Yes and no, Andrew. The average straight stitch industrial sewing machine is built for sewing soft material that is not sticky, with cotton or polycore garment thread. I am talking about dresses, shirts, pants, aprons and such. Most of this work is done at very high speed, where time is money. High speed machines need self-oilers to keep them from seizing during long production runs. Springs for both thread and foot tensions are usually light duty, to handle the soft cotton thread used in garment production. That said, some types of straight stitch machines are and were built for heavier and slower speed uses, with beefed up take-up levers and connecting rods, bigger bearings, manual oil ports. Think about the ancient Singer class 25 machines as an example. These are cylinder arm machines, with very heavy moving parts, a large roller foot, heavy duty springs all around, a very large cylindrical bobbin and the ability to sew with #346 thread. Modern equivalents of the Singer 25K series include the Cowboy CB2500, Techsew 3650 and the GA5-1 that is sold under various brand names. These machines are 25K clones, with modern improvements like a reverse lever, harness foot or roller foot option, and tech support (if bought from a reputable dealer). They are priced lower that the 441 clones, and a little higher than the average upholstery grade walking foot machines. With large tooth feed dogs and heavy hold down springs, these machines can lay down a tight stitch into about 7/16 inch of real leather, with #346 bonded thread. The only reason you don't hear more about them is because they leave deep tooth tracks on the bottom and maybe foot tracks on top, both of which can be smoothed out with some elbow grease. Also, some holsters exceed 7/16 inch and these machines just aren't meant to sew, feed, and hold down anything much thicker. One other limitation of the aforementioned machines is that they all use a needle system which has a #23 needle as the smallest leather point available (which is for use with #138 thread). This means no thin work with thin thread (wallet interiors, thin finished wallets, thin pouches, patching, typical zipper replacement, etc.).
This is not the machine you need to sew holsters. Consider its shortfalls in these critical areas. The maximum thickness that can be sewn is about 1/4 inch of compressed material. The longest stitch length this machine produces is about 6 or 7 to the inch, into thin material. It might be only 8/inch at 14 ounces of veg-tan (almost a quarter inch!). It has bottom feed only, with a flat foot that will drag the top grain, reducing the available stitch length. The presser foot spring is not made to hold down this much leather. If the leather lifts with the ascending needle there will be skipped stitches and bent/broken needles, plus a wad of thread on the bottom and maybe a jammed bobbin shuttle. The top tension beehive spring is light duty, allowing for better control of using thin cotton or polyester thread in dresses, shirts and pants. The thickest thread this machine can properly tension is #69 bonded thread, which is too small and weak for holsters. The largest needle commonly available for home machines is a #18 (good for #69 thread) A 14 ounce pancake holster should be sewn with at least #138 bonded thread, with #207 being more secure and better looking. This machine cannot come anywhere near handling those thread sizes. The treadle will probably slip as you try sewing almost a quarter inch of leather. That means it probably won't be able to punch through 14 ounces of veg-tan leather without help from your hand on the hand wheel. The take-up lever is thin steel and all the moving shafts and gears inside the head are designed for the pressure of sewing shirts and pants, not hard leather. These are just some highlights of what that machine will be up against, trying to sew holsters. You will end up with using undersized thread, skipped stitches and thread wads on the bottom. If you jam the shuttle with top thread that didn't get picked up properly, it will knock the poor machine out of time. Please read my sticky topic in the top of this section of the forum, where I explain the differences in drive mechanisms and what type of machine you really need to sew leather.
Yes, as long as the machine is able to run at slow speeds, under 600 or 800 rpm without running out of oil. Some modern straight stitch machines must be run over 2000 rpm to distribute the oil to the important extremities..
Prisoners also use these portable walking foot machines, which they pay for with money earned while in jail, then take home, if/when they are released. Then they become instant sewers/leathercrafters, until they offend again and end up back in the joint. Don't become a prisoner, buy a real industrial sewing machine, not a Thompson or Alphasew mini walking foot machine.
