Rockoboy Posted April 1, 2018 Report Posted April 1, 2018 (edited) It's a lubricant similar to WD-40, RP7, Ballistol, C-RC etc. It does not attract dust, displaces moisture, penetrates and lubricates against rust etc. It comes in spray can or half gallon, gallon bottle or larger. Edited April 1, 2018 by Rockoboy Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members DavidJohn Posted July 26, 2022 Members Report Posted July 26, 2022 Inox does not have silicone in it, some people say silicone is great others say no, I use Inox as a lubricant and I have been using an old Castrol high temp grease on sewing machine metal gears. Quote
Members sbrownn Posted July 26, 2022 Members Report Posted July 26, 2022 On 3/21/2018 at 2:10 AM, Matt S said: Anyone tried gearbox oil? 80W90 is £5/litre from Wilkos... That's pretty sticky. Why would you use anything else? That's what it is specifically designed for...lubricating gears. Quote
Members TomE Posted July 26, 2022 Members Report Posted July 26, 2022 Lucas Hub Oil is an upgrade IMO from standard 90W gear oil. Sold at Tractor Supply Co and auto parts stores. Not a sewing machine, but it quieted the gear box in my 14 year old rotary cutter (brush hog). Quote
Members dikman Posted July 26, 2022 Members Report Posted July 26, 2022 Don't forget that gearbox oil is generally used in enclosed sealed gearboxes so the gears are essentially running in an oil bath. It doesn't matter if it gets flung off as it is constantly replaced on the gear surfaces. Unlike sewing machine gearboxes. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members trash treasure Posted July 27, 2022 Members Report Posted July 27, 2022 12 hours ago, dikman said: Don't forget that gearbox oil is generally used in enclosed sealed gearboxes so the gears are essentially running in an oil bath. It doesn't matter if it gets flung off as it is constantly replaced on the gear surfaces. Unlike sewing machine gearboxes. This is absolutely right - Please do not think to use any kind "gear oil" in a sewing machine gear case - They are NOT sealed like that, and all you will do is make a mess! What works for a bush hog, is NOT what's needed in a sewing machine. Either use some kind light grease, that will stick to the gears, or just take the gear case off, and oil regularly. One grease I've found that works pretty well, if you go the grease route, is "Super Lube" synthetic grease - It's a clear grease, with no smell, and it seems to hang on the gears fine : https://www.amazon.com/Super-Lube-21030-Synthetic-Grease/dp/B000XBH9HI/ref=sr_1_3?crid=102Q4WNC2JWML&keywords=super%2Blube%2Bgrease&qid=1658919014&sprefix=super%2Blube%2Bgrease%2Caps%2C938&sr=8-3&th=1 Quote The model number giveth, and the subclass taketh away ......... Sometimes
Members Matt S Posted July 28, 2022 Members Report Posted July 28, 2022 On 7/26/2022 at 8:20 PM, sbrownn said: Why would you use anything else? That's what it is specifically designed for...lubricating gears. On 7/26/2022 at 11:33 PM, dikman said: Don't forget that gearbox oil is generally used in enclosed sealed gearboxes so the gears are essentially running in an oil bath. It doesn't matter if it gets flung off as it is constantly replaced on the gear surfaces. Unlike sewing machine gearboxes. 22 hours ago, trash treasure said: This is absolutely right - Please do not think to use any kind "gear oil" in a sewing machine gear case - They are NOT sealed like that, and all you will do is make a mess! What works for a bush hog, is NOT what's needed in a sewing machine. Either use some kind light grease, that will stick to the gears, or just take the gear case off, and oil regularly. One grease I've found that works pretty well, if you go the grease route, is "Super Lube" synthetic grease - It's a clear grease, with no smell, and it seems to hang on the gears fine : https://www.amazon.com/Super-Lube-21030-Synthetic-Grease/dp/B000XBH9HI/ref=sr_1_3?crid=102Q4WNC2JWML&keywords=super%2Blube%2Bgrease&qid=1658919014&sprefix=super%2Blube%2Bgrease%2Caps%2C938&sr=8-3&th=1 In the 4 years since I made that initial suggestion I've stripped a few more machines down and run several million stitches. Some machines have enclosed/sealed oil baths around the pinion gears, complete with watchglasses, gaskets and fill plugs. Others are completely open to the elements, where anything liquid will dribble onto your knees if the drip tray isn't installed. Many run halfway between, with closed (but not sealed) boxes to mostly keep the schmoo in and the crud out. Still others have pumped oil systems, but we don't use those much in leatherwork. As others have said gearbox oil is designed for cars where the gears, undergoing significant pressure and wear that isn't seen in a sewing machine, are kept wet in a bath. It's relatively high viscosity oil but not, in my humble opinion, high enough to prevent it getting flung off unsealed pinion gears. When I suggested gear oil back in 2018 I was overthinking things. These days my machines with oil baths around the pinion gears get white sewing machine oil, same as the rest of the machine. Unsealed gears get lithium soap grease (and a complete strip and regrease if it looks manky). I like simple. Quote
Members dikman Posted July 28, 2022 Members Report Posted July 28, 2022 Simple is good. White lithium grease may work, just a light coating to minimise fling-off, the idea of motorcycle chain oil is good but I've got several different types that I've tried on my bike and all but one tend to throw off and make a mess. The one that works best on the bike is Motul brand, minimal fling. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members HaloHockey Posted June 20, 2025 Members Report Posted June 20, 2025 I’m getting the tri-flow on amazon today. My 335’s also have a grease fitting. Triflow doesn’t see to have anything that comes in a Cartridge. What would everyone recommend to use that specific area where tri-flow can’t be used? Quote
