly hardened crappy steel - they cheapened the metal about a year ago and all the guys I know stopped using them. Bosch and Makita bits are ok, Milwakee is middle of the road and stay away from kobalt or Ryobi. I'm not a big fan of craftsman in general, but the little black handle ratchet for screw bits is inexpensive and works ok. A big step up is the Gearhead screw bit ratchet. I like these with an extension to break larger screws and without to break tight quarter screws. In super tight situations a bit can be cut almost in half or aviation suppliers seem to stock shorty bits. The little thumb wheel (this one is craftsman but available from others) gets used all the time with or without an extension. To me a dremel is essential to slightly thin a bit that is just a little too tight. Keep it handy and instead of messing up a screw head you'll have a perfect fit and not only do screw heads last longer, but the bit will as well. if you're a restorer or simply OCD there are screw slot files available from Brownells to either widen or deapen a screw slot. Quote
garypl Posted May 18, 2018 Report Posted May 18, 2018 I checked which bits fit most of the screw on my CB4500. I can use flat bits #90, 25, 19, and 98 for every screw I could locate on the outside of my machine. Gary Quote Cowboy 4500, Consew 206RB-4
Members R8R Posted May 24, 2018 Members Report Posted May 24, 2018 On 5/3/2017 at 5:55 PM, Gregg From Keystone Sewing said: These are some of the best darn, tried and true screwdrivers I can find, and I've tried a lot of 'em. Don't want to drop brand names, but I can attest to the fact that they were made here in USA. Expand I bought a full set of these a couple months ago and I can say without hesitation that Craftsman screwdrivers have become absolute and complete garbage. Every flat head driver in the kit had the plating coming off the tip on the first use. All of the flat head drivers were essentially unusable after a few uses. Nothing major, just basic adjustments to a machine and a couple uses around the house. The tips would flare out and chip and would often not even fit in the slot anymore. Garbage. Returned the whole kit. I got a set of Klein's that I'm happy with for now. Quote
Evo160K Posted May 24, 2018 Report Posted May 24, 2018 (edited) This is the only set I've ever used.....bought it in 1996. It normally resides in a leather saddle bag on my Harley. https://www.specialized.net/wadsworth-super-deluxe-mini-ratchet-screwdriver-set-4-52-pc.html?gclid=EAIaIQobChMIif_G_8Sf2wIV3LjACh3rYwdLEAQYASABEgIz__D_BwE Edited May 24, 2018 by Evo160K Quote
garypl Posted May 24, 2018 Report Posted May 24, 2018 On 5/24/2018 at 11:45 PM, Evo160K said: This is the only set I've ever used.....bought it in 1996. It normally resides in a leather saddle bag on my Harley. https://www.specialized.net/wadsworth-super-deluxe-mini-ratchet-screwdriver-set-4-52-pc.html?gclid=EAIaIQobChMIif_G_8Sf2wIV3LjACh3rYwdLEAQYASABEgIz__D_BwE Expand That looks like a really nice set! Gary Quote Cowboy 4500, Consew 206RB-4
