Trox
Contributing Member
Everything posted by Trox
  1. I ordered new bit for my burnisher motor from an English tool maker I know. It was a custom job, from my simple sketch and he did a great job. It fits my motor shaft perfectly and runs without any vibrations. He trowed in one of his awls as a gift too. Its a Little beauty. And of course for leather, its cocobolo and brass. This is Christmas all over again. Tor
  2. Thats not a motor problem. Here is several things to check out: Its most likely the twisting (twink) of the thread that does this. Thread top thread true all guide holes, several times around the top head thread pin. And center the guide above the thread spool to be exact in the middle of the spool. This will take the "twink" out of the thread, that make uneven tension. Otherwise, check the thread tension release pin, that push the tension disk open when you lift the presser foot (check for faults). Increase foot pressure will sometimes help on such errors. Check for burr on hook tip. Wrong size or damage needle. Good Luck and keep the motor. Tor
  3. Hi VanDutch, I understand you have the King Cobra machine with the EPS motor (position motor). I do not have the same setup as you. I use a expensive Efka servo system on my 441 machine that are strong enough without a speed reducer. I do have a regular Cobra servo/speed reducer on one of my other machines (same motor without EPS) These motors are among the most powerful economical servo motors on the marked today. Although they have had some faults on the speed control before (that has been fixed now) they have always had enough power. Very strong compared to others in the same class (price range). Its not fair to compare them to `high end motor systems as Efkas and Ho Sing that cost 1k $. If its a loose part on the machine somewhere in the needle feed a position system will stop, it reports the wrong position and the motor will stop. Or turn an extra rotation, thats the way these systems works. What ever the fault is you can rest assure you are in the best hands, Steve will make it right. And if it is a motor problem, I still think its related to the position system. The EPS motor is the same as the regular servo motor with a built on needle position system, same spec`s, power and torque. Together with a speed reducer it should have no problem sewing that on slow speed. Good luck. Tor
  4. Hi Frans, do you have the EPS motor or the regular servo motor without needle position (Called EPS by Cobra). If you have the EPS and your machine flywheel is loose the machine will stall, because of the position sensor installed on it. It will send faulty signals to the motor to stop. Otherwise, I would need to know about your sewing thickness and thread size etc. to see if its normal or not. This motor should be powerful enough for this machine. Good luck Tor
  5. One of these will for sure know where, if they are not able to help you them self. http://www.pilgrimshoemachine.com/ http://www.leightons.ca/catalog-general.html Both makes parts too. By the way, I have seen these for sale on on European EBay sites pretty regularly. Tor
  6. Its a top feed shoe repair machine with limited bobbin thread, that will mark up your weg tan leather. Nevertheless, a must in every leather workshop for all job`s other machine will not do. This is the heaviest subclass, max stitch length (new) 5 mm. Foot lift 12 mm., needle Nm 110-200, thread TKT 40/3-15/3 (max tex 180). These are the factory spec on the new class 30-70 (long arm big bobbin). with 12 mm. foot lift you will be able to sew up to about 8-9 mm. thickness. A very fine patcher it is. Thanks Tor
  7. Search this forum, there is someone (in Canada I think it was) that specialize on these. That sells part and needles. I might be wrong, but I know for sure its information about it here somewhere. You can perhaps find the part list and some help on this. Good luck with your sole stitcher Tor
  8. Hi Novaroper, there are not much "paperwork" around for these class 30`s. Is it the new "square" head Gray color machine, or the old green "round" head ? I have something for the new machine, for the old I have only the part-list. The new Adler class 30 is made on license by SL special sewing machine Germany http://www.sl-spezial.de/sl/index.php/shoe-repair.html , Perhaps they have some more info. Otherwise in the blog of Thomas Brinkhoff (Head of spare-parts DA) http://sew24.blogspot.no/p/downloads.html you will find the manual and part list here. Be patient and let the download finish, it takes time to download. If you have the old machine I have the part-list, just PM your email address and I will send it to you. The rest of what I have you will find in the links above. You can also use (user) manuals on the Singer 29K- 72 or the ones for the Singer 29U171A_172A_173A (the file format of the 29U machine in the Singers web site). The last one is a very good operator and service manual and very similar to the Adler class 30. (The machine is not made to sew as heavy as tex 207 thread, on a test piece with lighter bobbin thread; maybe. In real time repair sewing..... you will have stitch errors. Not that many before you are out of bobbin thread, that is ) Good luck Tor