If you hand stab the holes through 5/16" veg with your stitching awl, you'll understand how powerful a machine would need to be to do the same with just the needle. Not only must the machine punch through the leather, it must also hold it down as the knotted threads get pulled up inside the layers. You are probably using 4 to 6 cord waxed linen thread now. Most machines don't do well with waxed thread, so we use bonded nylon or bonded polyester instead. The closest equivalent sizes of bonded thread would be #277 or #346. Only the biggest stitchers can properly handle these sizes of thread, while still forming a well positioned lockstitch and holding down the leather as the needle ascends. Ferg accurately described the solution. You are probably not going to find such a machine on Craigslist, or eBay, unless it is a Juki 441, Adler 205, or clone. We have dealers who support the LWN forums and they have ad banners at the top of every page. Reloading a page loads a new set of banners. The big three represented here are Cowboy, Cobra and Techsew. I'm not sure if Consew produces a 441 clone. If they do, it may not be setup as a leather sewing machine. Why bother when the three brands I mentioned are already available, set up for leather and properly equipped to do so?
What Sewing Machines Do You Have? Shop/home
Wizcrafts replied to The Dawg Club's topic in Leather Sewing Machines
I care. That's why we have this forum. You're a member just like the rest of ussens. -
Remove the top thread completely. Remove the front face plate by loosening the two large screws holding it to the body (upper right, lower left). Raise the presser feet with the hand lift lever. Locate the presser foot bar (to which the outer feet are connected. Using the hand wheel, position the presser bar so that you can access the screws that secure it in position. Use a screwdriver or hex wrench as needed to loosen the screw or screws that clamp the presser bar. When they are hand loose, without raising or lowering it, rotate the bar slightly until the toe or toes are facing straight ahead. Test this by installing the double toe foot. With the toes facing true forward, lock down the screw or screws on the presser bar. It is also possible that the inside foot is screwed on at an angle. If this appears to be the case, loosen its screws (slotted screw or Allen screws) and turn it until it faces straight ahead, then lock it down. Using a precision oiler, place a drop of oil into every little oil hole you can find on both ends of each moving shaft and crank inside the face area. Do this internal oiling once a month. Carefully replace the faceplate, making sure you get the black lever with the slot cut in the end directly over the pin on the back of the head. That pin is connected to the foot lifter shaft and causes the lever to move up and separate the top tension disks. Tighten the faceplate bolts and thread the machine. The feet should all face straight ahead now.
Have Mercey On This Girl... New Consew 206Rb...
Wizcrafts replied to Danno3's topic in Sewing Leather
I have a few observations based on your comments Danno. First, the thread lying flat on the bottom can be caused by the following misadjustments: Bobbin case spring way too tight Top thread spring way too loose Top thread too springy, causing it to flip out of the center area of the tension disks (no top tension) Needle too small to pull knots up into leather Normally, the bobbin thread tension spring is set for a light, even pressure when you pull on the bobbin thread. If it is very hard to pull the thread that emits under the tension spring, something is binding as the thread leaves the bobbin. It could be a burr on the spring, or maybe the thread has unwound around the bobbin inside the case, or you left too long of a starting stub after cutting it off with your thread snippers. Also, if the bobbin case has an anti-backlash spring inside it and the bobbins are just a little on the wide side, the case and anti-backlash spring could jam the bobbin against the shuttle face, adding a lot more tension than you expect to have. Always prove the bobbin tension after pulling the thread up through the feed dog hole. Issue #2 can be fixed by adding more spring tension to the top disks. Screw in the adjuster nut to add more pressure from the beehive shaped spring. Improvements are usually noticed right away, unless issue #3 exists. Issue number 3 is trickier. This happened to me last year, as I was sewing. It is a known secret among professional leather sewers that a lot of times a spool of black thread will unwind like a coil spring. These windings tend to form twists and even knots along the path to the needle. One day, as I was happily sewing long strap on my walking foot machine, the top thread started bunching up under the leather and motion ground to a halt. There was zero top tension! When I followed the thread back from the needle to the top tensioner, I found that the thread was literally sitting on top of the disks, rather than down inside them. It was black #138 bonded nylon thread and it unwound like a clock spring. First, I tried looping the thread around a post on top of the machine, which added back tension, which helped pull the thread down into the business area of the disks. But, due to its springiness the thread formed another loop around the post and jammed the machine to a halt, filigreeing the leather. When this kind of trouble happens and you have no other suitable thread to change out to, you find unusual solutions. My unusual solution, which I am still using, is to feed the top thread under the little 1/16" diameter steel pin that keeps the top tension disks in alignment. The disks have a little semi-round cut-out that flits over the little spring-pin. My thread feeds