Wizcrafts
Moderator
  1. This sounds like a thread problem. Buy different thread and try again, top and bottom.
  2. Kat; The link you posted goes to the viewer's Google Drive account, not yours. You will have to share a photo or photos and place a link to your shared files. Or, better, just reduce a few photos and upload them to here.
  3. Here are the System 135x16 needles I have been buying from an eBay seller. They are Organ brand and most certainly titanium coated and leather point. They fit the 29k patchers perfectly.
  4. You will need what we call back pressure on the top thread to counteract the twisty black thread. If your machine has a post on top with a few holes in it, run the thread around two holes to get some drag in the twisty thread. Your machine should have the little steel thread guide in front of and below the top tensuion disks. See if you can lower it by loosening its screw and pushing it down. This will give a steeper angle to the thread going into the top tensioners. The top disks do almost all of the thread tensioning. The bottom disk are just rollers. They only add a tiny amount of tension.
  5. To do that you'd need to build a time machine and go back decades, to the early 1970s. Singer stopped building the 29k series by the mid-1970s. They sold off everything to do with their industrial sewing machine business in the mid-1990s.
  6. Watch our Marketplace > Sewing and Cutting > Sewing Machines For Sale > Used section. You can sometimes find a cast iron patcher base on Craigslist, or in antiques malls. Another source would be shoe repair shops. If you do find one in working condition, make sure the holes in the base line up with the threaded holes in the bottom of the machine. The 29-4 is a short arm model, mating to a short version of the two level iron base. Later models included long arm machines that have a bigger base and different mounting holes. All bases should have a dual pulley flywheel on the right end of the base. The wheel is driven by a treadle pedal and uses a 68 to 70 inch x 3/16 inch diameter leather belt.
  7. I usually buy Organ brand titanium coated, in walking foot System 135x16 and 17, on eBay. But, if you have an industrial sewing machine dealer nearby, call them and ask if they have or can get titanium coated needles in 135x16, or 29x4. Those are leather point systems. Round points would be systems 29x3 and 135x17. They really do make a big difference!
  8. I also own a Singer 29k71 and have done everything I am about to describe for you. You can view or download and save/printout the official Singer Service Manual and Parts List, here - for the 29k-71, 72 and 73. It will make everything below more understandable. Before adjusting anything, make sure the needle is the correct system (29x3, 29x4, 135x16, or 135x17) and that it is all the way up in the mounting clamp, and that the scarf is on the dead right and the rib is on the dead left. Also, make sure the needle size is correct for the thread you are using. For most users, that equates to a #18 needle for #69 thread, or a #19 needle for #92 thread. Finally, make sure the thread is bonded and stays that way throughout the sewing cycle. If all the above are positive, yet the machine skips stitches, there are only a few items left to check. First, make sure there is sufficient presser foot pressure to hold down the leather as the needle begins its ascent. If you see the leather lifting, screw down the pressure spring until it stops lifting with the needle. While you're at it, take a look at the thread on top and make sure it isn't binding, or coming out of the tensioners. Another cause of skipped stitches could be the tape or glue holding layers together for sewing. I use titanium coated needles to help fend off problems caused by leather tape and contact glue. If none of the above stops the skipped stitches, the machine is either marginally out of time, or the check spring is badly worn, or the gears in the bolt on gear box are very badly worn. The first step you take should be to slide open the throat plate and face it sideways, across the gear box, so you can see the hook and needle. Put a representative piece or pieces of leather (that are having skipped stitches) under the foot, lower the foot and slowly rotate the hand wheel in the forward direction (counterclockwise if on the end of the body; clockwise if on the right front). Observe the size and quality of the loop as the needle goes down, then raises up and stops. There should be a visible thread loop on the right side of the eye. The point of the hook should be about 1/8 inch away from the needle and loop. As you continue moving the hand wheel, that hook should move to the center of the needle and pick off the thread loop. Skipped stitches happen when something prevents a good loop from forming and staying intact until picked off. If a loop forms and holds, but the hook has passed the needle too soon, the timing needs to be retarded. If the hook is so far back that the needle and loop have moved up past it, the timing needs to be advanced. If the hook seems to be intersecting the needle at the proper time, but the loop has gone away, the check spring needs to be replaced. Timing is adjusted through a hole in the right front of the base of the machine. You'll need to loosen a nut on the back of the rack-to-down crank combination, then use a straight blade screwdriver to turn the eccentric screw one way or the other to get the hook in the best position to pick off the thread loop. Once you find that position, tighten up the locking nut to secure the timing. If timing the hook doesn't stop the skipped stitches, there is either a lot of play in the gears in the gear box, or the check spring needs replaced. You can see how much wear is in those parts by holding the wheel in place and using you fingers to turn the hook one way and the other. There is bound to be some slack, but too much will create crazy timing. These racks and gears can be replaced with aftermarket parts, which will probably need a bit of tweaking to get a good fit with the least binding or slack. I left the check spring replacement for the last item. This spring, which is inside the needle bar, above the needle mounting bracket, is tiny and has a paddle shape on the lower portion. The top is shaped like a T and has two tiny screws that secure it to the inside of the needle bar. You are going to have to remove the head again to see if this spring is the culprit. The spring eventually wears out and stops holding the thread in place, causing the loop to dissolve. Sometimes, you can bend the paddle end back in to get more life out of the check spring. Or not. If you've gone to the trouble of removing the barrel head, you might as well replace the spring. Just make sure you set the tiny screws aside in the same right/left alignment as they came off. You should reinstall them in the exact same positions. With the check spring off, examine the needle bar to see if a deep groove has been worn into the area where the paddle is supposed to squeeze the thread. If this has occurred, nothing you do about the spring will improve the situation. You would probably have to replace the entire needle bar to fix this. Good luck with your repairs!
