Trox
Contributing Member
Everything posted by Trox
  1. Hi Shawn, There are several different Necchi machines from home machine to Adler 105 and Singer 45 copies. Its very hard to tell value of something we have not seen. You have to upload a picture. Thanks Trox
  2. Bobbin winding looks simple, but can be a pain in the...... Bobbin winders and their thread guides are different from machine to machine. On some winders the thread tend to jump out of the tension disk and mess up the winding. To prevent this from happening I let the thread go one time around the disk (instead of just right true it). It is important to have the right tension, if you wind it to tight it give you a uneven bobbin tension (and make a mess, the same happens if its to loose too). I have to loosen up the tension a bit, but get a more consistent woven bobbin this way. It is important to have the thread rack`s thread guide directly in center over the spool. It is just as important here as it is for the machines top thread . Otherwise it will pull thread unevenly of the spool and cause problems. You have to test your winder, give it different speeds and conditions, brake the thread with you fingers etc. to test it. This way you will see how it acts and make your improvements.
  3. It looks more like some kind of shoe sole sewing machine, However, the pictures are still not detailed enough to tell. Give us a detailed pic of the operating parts. Thanks
  4. Hi Ron, I see he lives in New Jersey, he might not have electricity or Internet connection. Or how is the situation in that area now? What kind of new triple feed small arm machines do you sell Ron? equivalent to the Adler 69 or Pfaff 335. Thanks Trox
  5. lots of silicone lube and a half ton jack
  6. Thats true Bob, although its mostly used for spareparts and bobbin winding
  7. Thanks Greg, Thats true it is not avaiable here in Norway anymore. However, I see that Weaver still sell them new and some other US dealers as well. I guess they still have some left in stock.
  8. Your welcome, there are a free operating manual there as well, I have it in my PC. However, I did not find it when I searched for it. I found this one on Singerco.com industrial download http://parts.singerco.com/ http://parts.singerco.com/IPinstManuals/111W152_W153_W154_W155.pdf This manual has the hook timing and other adjustments as well. Maybe you already have it. Good luck Trox
  9. Hi, Pfaff are good machines,however it has expensive spare parts. Chinese sewing machine production works like the car industry, no ones produce all parts them self. They buy part from other contractors and assembly the machine. There are several different qualities of parts, companies like Pfaff and Dürkopp Adler uses the best quality. They also have support and spare parts, clones often uses the original copied machine brand for spare parts. Buying a clone be sure it has support, somebody that stand behind their product as our member dealers of clones do. Cobra, Cowboy and Tecksew sewing machines. Clones that comes in a box might need adjustment, changing of parts and several hours of work. About the machines in your list I have a older Pfaff 345 H3 (vertical hook, thicker arm, or else the same machine) very happy with it. Pfaff are very good machines H4 is the heaviest subclass of the 335, H3 is also good. Check the H number, H1 and H2 will not sew thick enough or take thick thread. You are located in the USA where prices on German sewing machine are high, you might also look at the Juki small arm, it might be available to a better price. I think the prices on those rebuilt Pfaff`s was a bit high, check this site to compare http://www.miamisewi...ials/canvas.htm They have several 335`s for sale to a better price. The Adler 69 is a good machine too, it came first time in 1955 and its still available new some places (name changes in 1990 from Adler to Dürkopp Adler) It is possible to check its age. I do not know the Supreme. I think the reliable is a decent clone, however you must buy one that is sewn off with support. Good luck Trox
  10. Hi Tom, I let Bob and Eric help you with this Singer, I have mostly Adler machines my self. I had a Singer 144W-305 (30 inch arm) very similar to your 111W, only bigger. However the adjustments is the same on them. Just remember when you have a timing issue like this it a reason for it. Most of the times its because of thread that jams in the hook. You must always remove the bobbin house and check for thread pieces underneath, clean it out and oil it. The machine has a clutch that protects the hook when it jams, the clutch might fail because of rust and dirt. Causing the drive belt to jump over some teeth. Or be hard to reset when its old. Anyway if you need a good service manual here is a link to a free E book, US army manual on several machine they used included yours. It might help you. http://books.google.com.au/books/about/Organizational_and_field_maintenance_man.html?id=jCUYAAAAYAAJ Good luck
  11. Hi, The Adler 30-70 is the new type with a square head and a long arm. It should use the 332 LLG, (the subclass -10 and -50 should use the 332L, according to the manual). The thread size you using should not be any problem, thats the same as Nm TKT 40 who is a normal thread size for this machine. With the foot pointing forward against you, the thread should go true the needle on the left side (the side with the long grove). If it is threaded right top and bobbin and still do not pick up the thread is a timing issue. You might try to thread the bobbin thread true the needle plate your self (first time after you have changed the bobbin). Sometimes the machine will not pick it up, However, it still might sew well. If you need a manual for it send me a PM with your email (personal message true my profile) and I can send you the manual in a pdf. Good luck.
