I think that a Consew 206RB-5 is perfect for sewing belts, guitar straps and leather appliques . It takes #138 bonded thread, top and bottom and has a large M size bobbin. The machine sews up to 3/8 inch seams (in soft to medium temper compressible material). It has a push down reverse lever to lock the stitches and can sew as long as 4 stitches per inch. This machine is equally at home sewing vinyl, canvas and upholstery leather. With an edge guide or edge guide foot it can sew along the edges of belts, guitar straps, chaps and anything else that can be sewn flat. It is also good at sewing patches onto the back of leather vests.
I read the specs on the eBay page and I believe it listed the throat length as just under 12 inches. It is a clone of a clone of a clone of a Singer 29ksomething. Each time they clone a mold it shrinks a little. The same thing used to happen to belt buckles that were copied in China in the early 1990s, ripping off the US based Bergamot and Siskiyou buckle companies.
Singer 29-4 and Champion Outsole stitcher
Wizcrafts replied to BreeanaKriston's topic in Leather Sewing Machines
The phone number for Toledo Industrial Sewing Machines is: 866-362-7397. -
5 machines (fell in my lap, details coming)
Wizcrafts replied to Teradee's topic in Leather Sewing Machines
@Teradee- I already recommended posting your machines for sale in the Marketplace section, under Sewing Equipment > Used. This Leather Sewing Machines section is strictly for discussing the capabilities, operation, repair techniques, specifications and rebuilding of leather sewing machines. -
Dürkopp 17 Patcher - Sunday Morning Barn Find
Wizcrafts replied to Constabulary's topic in Leather Sewing Machines
Wow! This project is making my heart skip a beat! -
111w153 Needle Thread Hanging Up On Bobbin Case Tab
Wizcrafts replied to AlZilla's topic in Leather Sewing Machines
You can try using a bobbin case tension spring screw from a domestic Singer machine. Maybe one will fit. Otherwise, contact an industrial sewing machine dealer. You can either buy the screw, or a new bobbin case, plus a spare screw. Maybe you want needles, thread, oil, edge guide feet, etc. Order a bunch of small items to make it worth while instead of just one or two screws (that may get lost again). Before you order, tilt the head back and look inside the oil pan under the machine. Use a magnet tool to fish around in the pan. You may find that screw! -
Dwight; Sewing patches onto vests, hats, jackets and riding suits is at least 33% of my income from my shared leather shop. Some days it is 100%. A person with the right equipment and skills can do well in this side of the business. Obviously, the person you asked is charging what they think the job is worth. They have probably invested a small fortune in their machines, multiple colors and sizes of thread, bobbins, extra shuttles, needles, thread snips, staplers, double sided tapes, oil and repairs as needed. Unless you intend to go into competition with that person, I would take the work to them. They will know how to accomplish the positioning you want and save you hundreds of dollars in supplies and machines you don't otherwise need. The cost of the parts is only half of the equation. There is a significant learning curve to be effective in the patch sewing business. You have to learn about sewing over single, double and triple pockets, opening and closing linings, avoiding sewing through a zip open back or side lining, or accidentally sewing over a zipper. There are hidden seams around pockets that will deflect the foot and break a needle if you don't know they are there and take measures to deal with those internal obstacles. Then there are the different border colors that require you to stock multiple shades of colors like browns, yellows, golds, oranges, grays, etc. Some patches are best sewn with a round point needle rather than a leather point needle. There's a lot to learn. Pay the man or woman to do the sewing and let them save you a lot of time and trouble.
I looked up that machine and it is good for leather upholstery, or chaps, jackets, vests, straps, belts, or other not too thick or dense leather projects. It should be able to use #138 thread top and bottom. This thread has 22 pounds breaking strength. It has a large M style bobbin.
It helps that I have the very same machine in my living room at home. It needed parts and adjusting when I got it. Now, I trust it to sew commercial goods. -
@Dwight Don't do it! Unless you have a machine shop and are skilled with metal working tools you are asking for more trouble than you can imagine. Why don't you check your local Craigslist, or Facebook Marketplace for an actual working used Singer 29ksomething patcher?
Here are some items to check for. Is the top thread threaded correctly through the tension disks, around the check spring, through the take-up lever, down to the guide on the needle bar? Is the foot lift lever down so the tension disks are closed and tensioning the thread? Is the needle inserted all the way up with the rib on the left and scarf on the right? Is the timing right? The hook should arrive at the centerline of the needle about 1/16 inch above the eye after the needle has risen about 3/32 inch above BDC. Does the hook pass the needle without hitting it or pushing it to the left? If it hits, move the hook to the right and retime. Is the bobbin case opener lever pulling back far enough on the flange on the bobbin case to let the top thread pass freely around the tab on the way out? Are you holding back the starting threads for a few stitches to lock them in place? Note: Retarded timing can cause the top thread to hang or snap as it goes around the shuttle. The extra stress can bind it at the positioning tab. -
I use a #19 needle with v92 and a #22 or #23 with v138 bonded thread. If you use a needle that is too small it makes tighter holes and the take-up lever has to work harder to pull the knots up. It also tends to lift the leather as the threaded, knotted needle ascends. This causes missed stitches and ratted top thread. Here's a needle and thread chart that I consult.