straight through the top post, winds around the three hole guide over the right side of the tension disk assembly, goes under the little spring-pin, then a sharp turn up to the left and around the tension disks, then down to the check spring assembly and on to the take-up and feed down guides. With this configuration my top thread has never again twisted itself out of the top tension disks. The sharp turn up from the pin adds more tension, so I no longer feed through two holes on the top post. It simply isn't required any more. I explained in the last paragraph that some thread is more springy than other threads. This is especially true of bonded black nylon, which is often redyed from a dark blue to black. I now keep different brands and batches of black thread on hand, purchased at different times. Some is springy, some is less so, some not at all. Bonded polyester tends to be much softer and less springy in all colors I have on hand. As for the needle sizes, #69 (T70) thread is usually sewn with a #16 or #18 needle and usually produces a great stitch in thin materials, like Naugahyde and garment leather and motorcycle patches on vests. However, if the tensions are decent, top and bottom (no jammed threads), but the knots lie under the leather, and the machine is properly threaded and the top thread has not lifted out of the top disks, increase by one needle size for a larger hole. If necessary, you can even try sewing with a #20 needle. Matching your reverse stitches can also be fine tuned by changing the timing of the alternating presser feet on the back of the machine head. In my photo below, the big six sided bolt locks down the timing of the feet, while the nut-secured sliding piece, that moves in the curved slot, controls the amount of lift the raised feet have. By loosening the big bolt, and rotating the shaft connected to it, you can adjust the moment when the inside foot makes contact with the feed dog to happen just after the tip of the needle passes the top and begins to enter the hole. Do this while the needle and inside foot are on the down stroke, without material under the foot. You will probably have to adjust it a few times before you zero in the stitch length to match in forward and reverse.- 18 replies
- consew 206rb
- reverse
(and 1 more)
I used to have two old Singer post machines, both equipped with roller feet. I used them to make leather caps and cowboy hats, as well as to sew moccasins. Most of the newer post machines can sew with up to #138 thread, whereas my old ones barely handled #92. Cylinder arm machines can be had in light, medium and heavy duty constructs. A shoe patcher (Singer model 29 and 29k) is what I would call a light duty cylinder arm machine, capable of maybe sewing no more than 1/4 " of leather with #69 or #92 thread. A Consew 227 type machine, such as the Cowboy clone that I pictured in my previous reply, can sew all day with #138 thread, up to 3/8" of leather. A big Cowboy, Cobra, or Techsew 441 clone cylinder arm machine can sew up to 7/8", with #346 thread, and even #415, using huge needles resembling porch finishing nails in diameter.
Consew 206Rb Skipping Stitches With Soft Leather
Wizcrafts replied to Andrew Chee's topic in Leather Sewing Machines
Yes, a needle feed machine, slowed way down, with a slotted Teflon or roller equipped presser foot will serve well for most flat work and linings. Just make sure you buy feet with a long slot between the toes. Some straight stitch feet just have a fixed position hole, which would be a disaster for you. Also, most of those machines are meant to sew shirts and have small needle holes and dog teeth. If that machine doesn't do what you want, or runs too fast, sell it and buy a common, manually oiled straight stitch with a fixed position needle. -
I use different sewing machines for different tasks and materials. I have found that my large Cowboy stitcher does not do as well sewing with thin thread and with heavy thread. I have to dink around more than it is worth to change over from sewing with #277 to #92. Tis better to keep a medium duty walking foot machine for middle weight jobs, small thread and small needles. Also, long needles bend more easily than short ones. So, I use a harness stitcher for holsters, a walking foot machine for thin flat items and a shoe patcher for sewing in different directions, or on top of pockets, or inside sleeves and legs.
I keep a straight stitch machine, with a servo motor and a big variety of presser feet, for such projects. A few nights ago I used my Singer 31-15 (a straight stitch, bottom feed only machine) to sew a lining that had separated, inside a pair of leather pants. I then sewed the fixed lining between two layers of garment leather. The machine was threaded with #69 bonded nylon and I had a flat, roller foot equipped attached to the presser bar. The little rollers allowed both the satin lining and garment leather to feed without any binding whatsoever. The machine is equipped with a medium tooth feed dog and a round throat plate hole big enough to clear a #20 needle (I only used a #18 needle for this job). My National walking foot machine might have eaten the lining, because of the way the feet work and the largish oval hole in the moving feed dog. -
Palermo; If you do buy a 441 type machine with the intention of sewing soft or thin leather, also get the accessory flat slotted throat plate and some packs of thinner needles (e.g. #18, 19, 20). You'll need to remove the feed dog and standard plate to use this plate. It has a long, narrow slot for the needle to move the work. The width of the slot is much smaller than the hole in the feed dog. That large hole causes skipped stitches and stitch length inconsistencies in soft garment leather and other soft materials.
