Tapered from 20-18, and with round padding.
Feel free to ask if you have any questions, and I do my best to help.
Great in all aspects.  Yes, I would like to know details about the stitching.  Method and materials would be interesting to know.
Thanks!
Thanks!
The tools and materials used for stitching. Irons: Ksblade 3.0/9SPI, Awl: Kyoshin Elle diamond Small, heavily modified from a diamond to flat (2mm). I almost always use an awl to open the holes from 1.6mm to 2mm width, the only time I don't is when I stitch a really thin watch strap without cast, then I prefer a smaller hole because the backside looks better. Thread: Meisi 40 lin thread (0.45mm) I often choose Meisi instead of Fil Au Chinois even if I have the same color of both brands. Meisi is more even and no lumps in the thread. And they have smaller spools.)
And the stitching. I cast the thread with moderate angles here. There are a lot of information and tutorials for saddle stitching, but very little information around stitching really thin leather. (This watch strap have 2mm thick edges)  From analyzing others work and tests I've done this is my conclusion. There are four ways to saddle stitch this thin leather with thread size around 0.4-0.5mm, and one of them give perfect results (But close to impossible on a strap with padding.
1. Punch from both sides with the same iron: You punch the top //// and the lining //// before assembly which results in a hole looking like an X and you stitch without cast, this result in an even nice slant on both sides.
2. Stitch without cast: Front side looks really good with a nice slanted stitch line. But the back side gets straight.
3. Stitch with cast and moderate angels. Both front and back side looks good, but front straightens a bit (I prefer a little gap between stitches)
4. Stitch with cast and heavier angels. The front side looks good, but the back side often looks uneven (Might be because I'm inexperienced.)
And of course it also depends on the type of leather. A stiffer leather is a lot easier to stitch with an even result.
Tools/materials.
Ksblade irons: http://ksbladepunch.com/product/pricking-irons
Kyoshin Elle awl: https://www.goodsjapan.com/kyoshin-elle-leathercraft-stitching-awl-for-sewing-leather-diamond-point-small-438-p.asp
Meisi thread: https://www.meisithreads.com/waxed-linen-threads
If you don't feel comfortable reshaping awls then I would go for an awl from Palosanto Factory. And even though I really like Ksblade. They cost a lot. People seem very happy with pricking irons from Kevin Lee.
Thanks for the detailed information.  I think the thing about soft, thin leather is that casting is made less effective due to the overall thickness of the piece.  I have no problem getting a nice slant on two layers of 4/5 oz. leather but when doing a leather strap or bracelet, casting just doesn't work as well for me.  I find it easy to tug too hard in order to get the knot to sit down.
Anyway, thanks for sharing your process!
Yes exactly. With thin soft leather both tension and tension angles are very sensitive. Thicker leather is more forgiving. And a straight stitch (no cast) on the back side of a strap or a bracelet doesn't have to look bad.
Beautiful stitching - it's a fine piece to use as an example of how stitching can look.  I'm really digging the red-on-black.
Thanks for the details you posted yesterday, in particular the 4 concise bullets, hardware and reference to Meisi thread. I'll probably order some, particularly because it comes in smaller spools.  Back to the bullet points: I have pictures of stitching where I did something similar - now I can use those 4 bullet points to go back and evaluate again what I did.
When  you mention,"... moderate angels...," and "...heavier angles...," are you referring to how you pull the thread, such as up-forward, down-back (or whichever direction it's supposed to go) to help set the thread slant?
Thank you. I find stitching to be one of the biggest challenges when it comes to leathercraft. Glue two stiff 2mm/5oz pieces together, and practice and soon you get a decent result. Stitch a wallet where you have mixed stiff and soft leather, a different thickness in "every corner" in some places you cast, in other places you don't. You can't do a practice stitch on scrap pieces, because you have skived edges and a lot of layers of leather.
Regarding the angles. When you have /// on your right side, and stitch towards yourself. The most common way is to pull the thread left upwards and away from yourself. Right thread downwards and towards yourself. I don't get good results this way on thinner softer leather. (around 2-2.5mm in total thickness.)
Moderate angles: Left hand straight out, right hand follows the hole (down and towards myself.)
Heavier angles: Left hand slightly upwards, right hand follows the hole (down and towards myself.)
This is what works for me, it might be different for you, but give it a try. The most important thing isn't to get the perfect "slant". consistency is.
