Trox
Contributing Member
Everything posted by Trox
  1. Thank you Aaron for pointing that out. Not that I usually shop there much. Nevertheless, I have seen they sell several products with names that sound just like a famous good product. I bought some "Pure Neatfoot oil" from them and got "Pure Dingo assoil" instead. I was recommended that product, but I`m sure they meant the good one from another supplier. I stick to the Danish gold quality leather oil instead, until I get hold of the right type. Hi LeatherLegion, nice mod on your Cowboy 4500. Is it a modified slotted plate or is it custom made from scratch? It reminds me of the flat plate on my good old backup; Adler 5-27. I use my slightly modified 441 stirrup plate in such situations, its lowered a bit to gain footlift. (And get more support for the foot). I think the original plate are unnecessary high. We where discussing these plates in an other topic and Leatherkind made this stirrup plate on his 3D printer. He sent me one to try out and it actually works well. Its a very good method to test out attachments like this before you make the real thing. However, the plastic is very strong so it would last for a good while too. I am sorry for the Off topic, its kind of related to the original topic. Thanks Tor
  2. Yes, it might be because its made before they changed to the new metric standard. There is a small hole over the big one for the takeup spring. There should be a pin in there that push on the mechanism behind your new unit; when you lift the presser foot. That again pushes the disks apart and release the top thread. You see this long pin # 91- 013 091-05. Here is a page of the new type, look for the same in the old manual. Tor
  3. Lots of goodies there, I be interested in some too. Thanks Tor
  4. Hi, looking good. Now you look fit for a fight what are you using it for, role play? Did you hardened the panels or is it just for show. Tor
  5. Hi StrigaMort, The Blanchard brass pattern knife is a very good knife with a stiff changeable blades, its has a long edge on the left side of the blade to cut against the pattern. Many prefer to make them straight on the left side and have the bevel on the right side only. However, it works well out of the box after some polishing of course. Its now also available in the USA http://www.fineleatherworking.com/leather-tools/indispensable-knife Hi Zayne Well, its important to have a good hard cutting board too, I use a HD polyethylene board same as the clicking machine board (but a bit softer). You could try the same as they use in a butchers shop too. To soft a board and the knife will cut to deep in to it and you will make mistakes. Your knife blade might brake off too. The utility knifes flexes to much and you will not be able to cut out a piece without stopping (stopping is a mistake made). You must first make your self an leather stropping board to polish up your knifes, then you will get them even sharper than the utility blades (you can strop them too). You can also buy them, buy your self an aggressive polishing paste to apply on the board (its a must have). I never have to sharpen up any of my knife more than once, I just polishing them on the board before use. (Read up in the pinned topics about it). Then get your self a good round knife, cut the handle to fit in your hand. Then you have a knife that will do all the cuts you ever need (without cutting around cardboard patterns that is). You can skive with it, do long rolling straight cuts and cut true sharp corners on the raised tips. Buy a good round knife. You have the choice of an very expensive new custom made knife or an 100 years old used knife. Anything else will not be good enough. My advice will be a good 4 to 5 " CS Osborn with a Newark stamp on it, rosewood and brass handle (thats the cheapest option too right now). You might find a good one on EBay, but then you should really know what you should look out for. My advice is ; contact Bruce Johnson (the moderator here) http://brucejohnsonleather.com/content/index.php/leather_tools_for_sale/knives-and-other-handled-cutting-tools/ and by one of his good old refurbished knifes. You will get them ready to cut, with some advices on the fly too. Any of these nice oldies will out preform most of the other knifes available today. I have about 20 different round knifes in my collection right now, and some of the best of them are these old CS Osborne Newark stamped ones. (CS. Osborne & Co Newark stamped knifes are minimum 100 years old hand made knifes) Bruce's knifes are very well sharpen/polished and will cut straight from the box. Buying from Ebay you have to sharpen up/clean it up your self and that is a skills it takes time to master. Al Stholmans book of Leathercraft tools is a very good investment too (inexpensive paperback with nice illustrations), it shows how to use and maintain all the leather tools available. Then you will learn from the master the right way. Just my two cents Good luck Tor
  6. Yes, stop using that gum tragant. I cant really see any advantages with this product, must be on certain leathers that will not burnish with anything else. You can use saddle soap, but the best thing is to stick to water alone. Then you keep your burnisher clean too. I do not want to use anything else than water on my new cocobolo burnisher. Then I keep it clean for fat and do not have to sand it all the time to make it burnish well. In addition the Fibings edge cote want come off either. Sometimes I use alcohol based dyes before burnishing, that will ease up the burnishing process and remove fat. Oil/fat and wax must be applied after the the edge cote and not before. There are an other option too, you can move on to heat treatment of your edges. Then you must move on to professional edge paint. You will have to invest in a hot glazing tool/machine or a "Filet electric" in French. Check out the topics about it or contact Campbell Randall. It will work on chrome tan leathers too. Very nice color on your watch straps, are they all Fibings? Tor