Not without all of our advertising dealers approving the content.
Thread Lint In Consew Tension Discs
Wizcrafts replied to georgeandgracie's topic in Leather Sewing Machines
Bob is also right. If there are grooves worn into the tension disks, bobbin spring, guides, or take-up lever, the thread will tend to fray. How fast do you sew? -
That is not normal for premium bonded thread. It may be a bad batch or poorly bonded (it happens). Try using a different brand (or batch number) of thread. Alternately, try running the thread through silicon lube in a lube pot, or magnetic lube jar. You might even try soaking the spools in a quart or gallon of silicon lube. -
Tony; You can run a stitch marking wheel over the last machine stitches, up to where the hand sewing ends. This should keep the spacing constant, depending on your stitch length used on the machine. Most overstitch wheels don't exceed 5 to the inch, but our machines can easily pass that length. If an overstitch wheel doesn't work for you, use sharp point dividers set the your stitch spacing.
A typical Juki 441 or clone is not usually set up as a leather sewing machine. They contain parts and are timed to sew tents, tarps, buffing wheels, tow ropes, horse blankets, padded car seats, etc. As such, these machines are equipped to sew at about 10 to 15 stitches per second. Here are some of the changes that must be made to make a Juki 441 or clone into a dedicated leather stitcher. Change feed dog to custom made smooth type (original has aggressive teeth) Change big, wide, tooth-bottomed blanket presser feet to narrow, smooth bottomed harness feet, plus include a left and a right single toe outside foot. In the case of Cowboy 441 clones, change feet, feed dog and throat plate to stainless steel parts. Adjust reverse lever to sew into same holes. Increase lift to at least 1 inch (factory lift is 3/4 inch), allowing sewing to 7/8 inch of leather. Change motor to powerful, slow speed capable servo, with very small motor pulley, which feeds a speed reducer wheel, which drives the machine at about 8 or 9 to one speed reduction/torque multiplication. This allows you to sew at less than one stitch per 2 seconds, up to about 7 per second (depending on your motor). Adjust timing and placement of hook for best results when sewing leather, forward and reverse. Non-leather projects do not usually deflect the needle sideways as much as leather does. Optional installation of a wax/lube pot. This can be filled with liquid silicon thread lube, sewing machine oil, or (Ceroxylon) liquid wax. The lift and timing of the alternating feet may be altered for best timing with the motion of the feed dog, needle and inside foot. The pressure spring may be replaced with a heavier duty part, capable of holding down 7/8 inch of leather. Accessory throat plates may be included, or sold as accessories. These include a raised holster plate, a raised, rounded top stirrup plate, and a semi-flat, narrow-slotted plate that is used without the feed dog. Using the slotted plate without the feed dog can produce a bottom stitch line that comes close to the appearance of a needle and awl machine. Every nut and bolt gets inspected and tightened down, which doesn't always happen at the factory. ;-( Paint or casting mishaps are corrected before the machines are sold. Machines are tested with real leather, stacked to about 7/8 inch. The machine must sew to that thickness if it is advertised as capable of doing so. These are some of the things that our dealers do to each 441 clone they have for sale. It takes upward of 4 to 6 hours per machine to convert them into proper leather stitchers, assemble them onto pedestal tables with speed reducers, and sew them off. If you were to buy a no-name 441 clone, you would have to purchase all these parts from our dealers, who have them made to order, then upgrade and readjust the machine yourself.
I now get Family Sew motors from Toledo Industrial Sewing Machines. They have a rotary speed control switch on the front and lots of power. Your Juki is a light duty dual feed machine, with a fixed needle position. It was built to sew cloth garments, not leather. Thread-wise, you'll be pushing it with black #138 bonded nylon. You'll be better off buying the more expensive, but typically softer bonded polyester thread. Sewing with #138 thread, top and bottom, requires either a #22 or #23 leather point needle. Schmetz are best, if you can get them with an S point favored by most of ussens.
What Type Of Feet Should I Buy?
