Members akguy59 Posted November 17, 2018 Members Report Posted November 17, 2018 Hi folks, I just have a quick question that will probably seem a bit silly to some but here goes. I am ready to try my hand at a holster with a metal reinforced mouth. What kind of metal is commonly used for the reinforcement piece. Thanks in advance for your help. Quote
Moderator immiketoo Posted November 17, 2018 Moderator Report Posted November 17, 2018 You'll want to get some galvanized steel. Its firm but malleable and easy to cut. Quote Learnleather.com
Contributing Member fredk Posted November 17, 2018 Contributing Member Report Posted November 17, 2018 Not done a pistol holster but on certain knife sheaths I've used brass sheet. A bit more expensive, as easy to cut and shape as thin steel without the risk of iron staining of the leather Quote Al speling misteaks aer all mi own werk..
Members akguy59 Posted November 18, 2018 Author Members Report Posted November 18, 2018 Thank you for taking the time to answer. I also have access to metal banding material at work and was wondering if that wouldn't be another one to try. It's already painted, easy to cut, and fairly stiff. Quote
Moderator immiketoo Posted November 18, 2018 Moderator Report Posted November 18, 2018 Depending on how you plan on using it, it should work, unless you want to use it for tensioning. Then it needs to be malleable and hold a shape. Quote Learnleather.com
Members Joon1911 Posted November 18, 2018 Members Report Posted November 18, 2018 Most holster manufacturers use something similar to strapping used for shipping pallets. It’s spring steel so it had some natural resistance to bending. I’ve dissected a bunch of mainstream holsters and that’s what I’ve seen inside just about every holster I’ve taken apart. I could be mistaken but I think that galvanized steel would be corrosive over time with sandwiching it in the leather. Quote "Make every product better than its ever been done before. Make the parts you cannot see as well as the parts you can see. Use only the best materials, even for the most everyday items. Give the same attention to the smallest detail as you do to the largest. Design every item you make to last forever." -Shaker Philosophy of Furniture Making
Members Dwight Posted November 18, 2018 Members Report Posted November 18, 2018 1 hour ago, Joon1911 said: Most holster manufacturers use something similar to strapping used for shipping pallets. It’s spring steel so it had some natural resistance to bending. I’ve dissected a bunch of mainstream holsters and that’s what I’ve seen inside just about every holster I’ve taken apart. I could be mistaken but I think that galvanized steel would be corrosive over time with sandwiching it in the leather. Considering that the galvanizing itself is resistant to corrosion, . . . then we have the layer of contact cement which is resistant to allowing moisture thru (same for galvanizing), . . . and then several coats of Resolene (or something similar) to top coat the leather. THEN, . . . after the moisture has made it's way down thru all of that, . . . the corrosion has to make it's way up, . . . The article would be worn out and useless before all that would take place, . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Contributing Member JLSleather Posted November 18, 2018 Contributing Member Report Posted November 18, 2018 It will depend on teh REASON you want to "try your hand" at it. What is the desired outcome? Spring steel does exactly that.. it wants to return to the shape it started in when formed (with banding, that would be FLAT). So, bending it around a pistol would be a bit difficult, but once in place it WOULD tend to try to return to flat and thus tend to keep a holster "open". If all you are wanting is a holster that is more "firm" or "solid", just make it from 2 pieces of top grain leather - for example 2 pieces of 4 oz instead of a layer of 8 oz -- and it should be more than firm enough. I've made holsters with a double layer of Hermann Oak 4 oz leather that were a weapon in themselves.. if you don't have bullets, you could just hit an attacker with the holster At that point, "sammiched" metal is little more than a marketing gimmick. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members akguy59 Posted November 18, 2018 Author Members Report Posted November 18, 2018 Thanks for the replies. You have given me several options that all seem to have a lot of merit. Quote
Members dikman Posted November 20, 2018 Members Report Posted November 20, 2018 In my opinion metal linings might be of benefit for "fast draw" competitions, but other than that I can't see much need. All of the holsters I have made (I'm talking Western style here) have been made with two layers of leather and once they've been wet-formed they dry almost as hard as wood (as JLS implied) and tend to keep their shape. Making them with a metal liner is just another complication I can do without. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
