I picked up this machine ~10 ago in Munich. No idea what this machine could do or not or if it will suit my need at all. You barely find information on the 51W machines and especially not on 51WSV2 (Special Variant) - I mean stitch length and so forth...
However, I did a lot of research and figured there are 2 different 51W post bed models. Mine is the earlier one based on a Wheeler & Wilson N12 (as it seems). I found a picture on Alex Askaroff´s website (scroll down). The later models (made after 1938 as it seems ) are more Singerish than the W&W based 51W model and have a different tension unit, stitch length adjuster, thread lever moved to the front... and so forth. Lots of features you also find on other Singer models like 108W, 107W and so forth. So what I have is the earlier model. On the back side you still can see the cam for the trimming device which was mounted on the top of the machine head.
https://sewalot.com/wheeler%20&%20wilson%20sewing%20machines.htm
Singer took over W&W in 1905 and even produced some W&W machines 1:1 but with Singer label. That probably explains the short serial number w/o prefix - I guess Singer produced some SV machines with from existing (already cast?) W&W parts - this is a wild guess, I know.
Anyway - machine was badly gummed and VERY dirty inside - sorry I did not take pictures. I figured it uses an odd needle system 128x2 / 128x3 (short needle with thin shaft) so thats nothing I could use. The NB also has an odd cut out and seems someone already "bubbaed around" on it's not functional att all :thumbsdown: So I robbed a needle bar from my old Singer 111D which rests on a shelf for some years already and - surprise surprise - the needle bar is pretty much the same so I now can use 135x17 needles - downside is the 111D needle bar is shorter. It works but I have to install a extra guide (have to figure how to do this - already have an idea).
Next think is the presser foot bar - looks like it can accommodate 111 type needle feed presser feet or 107w presser feet - but thats a bummer too cause the 51W presser foot bar and feet are slightly different... Next idea - I take the PF bar from the 111D and - surprise surprise #2 - it perfectly works and fits and now I can use wide spread 111 needle feed feet and similar. But I decided to try a PF bar with fixed roller foot I once bought "in wise foresight" cheap on ebay a while ago and it also works perfect. :)
Next thing was the badly worn hook and bobbin case (0.5mm horizontal and vertical play :blink:) The machine already has a rotary hook but without bobbin case opener (later 51W models have a bobbin case opener). So I removed the hook from the machine and figured it has the exact same mounting as the Singer 136w / 153w hooks which are the same as some of the Durkopp hooks I have in my parts box - so I installed one and - holly crap - it works perfect even though the Durkopp hooks where meant for using with a bobbin case opener but seems it does not matter in this case :lol:. But -belive it or not I found a source for an original new hook but they ask $80 + shipping (+ EU VAT and import tax) to I will keep the Durkopp hook - good think is I now can use the bobbins of my 111 and 212 in this machine and don´t have to stock different bobbin types.
So - lot of words... here are some pictures.
I know most would have kept the original decals but they aren ot as nice as they seem and I personally do not like the Singer floral design very much...