  9. Hi Constablery, I would demand my money back for such dangerous motor. Its a very easy to stitch true your fingers. Its clearly a construction fault, it's not doing what it's supposed to do. Good luck Tor
  10. Hi Dirk, nice job. Although I have enough skiving knifes, I am always on lookout for high speed steels that could be made in to good knifes. The wide wooden drill bit was a good idea. And it turned out looking good too. It also have a hole in the blade to hang it on the wall; very nice. Hi Michelle, if you use high speed steel like used in drill bits and hacksaw/metal saw blades, U can heat them very much without ruin the tempering. (Bi metal is not usable, look for hs or hss markings) I use a cheap bench belt sander for the grinding/sharpening of my blades. It runs very cool all the time; I normally do not need to use any water to cool down the steel. I use normal wood belts (because that's the only I find for it) 80 and 180 grit. When the belt is almost worn out it gives an almost polishing effect. Then I use a buffing wheel (with buffing/grinding compound) for the polishing. Thanks Tor
  11. If you read my post, I like your design part from the spring. It would not work for me. Sometimes i need the jaws to press hard, other times not. I thought you wanted some inputs? If you want sell it, you can add it to the " for sale" section. Thanks Tor
  12. Take your awl and push true that pine Wood without supporting the jaws. If the Woods still do not move it would work. Its not the matter of holding the weight alone. Do some real time testing and you will soon see what we are talking about. Good luck Tor
  13. I have seen many different saddler horse designs, and I like parts of your design. However, the spring as the only locking device.... it will not work for heavy stuff. If you added another wheeled lever on the opposite side; that locked the jaws. Then you would have something that might work well. Tor
  14. Hi Big Jake, thanks for your update on Heritage mod 84 splitter. Intresting defination of the skiver/splitter. Although English is not my native language, I would call them both pull true splitters. Regardless of the means of locking the handle or not. The model 84 are still for sale with CS Osborne and Campbell Randall,who both have produced them for about hundred years now. And made them in the USA too. Like you I also believe that both the Tandy and the Heritage are made in China. The strange thing is that the Tandy model is the most expensive of them and the Heritage is the second most expensive one. They might both be good. However, Why not buy the real deal instead. Have look at the Campbell Randall, it's a real beauty. http://www.campbell-randall.com/shop/index.php?route=product/product&path=1_143&product_id=13842 priced to 545$. It would be my choice. Thanks Tor
  15. Thank you Steve, I already have such machine, I made one my self some years ago. Not as nice as yours, but still doing the job. If yours had been available when I made mine, I would have bought yours instead. However, there must be lots of other 220v users out there wanting this. Perhaps if you made it available without the table for international buyers, to get the shipping price down. Just a suggestion. (I guess the motor weights a ton anyway) Thanks Steve
  16. You are welcome, I did not do much. Tor
  17. Nice Steve, not my voltages.... part from that it looks perfect. I liked the stand too, our benches are alway full of something. You have really thought this through. Good job Steve Tor
  18. Knowing that those attachments was that easily available and to a decent price; was my reason for buying a 441 clone. Did you come up with some good modifications Wiz. Anything you care to share? I love a good modifications Thanks Tor
  19. Here you go http://www.duerkopp-adler.com/en/main/Support/downloads/index.html?action=search&prop0=%2Fcommons%2Fdownload%2Fpublic%2F205-370%2F&prop1= here you find all kinds of manuals for it. Tor
  20. Thank you, that is an option. But I am afraid it will take to long and be more expensive that the options I already have. I can order the the small Blanchard sizes from 36,57 $ to 42,11 $ from Denmark (who is close to Norway where I am located). I see that CS Osborn sell them for 43,67 $ each regardless of size and Dixon's (from Abbey) cost from 26,64 to 28,30 $ each (for the small sizes). The Danish option, Leaderiet.dk is the only European leather shop that sell tax free to private customers outside EU. In fact thats the only shop I know about that do this. We do have to pay that same amount in import tax and in most cases we pay that tax twice. The Dixon are the cheapest ones, but they do not describe their sizes other than in numbers. Those numbers do not tell me much, other than they are getting bigger with increasing numbers. A friend that bought some new Dixon told me they was not as good as he had expected them to be. A bit "sloppy" made was his word, I would be very careful using this description when I have not seen them. The older Dixon tools I have are very good, and nothing are made as they use to 100 years ago. That goes for all the mayor leather tool manufacturers. I guess I answered my own question, or maybe you know about some other options. The price differences are not that large on one tool, but buying several punches at once it will matter allot. Ovals for screw presses on the other hand, I have not seen many of them.
