My arn't you clever
Mi omputer is ot ood at speeling , it's not me
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
9 hours ago, chrisash said:
My arn't you clever
Hey, just poking fun . . and I can feel your pain, I spent last couple days binding on radius items.
Over the years, I have picked out many a stitch out of seam Binding on an radius item, just to re-bind the job over again . Doing Single and double-needle binding radius, There is definitely some acquired technique to it, but a Lot of the battle is getting your setup tuned just right .
Thats the point!
Just as everything in sewing - it has to be set up properly... needle bars, hooks, feed dogs, feet... you name it... edge guide, binder brackets and attachments. And sometimes it requires to modify parts cause not everything comes of the shelf and is a universal fit part. There are just toooooo many variables in sewing.
@chrisash the swing bracket may be a solution but is not guaranteed to be the solution that works "of the shelf"
For the 111 there are special raised throat plates + feed dogs for binders, built up slide plates (for drilling holes and taping thread) and feet sets for binding... just dig through their 111 parts side (also look at the Singer 211 and Juki 562 / 563, Seiko STW 8 / LSW  part sites)
Edited by Constabulary
The college swing away did not work just placed the guide alongside the needle, but attaching the binder would still leave it to far away from the needle so back to drawing board for a binder that has adjustment screws on the outside of the binder not the inside as at present. Well at least i now have a fixed guide rather than magnetic ones
That is also a big toe on your foot? I would get a cheap one the same and grind it down. This is ideally what you are looking to achieve...This is a Pfaff 335.
20210706_133502.thumb.jpg.21d5b2e78e9edd08873bd88ff6fc1917.jpg20210706_133449.thumb.jpg.892e507497ed70a81c75f5aea799d69b.jpg
A few decades ago I was sewing safety vests that were edge bound. I tried using off the shelf binders to no avail. The dealer finally gave me a number to call and I had a binder custom built for the machine and the binding I wanted to use. Once I got that binder I never had a binding problem whether on inside/outside curves, turns, or straightaways. You may need to explore a custom binder and foot set to go with it.
Posted IMHO, by Wiz
Thanks guys your advice always welcome, My thoughts were to learn a new skill at low cost to myself, just for the hell of it with no real idea of what Project if any I would use the skill for
It does look like my machine and cheap binders are against me at nearly every turn, so will put it on hold for the moment as have a few ladies handbags planned to make, using Chrome and fabric non of which require the binder
So frustrating that these machines do not have a couple of standard holes, to fit attachments to, but just like cars a few years ago, horn switch, light switch or headlight dimmers could be anywhere around the steering wheel and as a heavily user of hire cars where i could drop off and join ships anywhere, the first 20 miles of driving a hire car was always interesting finding out that models eccentricities especially on a dark winters morning
I have to admit binder are a special topic but the cheap ones are not against you. It´s just tinkering and knowing how to set up the binder.
I´m using the freakin cheapest binders I could find (back then) and they work very well. Mine came from kits for flat bed machines like these (just minor differences):
https://www.ebay.com/itm/353465220561
and I modified the brackets to fit my 108w20 cylinder bed machine. Zero issues - really!
You can find complete 111w binder kits like this one:
https://www.ebay.com/itm/300921860528
Pretty sure College Sewing has all the components.
I fell down the rabbit hole after getting frustrated with binding curved pieces. I mostly do bags/backpacks and was having a hard time properly binding the foam and Cordura sandwich on the back panels. Someone on gearmaker (rip) suggested I needed to get a good binder, made for my machine and materials, and suggested three places:
B&J Attachments (Montreal) http://www.bjattachments.com/
Tennessee Attachment Co http://www.tennattachment.com/
Atlanta Attachment https://www.atlatt.com/
I own two B&J's, a 1" needleplate and ¾" swing-away for my Juki 1541s and it improved binding tremendously. I live in Los Angeles and tried three local places assuming because I had a common machine with a common foot that it would be easy, especially considering how many industrial machines are in the city- I was wrong. All three stores absolutely botched the binders, they were modifying cheap Chinese clone pieces and most didn't even fit and the ones that did either didn't work well or the cut-down feet weren't sized correctly.
After spending weeks spinning my wheels I realized why good binders cost more (~$175-250). When you order from the places I listed they will have you send in what materials you plan on using. It's such a huge upgrade and really alleviates a lot of the headaches. I've since acquired a cylinder arm w/ synchronized binder that makes binding even easier to but still keep the attachments for the Juki on the days I need to do two colors or different setups. I cannot stress enough how much frustration and cursing are alleviated by replacing a crap binder with one that's specifically made for your materials and machine. All three of the companies I listed make quality attachments so you have options.
EDIT: An easy way to sum it up: the materials you use for binding might be totally thicker or thinner than the materials I use, same with the materials we're pushing through. No Goldilocks binder exists, so imagine how hard clean binding is to achieve when either your binding material is too tight or sliding around in the folder and the materials you're binding are either too large to fit through so they're not feeding evenly or are swimming in the open space. This is why getting a binder made to your individual specs is so crucial. More precision = cleaner stitching and a more even binding
Edited by Esket
Just my 2 cents...Some binding tapes are very bad on corners and some are wonderful even though they measure the same and the same applies with some leathers as well.
YouTube Channel
Instagram