  9. It could be a problem with a self oiling machine, but not a manually oiled model. Some folks with self oilers will unthread and run them at full speed before sewing commences. This pushes the oil around the extremities so that there is oil where it needs to be as you sew slowly. You normally wind bobbins on an industrial sewing machine as you sew. But, intentionally winding a bobbin at full speed is another way to distribute the oil. Be sure you are able to try out these machines before you commit to buying one of them. Go with the one that you feel better about as you sit in front and press the floor pedal. Is the motor speed controllable? Can you sew slowly, or is it off to the races? If so, you'll likely need to buy a servo motor replacement.
  10. The oil pump situation that Floyd referred to is that some machines have an oil pump on the bottom of the machine that sits in an oil pan and forcibly sucks up oil and pushes it to wicks along the top and bottom of the machine. These machines usually need to be run very fast to get oil to the extremities.This generates a lot of heat and makes for a hard to control machine that may have a 1:1 motor pulley to machine pulley ratio. Failure to maintain a proper oil pan level, or only sewing at slow speeds can lead to damage to the machine, as can be noted in the sticky topic about Venator's Adler 467 that seized due to a bad oil wick system. The rest of the machines have oil holes that the operator has to fill with fresh oil every now and then. These machines are not usually run at very high speeds and don't generate as much heat as a high speed garment machine. You can sew at very slow speeds with these machines as long as you place a few drops of oil into all the oil holes before or after using the machine or letting it sit a while. The machine will leak a little oil that you'll have to wipe off the lower surfaces to avoid soiling your materials. If you are planning to sew at slow speeds, buy the manually oiled machine, if it is still in good sewing condition.
  11. I buy most of my industrial sewing machines in Toledo, Ohio.
  12. You will probably need to order a custom binder attachment from Atlanta Attachment Company
  13. Any (computer, tablet or phone) photo editor that has the ability to reduce the dimensions equally can reduce the file size. It does this by making the image smaller in length and width. The file size reduction is directly related to the percentage of reduction of the dimensions. Better photo/image editors are able to change the quality of the image, as well as the dimensions. This can reduce the file size by magnitudes if properly used. I use Corel Paint Shop Pro to edit and reduce photos and drawings. PSP is a Windows computer program that competes directly with Photoshop. All of the features are listed here. My Galaxy S5 smartphone shoots photos that start out at 3264 x 1836 pixels (6mb) and goes up from there. By running my photos through PSP, I can reduce the dimensions to 250 x 300 pixels, the size of a typical rectangular Google AdSense ad. By combining cropping and size reduction with a virtually unnoticeable quality reduction of 25%, I can get a poster size 3 to 6 mb photo down to 20 kb to 50 kb (jpg). When it comes to artwork, clipart, vectors and lettering, I can optimize and reduce these graphic files to as low as 12 to 15 kb, saving them as gifs or pngs.
  14. Why? Removing the 4 screws is almost effortless and takes about three minutes. You just need a long flat blade screwdriver to turn the screws out. Two are near the top and two near the bottom of the machine body and revolving head assembly. Remove the presser foot, regulator and needle clamp assembly, unscrew the 4 screws and the head can be pulled down and away. The needle bar will simply come out the top as you lower the head. There is no need to disconnect the needle bar from the top mechanism.
  15. I will address your thread requirement. You say you are used to hand sewing with .6mm thread. Here is the closest equivalent in bonded sewing machine thread: Thread size: 277 (T270) Breaking strength: 45 lbs Diameter: .0231" (.586mm) #25 needle The next size up is 346, having these specs: 346 (T350) 5 Cord 53 lbs breaking .0258" (.655mm) #26 needle These are some of the heavier thread sizes used by the biggest heavy leather harness stitchers, like the Cowboy CB3200, 3500 and 4500, and equivalent Cobra and Techsew harness stitchers. There are no normal upholstery grade industrial sewing machines that can tension and pull up #277 or #346 thread. There is one class of bottom feed only heavy leather stitchers that can handle these threads, but they leave deep tooth marks on the bottom. The reason these machines can handle and tension the heavier thread is due to their having huge beefed up moving parts and substantial bearings and steel shafts. They have no trouble sewing together 18 and more ounces of hard temper leather with #277 or 346 thread (about .6mm). The bottom appearance is different than on top. That is just how it is. If you want the bottom to virtually match the top, buy a Campbell Randall or Union Lockstitch machine. They use a needle and awl in combination with a jump foot and either needle or awl feed.