  7. Great work Jimi, Screws on the presser foot are normal metric threads, but use good quality steel so you do not brake them. If you need some spare feet's and plates try http://www.kwokhing.com/pfaff/ Its not expensive and you will have the screws included with the new feet`s. You will need a thread stand of course or you will have problem with twisted top thread. Very good work. Tor
  8. Hi Zayne, I have the knife on your link and I do not like it, the blade is to thin/flex to much. When a knife flexes you will cut wrong (most of us anyway, I heard somebody likes it) I mostly uses my round knifes cutting leather. However, when I cut around cardboard patterns I use clicker knife/pattern knife. Either my Blanchard L`indispensable (brass) or a modified Stubai wood carver knife. I bought this knife in a wood worker shop because it looked promising (right proportions). Nevertheless, it had a microbevel edge like you often find on modern pocket knifes and was useless on leather (for anything else too). I grinded of this microbevel and made a long bevel all over the blade wide (on both sides), polished it and it turned out to be great. Its stiff enough and sharp enough to be a great little clicking/ leather pattern knife. You can also use it in your draw gauge. Many of us makes our own knifes from High speed (HS or HSS and not Bi metal) hack saw and colt saw blades. You can grind them to be very hot without loosing the steels tempering, they makes very good blades. Tor
  9. HI Tallbald, what Andrew says is right, these machines was original made to sew heavy industrial fabrics. I have lowered the feed dog on my 441 to about 0.9 to 1 mm (over the plate). The Juki manual says 1,4 mm. and thats way to high for leather work. Especially when you sewing reins close to the edge. When the feed dog pushes the edge up to much, it makes the needle exit outside the leather edge. I can also use my slotted harness plate to eliminate this problem. However, the setup I like the best is a smooth feed dog, with a smooth standard plate and harness feet`s. And of course a drop down roller guide. Lower your feed dog its the easiest solution to this problem. Use a caliper or a correct thickness leather piece to adjust it. (Juki recommend removable locktite on the feed dog screw so it might be a bit hard to unscrew, I believe Bob K. uses it too) Good luck Tor
  10. That was a nice machine Greg. I seen them selling special plates and foot set for the DA 767 machine with a edge knife on. Its a small video on Kwokhing.com on how it works. Perhaps you have these parts to. Can be a labor saving device for sure. I saw a you tube video with such foot installed on a Adler 105 too. Tor
  11. This is a old machine and before they started to use H subclasses (I guess, since it misses on the plate) Normally (on later machines) the "B" always stands for version B. "17" stands for sewing equipment class number (which feed dog, foot and so on) "S" stands for "Stoff"= fabric and "L"= for leather and so on. Where are you based? in case I find some old Pfaff parts laying around. Tor
  12. You can forget about original Pfaff parts, then its cheaper to buy a new machine. Example Pfaff 345 binding needle plate $900,- They are hand made in Germany and are out of the question if you want to keep your budget low. There are old broken sewing machines laying all over the world, it was made allot of these 335`s. Everybody used this class, small leather, jeans, synchronized binding work and so on. Its a nice little machine for small project and thin threads (max tex 69 or tkt 40). They where made of the best German steel ever made, so you better hope your broken screw are not hardened ones. Every one that have tried to modify original Pfaff plates and feet`s know what I am talking about. These machines are pretty easy to find used to a descent price, because the smaller subclasses will not take heavy threads. So its important to keep you budget low. good luck Tor
  13. Hi Jimi, first; there are tools for pulling out broken screws (see pic.). We call them "grisepigg" in Norwegian; and direct translated to English that will be "pigtails". I do not know if thats the English name of them, thought. you drill a small hole in the middle off the screw and screw it in, its links threaded and will unscrew your broken bolt. Then soak your "project" in diesel or paraffin (if you can afford that) and let it stay for some days, leave it in there when you work on small parts (24 hours will help too). That will take care of the stuck parts and some surface rust. looks like you missing its base, with the hinge and screw tabs? Write to Pfaff industrial info@pfaff-industrial.com and ask for the service manual and part list (report every number on its brass plate in right order) I am sure they will send you the original pdf`s for your machine, they are very helpful there. So far I have not seen any of your pictured broken parts that cannot be replaced with aftermarket parts, or can be taken from another Pfaff class. Good luck Tor
  14. Perhaps I need to chance my needles then and not the tape. I will try these needles my Norwegian supplier has them; "Groz Beckert San-6 Gebedur": but I don't know in which system yet. Do silicon lube help anything?
