Everything posted by amuckart
Something I've read in a few posts in the archives of this forum is that the big advantage of the machines sold by the likes of Artisan, Cobra and CowBoy compared to other Chinese import machines is that a lot checking and tuning gets done on them before they get sent to the end customer. Is that still the case? I ask because I've got a friend with a machine received direct from the factory that builds machines sold by one of the popular retailers on here. I don't know who they purchased it through and I won't mention the brand, but my friend was quite unhappy with it as-received and said it needed an almost total rebuild before it performed well. I have no doubt that the quality of the tuned and tested machines from the US vendors is great, but given the additional costs of getting a machine from the USA to NZ compared to getting it shipped direct from China, and the distance from the vendors if I do need service/parts, I'm curious as to whether things have changed in the last couple or three years with the factory quality of the machines or whether I'd be better off going for something like a Highlead which is a lot more expensive but seems to have a good direct-from-factory reputation. Having hit the cost/benefit wall trying to get my 45k rebuilt, I'm saving my pennies for a big cylinder-arm machine, but I'm also interested in how this applies to lighter-duty machines as well. Given a decent service manual I'm able to work on machines just fine, but when it comes to things like this I want to start out with something that will Just Work. Cheers.
To what extent have you looked at the workings of crank splitters in person? I suspect that you'll put more than a few hundred buck's worth of work into modifying this thing before you even try making and heat treating a blade for it, only to end up with something that won't work as well as a purpose-designed splitter would. There's a lot more to them than the rollers, and there's a reason they cost what they do. I was lucky enough to get two 6" crank splitters cheap, but they needed work and just setting them up again post-assembly was hard, let alone building one from scratch. Given the initial cost, and the work it took to get them going I wouldn't let either of them go for less than several hundred dollars. If I were going to make a crank splitter this big I'd start by working out where to get single-bevel blade made in high-quality tool steel so that it comes out completely flat and true. For something with a finished size of 300x40x5mm, that's a non-trivial task in itself. Next you need to find somewhere that can mill lengthwise grooves into the bottom roller close enough together to give you the good sharp ridges to feed the leather. Unless you own, and can program, a CNC milling machine, those two operations alone will set you back the price of a second hand splitter. If you do own a CNC milling machine, then you're in a good position to make the rest of a splitter too.
This drove me nuts with my 45k. There were a couple of grub screws with damaged threads that held tight enough under hand pressure but slippped when sewing. I ended up stripping the whole machine right down and still haven't put it back together again.
What's your budget? If you've got the funds for it D.W. Frommer's books and DVDs are about the best information you can buy on making western boots. They ain't cheap though, but I've never heard anyone say they weren't worth every cent. http://bootmaker.com/mybooks.htm
If Neoprene gives the effect you want, but you want a leather surface, have you tried stitching a layer of garment leather over a layer of neoprene?
Do you have a picture of the watch band? A 111W is a pretty big machine for doing this kind of work. What size and point style of needle are you using? My guess would be that the leather is getting pushed down the hole in the needle plate as you try and sew right close to the edge. You'd probably be better off with a lighter wheel-foot machine for things like watch straps with a needle plate that has the smallest feasable hole in it.
I've been looking at various options for motors, and one of the things I'm curious about is just how much torque you need to drive a heavy stitcher like a 441 clone or an Adler 205. Does anyone have torque/rpm graphs for the various servos people are selling, or even ballpark figures? Am I looking in the 1.5Nm range or in the 10-20Nm range? Thanks.
Glad to hear it's working better for you. If you want to get that blade *really* sharp, pick up a few sheets of 3M microfinishing abrasive and use them stuck to a sheet of thick glass. build a jig to hold the angle and you'll have something that'll split like a dream.
If you don't want to lube the whole thread, put some neatsfoot oil in the wax pot on top of the machine and lash a thick chunk of felt on the front edge using the two holes provided to strip the excess oil off. The oil will just dissappear into the leather when you're done sewing and won't permanently gum up the works of the machine. If you also use it for things that absolutely positively can't have oil anywhere near them, either get a second machine or wipe out the thread path with alcohol between jobs.
Becker Piggy Back Sheath
amuckart replied to GooseBGL's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice. What are the hex-key screws you've used to attach the belt loop? -
Have a read of http://www3.telus.net/BrentBeach/Sharpen/ It's about plane blades, but it's just as applicable to splitter blades.
Have you tried a crank splitter?
I don't know where to get 'em but my experience of bags with fittings like that is that the proper name for them is 'useless junk'. On all of the bags I've seen with that style of handle fitting it's been a nasty flimsy bit of metal on the inside trying to make up for the fact that there isnt' enough substance in the actual lid of the bag for the handle to hold on to.
