Everything posted by Trox
Hi Peter, U have allot of nice machines. The 169-373 is the same machine as my Pfaff 345. However, I would prefer the Adler before the Pfaff. If I find a 269 or newer I change out my 345. Because it has no clutch or drive belt, U have to adjust it pretty often because of that. Do U use all your machines or are U like me; have allot of backups. I do have a old Singer 236 W-100 post bed that I never have used. I maybe will use it for making some watch straps and hats, it has a roller foot. Where are you located, I have a Pfaff postbed for sale. It belongs to a friend and has top/bottom roller feed and needle feed. Efka variostop motor, looks good. It has only a normal post, not a high post. Tor
Hi, I am afraid thats all who can be find out there. I too have a manual who covers several subclasses of the 204 (flatbed) and the 205. Only the modern 204/205 -370 subclasses has their own service manual. And thats the latest triple feed subclass. The manual has allot of errors. In your case you must only follow the bottom drive bar and shafts to find loose parts. However, it might be as simple as a loose feed dog screw. You might find some stuff here http://sew24.blogspot.no/p/downloads.html You can also ask Thomas Brinkhoff, head of DA spare parts, he run this blog and are very helpful. Tor
Thats real nice Peter, I liked your version the best. It warms my hart to see this kind of craftsman's ship. Tor
Thats a possible solution Les, thats why I told him to look there first. Do not worry it is not rocket science, take of the shuttle race , two screws and inspect the bottom feed.
Hi, Yes thats right, Locktite on the threads of the screw. The screws tends to open because of the big foot pressure. However, if the foot presses it down other parts can be broken or loose too. You have to check all shafts, joints and bars. Check for play in all parts connected to the feed dog, loose collars and screws. Take of the shuttle race and check. Check in all inspections holes too. I do not use any locktite on any of my Adler's and I never had this problem. I think something is loose inside your machine, and it is very hard for me to give you remote help on a issue like than. Take of the face plate too and check for play in the needle feed. The bottom and the needle feed is connected to each other, if the play is in the needle feed the result will be the same. Therefor check all of the machine for play and loose parts. (Check the eccentric in the stitch regulator system too) Good luck and keep me posted. Tor
Shims its a easy solution to above problem. It also is important to use all of the splitter blade, and not get a habit of using the same place every time. Tor
I am an European and use many European leather tools. However, when it comes to edge beveller the only good ones are made in the USA. I have different CS and HF Osborne edgers , my favorites are the fine edge bevellers. Tor
I have two # 86 (8 and 10 " versions) and 6 " Heritage splitter. I do have exactly the same problems too. I am looking toward a Campbell Randall (osb. 84) or a crank driven splitter. I believe the # 84 is a much better splitter than any of these. However, I never own any myself.
Hi Mia, here is how I do it. You need three parameters: 1, The needle height: How high the needle bar should be over the needle plate when it is in its highest position or vice versa as in this manual. 2, Then the needle rise: when the needle bar has past its lowest position (bottom dead center) and raised with X mm (X= 2,4 mm or 3/32 " on this machine, I peeped in the manual) 3, Then the hook timing position: the tip of the shuttle hook should be 1,6 mm (1/16 ") over the needle eye in the center of the needle. Before you start with the timing adjustments make sure the feed dog is in the middle of the needle plate (side-wise; equal space on both sides of it), if not make the necessary adjustments. Insert a new needle (right size needle, the one you use the most), I see the maximum needle size is Singer 22 (Nm 140), I use this for thread size TKT 20 (TEX 135) Make sure the needle hits in the center of the feed dogs needle hole, if not make your adjustments according to the manual. Check the feed timing; the needle and the feeding foot should hit the feed dog at the simultaneously. And in the same moment as the feed-dog is coming up from the needle plate. If not make your adjustments. Then back to point 1: Remove the needle plate and insert a new needle (right size as you have already done), set the stitch length to zero. Then you must do some calculating because two things are not as they appear in the manual. First; the different needle system, who maybe is longer than the original? The second problem is invisible timing marks on the needle bar. You must measure the length of the needle-bar with a caliper, wipe the needle bar dry and make some ink marks if it helps you. If the timing needs to be adjusted: You know where the timing marks on the needle bar should be; 50,8 mm from the lowest point of the needle-bar (that is the same as the right needle height). Then measure the difference between the original and the new needle systems length. The new system is a bit longer, draw this difference (X mm) from 50,8 mm. and you have the right needle-bar upper mark. (X= the length difference between the new and the original needle in mm). 