  15. Thank you Wiz; I try to find a good one that do not stick to much to the needle. I will check it out. Thanks Tor
  16. J. Dixon Tools UK. and Vergez Blanchard, France both make very nice European leather compasses. Same ones as for hundred years ago. Tor
  17. Hi Wiz, I do not know this brand of tape, could you please enlighten me about it. Thanks Tor
  18. HI Bruce, yes mine has such varnish on the handle too. I remember I wrote to ask you about it a couple years ago when I found it on EBay. I think this was one of Al Stholmans favorites too, he write about it in his book the "Leather craft tools". Where he name it as a 4 1/2" head knife. He preferred using it because of the angle of the tips and its small size. I would not agree with him in calling it a head knife, the typical European head knife is smaller and have a 180 degree blade and have a very long handle (see pic of J Dixon tools for example). The tips on this OSB is slightly leaning backward more than 180 degrees, that makes a small round knifes does it not. The blade shape is very similar to my latest favorite user; a HF Osborne. But that has a much thicker blade and a wide short rosewood handle, a very well made knife. No flex in this knife. On to something else. I bought a pretty rare Dixon screw plough gauge on British Ebay that I am very exited about. Its still in the post but I cannot wait to compare it to yours. Its has some small differences from the one you have on your site, different locking of the long screw. It look exactly as the one in pictured in page 277 in the book of R Salaman "Dictionary of leather working tools........"(Ward and Payne catalog of Dixon tools). It has a dark patina but looks to be a nice tool after refurbishing; I hope I am right about that ( I think so). I will show it to you here when I get it. Sorry for the of topic. Thanks Tor
  19. Hi Hayes, mine is exactly like yours but have a Newark stamp on it. The handle is not rosewood but some kind of hardwood with stain on. The stamp is not as visible as yours anymore, but its a CS Osborne Newark stamp on it. When I wrote the larger OSB rosewood and brass knifes was the same blade thickness, I forgot to mention they are ticker where it goes up in the handle: approx 2 mm. Here are some pictures of it. The steel are not bad, but not of the same quality as the rosewood more expensive knifes. Tor
  20. Hi Constabulary, Well the NPS will not work properly with a speed reducer because of the extra gear and its belt slippage. Some digital servos have the synchronizer that only calculate belt slippage like new Efka`s. The motor has a so called community drive, the control-box gives the motor the distance to run and not the synchronizer. (The synchronizer is only there to calculate belt slippage on the specific machine pulley) Then the speed reducer will mess this up. Then you have the old type of NPS motors with the position adjusted in the synchronizer, it will run with a speed reducer but not accurate. The belt slippage on the reducer will mess up the NPS timing and makes it miss the positions. Like when it miss down position with to many degrees it will return to up position and opposite. One solution that might work is to place the synchronizer on the speed reducer, I have seen that setup but do not know if it works perfect. Depended of the particular NPS motor construction you can have a error signal, some run inaccurate and some do not run at all. Tor
  21. Good morning to you Constabulary, Joe's motor is from the 1880`ties not 1980 ties. No, but its a pre WW2 motor I think. Anyway, I have the same one in grey color too and thats even worse than the earlier black color one. I agree about the WEG motor, I had one of those too. I also have a good one from Kobold Germany, only 370 Watt single Ph but good control on it. It came with my Pfaff machine and really did not needed to be changed out. I had that Cobra servo laying around and some speed reducers so I changed it out. I often wondered about that Jack motor with position system, was it any good? did the needle position work on it? Yes Wiz talked allot about that gear reduction motor, but suddenly I heard nothing more about them. Perhaps it turned out to have low quality gears in it?? I do not know. Anyway, it was not available in 220V. Europe have a "pretty strict" quality control on electrical products "CE", perhaps thats why many of the Chinese motors do not turn up here. That FESM 550 look pretty low tech and simple, just what the Chinese electronics production is capable to manage today. Then again the pot meter on them was not a good quality, according to the topics about them. Thats not a big problem anyway. Tor
