Everything posted by amuckart
Hi Norman, Simple: practice If you're used to shaping things on a grinder, but you don't do a lot of this kind of leatherwork, you could do worse than to rubber cement the leather to a rigid backing and grind the taper on then clean the glue off with rubber cement cleaner. The traditional way, as the previous reply says, is to make a skiving cut with a long, thin, very very sharp knife. Either way you go, get a strap and practice to find out what works best for you.
I'm curious as to what needles in current production will sew up to or greater than 1". The only two I'm aware of that will are 331 and Singer's system 97 needles, neither of which are in current production (331 is, but only in round point). Surely there are currently-produced needle systems for super-heavy duty machines. Can anyone tell me what they are, and whether any come in leather points? Cheers.
A T-7 sure will sharpen just about anything, so long as you're willing to fork out for all the fancy jigs and attachments to go with the $600 machine A 1x30 belt grinder and a good tool rest will also sharpen darn near anything and to total cost of a belt grinder, tool rest, jig, five 3M Trizact belts in grits from 240 to 2000, and a leather belt for stropping is US$212 - less than half of the cost of the Tormek alone, even if you allow US$80 for a motor and the shipping Tormeks are probably great for professional sharpeners, or someone working in a huge woodworking shop sharpening a lot of tools on a regular basis, but I know a few people who own them for general sharpening work and none of them think the machine was worth the cost.
Get some logwood extract and wash the leather down with that beforehand, or add it to your vinegroon before you apply it. I've had iron-dyed things self-destruct this way too, and according to the early 20th century book I have on the topic this can be caused by the iron oxides in the vinegroon stripping tannins out of the leather and leaving it brittle.
Four? Hah! Tell her my lot peaked at 36, ranging from a Pearson #6 at the large end through shoe machines and domestics down to featherweights at the small end.
Is There Anything Better Than The Lansky Knife Sharpening System?
amuckart replied to UKRay's topic in Leather Tools
Ray, there's all kinds of things better than the Lansky system. It's good for small jobs and touchups where you don't need an outstandingly sharp edge, but it's not something I'd use for tools. The same things I linked to in my reply to your scissor sharpening post will do knives, tools, and all sorts. There's a lot to be said for powered sharpening systems, and contrary to what Tormek's marketing will tell you you don't need to spend thousands to get something really really good. -
Two questions: What size/style of scissors, and what do you use to sharpen your existing edged tools? You can sharpen most types of scissors quite effectively by removing the pivot bolt and putting the blade in a vice (with non-marking jaws) then just follow the existing bevel angle with your preferred sharpening device. I use a variety of things from files for really blunt ones right through to ceramic sticks. You need to lap the back between grits too to remove the wire edge. If you lack an appropriate sharpening device, then a solid flat thing with wet-n-dry sandpaper either wrapped around it tightly or lightly contact-glued on works extremely well. You can do this with scissors that lack a removable pivot bolt, it's just less convenient. I've found that if a pair of scissors can't be taken apart then they often aren't worth sharpening. I usually look to the woodworking community for sharpening ideas since good edged tools are so critical to fine woodwork, and they have some of the weirdest shapes to deal with which means there's a lot of really good info and ideas to be found there. For some reason there seems to be a lot more scientific an approach to sharpening in the woodworking community than in the leatherworking community. Brent's Sharpening Pages is one of the best places on the 'net to look at for basic principles and info on abrasives. It's very focussed on plane blades, but his jig and techniques are adaptable to various edged tools other than plane blades. At risk of coming across as a Lee Valley fanboy, here's some links to things I think are useful. You can probably find them elsewhere too, but Lee Valley is a convenient one-stop-shop whose service and shipping I've always been very happy with. It's run by woodworkers, for woodworkers, so their kit is well designed for the job. You can use a 1" belt grinder to sharpen scissors and darn near anything else you might have too. It doesn't come with a motor, but the big advantage it has over cheap 'n' nasty belt grinders you'll find at big-box hardware stores is that it can run in reverse which means you can use it to strop/hone tools with the edge up, which in turn means you can use a tool rest and jigs to ensure a more accurate edge angle. One of these with a variable-speed reversible motor is awfully close to the perfect device for tool sharpening. They also make a nifty tool rest that'll fit that grinder, or bench grinders, and let you sharpen from 90" to extremely acute angles. Get yourself a decent selection of grinding belts while you're there and you'll be se up to sharpen almost anything for a good long time. I think the belt grinder is a better solution than a bench grinder because you can get access to a wider array of abrasives, and you can do slack-belt sharpening of appleseed edges, which you can't do on a bench grinder. If you buy one thing to help you with sharpening, make it Leonard Lee's The Complete Guide to Sharpening. It doesn't cover scissors explicitly but as he says, "sharpening is mostly common sense augmented by a few basic principles, some standard abrasives and a few cunning jigs", and it will certainly give you the background you need and ideas for how to sharpen all kinds of things. The Perfect Edge by Ron Hock appears to cover scissors explicitly, but I don't have a copy.
Hi Kevin, What do you mean by "all heads"? Cheers.
