Members htraps Posted September 1, 2021 Members Report Posted September 1, 2021 I'm thinking of making the welt of a knife sheath out of plastic sandwiched on both sides with leather rather then building up the welt with multiple layers of leather. I have ordered some bakelite which I assume will glue and cut/machine well but am now hesitant because its damn hard stuff and have some concern about it damaging the edge. Has anyone had success gluing plastic to leather? What plastic should I be looking at for this purpose? Quote
Members Dwight Posted September 1, 2021 Members Report Posted September 1, 2021 (edited) Bakelite is far too hard for your purpose . . . it will destroy the edge of the knife . . . just by pulling it out and putting it in. Bakelite is also brittle . . . and will break . . . leaving broken pieces to fall down into the sheath and do even more damage. There is really no plastic I can think of that will glue well to leather . . . and honestly . . . I really do not understand your reluctance to use leather. I make cheek pieces for rifle shooters . . . stackingup leather to as much as 1 1/2 inches. A knife sheath should not need more than one welt of 8 oz leather which is 1/8 of an inch thick . . . and glues or contact cements well to the outer pieces of the sheath. The welt is more than anything else . . . there to protect the threads . . . by being made of leather . . . it also protects the knife edge. May God bless, Dwight Edited September 1, 2021 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members zuludog Posted September 1, 2021 Members Report Posted September 1, 2021 (edited) 5 hours ago, Dwight said: Bakelite is far too hard for your purpose . . . it will destroy the edge of the knife . . . just by pulling it out and putting it in. Bakelite is also brittle . . . and will break . . . leaving broken pieces to fall down into the sheath and do even more damage. There is really no plastic I can think of that will glue well to leather . . . and honestly . . . I really do not understand your reluctance to use leather. I make cheek pieces for rifle shooters . . . stackingup leather to as much as 1 1/2 inches. A knife sheath should not need more than one welt of 8 oz leather which is 1/8 of an inch thick . . . and glues or contact cements well to the outer pieces of the sheath. The welt is more than anything else . . . there to protect the threads . . . by being made of leather . . . it also protects the knife edge. May God bless, Dwight This answer sums up my response - I make knife sheaths from 3mm thick leather.......alright it varies a bit around there, but is usually 3 to 3,5mm I don't know if they have proper names, but I do two styles, the one piece fold over, and two piece front & back. Though strictly speaking these are two piece and three piece respectively, as they have a welt, which is made from the same leather, and I don't have any problems with that But just at the moment I'm making a knife from a small, narrow blade so I'll use slightly thinner leather, about 2,5mm, and the same for the welt; I'm not expecting any problems, it is, if you like, self compensating, as the leather used will vary with the item, going up to 3,5 or 4mm for a machete or an axe cover I've watched many sheath making videos, and I think they all use a leather welt, though some do use a plastic or wooden insert, which is slightly different to a welt Mostly the welt is one thickness of 3mm leather, but sometimes I add an extra layer at the top or hilt area of the sheath to give a larger opening, and skive it to blend in - usually because I've misjudged cutting out the pieces! Edited September 1, 2021 by zuludog Quote
Members battlemunky Posted September 1, 2021 Members Report Posted September 1, 2021 I've made many sheathes and have also only used leather for welting. Initially I recoiled at the idea of using plastic but I don't see why you couldn't. It would need to be the right plastic too though. You would want something similarly pliable to leather so the edge can rest up against it and it gives a bit but still can protect the stitching. I don't think the bakelite is going to work because it will break and become a potential hazard because the sheath won't work correctly. Although it is unconventional it isn't wrong. If you pull it off, share pics and let us know how it carries. Also, I'd go with contact cement, either Barge or Weldwood. You don't want the eco-friendly water based versions for this. The smellier and more volatile the better. If you can find one that extincted everything on Mars due to its volatility and then fell to Earth, it'd probably be the one I chose. Quote
Contributing Member fredk Posted September 1, 2021 Contributing Member Report Posted September 1, 2021 The only plastics I can think of which might suit are nylon and HDPE Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted September 1, 2021 CFM Report Posted September 1, 2021 (edited) 11 hours ago, htraps said: I'm thinking of making the welt of a knife sheath out of plastic sandwiched on both sides with leather rather then building up the welt with multiple layers of leather. I have ordered some bakelite which I assume will glue and cut/machine well but am now hesitant because its damn hard stuff and have some concern about it damaging the edge. Has anyone had success gluing plastic to leather? What plastic should I be looking at for this purpose? no! just use leather there is no benefit to overthinking this. if you glue and hammer your welts then there ill be no seam for the blade to find. useing plastic wont guarantee this. Edited September 1, 2021 by chuck123wapati Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM tsunkasapa Posted September 1, 2021 CFM Report Posted September 1, 2021 Plastic??? Really?? Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
ljk Posted September 1, 2021 Report Posted September 1, 2021 You could try cording/welt. Sailrite or Rockford Supply. Quote
RockyAussie Posted September 1, 2021 Report Posted September 1, 2021 On another forum the other day I saw an odd knife where the owner was wanting a sheath made. This knife was heavily sharpened on both sides at the tip end and had no stopper or shape to the handle end which made me recommend a plastic end stop inside the sheath. I suggested I could print one out in pla+ and I know this will hold glue pretty well but I would do it so that the plastic would be fully inside the stitch lines of the leather. I would also think to bring the shape around enough to make the blade make the contact further up than the tip. The shape of this knife would easily allow little pressure to push right through the leather welt bottom I think. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
RockyAussie Posted September 2, 2021 Report Posted September 2, 2021 This is the one I was mentioning above. What do you think? Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