- 26 replies
- thread size
- sewing machine
(and 1 more)
You can start her out with a domestic sewing machine found at Joann Fabrics. They have a (Viking) section where there is a person demoing the machines they carry. They even give classes. Everything from sewing seams up to embroidery. If she gets good at it and wants to take the next step, you can buy her a straight stitch dress makers' sewing machine (e.g., Juki DDL-8700). Some of these spin at 90 stitches per second and have oil pumps! Not a beginners machine!
@CowboyBob has them made for the Cowboy machines he sells. They also fit on Cobra and Techsew 441 clones, as well as on the actual Juki TSC-441.
- 8 replies
- tack
- inline presser foot
(and 1 more)
Awesome work!
- 8 replies
- tack
(and 1 more)
@RockyAussie sells them directly. Message him through the forum PM system. I use his narrow set full time on my cb4500.
The Juki DDL-8700 is a light duty, high speed, straight stitch, bottom feed garment sewing machine. The high lift in the specs is the clearance under the raised foot for moving thich seams past the needle and foot. The needle is a DBx1, which is a short needle often used in garment sewing machines. You will probably be limited to a maximum thread size of #69, or possibly #92. This calls for needle sizes 18 and 19. The timing may have to be changed to use a #19 needle. The only leather this is going to sew is fashion leather like used in clothing, or light weight vests and thin wallets. This machine has an oil pump and needs to spin fast to distribute the oil to all the extremities. This machine is used in tailor and custom dress shops and small garment factories where they operate flat out at 50 or 60 stitches per second!
Thickness/Torque Capability Difference
Wizcrafts replied to MartelloDesigns's topic in Leather Sewing Machines
If you call Toledo Industrial Sewing Machines (866-362-7397), they will ask for your current v-belt length to your motor and its pulley size. Then they will know what belts to include with the reducer. -
@kgg - his machine is a shoe patcher! He can only use small patcher bobbins, #8604. Those have to be ordered from industrial sewing machine dealers. Here is one source.
You answered your own question. Just buy a speed reducer. A 2:1 reducer doubles the punching power at the expense of the top speed. I get my motors and reducers here. -
Make sure the needle is firmly seated all the way up in the clamp and that the rib is on the due left and scarf on the due right. Ensure that you have threaded the top correctly. The route is as follows: Feed up from the spool to a loop overhead, then to the top of the machine. I usually feed the thread through the center cutout in the top rack. Under the lube pot clamp then out thru the lube pot hole. Around the post on the right side of the top tension disks and into the right side of the disks. Out of the disks and through the eyelet on the top front side of the head. Up to the take-up lever. Make sure the spring on top of the take-up lever is functional and exerts force to pull the lever up, but lets the lever go down as the rack moves up on the take-up stroke. Out of the take-up lever and down the needle bar hole, using a patcher threading rod or thin wire that has a V cut, or split on the bottom to hold the thread. Through the paddle spring above the needle clamp and down to the needle. Thread the needle left to right. Test to make sure there is tension on the thread with the foot lift lever down. Ensure that the paddle spring exerts some friction on the thread in the snout. If the paddle spring is bent, weak, or broken, the loop will dissolve before pick-off time and it will skip stitches. If the hook timing is off, adjust it via the eccentric screw accessed through a hole in the right side of the base of the machine. There is a rod coming down that joins a rod feeding under the arm. You'll have to wrangle a wrench under the base to loosen the nut on the back of the adjustment screw to turn it. Turn either way to get the best timing that picks off the loop as the needle moves down, then jogs up, then moves down again. Once the timing is right, tighten down the locking nut.
Ask and ye shall receive! Go here for a needle and thread chart.
Sailrite sells piping foot sets for their machines. Since you are using vinyl, feet with teeth won't be a problem.
You can order the hook and bobbins, threading rod and other replacement parts for shoe patchers from Bob Kovar (Toledo Industrial Sewing Machines), and from @shoepatcher I uploaded three manuals for your patcher and similar models. 29K62.pdf Singer_29K.pdf Singer_29K58,_K60,_K62.pdf
The thickest thread you can run through the Rex 26-188 is probably #207 on top and #138 in the bobbin. You will need a #24 needle to do this. If the leather isn't too dense you might be able to run #207 in the bobbin also. This was discussed in a previous topic.