  12. Is it the take up spring or a thread guide I see on lower disk? If that hook is a take up spring (and it moves down wards if you try to move it, yes I think that is the take-up spring. I did not see it before, it did not work either because of your threading mistake) you only have to do as Wiz wrote. Thread it true the top disk (top front) down in to the square guide, around the lower disk and over the spring hook (where the thread are going in the pic). Down and under the J-shaped thread-check bar, up true the square guide and in to the hole in the take up arm. Then your threading will be correct. The only missing part will be the hook cover, you have to watch your fingers as you sew.
  13. Leather Guru is right, the first black tension screw is for the bobbins. Then there is no take up spring there, I guess its missing. You will have no problem having the machine to work when you hand wheeling it. However, when you get some speed on it and more thread tension it will start missing stitches. The takeup spring are there for the reason, together with the thread take up arm it will allow slack in the thread so the hook cathes the thread loop. Then it will pull the stitch tight. Do you have a part list on it? check it out. The picture do not show if its a needle feed on it or just a bottom and top feed. If it is a triple feed (bottom, top and needle feed) you can lower the feed dog in level with the plate, this way you will eliminate those marks. Then you also can grind of the feed dog and feets smooth, the needle feed will take care of your feeding. On the backside of the head it should be an adjustment for the alternating height of the feets. On the shaft it should be a slide and a nut to adjust the feets alternating height. Lets have a look on the backside too.
  14. You are right, It must be a 16K-28. It has a shuttle hook like the big stitcher's and can sew medium thick materials. It has only drop feed, however it is in a very nice original condition. A good piece for a Singer collector, you do not see these to often in a this good condition. There is a nice Adler 467 with Rotan pos motor and all air pneumatic for sale to, Any Norwegians looking for a good machine check it out on Finn.no. The thread jungle is not funny at all, if its something our industry should work together against; its a standardization of thread sizes. Even experienced saddler are afraid of trying something new when it involves a hole new size chart. It is complexed enough to remember what needle we used for which thread size, we do not want to take on whole new type of measurement, time is money. Standardizations must be done fast before the politicians starts to mess with it, we still fight about Metric or imperial. I guess we never will agree about what is the best system. I somebody made a Iphone app with threads and needle conversations I sure would have bought it.
