Members grimdaddy Posted October 26, 2019 Members Report Posted October 26, 2019 Hey y'all, I've decided to attempt to disassemble a patrolman swivel holster, and I figured that while the unstitching part would go easily enough, the contact cement would go differently. I've read that acetone will dry out and crack the leather (which i want to keep as a pattern to make a copy of the holster), and I've also heard that heat is helpful, melting the contact cement i guess. I don't have any experience with contact cement, what do you guys reckon? Quote
Members HaloJones Posted October 26, 2019 Members Report Posted October 26, 2019 Do you have any idea of they type of cement / glue used? Quote
Members Dwight Posted October 26, 2019 Members Report Posted October 26, 2019 My first attempt would be a hand held wire brush. I have one that looks very similar to a tooth brush, . . . it would be the first tool I would grab. Another I would think of is a 1 1/2 inch wide wood chisel (very VERY sharp) and if the pieces were flat enough, . . . I would use it to cut of any fibers that stick up on the piece. The cement does not penetrate deep into the leather, . . . actually, more or less, lays on top of it, . . . and it would be especially easy on any flesh side parts. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Contributing Member JLSleather Posted October 26, 2019 Contributing Member Report Posted October 26, 2019 SOunds like a time burner. Probably faster and easier (and likely cleaner) to just use a very sharp knife, cut down between the glued layers. If you get off just a tad, doesn't matter. As long as you don't cut through, it'll glue back together as before, and sew. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Squilchuck Posted October 26, 2019 Members Report Posted October 26, 2019 To disassemble I'd use a Xacto blade to cut through stitching and glue. I've used a heat gun to take apart large pieces, but be careful not to get the leather too hot. I peeled back some then directed heat to where leather joins. Not fast or fun. -John Quote
Members Louiesdad Posted October 26, 2019 Members Report Posted October 26, 2019 (edited) I use a single edge razor blade and lay it flat on the leather then rock it back and forth while pushing into the glue. Edited October 26, 2019 by Louiesdad Quote
Members paloma Posted October 26, 2019 Members Report Posted October 26, 2019 try it with a piece of fabric with steam and pull of delicately progressively. Quote time does not respect what is done without it https://tradisign.blogspot.com https://www.instagram.com/tradisign/
wizard of tragacanth Posted October 26, 2019 Report Posted October 26, 2019 Well, I have never done this but I think that soaking the piece in very warm water would be the best first effort. Hot as you can stand it on your bare hands. Let the leather soak until it is well saturated and the glue has had time to warm up. Then try to pry it apart with a butter knife or some dull edged tool. nick Quote
Northmount Posted October 27, 2019 Report Posted October 27, 2019 20 hours ago, grimdaddy said: melting the contact cement Not melting! Only warm enough to warm the cement to reactivate it, but instead of pressing it together, you are going to pull it apart. Tom Quote
Members Handstitched Posted October 27, 2019 Members Report Posted October 27, 2019 G'Day, I have used *toluene to soften up contact adhesive, and I have also used it to ' thin' out the the last remaining bits of contact in the tin to make it stretch. It gets a bit ex$y to keep chucking out the little leftover bits in the tin. But yes, acetone can dry out leather . *Be very careful if you decide to use toluene . Wear eye protection and gloves, because it burns !!! HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members grimdaddy Posted November 3, 2019 Author Members Report Posted November 3, 2019 Thanks y'all, i figured it would be best to use an exacto knife after applying heat and water, but i just wanted you guys' opinion, as i'm fairly new to leathercrafting. I appreciate all the replies :) Quote
