Ashley55 Report post Posted December 14, 2020 I'm wondering if someone could help me figure out what size of beveler(s) I should get? I currently only have the Crafttool B701, which is fine for most things but is just too big for those small, finer spots- and I end up just mushing everything Tandy is the only store around, and even that is 1.5hrs away, plus covid so you can't go in. It's so hard to judge the pictures online, so I'm just not sure what exactly I need. If anyone could reccomend what size of bevelers are good for small/fine areas I would be very grateful! Quote Share this post Link to post Share on other sites
fredk Report post Posted December 14, 2020 B701 is a beveller with a fine check pattern on it? I prefer smooth bevellers. B200, is about the same size as the 701, and a B935 is good for small tighter areas. Its about half the width of the 200 If you want to keep to the checks then a B936 would be the smaller size, just about half the width of the 701 To go any smaller you'd need to grind a beveller down with a dremel type motor tool Also, have you tried tipping the beveller to the side to avoid any other work? Quote Share this post Link to post Share on other sites
Ashley55 Report post Posted December 16, 2020 Thank you very much for the reply! Yes the 701 is checkered, although I am also curious to try smooth ones to see which I like better. I have tried tipping it to try and make it work, it helps but.... I'm still a beginner and my tool handling skills are not quite up to par just yet Quote Share this post Link to post Share on other sites
OLESKIVER Report post Posted January 2 I use craftool B198 as my every day beveler, and the B936 for smaller places, plus B902 for corners and sharp points. you can get smaller bevelers than these but they are in the F series{ ie figure carving} pl;us they are also smooth faced. you would have to practice with them awhile to get used to them. the smallest one will act like a punch if you hit it too hard{ don't ask how I know that} hope this helps Quote Share this post Link to post Share on other sites
Ashley55 Report post Posted January 3 Thank you! Very helpful! Quote Share this post Link to post Share on other sites
DJole Report post Posted January 3 My smooth bevelers: Craftool B395 (for small spaces) and Craftool B203 (medium). I use these most often. I have one checked beveler which I use not too often (Craftool B936). that's apparently narrower than the one you mentioned in your original post. Quote Share this post Link to post Share on other sites
JLSleather Report post Posted January 3 I havent' seen these up close and personal, but if I was looking for bevelers I'd give these a try. Price isn't bad comparatively, and the impressions look good. Nice to have a SET whre the face is all the same... narrow ones for tight turns, the wider ones for broad lines and borders will save a lot of time over using teh small ones - and the textures will MATCH https://www.ebay.com/itm/Craft-Japan-Checkered-Beveler-Stamps-4-Piece-Set-Leather-Stamping-Tools/391858490975?hash=item5b3c960e5f:g:i0cAAOSwlshetqns Quote Share this post Link to post Share on other sites
Outfitr Report post Posted January 3 I know they're pricey but Barry King steep bevelers transformed my floral carving work. I've got both the steepest and next steep 3 widths each and I don't ever touch my old bevelers. Quote Share this post Link to post Share on other sites