  21. By the way, as I mentioned above; I am looking for some small good oval punches. I am long past buying cheep tools and some Blanchard's, Dixon or Osborn will do fine. I would prefer the Blanchard's over the others if the prices are similar. Oval punch bits for screw presses will also do fine. If anybody know a good supplier, please let me know. Thanks Tor
  22. It seams as its greater than mine, you right. I am sorry, I guess my mind was set on that "problem" when I read about it the other day. The site turned up in my google search when I looked for the knife. Sometimes you read what already in your mind, instead of what it actually says. My mistake. This mistake costed me some time and dollars too. Nice to deal with Fineleatherworking, they ship fast too. I should probably have dealt directly from Blanchard, because not I remember I need some small oval punches too. With them I am close to that magical minimum buy limit anyway. I think I am starting to be a bit absent-minded. Thank you for setting me straight Tor
  23. Hi Django, yes, this French company offers exactly the same Blanchard knife, its stamped Vergez Blanchard. However, you have to place an minimum order at 100 Euro here too. Its priced at 23 Euro, the same price as if you order it direct from Blanchard. Therefor, It makes no difference if you order it here or directly from Vergez Blanchard. Hi DavidL, I have not received it yet. According to the tracking system, it past true LA yesterday. Tor
  24. Hi, I haven't received it yet but I will post about it when I do. I purchased this knife to use it to cut out leather from cardboard patterns. If it has an double edge I will re grind it to have one on the right side only. This to get close up to the pattern without cutting in to it (I am right handed). I was told this blade was much thicker, stiffer than the other types on the marked; It has to be seen. Anyway,I know it`s a favorite of many European leather bag makers. I have also made some knifes myself, out of high speed hack saw blades. However, I find them to flexible. I have tried out many other US and European clicking knifes with changeable blades. And the same goes for them too, they all are to flexible. Most blades are only 0,8 mm thick, and thats to thin, they will flex and follow tracks in the cutting surface. I am sure you have experienced the same problems. Most of the time I trace the pattern on to the leather with an (round) awl and use a head knife to cut them out. I hope this knife will save me some time, at least on thinner leather (bag leather). INFO TO FOREIGN BUYERS ON FINELEATHERWORKING.COM (like me) I you are not able to check out from their website (international shipping). Please contact the shop owner and he will add your country to the shipping list. He is working with the list as we speak, to add as many new countries as his able to. When I tried first try to check out my country appeared in the shipping list, but I was still not able to check out. If this happens, he have to add your country to the list. Send him an email and he will answer it right away. They did not expect that many Europeans to buy from them, since they are much closer to France. I was told to update you all about this and now I have done my duty. Very fast and good customer service by the way (this are my own words) I guess than many find European dealers with high minimum orders difficult to deal with, I do not blame them. Most of the times I buy for more than the minimum order anyway, but I do not like to add unnecessary thing to my order just to qualify. I understand the work load and that small orders do not pay. This is the same for all of us that do sell something. Nevertheless, I think it is disrespectful to the customers to have such rules. I do not have to mention any names here, but there are at least two big American dealers that do this (one way or the other). One of them recently had to rethink their market strategy, I guess they needed to sell more. Others has prepaid memberships to price their goods higher. Customer do not look kindly on to this systems and choose other options if they are able to. I am not talking about small tools companies like Blanchard and CS.Osborn, I am willing to pay extra to have them around. I am talking about greed and not need here. And I know the leather worker business can be very hard to survive in, but I still think the best business is to threat your customer right. European dealers has much to learn from their US counterparts when it comes to customer service. I buy 80 % of my tools and machine parts from the USA, despite the higher shipping costs. That speaks for itself. Thank You Tor
  25. Hi John, I did not mean to be a "smart aleck", I just happened to know about those famous Scandinavians. Western history in the other hand, I know very Little about. Thank you for posting. PS. I would love to See your holster pictures. Tor