50,8 minus X = is the length of the needle bar when it is in b.d.c (in its lowest position). (Normally this should be 50,8 mm, but with a longer needle, it has to be less. You can always put the original system back in and use 50,8 mm, however just compensate for the longer needle and push the needle bar up X mm). Then rotate the hand-wheel until it raises 2,4 mm up from b.d.c, loosen the screws in the hook gear hub (as in the manual) and turn the hook until it is in the correct position. (Middle of the needle, 1,6 mm over the eye) Then tighten the screws. Then you can proceed to the Hook needle distance ; move the hook as close as possible to the needle without hitting it when it is in the above position (as described in the manual). (The hook tip is now in the needle charf) Why go to all this trouble and not only adjust it by the needle bar. Two things may have happened to your machine that knocked it out of timing. Either the needle-bar has moved or the hook gear on the hook shaft has, you do not know yet. If hook gear has moved and you adjust it with the needle bar, the feed timing will be wrong. And the other way around, if the needle bar has moved and you adjust it with the hook gear you will have the same result, wrong feed timing. Wrong timing of bobbin case opener and so on. Thread and needles may brake or other kinds of errors happen. http://parts.singerco.com/IPsvcManuals/211G155_G156.pdf I hope this made some sence. Good luck Tor
Yes Erik, what you are describes so well is very important factors to problem-free operation of the machine. Users should remember this when they expect these machine to work perfect with all thread and needle sizes. These machines should be adjusted with the needle size u use the most, the possibility of stitch errors increases for every needle size bigger or smaller than the adjusted needle size. I guess the machines in your factory only use one thread size all the time and you readjust hook needle distance if you change the thread size. Hi Mia, lets stop there for a moment before you starts to adjust your machine. Am I missing something here, or is this a second thread you posted about your stitching errors? I went back to your first post and you wrote this: "Now what I really want to sew is Navajo blanket and soft garment leather... 4 layers thick, two layers of each... It barely fits under the raised walking foot. NO DICE, the thread either breaks at the needle or it skips stitches badly... So, do I have the wrong machine for the job? or am I still doing something wrong?" You also wrote "Take a old pair of denim jeans, double them, and the machine walks thru 4 layers of denim like butter... as long as you can keep the upper thread between the disks, it does seem to want to "jump" out." Your machine sewed fine on the thinner stuff. Then I see you have changed the needle system, is the machine adjusted to this needle? What size was is adjusted to? and was the needle hook distance set to this needle? When you read what Erik says about the hook needle distance, make sure you have not adjusted your machine to a size 120 needle and using a 180 (or equivalent in Singer sizes witch I am not familiar with). This is important factors, you might have the machine to do what you ask of it. However, make sure its set up to properly for the job first. Good luck Tor
Its not a easy job to adjust a machine if it is your first time, thats why there are sewing machine mechanics. However, you are lucky its a Singer machine who is well covered with service manuals. On older German machines its often hard to find such manuals. Its important that you do all the adjustments, and in the right order to get it right. Make sure you use a new right size needle (as listed in the manual), and fresh left twisted thread. Make sure you thread your machine right, use all holes in the top thread guide (s) to get twink out of the thread. Good luck
Just take it apart and check the position of it in the middle of the needle plate (side wise), get a service manual. Good luck. Tor
These are copies of Germans and Japanese position motors, I have Adler's from the 1980`s who came fully equipped with such motor. Sometimes it helps to look out of the window. However, the pro motors like Efka and Ho sing cost more; they can also do much more. They are in no need of a speed reducer and can be equipped with all kinds of extras like: Back-tacking, foot lift, thread trimmer, needle cooler and you name it....... The one I use on my 441 clone ( German Efka 1550-AB 321) has up 1800 watt and 8 Nm of torque, I only use the half of it. You might not need all this on a leather machine, nevertheless it makes all the upgrades possible if you need it later. They are small and can be placed inside machines or on the back side of the machine like on the pic. Or the traditional way under the table. Then the quality is superior, the ones I have from the 1980 still works very well. Price from 600 to 900 $, remember you do not need a reducer; then it is not that expensive. Tor
Shoes off, easy on the pedal and use your right hand on the fly wheel to as breaks. Here is a home made reducer one of our member made (pic one). If I have a machine with three phase motor who needs to be slowed down I use a frequency controller, it gives you full controller of the motors speed and many other parameters too. You can run it at one stitch a minute if you like. And it converts the motor in too a single phase so you can use it on the regular household current. Here is one. Tor
Nice Ludvig Adler 205-370 clone for sale in the used forum 1250 $, thats a bargain, these cost more than 3k new.