  22. Thank you Joe, you are welcome. Thats what this forum is all about, to help each other. I have learn allot here too. Sometimes i wish members would be better to post about bad products, like faults on machines and tools. Its allot of good feedback here and not so much of bad ones. Often when somebody breaks the ice and complains about a product, many others follows with the same problem. In the mean time to many others buy that same faulty product. I have seen this a number of times here. Nobody gains on this, nor the seller or the customer. I think that in general Europeans complains more often than US Citizens. Or am I wrong. Thanks Tor
  23. Hi Hayes and Bruce, I have one just like it with the Newark stamp on it, that makes it old does it not. Same handle and ferule but no sloppy fit. The blade feels a bit thinner than the OSB (Newark) rosewood and brass knifes, and the blade flexes allot. So I measured it; its 1,5 mm the same as my bigger rosewood and brass OSB knifes. The reason it feels thinner and flex more is because the blade is narrower where it goes up in the shaft. The steel will not get as sharp as the more expensive knifes. I do not like to use mine because of the flexing blade, so I cant tell you how it keeps an edge. Thanks Tor
  24. Hi Joe, yes I know them and I have a couple of them laying around too. Its very old and very weak. One Hp (horse power) is 746 watt and 1/3 HP is only 248 watt. Even if it was brand new thats not enough to power your machine true leather. It will struggle all the time and then be uncontrollable. You better find something in the range of 600 to 750 watt. I have a inexpensive Chinese Cobra digital servo motor on my Pfaff 345 machine, 145$. The Pfaff 345 is a medium triple feed in the same class as your Adler 67. (My Adler 67 now sold, sewed true 11 mm. bridle leather with that motor) The motor is more than strong enough with out any speed reducer. Then you have the Family FESM-550 types of analog servo motors. I have seen them from 90 to 150$, I have not tried them because they do not come in 220V. However, I have heard good things about them. You will not find a cheap servo motors with perfect speed controls like on expensive Efka`s and Ho Sing motors. Then you get what you pay for, a Efka cost nearly ten times more too. With enough power the motor will always be more controllable, clutch or servo. I will echo what others have told you, buy your self a Chinese servo.Thats better than a clutch/speed-reducer, saves energy too. Read up on them in the forum, all the member dealer sell them. Good luck Tor
  25. Hi Joe, Your clutch plate might be used up and its possible to get replacements. The brake on these motors should kick in when you let of the pedal or heel the pedal (depended of how it is adjusted). I mostly replace my clutch motors with servos (Efka`s and one Cobra), but I still have a couple machines with Clutch/speed reducers. One of them is a new low-speed 4 pole 600 w clutch motor; this is a very good motor and its easy to control at slow speeds. I had others that are totally uncontrollable, so yours might be one like that. If you un hook the connection from the pedal, you can see how the brake engages. It`s adjustable on the pulley end of the motor. There might be two screws; one for the brake and another for the pitman arm`s return spring. Try out some different settings. To find out if your clutch needs a new friction plate, you better try a good one and see if its any different. Hi Pcox, its against my better knowledge to put oil/fat on a friction plate. I can`t tell you how much or when you damages it, only that you will loose friction. It will soak in to your plate and you never get it of again. Sometimes it will form a hard slippery surface and your clutch will start slipping. You needed it to slip a bit more and then took very little on. You succeeded against every advices, but personally I would not risk it. Well, thats perhaps not that big a risk when people trow these after you now a days. I have some old ones laying around, I could donate one if anybody locally needed one (V single and V, 3 Ph. They are to heavy to ship abroad) Thanks Tor