This is what I have found:
155106439_Singer51WSV2.thumb.jpg.c7f63d4bfdbd0639e6c22db03160728f.jpg346.thumb.JPG.6cfa4ea3d2981ea72a5e2b6f97700fd6.JPG51WSV2_.thumb.JPG.33ab801ad16be1943ec553a875bdb4ab.JPG
  • Replies 47
  • Created
  • Last Reply
Top Posters In This Topic
And this is what it looks now
IMG_7355.thumb.JPG.dd81f6610b9d972501a77d0f3118f011.JPGIMG_7357.thumb.JPG.4b0782b873789a037563dcc263fa9464.JPGIMG_7359.thumb.JPG.539dc48f7ccc177436da15d54519715b.JPGIMG_7361.thumb.JPG.0e4a58213ef2f91b5c10425ec8b13333.JPGIMG_7363.thumb.JPG.2197746439b5801fe51ae707392e82de.JPG
IMG_7365.thumb.JPG.dce00352e0931a9203473cd9033cbd97.JPGIMG_7366.thumb.JPG.09d1b7af9aa22168310bc3d2c2959132.JPGIMG_7367.thumb.JPG.afe8437fd5f0bed8cda70f1ff92e6a26.JPGIMG_7373.thumb.JPG.831c441947bc34b3f9cf2de77e0db755.JPG
IMG_7374.thumb.JPG.6ba982225e5e37d370ef3e4457f1838e.JPGIMG_7375.thumb.JPG.3702e1b1306b978e57a57f332303d234.JPG
Edited by Constabulary
some more
I also added a thread holder I found on Ebay a while back. I also figured when you remove the silver limiter which is mounted to the stitch length lever and grind down the feed dog a bit on the backside you can achieve almost 5mm / 5SPI stitch length - original stitch length was approx 3.2mm  :spoton:
The paint once again is VHT crackle / wrinkle paint
Impeccable restoration..superb.. :)
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Looks great, but just like me gets more crinkles every day, but your efforts seem to be much more uniform crinkles than me
Mi omputer is ot ood at speeling , it's not me
Another nice job, Constabulary.:specool: Beats me where you find these old things.
Another great restoration.  Really great that you share all your machines on the forum :)
Current Industrial Machines:  USM No6; Claes Atlas; Singer 29k, Union Special 11900; Durkopp 18; Adler 5-36; Singer 108w20; Singer 107w1; Singer 75-1; Singer 46k15; Singer 18-2; Singer 133k13; Adler 30-15; Singer 31k15; Singer 31k32; Singer 134w3; Singer 34k11; Singer 91k6
Looks great, well done.
  • 4 weeks later...
So I have installed a new needle bar guide because the Singer NB is a lot shorter than the original W&W NB. Interestingly the NB guide came from a Durkopp machine and has the same diameter as the Singer and W&W NB. Really interesting how parts pretty much remained the same for decades and that different sewing machine Co´s followed the old W&W / Singer specs. I really love to figure out when parts are interchangeable.  :)
The long tube on top of the NB (see above pictures) was not a NB guide it rather is a dust protector for the NB and had a wider diameter so nothing I could use.
Surprise #3:
You still find needle plates and feed dogs that work with this old 51W machines :blink:
While playing with google searches I figured the needle plates of the GOLDEN WHEEL 810 pretty much look the same. So I ordered some cheap sets on Ebay for for testing (hell they are dirt cheap).
This was the 1st set - it fits but needs modification. Feed dog needs an oblong screw hole for height adjustment and the outer ridge of hook is touching the needle plate (remember I installed an Durkopp hook that was not designed for this machine) but needle plate can me modified.
https://www.ebay.de/itm/143143427599
IMG_7515.thumb.JPG.2b7f1f905fd778b1806416e84fc135d0.JPGIMG_7516.thumb.JPG.d0bebbad15dc461b4b7994fde76912f1.JPG
This was the 2nd set I have ordered and it works w/o problems I only had to play with the feed dog height.  :banana:
https://www.ebay.de/itm/143164778742
Hook works a lot better with this set and yet no modification is required!
IMG_7904.thumb.JPG.0865e0126291c187046dc9aa6dbfddd9.JPGIMG_7905.thumb.JPG.6c0d7980a5f212ab08e93273d1096eac.JPG
Surprise #4:
Damn - there are even hooks for the Golden Wheel 810 / 820 that looks very much like the Singer 111 hook. They have the same needle deflector but no shaft instead they have the same "2 prong mount" as my original 51W hook and the Durkopp hook I´m currently using. So I´ll gave it a try. For less than $10 you can do much wrong.  :lol:
GEH-820 hook
Hook is on the way already and should arrive within the next few days.
Machine already works good for far... (I know needle too thick)
BTW - I have removed the limiter from the stitch length lever (2nd post, last picture) and I now get approx 5 SPI. with NP / Feed dog set #2.  :)
