Everything posted by Trox
Do you need a big industrial stapler to install these, or is it small (less expensive) hand held models available for sale. These sure look more professional than the rapid staples. Thanks Trox
You are welcome.
Hi Ran, Yes I see. I would too, unfortunately I would need a much bigger workshop to do so. I am dreaming of an bigger shop where I can have a very large workbench in the middle, rooming a full hide cow leather at least. My machines will be surrounding against the walls, tools be hanging on a sealing mounted rack over the work bench (much like a modern kitchen cooking island with a large free hanging damp cap). Light colors and lots of modern lightning. My workshop has been re-modeled every time I have purchased a new machine ( about twelve times), just to get room for more. There is nothing else to do, than to get a bigger shop.
Yes they normally just break in two pieces. You are learning, it is a lot of great stuff about your kind of machine here. Read the pinned post about needle thread sizing. Get the 441 service manual, read up on your machine. Remember, this is a powerful machine; do not force it by hand wheeling it if it stops in something. Check what stops it from advancing, you might have a bent needle thats hits the shuttle and will make some serious damage, etc. Normally beginners issues are thread tension issues. If possible do your adjustments on the top thread tension disk, leave the bobbin tension screw alone. The screw is small and easily worn out. Thick leather and thread needs much tension, to make a nice tight stitch. Your machine was probably adjusted and sewn of by Bob. Happy sewing, you will get a hang of it.
This is what they talk about, or what you can use this nice press for. http://www.youtube.com/watch?v=ZVyV3ZTVpqY Sadly this is not for sale in Norway, and I guess it weights a bit, will be expensive to ship from the US. I have a couple of screw presses for my snaps, rivet and buttons, nevertheless I want one for stamps. If anybody knew where to get one in Europe, preferable northern Europe. Please let me know.
Hi Ran, You can use the original Juki TSC 441 manual available @ Juki`s web page. This is a clone, it means all parts are interchangeable (some small difference according to the foot lift, the clone has a higher lift). I check and add some oil if needed before start every day. Remember to place a old newspaper (or something) over your foot pedal to avoid excess oil on it when lubricating.
A very light and clean work shop, I wish I had all that empty space to fill up. I do not have a free spot to hang up a tiny edger in mine, good luck with your new machine. I like those big Cowboy flywheels, Hi Bob, remember to tell me when you get them in stock again. I do not know if I really need one, but I want one anyway.
Hi, congratulate with the new machine. I have never broken any needles with my 441 clone (same machine as yours, but different brand). The 441 uses a 794 needle, it is a very long needle . Thats because of the high needle stroke of course. Make sure your needle is at the bottom D.C. before you lifting the foot and turn the material. When it is in this position it is protected by the needle guide and will not break. You probably turned the material before the needle was down in the feed dog (under needle plate level), then it will easily break off. Make sure you have found all of that broken needle (measure it against a new). If not look inside the shuttle race, a piece off a needle can damage your shuttle or shuttle race. I have a position motor on my machine, when I stop sewing my needle stops at the bottom D.C. You must hand wheel until your needle is all the way down after stop sewing. Also when you shall remove your work; lift the foot by the pedal all the way up until the top tread release kicks in. Do not pull the thread direct from the needle, pull out some top thread on the face plate before the needle. This is a safe way to avoid needle breakage. Good luck
Which Motor Type For A Skiving Machine ?
Trox replied to CustomDoug's topic in Leather Sewing Machines
There are different kinds of bell knife skiving machines, that needs different motor solutions. Some are like my Italian Alpha skiving machine; it has tree motors. One for the bell knife, is a continuous run motor; the knife rotate at full speed all the time. One small servo motor for the feed wheel and one big continuous run motor for the exhaust fan. For the models with variable speed on the bell knife you can use a clutch motor and like Kevin said; adjust the speed with the pulleys. Then again it might be some skiving tasks that needs the slow speed control of a servo motor. So you see there is no general answer to this question, you use what suits the application. -
This is a question about thread size, it must have the correct size needle. I guess it would be easier to change thread size. OK post a picture of your machine and the thread, then we can help you. I do not know what kind of work you want to sew either. On the front left side of the machine head you have a model number. What number has it?