  15. Some tape or nail polish lac on the wheel will work too. Trox
  16. I understand why they will not change threads when they have something that works. Sewing threads are a jungle of sizes, it even changes with material its made of. Then it is the old trouble metric or imperial. I could not get bonded nylon to work for me, polyester did and I stuck with it. Many times I wished I used the same as you guys in Australia and USA, that way I knew what you where talking about in the the related topics about it. I will check with some of our US dealers to get some tex. 400 to 500. I guess TKT 40 thread you import are for your Patcher customers, Anne Bonney Locker`s finest bonded nylon? It sounds real good to me. I do not know what you call it, However, "Bonded" will for sure have a relaxing effect on your customers. By the way Here it is some old Singers I know you would have wanted. http://www.finn.no/finn/torget/tilsalgs/object?finnkode=38162206&reference=2012%2F11%2Fvertical-5%2F04%2F6%2F381%2F622%2F06_33347346.jpg price (before bargain) 220$ http://www.finn.no/finn/torget/tilsalgs/object?finnkode=37755993&reference=2012%2F10%2Fvertical-5%2F14%2F9%2F137%2F486%2F99_1625143583.jpg (This one I cannot identify) 120$ http://www.finn.no/finn/torget/tilsalgs/annonse?finnkode=37442286 And a nice Adler zik zak 220$ Plus One 7K-32, 75$ and one 45K with cylinderarm 120$, the add was to old to show. It did not sell and I have no room for more.
  17. Hi Tom, You must go true the rest of the adjustments as well, like the feed timing. When you talk about the upper arm, do you mean the thread take up arm? If you post some pictures of your threading we can better help you. The thread take-up will allow the thread loop be picked up before it tension the thread. You must check your thread take up spring too, lower tension disk. It seems like a threading error. Post some pictures. Trox
  18. Hi Darren, I am only using polyester threads (Coats Gral and Amman Serafil). My big Adler's (204, 105 and 5) like polyester much better than bonded nylon, B. nylon is too stiff for them. Polyester are much softer. The strength is not an issue, they are both almost too strong. My reason for trying bonded nylon is the difficulties to get thick enough polyester for my 441. I have to order the thickest sizes abroad, I cannot get them here in Norway. What brand of threads are you buying in a so large scale? are you selling that much. You aren't afraid it will become old before you get rid of it?
  19. Hi Reese, First of all Adler and Dürkopp became Dürkopp Adler around 1990. The class 267 was made by Adler before and after the merge, all machines sold after 1990 has Dürkopp Adler decals. Then the color can tell you about the age; early Grey/black, later silver and new white. There also a change in production after 2003, after 2003 the 267 is made in China. I comes in two subclasses -373 one needle and -273 two needle and color is white. The subclass Gk-373 tells me it probably an early Grey model. If this does not help you tell the age you can ask Thomas Brinkhoff, head of spare-parts Dürkopp Adler in his blog; http://sew24.blogspot.no/p/downloads.html A picture will also help. I have a 267 -373 with Efka dc 1600, I am very happy with it. Simple, straight forward versatile machine with triple feed, with the Efka motor it is a dream to use. It will work well for canvas, nylon , leather etc. Mine sews up to 11 to 12 mm thick and thread TKT 11/3 down to TKT 60 (Nm, polyester and braided polyester) I hope this helps. Trox
  20. Not many Consew machines in Europe so I do not know them. I know they are popular in the USA. Read the pinned topics about choosing a leather sewing machine, it will help you. I read a bit about them in the Consew website, I find the machine descriptions a bit incomplete . You should look for a compound triple feed machine ( bottom, top and needle combined feed) The term " walking foot" is often mistaken for such macines, nevertheless, it can be applied to any machine that has a feeding foot. I saw a other topic here a couple of days ago what the letters behind the Consew class numbers meant, (use the forum search option it is a lot of topics about Consews here). It looks like the 277 is not a triple feed, however the 227 R-2 and 287 RB-2 seems to be triple feed machines. I think the letter "R" stands for reverse and "B" for big bobbin. Site says nothing about thread and needle sizes, you need to find the data sheet about them. Our member dealers (top site banners) sells fine machines too, Cobra, Cowboy and Tecksew. They stay behind their product, call them and tell them about your needs. There are a lot of people here that have Consew machines and can tell you much more about them than me. I am located in Norway and have mostly German machines (and one Chinese 441 clone that works well) Any of those Consews will be an upgrade for you. If you rephrase your topic and ask about the Consews, you will get a much bigger response. Do not forget to search the forum, it is tons of information related to your questions here already. good luck Trox
  21. Yes, it looks like the 153K-102 is a bottom feed machine same as your 31-15. You better save up for a triple feed cylinderarm machine, the 153K-102 is no good for leatherwork.