Singer 153W Might Have Died - What To Do?
amuckart replied to Eldorado's topic in Leather Sewing Machines
Do you have any pictures of the offending parts? -
Pfaff 34 Missing Stitches And Pulling Up Bottom Thread
amuckart replied to amuckart's topic in Leather Sewing Machines
Thanks Kevin. I'm fairly sure I've got the right bobbins for this one, but I'll check. They certainly fit the bobbin case perfectly and the bobbin case fits the hook just fine. What was the clue you had the wrong bobbins in your Singers? -
Hi all, I've got a couple of Pfaff model 34 wheel foot machines for closing shoe uppers. Both of them are missing the occasional stitch when running at speed, and one of them is pulling the bottom thread up in a big loop so there's an inch or so of it above the material I'm sewing. The two machines are slightly different, one has a standard drop feed and reverse, and the other has a wheel feed with no reverse but other than that they're the same. The machines are pretty old, but are still tight and the timing doesn't seem to be slipping. I am wondering if the hook/hook race is worn; the one with the drop feed there's a little more 'rattle' in the hook than I was expecting, but I don't know what it should be like when it's right. The points of the hooks on both machines seem to be in good condition. I can time a machine, but I've never been good at figuring out intermittent dropped stitches and I'm at a total loss as to what's causing the loops of lower thread on top of the work. Can anyone help me out with pointers as to what might be causing this? Unfortunately I didn't have my camera around when it was doing it and I had to cut the thread to keep working on the machine, but I'll get it to do it again and post pictures. Thanks.
Junker & Ruh Lever Operated Leather Stitcher
amuckart replied to Aidan's topic in Leather Sewing Machines
Couple more points on these. Good luck finding needles. They're getting like hen's teeth these days. The good thing is you don't need many, you can resharpen 'em if you're careful and they just don't break unless something goes horribly horribly wrong. You need a good sharp point on the shuttle or it won't pick up the top thread, this can be a bit of a pain if the shuttle is worn. My two don't cycle right without tension on the top thread. I don't know if this is normal, but they both do it. The tension on the top thread pulls the takeup lever into the right position for the roller to move it. Without the thread tension the spring pulls it into a position where the roller sticks in the wrong part of the 'loop' bit of the takeup lever. -
Shave Kit Bag
amuckart replied to wood's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I've never made a shaving bag, but if I were going to do one like this my instinct would be to make the zip go all the way down to the ends to let it open more easily. -
+1 to what Wiz said. Henry's da man for these. They're good machines, but can be a little fiddly to get going. Needles are a pain to find, so grab all the ones you come across and be real careful how you store them. Parts haven't been made for years, so the only way to get them is to get another machine, but not all Junkers are the same and the Pedersen's are different again. I have 2, and the plate from one won't fit the other, and there are other minor thread/part differences. -
How To Make Shoe Lasts
amuckart replied to builderofstuff's topic in Shoes, Boots, Sandals and Moccassins
Casts are great for people like orthoticists and prosthetic engineers who are making a very specific formed surface to fit a part of the body, but not so great for lasts, because lasts aren't a model of a foot, they're are a model of the inside of a shoe which is quite different and very not-foot shaped in a lot of ways. You can take a foot cast and turn it into a passable last but it's not the best way to go. Feet are complicated mechanical structures that move and change shape and volume as you walk on them a shoe needs to accommodate that movement, either by stretching or by having space in the right places inside the shoe to let the foot move while conforming tightly to the parts of the foot that move less and that the shoe hangs from. If you made a shoe over a cast of the foot it wouldn't fit and would be quite painful to walk in unless it were made of lycra. It'd be like building a machine with absolute zero tolerances between moving parts. It wouldn't move. Pretty much everyone I've talked to, and every expert shoemaker I've read treats foot measuring and last making as an art more than a science. Golding and Koleff quantified the art and came up with general rules but there are subtleties in the exact tools a given maker uses and the exact way they use them that have flow on effects in how they make the patterns, shape the last and build the footwear. You can apply computer modelling and CNC technologies to making lasts but without someone driving those technologies who has a really profound understanding of the way a last relates to a foot the result won't be much good - as evidenced by the vast bulk of factory-made footwear today which in its attempt to fit everyone generally fits no-one, or "fits" by being so padded as to be useless (and bad for your knees, to boot). Most cordwainers don't make lasts from scratch - last making is a separate highly skilled trade in itself - but they do modify stock lasts to precisely fit given feet and the good ones at least will have a deep understanding of how a last shape relates to a given foot shape. Poor buggers like me who are learning to make 16th century shoes have to figure out how to make lasts themselves because there's no stock ones to modify -
Prosthetic Arm - Calling For Harness-Makers!
amuckart replied to StrayDogLamont's topic in How Do I Do That?
There are pictures of extant ACW-era prosthetics online. Have you looked at those to see how the prostheses of the period were done? -
Table Ideas For Cylinder Arm Machines?
amuckart replied to DenverLeather's topic in Leather Sewing Machines
I get back problems and quite bad RSI, so the ability to adjust even a little bit up and down can make a big difference to me. I've been working on how to get four low-weight props synchronised so I can put them in the legs of my desk for that reason. -
Oh, I'd have cam clamps to fix it in position, I was just thinking of the gas prop as a way to allow the height to be easily adjusted with weight on the table. -
Oh man, now I really want it! Problem is I live in New Zealand, so getting it here would cost a fortune
I think machinehead has it right and the safety clutch has disengaged. The very last page of that PDF I linked to above has instructions on resetting it.
