What do you think of the double sided tape for leather instead of glue?  I am wondering what the edges look like without the glue?
I tried one, not as effective as glue & you still have the possibility of the tape being seen the same way as glue
I rarely glue my work but have used double sided tape ( Tandys, when it was on offer ) you can get the same stuff from any craft shop.  Found it worked ok.  If you 're worried about it showing on the edges,  cut it narrower-  then your work should not be seen.
Hope this helps
JCUK
Edited by jcuk
If you properly sand, bevel, and burnish the edges, . . . the glue or contact cement (if properly applied) will never be seen.
Tape, OTOH, . . . will always be subject to drying out, . . . letting go, . . . and then you have a gap in that edge.
Contact cement is the best in my book, . . . it is my 99% product to use, . . . Elmer's white glue rounding out that last 1%.
Tape is also finnicky, funky, and hard to use compared to contact cement.
The suggestion of not bringing the tape all the way to the edge, . . . leaves an edge that undoubtedly will produce a gap between the layers, . . . not a desirable feature.
May God bless,
Dwight
www.dwightsgunleather.com
Ditto what Dwight said...except for the white Elmer's glue part...and that's only 'cause I've never tried it. Been using the good 'ol Dap Weldwood Original Contact Cement (in the red can...the strong smellin' stuff!)...it's worked extremely well for me since way back in my cabinet/woodworking/laminatin' days and is available locally...see no reason to try anything else.
Have a great day!
Chris
Lots of people on here with more experience than me but I use both but prefer glue.  I feel you have the advantage of the glue adding strength to the seam. Tape is a temporary and very weak handling ability. If you use barge or contact glue be sure to read the safety warnings.. I have built a vacuum table for my glue station and vent it outside. Works great.  Stay safe
Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy  bell skiver,  Beilers embossing machine
I find the (Tandy) double-backed tape excellent to use for mounting zippers prior to stitching, I have tried various adhesives but found they tend to be messy ( for zippers anyways).
Agree
Thank you for all the replies. I get the idea that the glue not only holds the work but keeps the edges locked together for a no gap edge finish?
I just recently used double-sided tape for the first time on a project. I found it at a local craft store, about 1/8 inch in width. I used it to help create interior slash-style wallet card pockets.
For light leather, it's nice and quick, and straight, to hold the pieces together. I did not use it for outside edge seams (those were glued, clamped, and then let dry.)
For heavier leather, I don't think it'll work so well -- a good glue would be much more secure.
Edited by DJole