I agree Greg, they later found out it was not a 67 but a 367 ( see the other thread http://leatherworker.net/forum/index.php?showtopic=47906 ) And thats an hole different story and a very good price. Tor
The only thing that is important to me is that the material is workable. I seldom find a foot that does not need to be modified Tor
Hi Steve, I have several big old Adler's myself, 204, 105 and a very nice 5-27 with all saddler's attachments. The last one is in mint condition and I used it for many years before i got a 441. Here is a German used leather machine dealer who has all the Adler on your list and more. http://www.sieck.de/en/machines/sewing/diverse-machines/ The Kochs Adler cl. 43 is a long arm cylinder-bed barrel-shuttle lock-stitch. Kochs Adler made eleven subclasses for export; 43-1 is drop feed up the arm. Cl. 43-3 is a Zig Zak up the arm. Sieck has these two for sale. The Class 20 is the same machine as the Singer class 7. Adler later made a newer version of this machine class 120, I know of one for sale is a brand new machine made by Adler. These Adler 120-30 is made new in Germany on license from Dürkopp Adler and the price is plus 300 000,00 Euro. The same company also make the class 30 shoe patching machine. http://www.sl-spezial.de/sl/index.php/flat-bed-lockstitch-machine-adler-class-120-30-e2.html So if you know of anybody who want one there is one Adler 120-8 available in Norway to "normal" price. It has a 40 mm foot lift and its a monster. I do have these three Adler`s for sale cl. 5-27 ( Cyl. bed, 220V electronic adjustable top speed clutch motor and speed reducer. All saddler's attachments ), cl. 105-25 top and bottom feed cyl. bed (new table and new 4 pole low speed clutch motor, speed reducer) cl. 204-64 needle and bottom feed flat bed with Efka variostop. All set up for leather work, ready to sew and in good condition. Thanks Tor
Thanks Mike
Hello Leatherdog, I have several Adler's, on one of them a 105 I had to change the feed dog screw. Otherwise I had no such problem on them. However, if the screw loosens on it use removable locktite (I do not remember the color on , red or blue). Both Dürkopp Adler and Juki recommends to use this on their big cylinder beds (DA 205-370 and Juki 441). It is written in their service manuals as well. The reason it is not recommend in the 205-64 manual is simply that it was not invented the time it came out. If the screw is not the problem you got to take apart the shuttle race and inspect the feed bar and links, see it there are any loose screws. If it moves side ways, check for gap between the collars on its feed bar drive shaft. The only common problem is that the feed dog screw tends to loosen on these kinds of machines, because of much use and big foot pressure. Good luck Tor
Revised Question: Adler 367 Versus Consew 206Rb-3
Trox replied to georgeandgracie's topic in Leather Sewing Machines
The shipping would kill me and I already have 11 machines, it should be enough. This is a good opportunity for somebody to get a very good machine. If you had the right class from the beginning you might have chosen otherwise. However, the Consew will do the job too and you will have $ over for other stuff you need. Good luck Tor -
That a very good buy, If I was in a need of a heavy stitcher I would happily pay the shipping to Norway for that. There was no price on it, these costs much more that the 441 clone new, Around 3500$ I think.