Hi, Yes you can melt the thread ends and hammer it flat when its hot. Or you can buy a special thread burner. Or you can leave long ends, attach sewing needles and stitch outside the edge several times in the first hole, (the same in the end). It called finishing by hand, you will See this technique on old harness work (I use this technique myself). On leather you must hammer the seam to close the leather around the thread ( if you wet the leather before hammering it, you get rid of the marks left by the 29K feeding foot too). Remember to hold your thread ends when you start the sewing. Good luck Trox
Hi, Read the pinned topic " neat trick for needle sizing" top site here. Metric size 10 equal to Tex 270, and if thats a 17 singer needle it equals to metric size 105. I am surprised if you even could get that thread true the needle eye. You need a 200 needle for that thread (a 180 minimum), twice as big. I do not think your Sunstar takes that big needle sizes. However, you have not told anybody what kind of machine you have, so thats possible for all I know.
I always measures my needles with a caliper, a metric size 120 is 1,2 mm in diameter, a 90 is 0,9 mm and so on. For a Singer size system use a conversation chart on internet.
Ferdco Monster Machine Sewing Up To 3 Inch Thickness
Trox replied to Trox's topic in Leather Sewing Machines
Hi Greg, I was wondering about the same thing. It will not make it any easier that Ferdco now is closed. -
Normally not, however you can build the DA 267 in to a two needle with a special kit. Both needles will then use the same bobbin thread, so it will not become a true 2 needle machine. I think http://www.kwokhing.com/da/ have this kit, or It is available from Dürkopp Adler. Trox
Hi DJ, Thats a very nice looking rounder, your husband did a good job there. I will agree with Dirtclod metal works much better than hardwood. I to tried to make Stohlmans hardwood rounder with no success. DJ, what kind of soap are you using when you soak your reins? I have used green dish washer soap before and I am now trying with Fibings glycerin saddle soap. I am often making round dog collars with hidden stitches (I am doing one as we speak) and I have made my self a pretty good tool for the rounding. I am using steel eye bolts with wooden handles (see pic). I hold the tool with my left hand and pull the rein back and forth with my other hand. As the reins is getting a rounder shape I am twisting/angling the tool so the diameter of the eye bolt gets smaller. These bolts are perfect for the job. I have several eye bolts in different sizes, however I use only one or two sizes for rounding the strap, it works well. (you can also fix the tool in a vice to free your hands of course) DJ, a last question. I have often wondering about a way to sew these reins on a machine. When you sew these on your Pearson does it make a slit or a groove for hiding the stitches. I do not think a groove will work well for me, it will leave visible marks. I would very much like to see that Person attachment, do you think it is possible to do the same job on a 441 lock stitch machine. I would love to see a picture of that attachment. In advance thanks. Trox
I have a German DA 267-373 with Efka DC 1600 still in new condition, I is a dream to use. However I know the Pfaff 1245 is a very good machine too. I have mostly heavy Adler machines and I love them. However, I got a small Pfaff 345 (triple feed cylinder bed) I am using. It is old but still very good. Old Pfaff machines are very well made, I have never seen better steel quality in plates and feet`s. The feet`s are so hard it is almost impossible to alter them, (it will take more time anyway) It made like a Swiss watch. Like Seweng told you the Pfaff spare part prices are extremely high, thats because they are hand made in Germany. Here in Europe Pfaff part cost about the double of DA parts. Example from Norway, a high priced country ; a binding needle plate for my Pfaff 345 costs 750,- euro (960,- $). A needle plate for my Adler 204 costs 299,-Euro ( 382,- $) You can get aftermarket parts like feet`s, shuttles and plates from Kwokhing.com to very good prices.
Well what can I say sewing is not rocket science -
Yes, thats not bad. Try them out, see who suit you best. The Pfaff will be a bit more expensive than the DA new. So if the Adler is newer, check the motors. A clutch motor is of no value even new. A Efka position motor will cost you 900 Euros new. Check motors and extras.