  22. Adjust and thread your bobbin winder right, you might want to let the thread twice around the tension disk and loosen up the tension a bit to get consistensy in your winding. It is more that one way to do it, ask the guys in the factories. They do not hire a person to wind bobbins, they adjust the winder right.
  23. Hi Greta, This subclass of the 169 do not use a foot. You can do as James suggested, buff off the sharpest edge of the wheel since it has no feed on it. Get a rubber band around it or change the wheel to a teflon wheel. You can ask for help on your Adler here too http://sew24.blogspot.no/p/downloads.html this blog is runned by Thomas Brinkhoff head of Dürkopp Adler spare parts. He knows what is available for your 169 subclass, and he is a very helpful person. Wet the leather as Art suggested and hammer the seam with a smooth faced leather hammer will remove those marks (and close your stitches) Good luck Trox
  24. Hi Amy847, I do not know the different between the Singer 133K-8 or subclass 9. I know that some of them have a so-called walking foot feed. I will try to define the term walking foot as simple as possible: Every machine that has a foot that feeds the material can be called a “walking foot”. However, when leatherworkers talk about a “walking foot machine” we mean a compound triple feed machine. Bottom, top and needle feed working together and adjusted with one stitch-length regulator. In Europe, we simply call this a triple feed machine; this is what works best on leather and thick materials. I believe the 133K with a walking foot is a double feed; bottom and top feed (the bottom feeder is called a feed dog, and the top feed is a feeding foot). I might also have two presser feet’s; one is a vibrating foot and the other the feeding foot. (That alternates; called alternating top feed) It still only is a double feed because it misses the needle feed. The class 133K will sew up to about 3/8 max ½-inch thickness, how thick thread it will take I do not know. Explaining the feed systems are not that simple, however that’s what adds value to a used leather sewing machine. The number behind 133k is called subclass number. Subclass 9 has a better feed system than the subclass 8; it makes it more useable for leather or other heavy work. (It might help you to read the pinned topic about choosing a leather sewing machine, on top of this forum)   The 45K is a heavier rating machine, it comes in many subclasses, however none of them are triple feed. How thick they will sew depends of the feed; 12 to 15 mm material thickness. It will take a much thicker thread than the 133K and has a bigger bobbin. The Singer 45K and the Adler class 5 (the machine I believe Singer copied to make the 45K) was the saddlers choice of heavy stitcher for more than 50 years. It is the forerunner for today’s heavy triple feed stitchers, like the Adler 205-370 and the Juki TSC 441. These machines and copies of them (called clones) are today’s industrial standard of saddler’s heavy lockstitch machines. The class 133K is popular in the UK, Australia (used to sew horse blankets) and in Asia for sewing jeans. I would choose a 45K before any 133K, because its heavier rating, heavier threads capacity and bigger bobbin. Some medium weight cylinder arm machines with triple feed will also sew up to 3/8 of an inch maybe more, they will not take the same thick threads. Some of them can be found in Europe, within your budget. Examples are the Adler 69 and 269 (not commonly cheap machines) Pfaff 345 H3 and H4, Pfaff 335 H4 (H4 is the heaviest version of old Pfaff) And Singer 153W with triple feed. About Necchi, It is an Italian made machine. The Italians make fine machines; Necchi makes copies of Adler and Singer machines. I have seen several Necchi 45K copies and some 29K (Adler 30) copies. They are big on domestic machines too. I have never own or tried a Necchi so I cannot tell you anything more about them. However I would choose the Singer 45K before a Necchi copy, although the 45K is an obsolete model parts are still available around the world. Post pictures of the machines you thinking of buying, it makes it easier to help you value them. Good luck, Trox
  25. Thats a little coarse, it is used for plasterboards. I use my dremel tool with a Little sanding drum, for bigger areas I use coarse sanding paper.
