Contributing Member fredk Posted September 16, 2019 Contributing Member Report Posted September 16, 2019 There ya go with the differences in terminology. I think what you guys are describing is known to me as an 'adjustable' To me a 'crescent' spanner/wrench is C shaped with a small hook on the inside of the top curve, at the edge. Its used for loosening & tightening special nuts such as found on the handlebars head bearings and the pedal bearing box on bicycles and certain parts on vintage Austin 7 cars. The gap between the jaws of the C are measured to fit the special nut properly Quote Al speling misteaks aer all mi own werk..
CFM Frodo Posted September 16, 2019 Author CFM Report Posted September 16, 2019 (edited) 13 minutes ago, fredk said: There ya go with the differences in terminology. I think what you guys are describing is known to me as an 'adjustable' To me a 'crescent' spanner/wrench is C shaped with a small hook on the inside of the top curve, at the edge. Its used for loosening & tightening special nuts such as found on the handlebars head bearings and the pedal bearing box on bicycles and certain parts on vintage Austin 7 cars. The gap between the jaws of the C are measured to fit the special nut properly different terminology I was transferred to Colorado to get a job started, I kept hearing guys talking about an ''excavator' that was on it's way to move dirt. thye way they talked this was one badazz machine. I had no idea what an ''excavator'' was, so I just kept my mouth shut and eyes open to see. Truck pulled onto the job site with the ''excavator'' LOL That is a ''TRACK HOE"" every one knows that. Edited September 16, 2019 by Frodo Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Northmount Posted September 16, 2019 Report Posted September 16, 2019 5 hours ago, fredk said: To me a 'crescent' spanner/wrench is C shaped Here is a crescent wrench by most North American usage. It is an adjustable wrench, I believe originally made by the Crescent Co. Tom Quote
Mark842 Posted September 16, 2019 Report Posted September 16, 2019 Here you go. http://www.derose.net/steve/resources/engtables/englishmetric.html Quote
Contributing Member fredk Posted September 16, 2019 Contributing Member Report Posted September 16, 2019 22 minutes ago, Northmount said: Here is a crescent wrench by most North American usage. It is an adjustable wrench, I believe originally made by the Crescent Co. Tom an 'adjustable' a C or crescent spanner 9 minutes ago, Mark842 said: Here you go. http://www.derose.net/steve/resources/engtables/englishmetric.html spoil-sport Quote Al speling misteaks aer all mi own werk..
CFM Frodo Posted September 17, 2019 Author CFM Report Posted September 17, 2019 7 hours ago, fredk said: an 'adjustable' a C or crescent spanner spoil-sport crescent wrench [crescent wrench] NOUN NORTH AMERICAN trademark an adjustable wrench designed to grip hexagonal nuts, with an adjusting screw fitted in the crescent-shaped head of the wrench. adjustable wrench Also found in: Thesaurus, Encyclopedia, Wikipedia. ThesaurusAntonymsRelated WordsSynonymsLegend: Switch to new thesaurus Noun 1. adjustable wrench - an adjustable tool for gripping hexagonal nuts, with an adjustings crew in the head of the implement adjustable spanner monkey wrench, monkey-wrench - adjustable wrench that has one fixed and one adjustable jaw pipe wrench, tube wrench - adjustable wrench for gripping and turning a pipe; has two serrated jaws that are adjusted to grip the pipe screw wrench - adjustable wrench that has one jaw that can be adjusted by turning a screw spanner, wrench - a hand tool that is used to hold or twist a nut or bolt Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
480volt Posted September 17, 2019 Report Posted September 17, 2019 14 hours ago, Frodo said: different terminology  I was transferred to Colorado to get a job started, I kept hearing guys talking about an ''excavator' that was on it's way to move dirt. thye way they talked this was one badazz machine. I had no idea what an ''excavator'' was, so I just kept my mouth shut and eyes open to see.  Truck pulled onto the job site with the ''excavator''  LOL That is a ''TRACK HOE"" every one knows that.  Might be a regional difference. Here in the SF Bay Area, you have backhoes (rubber tires, arm swings 90 degrees left or right) and excavators (tracks, house rotates 360 degrees). Backhoes are all similar in size (Kubotas don’t count) and excavators come in many sizes, from the little “Fisher-Price”-sized mini-ex to so big the tracks hang off both sides of the low-boy when they bring it on site. The contractors I usually use for trenching prefer an excavator for digging and a bobcat (skid steer) for moving spoils and placing backfill. Quote
Members Handstitched Posted September 17, 2019 Members Report Posted September 17, 2019 Here in Oz, a 'crescent wrench ', as you call it , or an adjustable spanner, as we call it, is also called an ' AFS' " any f*&^ing size " . This is going a bit off topic , unless of course you're trying to use a 'crescent wrench' or an ' adjustable spanner' to open a drum of dye ? HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members TonyRV2 Posted September 17, 2019 Members Report Posted September 17, 2019 4 hours ago, Handstitched said: Here in Oz, a 'crescent wrench ', as you call it , or an adjustable spanner, as we call it, is also called an ' AFS' " any f*&^ing size " . This is going a bit off topic , unless of course you're trying to use a 'crescent wrench' or an ' adjustable spanner' to open a drum of dye ? HS OH!! ... you mean a 'several sixteenths' wrench. Quote Tony VRifle River Leather Ogemaw Knifeworks There are two individuals inside every artisan...the poet and the craftsman. One is born a poet. One becomes a craftsman.
Members Matt S Posted September 17, 2019 Members Report Posted September 17, 2019 3 hours ago, TonyRV2 said: OH!! ... you mean a 'several sixteenths' wrench. 8 hours ago, Handstitched said: Here in Oz, a 'crescent wrench ', as you call it , or an adjustable spanner, as we call it, is also called an ' AFS' " any f*&^ing size " . AKA "Swedish nut lathe" or "Chinese nut f***er", depending on the origin of your preferred fastener-rounding tool. Quote This is going a bit off topic , unless of course you're trying to use a 'crescent wrench' or an ' adjustable spanner' to open a drum of dye ? Your countryman Ron Edwards depicted a way of cutting the top off an oil drum using one of the old-fashioned F-shaped adjustable spanners and a hammer. "Crude, noisy and slow... but effective." I spose, though, a chap could drive a punch, a stamp or a saddle nail with a stilly, or even the millwrong's favourite friend... Quote