  16. I normally remove the 4 screws securing the revolving head assemble, plus the needle clamp, then pull the head away from the arm and down. I suspect that you'll have to do this too. This gives you complete access to the parts inside the head. You'll just have to remove the presser foot and stitch length regulator, then unscrew two screws inside the bottom, and lift out the bell crank. Use bronze brazing rod to build up the little puck on the end of the crank, shape and polish it for a good fit without binding and put her back together.
  17. Because there are only two roving forum moderators on call and we both have day jobs and things to do in the evening. One of us will see a notification icon when we log in. I didn't even know that this section of the forum requires moderation.
  18. I agree about the table and stand. After you remove the rust and repaint the stand, it will be valuable.
  19. Don't expect this old machine to be usable until you have rebuilt or replaced the worn out parts. Some gears will have to be custom milled. Other parts can be brazed or welded then reshaped to get a best fit. Shuttle drive gears for these ancient patchers are not available in the aftermarket and would have the be custom cut from steel rod. So, if the drive gear is badly worn, the timing will never be right and you'll need to have one made.
  20. From the home page of Toledo Industrial Sewing Machines: Bob Kovar Sr. - Owner Call us toll free, at: 866-362-7397 If you can't reach him on the phone, there is a contact form here.
  21. The needle bar position could have been moved up due to impact with the feeder or throat plate. This would retard the timing, possibly beyond picking up the bobbin thread. The hook hitting the needle means that the needle deflector plate has already passed by and is out of the equation. That means that if the hook saddle is positioned to just miss the scarf of the needle with the deflector in play, that the tip of the hook will intersect the needle with the deflector out of play. Your machine also has a safety clutch that disengages the bobbin drive in the event of a serious binding from thread or a broken needle. If the clutch has popped, the shuttle won't turn at all, or very little, as you rotate the handwheel. If that happened, clear the broken piecs and any thread in the bobbin case, then hold down the push button on the right side of the arm as you turn the wheel one way or the other (with no thread in needle!). The clutch will re-engage at some point of rotation and timing will be restored. If the clutch has not popped, the culprit would be the needle bar raising from impact. You'll have to remove the top thread and the face plate, then locate the screw or screws on the needle bar clamp that secure it to the bar. Get the correct screwdriver or Allen wrench ready. Remove the bobbin cover and throat plate and take out the bobbin from the basket. Slowly rotate the hand wheel towards you until the needle reaches BDC and raises up about 1/8 inch, then stop. The hook should just be approaching the scarf area above the eye of the needle. The deflector should be touching the needle below the eye, pushing it ever so slightly away from the hook. If these things are not happening together, something has shifted out of time. Troubleshoot as follows. Examine the needle bar inside the head and see if it has one or two thin rings cut into it and visible below the rock frame that it goes through. Those are timing marks. One mark is for the setting the bottom position and the other for the raised position for the hook to work. If there's only one ring, it's probably to time the hook intersection. Loosen and retime the bar as necessary to show both of the rings at the bottom edge of the needle bar frame, in that/those vertical positions. If there are timing rings on the needle bar and you have set the position of the bar to show and hide them at the appropriate points of motion, the following will test the hook's position for correctness. As the needle raises about 1/8 inch (or to its second timing mark), the hook has not yet reached the needle (retarded). You'll have to advance the hook until it is centered above the eye, in the scarf. Consult your manual about moving the hook position. The hook has passed the needle already. Retard the position of the hook. The hook meets the needle above the eye, inside the scarf, but the hook impacts the needle. Bend the deflector plate slightly to the left until it pushes the needle out of contact with the hook. If you don't have timing rings on the needle bar, adjust it up or down as necessary, as follows. The needle's eye and scarf is too far below the hook after raising ~1/8 inch above BDC. Raise the needle bar to get the hook over the eye, inside the scarf. The needle's eye is above the hook. Lower the needle bar to position the eye about 1/8 inch below the hook. After positioning the needle's eye to the hook, check the deflector plate and move it as needed to protect the needle from the tip of the hook. Examine the hook for damage from the broken and impacted needles. If it's chipped or has a burr, it will need to be reshaped and polished, or replaced. Don't forget to lock down any screws you have loosend. Take advantage of the open face to oil the internal crank arms in the head.
  22. You would use #18 needles with #69 thread. Move up to #19 or 20 needles with #92 thread. #23 (160) is for #138 and possibly #207 on top. Your machine is not meant to sew with #207 thread in the bobbin. It is beyond the tensioners design specs and will probably leave the knots laying on the bottom of the leather, if it sews at all with that size thread. It could possibly void the warranty on the machine. Always use System 135x16 leather point needles with leather, or 135x17 round point with vinyl, webbing or cloth.
  23. I believe that Darren does (or did) have a large supply of new Chinese cylindrical bobbins for the Singer 42 class machines. That was in early 2017.
  24. Good choice. Now remember to always pull back the starting threads for a few stitches as you begin a stitch line. If you start by reversing, hold the starting threads until you cross back over them in forward.