Rebuild/resole Possibility
amuckart replied to midnightrider454's topic in Shoes, Boots, Sandals and Moccassins
Yep, that's one of the things that is driving me to learn how to make my own. It's also why I wear NZ$500 dress shoes to work. People's eyes bug out of their heads when they hear that, but in 10 years I'll still be wearing those shoes and they'll have spent more than that on cheap Chinese crap, and y'know, when my English-made brogues are 10 years old they'll still look better than a brand new pair of $90, or even $200 Chinese-made shoes. -
Thanks Wiz, I'll drop them a line. Do you know if the Campbell uses Whitworth or SAE machine screws?
Hi all, Along with my Pearson I've got a few machines with square-head screws all over, but I'm having a bear of a time finding T-wrenches to go with them. Can anyone point me to a source that doesn't involve selling a kidney to fund the purchase? Where I am I haven't even had any luck finding sockets for square head screws. The local auto parts store has 'universal' jobs, but they go in the same drawer as adjustable wrenches and only get used for things I don't care about afterwards. I'd rather have proper t-wrenches than sockets anyway, sockets are a PITA for quick minor adjustments. If anyone knows where I can get replacement square head machine screws I'd be real interested. I suspect the most likely place to find 'em these days is near the back end of the proverbial rocking horse. I've got access to BSW tap/die sets so it's conceivable I could get some made up and thread them myself. If I did that would getting the 'blanks' cast work, or do they need to be machined up? Thanks.
Thanks Art, I appreciate that. I have been down the Stockholm tar path, I just haven't written it up yet. I'm still looking for a workable black wax recipe that's doable with commonly available materials. It's difficult now that good genuine pine pitch is so rare, but I'm fairly close now.
Step by step with pictures: my shoemaking wax instructions
That speaks to pretty sub-standard construction. Good footwear should be repairable forever unless the actual uppers leather disintegrates. Cardboard is for notebooks, not footwear. If you want to get some decent motorcycle boots, have a look at wesco engineer boots from boot.com -
That's nice work, but I can't pass this without checking: You do know that ring belts like that are basically a late 20th century invention, right?
Actually, now that you mention it that might have something to do with it. I have found Australian customs charges usurious in other situations.
That's a right cunning plan. Well done. If you want the best way to get a plane blade terrifyingly sharp, have a look at Brent's Sharpening Pages they're some of the best freely available sharpening information out there, and his techniques are applicable to pretty much anything you can build a jig for.
According to the Cruiserworks website the official place to send 'em now is www.resole.com Have you tried them? -
You looked at Leffler, didn't you? I wouldn't buy anything from there unless it was something I absolutely couldn't get anywhere else. Their markups on things like tools are eye watering. I've had some great service from them in the past in the times I was able to get the old man on the phone, but I think he died a while back and the last time I called them up they didn't know what I was asking for or where it was.
Yep, they look repairable to me too. Where did you send them originally? "Thank you for your 12,000-plus views, comments and e-mails since we announced the purchase of CruiserWorks™ by Sharp Capital Group, LLC." Yeah, because "Sharp Capital Group, LLC" sounds like a really customer-focused business that cares about the quality of their products! -
Do you have pictures of them in their current state? -
Do you have any pictures of the machine? The top of the head end and pictures of the various stages of the stitch cycle would be handy.
Junker & Ruh Lever Operated Leather Stitcher
amuckart replied to Aidan's topic in Leather Sewing Machines
Personally, I wouldn't pay EU525 for that machine, especially if I already had an SD.28, but the gear-head in me totally understands wanting it anyway! I think EU80 is a pretty fair price for a used SD.28 that hasn't been restored or rebuilt. If you watch the auctions for the EU600 SD.28s, are they actually selling at that price? The only way I'd pay that for one is if it came complete with all of the original parts, burner, bobbin winder, manual etc. It looks like the Rafflenbeul's are a lot more common in Germany (surprise, surprise!) than over here in New Zealand. For a machine I just happen to want for the collection and don't actually need It'll be a while before I can justify shipping one here though. If you can get bigger pictures, I'd really appreciate it, thanks. -
What an interesting machine! Any chance you could email me bigger pictures of it? It's an obvious earlier version of the SD.28 and it's interesting to see what's been refined. I'm quite interested in Junker & Ruh machines from a historical persepective. What you should pay for it depends on what you want it for. If it's being offered as a collector piece, be prepared to fork out big, the 22s are less common than the 28s. If you want it as a using sewing machine, consider what it does compared to what you want to make, local availability of needles, how it fits into your workshop, how well it sews, etc and go from there. Their advantages are that they're small, and hand operated. Their disadvantages are a very short throat depth, needles that make quite a big hole for the thread size, and lack of availability of needles and parts. If you want it for outsoling shoes, there are better hand-cranked options, but none quite as small as the Junker & Ruh. I have a Frobana Gritzner outsoler that makes a better stitch than the Junker, and uses the same shuttle as the 45k. The needles for it make a huge hole though. I still want to get my hands on a Rafflenbeul MS200 - they're a hand-cranked needle & awl machine. IMO, used SD.28s go for far more than they're worth. They're good machines, but the reality is they're just not EU600 good, considering what else 600 Euros will buy you. When you consider that Henry Veenhoven sells refurbished ones for US$600 and that unless you luck into a really good second-hand one they can take a lot of work to get going well, they aren't rare enough as collector pieces to warrant that kind of price. I have two, I paid NZ$120 for one, and NZ$400 for the other and a 6" crank splitter. The only reason I bought the second one was for the harness plate. Both of them have been fiddly to get going properly and needles for them cost me as much as one of the machines.