Wizcrafts replied to LeatherWerks's topic in Leather Sewing Machines
Those are sold as zipper feet. Get smooth bottom feet or they'll leave tooth marks in the top grain. If you have trouble finding smooth bottom single toe outer feet, buy two more standard (double toe) walking foot sets and grind off the left toe on one and the right toe on the other. Afterward, get a swing-away edge guide. -
By the time you buy a servo motor and new belt and pay shipping, you'll be well over $800. This, for a 20 year old first of its kind machine. For about $500 more, you can get a brand new series 5 Consew, with a warranty and new servo, already set up and ready to sew. Just sayin'.
Your hand sewing thread is about the equivalent of #207 (3 cord) or #277 (4 cord) bonded (nylon or polyester) machine thread. Bonded Polyester is a tad softer than the same size of nylon, forming knots more easily, and is UV resistant. The vast majority of industrial sewing machines cannot handle #277 thread at all. You need to look into an Adler 205-374, or clone, or a (Juki) 441 clone. An actual Juki 441 is not shipped equipped to sew leather; it needs a lot of modifications. The 441 clones, like Cowboy, Cobra and Techsew, as sold by our dealers, have been modified for leather work. All of our advertising dealers can ship a machine to you by ocean freighter. As for machine sewing with linen thread, it is a crap shoot. Pre-waxed thread gums up the guides and tension disks and clogs the needle. Post-waxed (with liquid wax) 3 or 4 cord linen thread tends to break after so many stitches. Mind you, I have not tried using 5 or 6 cord Irish linen in my Cowboy CB4500, as I have none at this time. But, the 3 and 4 cord threads have problems after running through the liquid in the wax pot. The machine you choose must have large needle capacity. You will be using needles ranging in size from metric 180 and up. I usually sew with #277 thread and it requires a #25 (200) needle. This is the standard factory needle on an Adler 205. It would be the minimum size needed to sew with 4 cord (pre or post waxed) linen. However, thick bonded threads need a certain amount of thickness of leather to form a properly positioned lockstitch. Anything thinner than about 9-10 ounces will give the machine trouble placing the knots inside the leather. We usually use thinner thread, like #138 or #207, on thin leather, like 6 to 8 ounces. The difference between hand sewing with two needles and machine sewing is that the hand thread forms daisy loops - over and under the leather. There are no knots between the layers. Most sewing machines form a lockstitch, with a knot formed inside the material. The top thread gets pulled around a bobbin, capturing the bobbin thread and pulling it up, forming a wrap around knot. The thickness and toughness/softness of the thread affects these knots. Black bonded thread tends to be stiffer from multiple doses of black dye, so it needs more tension and more thickness to hide the lockstitch knots. Bottom line is, you'll always be able to use thicker linen thread when you hand sew with two needles (daisy loops), than the bonded threads required by industrial sewing machines (lock stitches). Linen (glazed or waxed) bends much easier than bonded nylon, which bends a little harder than bonded polyester. Most sewing machines don't like waxed thread, unless you are very careful and clean the guides, disks and needle after each use. Note, there are some machines that were made to use waxed linen thread. They are horribly expensive, very heavy and usually ancient (but rebuilt). Brands that I have used are Union Lockstitch and Campbell-Randall. Also, some shoe sole stitchers can sew around the perimeter of leather goods, using waxed linen thread. Prices A new Adler 205 might cost you several years income. You can buy a 441 clone from the USA and have it shipped to you for half the cost, landed.
The foot lift can be modified by the owner. However, foot lift is tied into top thread disk release. If your machine has adjuster nuts over/under the presser bar, fastening to the lift plate, adjust them to allow the foot to lift higher before disengaging the disks. Once you reach the height where the hand lift lever engages, there is no more lift to be had. I suspect that most tweaked Singer patchers will max out at just under 3/8 inch of lift, allowing you to sew about 5/16 inch. The machine needs clearance to let the foot pull the work, then return to its starting position. If you need higher lift and sewing capacity, buy an Adler 30-70, or a newer Claes patcher. That Adler actually sews 3/8 inch and the Claes manages almost 1/2 inch.
You'll get better results if you run one size smaller thread in the bobbin than on top, with that machine, if you go above size 207. If you limit the size of the top thread to #277, and use #207 in the bobbin, it shouldn't give you any trouble. You will need leather point needles, in sizes 22, 23, 24 and 25. This covers a range of thread from 138 through 277. Note, the feed system is not a real walking foot. It has a spring loaded top foot that simply follows the work backwards, until the feed dog drops. At that point, it snaps forward for the next stitch. You should read this topic about the Singer 132k6 for a better understanding of its capabilities and limitations.