Hi Janet, Thats a different story the 367 is a very good and valuable machine in the upholstery class. Used ones are worth the same as three new Consews 206. All Adler and later Dürkopp Adler machines that ends with "67" is flatbeds of the upholstery class. This one is the first of the modern M class machines. It will do the same as the other 67`s (and other upholstery triple feeds) at low speed, in addition to do it in high speed too. Dürkopp Adler (DA) do not make low and high speed upholstery machines any more. They are all capable in doing both and has central oil lubrication systems. Both Adler and Dürkopp (before they became the same company) made such machines already in the 1980`ties. Examples are the triple feed Adler 767 and Dürkopp 291. I would love to trade my "new" Dürkopp Adler 267-367 with Efka pos motor for it any-day. This machine has a bigger bobbin takes heavier thread and has a longer arm. This is the latest in German sewing machine technology and is what the Consew is going to look like in about ten years time. Have a look at its specs: http://www.duerkopp-adler.com/export/sites/duerkoppadler/commons/download/public/367/367_d_gb_f.pdf http://www.youtube.com/watch?v=1liHhCliUDU No offense, I get a bit carried away here. Nevertheless, is should not be a difficult choice. The only concern I have is the low price, these machine are normally for sale for much more than that. That is if you can find a used one for sale at all. There are no reason to sell it unless you get bankrupt and have too. Used German upholstery class sewing machines are usually much cheaper in Europe than in the US. The few 367 I have seen for sale here was all around 3500$. However, the price it also depended of the version of it. They are normally equipped with a Efka 1550 internal position motor (900$ new) and all extras (air or el. back-tacking, foot-lift, thread trimmer etc.) This is a very high quality machine. Nevertheless, it might have been used in a factory and are in need of a refurbishing. I would definitely have looked in to this DA (Dürkopp Adler) 367, the only better machine around is the new DA 867 (based on the same head as this). If you cannot see any motor on it do not worry, the servo motor is placed inside the head. Here they sell them with the Efka 1550 mounted in a direct drive on the main shaft. I use the same motor on my 441 clone, it has 8 Nm of torque and I only use the half of it. It would be a shame to put a clutch motor on it, you would not use a Volga (Russian antique) motor in a Cadillac either. However, most of the high end system servo motors only comes in a 220V., therefore anything is possible. If this machine is OK you have a easy choice, this is a Mercedes-Royse of the upholstery class. Keep us posted. Good luck Tor -
Hi Cmore, The Cowboy Cowboy CB227R is the right machine class for your kind of work. The Techsew 2700 looks like the same machine too. I use a Pfaff 345 (triple feed) who are similar to these two for work like that and a 441 for heavier stuff. I do not think the Boss will be a good choice for you, unless you are planning to use very thick thread. A triple feed cylinder bed like the CB 227R, my Pfaff or equivalent is what most bag makers use all around the world. Both Techsew and Cowboy dealers are member of this community. Both machines are Chinese clones built strong enough for a leather shop. For factory use eight- seven a original German or Japanese machine might be a better choice. Based on the hours of use in a saddler/leather work shop, a clone will be the most economical choice. A other advantage is the support, the dealers are both members here and are frequently helping others in this forum. The Cowboy CB227R ( The Techsew too, I guess) uses the same foot as the Singer 111W. Therefore, feet's and attachments are readily available to affordable prices. The last thing is very important, if you cannot find feet's for a machine its not very useful. Make sure your machine comes with a servo motor, unless you are a pro at controlling a Clutch motor you will need it. Both machines does, and the one on the Cowboy gets good feedback in this forum. Good luck Tor
I do not know them, I know the ones for sale new are RB5, maybe this is a old one made in Japan. I know this info is in this forum already, you can try searching for it. Otherwise, I am sure somebody will help you soon. Good luck. Tor
