Has anybody used one of these?  I don’t mind having to do a little work to get it up and running, but I’d like it do be able to decent stitching.  I would mostly use this to  do belts and suspenders so this would this would be used to stitch around the edges.  This is strictly a hobby for me so I’m not looking to spend a ton of money, but hand stitching belts/suspenders takes way to long.
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Pics???
This is also the issue with the Tippmann Boss (that is way more expense), its hard to sew long runs, belts and straps, with just one hand and keep them looking good.  Sure it can be done, its just tricky.
That is a Chinese shoe patch machine.  Similar to a Singer 29-4 in the operation, but that's about it.  I don't think you will be happy with this machine if your going to try and actually make something and want it to look good.  Save up a little more money and get a machine with a motor.  It will give you much better control of your project and they will look better.
One day I hope to learn how to sew.....
Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
You may want to motorize it- there are a series of videos folks doing it... Here is one example:
I have purchased one of these machines- and will be mounting it on a block base- make a table for it with a piece of 3/4 inch plywood to convert it to a bed versus an arm machine. With the hand crank I have found it only good for short runs as noted above- but when I get my wife to turn the crank I am able to manipulate larger pieces more easily.
These are "In Fashion" right now and among the prepping and homestead minded folks- and there are many you tube reviews- BE AWARE- Some reviewers and folks posting vids of these machines are AFFILIATE SELLERS for importers or Amazon- so they are biased- CAVEAT EMPTOR (buyer beware)
Modifications that will help you use this machine better:
  1. A high power square shaped magnet to act as a guide
  2. please paint it to prevent rust (bad castings overall) Main arm and UNDERSIDE of the long arm are the most prone
  3. use a thread tower not on the machine (the thread spool being ON the machine the loops fall over the handle and vibrates excessively)
  4. put a washer on the handwheel- or a locknut- the rotation of the flywheel causes the nut to back off
  5. take a file and DEBURR the casting- the casting quality is dubious at best- file off the casting goobers that like to grab fingers and fabrics (and threads)
  6. Make witness marks where the bobbin shuttle is located- these will become handy when you have to clean the rack or threads get wrapped around the shuttle and you have to remove it to clean and then replace it- and wonder where the heck did this thing go????
  7. Take a round or half-round file and enlarge the finger nick to take the bobbin cover off with.
Hope this helps- be safe and enjoy.
I bought one off these machines because my Adler or Singer patchers didn't have
enough lift or stitch length to put pulls on the boots I make.  It has adjustment for
needle bar and hook. The cams are bearings vs plain and the main shaft has ball bearings.
Because of adjustable needle bar I use 135x17 needles.  It has a longer stitch than most
shoe patchers and it has a 1/2 lift.  The bobbin winder is crap and the bobbin and hook
need polishing. It handles 92 bobbins and 138 needle thread.  I put a Teflon pad
on the throat plate.  There is a video on youtube Wolf Moehrle who will make most
of you jealous with this machine.  His wallets are very well done.
I have one and love it.  More than my Techsew.  I've had mine for a couple of years.  It sews smooth now after doing the modifications mentioned by Silver Forge.  One thing Silver didn't mention is the presser foot leaving marks.  To help alleviate those take the foot off and take a flat file and give it a few strokes on the bottom to flatten down the ridges.  Then play with the presser foot tension screw until you get the desired effect.  As for the stitch length you can raise and lower the stitch length screw for the desired length.
Just a warning, most of these machines come rough and need to be filed on some areas, oiled, and then run the machine without needle and thread to get it operating smoothly.  After all that practice, practice, practice with it.
I truly feel you won't go wrong for the money.  There a quite few more youtube videos out now than when I started with mine that cover pretty much any issue you may come across.  And you have this forum.
Take care and stay safe,
Mickey
Arrowhead H Ranch
What size thread do you want to use? The bobbin capacity is very small as they're not intended to do long stitching runs.
I’d like to use the thickest thread possible, which sounds like it would be 138.  This would mostly be used to stitch around the edges of belts and suspenders to help prevent stretching.  How many feet of 138 do you think will fit in the bobbin?
Probably not big enough to go round a belt in a oner. Those bobbins are pretty small. I think that those who report using v138/tkt20 in these patchers are using it only in the needle, with a thinner thread in the bobbin. That's fine, but it limits the strength of the seam to that of the thinnest thread. It also presupposes that you can get yours to work with such a chunky thread. The tolerances on these machines is so loose that there is no guarantee that you'll be able to do so. For example not all the bobbins that came with my machine fit it.