Thanks for that info Wis, I guess that would be a problem yes. A problem NASA should have thought about before buying the machine with your tax dollars. It is a real nice machine anyway, it makes me sad that we lost Ferdco. They was really innovating machines builders. -
Pfaff 1445 With An Efka Variocontrol - Who Knows Anything
Trox replied to Shed Tinkerer's topic in Leather Sewing Machines
Yes, customer support is the European sewing motor companies only way to compete with China. (They are still far ahead on technology and quality) Efka told me, it does not matter from who or where you bought your motor, If it is a Efka it is our job to help you until your machine works the way you want it to do. And they did so true Skype video call. I did not expect that kind of service, it was a pleasant surprise. The German dealer I bought it from gave me the wrong control box, it was for a Dürkopp Adler instead of a Juki as I needed. These new motors are computers, they recognize the machine automatically and normally set up them self. With the wrong controller it did not work, and no help from the dealer. I am glad I called the manufacturer before sent it back to Germany, they programmed it true Skype and sewn it off. Thank you Manfred in Efka About the Pfaff 1445, I believe that was the top of the line Pfaff flat bed triple feed production machine in the upholstery class. High speed, automatic and self oiling, it compares to the DA 767 and Dürkopp N 291. What the famous Pfaff 1245 can do at lower speed, this machine can do in a factory setting at high speed. Thats why you often will find these machines second hand with air pneumatic like; thread trimmer, needle cooling, back-tacking, presser-foot lift and more. They was preferred for factories, when small workshops would choose the 1245 with fewer automatics. You have to check hook and needle bar for wear, get a small (silent) air compressor that can deliver 6 to 8 bar pressure and hook it up. Good luck Trox -
This Ferdco machine is currently for sale on EBay and is called a pro 4000 serial # 001. http://www.ebay.com/...984.m1438.l2648 This machine was made for the aerospace industry and is one of a kind machine. They claim it capable to handle materials up to 3 inch thickness. It looks like a triple feed lock stitch machine with a monster needle. It has the same Efka motor as I use on my 441, a DC 1550 (they have listed the control box number only in the add). If you look closely, (if you are interested monster sewing machines as I am) you will see the motors position head(synchronizer) is located on the speed reducer, not at the machines hand-wheel as they usually is. This is the way to do it if you need a speed reducer in addition to this powerful motor. (Efka Dc 1550 has 8 Nm and up to 1800 watt of power) On older motors the machines position was adjusted in the position head, thats why it was placed on the hand-wheel. On the new motors the position heads only function is to calculate belt slippage. Motors mounted in direct drive do not need it. The best way to mount a modern mini servo on a saddler machine like the 441, is to use a toothed belt like they use on Harley Davidson custom bikes. This way you will eliminate all belt slippage. Do it like my Swedish friend has done with his Cobra class 4, only use a toothed belt and pulleys instead . Anyway, if somebody needs a real monster machine, start bidding now.
The Efka variostop motors are electronically clutch position motors with a 12 step speed control. Clutch and brake are electronically controlled. The control box can also control a lot of extra air pneumatics (or solenoids) like presserfot lift, back tacking etc, If your machine has those extras it need compressed air to operate. This is a old system, Efka was first on developing these kind of motors, your control box might be from the 1980`s. As Eric told you you can easily update your system with a new Efka DC 1550. That is a very good motor, I use one on my 441 clone and I am very happy with it. I also have a couple of other Efka`s, one is a old variostop similar to yours. It still works fine. http://www.efka.net/ have a download section on manuals and sell spare parts. They have excellent customer service, on my latest motor I got help true video call until my motor setup was complete. Thats something you never will receive from China, you pay a Little more to get the best of everything. -
Hi, The DA 267-373 is a triple feed single needle (273 is a two needle version). It is a good basic machine; I have one myself and am very happy with it. It will take up to TKT 15 (maybe TKT 10 on top, as Ken already has told you. I have never tried since I have heavier machines and do not need to) The Pfaff 1245 is also a very good machine, since I do not know the numbers behind 1245, I cannot tell you more about it. It is as heavy as the DA and maybe a bit stronger too (both up 10 to 11 mm thick material). Here in Norway it is a very popular choice for upholstery. The Pfaff spare part prices are more expensive than DA parts here in Europe. The most important parts like hooks, plates and feet’s can be bought after marked. This is like choosing between a Mercedes and a BMW, they both are very good. Therefore, you must look for the age of the machine (paint color and subclass # can tell). Check hook and needle bar for wear. Look for extras like a needle position servomotor etc. Good luck.
They are both in the same class (upholstry class sewing machines) and will do the same. To compare them I need the sub class numbers on both. (the number behinde 267 and 1245). Picture and price will also help. Thanks Trox
