amuckart
Everything posted by amuckart
  1. Yep, I'm coming to realise that the threads in this machine are a bit special. That really surprises me because I figured that at the point where you're cloning a machine it would just be easier to use a common thread standard instead of having to replicate whatever weird ones the original manufacturer used. For that matter I'm a bit surprised that a late 20th century machine still uses all those weird threads. I've got a parts list for the TSC-441 and it's a mix of metric and imperial and god knows what.
  2. Thanks Bob. I guess I was hoping that since it's 2013, not 1913, that the screws were an actual standard standard. I was aware that Singer screws were almost all weird and proprietary but that's not universal in sewing machines - my Seiko and Pfaff machines seem to have standard threads in the various holes they have. I'll just drill out the three holes I want to mount things on and put metric helicoils in them. It'll be easier than finding a source for Juki screws just to build a sensible table mounting. Cheers.
  3. Can anyone tell me what thread standard is used throughout the Cowboy 4500? There are various tapped holes on the machine that are neither M6 nor 1/4" and it's driving me nuts trying to figure out what sort of machine screw I need for them. Thanks.
  4. Excellent find. I am intensely envious :-) It's not a No.6 and it doesn't look like the No.2 I have. It also doesn't look anything like the No.4 in the catalogue that was posted on here a while ago, so I'm not sure. If you look at the parts they should have part numbers and a model abbreviation cast into them - the No.6 parts all have "HM6" for example. That should tell you what it is.
  5. Adam, who made that one? Thanks.
  6. It's getting powdercoated gloss black, then I'll pinstripe it. I'm still toying with whether or not to get the main balance wheel stripped or not. There's a reasonable amount of the original decoration on it, and I'm toying with having it stripped and redone by a professional signwriter.
  7. Here's a view of a Pearson No.6 Harness Machine that most folks won't have seen before. It's off to the powdercoater tomorrow.
  8. Sorry man, I haven't been on here for ages. I've just emailed it to you.
  9. Gudelon is pretty much the coolest project ever, and high on my list of places I really really want to visit as a reenactor. Given what I know of the people involved, and my experiences of doing medieval reenactment for the last 13 or so years, I'd say that there are likely to be two main reasons they're using modern harness: firstly that there's almost no concrete information on what 12th-13th century harness looks/works like; and secondly that modern harness is probably far better for the animals they're using. There are also issues that you can't really find 12th-century equivalent horses any more, modern horse breeds are quite different. It's an anachronism, but it's a second-order effect for the work they're doing, i.e. it doesn't have a direct impact on the outcome of the build the way, say, using power tools instead of medieval stonemason's tools would. The only resource I'm aware of that's easily available is the Museum of London book The Medieval Horse and its Equipment.
  10. Pfaff made a variant of their model 35 machine that has reverse. I have one, but I've never tried to put any high-shank feet on it so I don't know if they fit or not. They also made a non-reversing version with a lower wheel feed rather than a drop feed.
  11. This is interesting to me as there are a couple of 3-phase clicking presses nearby. What sort of HP rating do the motors in them usually have? I know nothing at all about the inner workings of clicking presses.
  12. I've seen others use small French edgers for this kind of thing.
  13. Thank you both. So far I haven't needed binder clips, the contact adhesive I'm using is more than strong enough. The difficulty I'm having is in getting the gusse to form neatly. How much sewing allowance do you leave on the gusset, I.e. how big is the turned out lip? Thanks.
  14. Hi all, I'm making my first gusseted bag, it's a man bag for me. I'm wondering if the leather I'm thinking of using for the gusset is too thin, it's 1mm chrome tan calf. It seems pretty strong but I don't know how it's going to wear in practice, so I'd appreciate any advice you good folks can give me. Thanks.
  15. I'm making my first gusseted bag, and I'm wondering if anyone can share tips on getting the gusset to go around the corners neatly without wrinkling or getting bad folds that make it impossible to machine sew? I'm using chrome tanned leather for this project, so wet forming isn't an option. Thanks.
  16. Judjung by the picture, that's not in bad shape, all I'd do to it is polish the channels if they need it and be done with it. If its dirty, just wash it in some very hot very soapy water, dry quickly, spray with WD-40 to displace the moisture in the hinge, wipe downand oil lightly.
  17. Do you have pictures of it? What I do depends an awful lot on the state of the tool to begin with.
  18. Hi Art, Thanks. I wasn't sure I was reading your previous post right. A while ago I asked what left foot was used for and was told it was to allow the roller guide to get right up against the side of the inner foot, which made good sense. When I was sitting staring the bits I'd pulled out of my 441 in the process of getting the @!$#%!@# thing going, I got to thinking about the lower needle guide in my #6 and the upper guides that can be had for it for using thin needles. That got me thinking about grinding a feed dog down so it would either run under the slot/stirrup/holster plates or so that it was just the same width as the inner foot and opening up the slotted plate to match. I might still have a go at that if I can find a cheaper source of bits to experiment with in NZ. Even getting them in from China is a bit pricey just to have a play with. There are a few. If you go to google patent search and search for "Ferdinand Jean Blanc" they show up[1]. The results I got from that were: US3779184 Feed dog awl assembly US5425320 Needle guide components for a sewing machine US4947773 Thread ring guide for a needle bar US5762014 Needle guide components for a sewing machine US5520127 Needle guide components for a sewing machine US4991526 Bed plate insert and presser foot, each having a guide surface for laterally supporting a sewing machine needle US3759202 Self-centering foot for sewing Mr Jean-Blanc had obviously put a lot of thought into how to make these machines sew better, and it's sad to see Ferdco closing their doors. I do hope one of the active and reputable clone makers picks the relevant ones up. [1] You also get a hit for US5538943 "Use of 1,3-undecadien-5-yne as a perfuming ingredient" but I think that might be the odd one out :D Hi Bob, Thanks for that. Did that go on in place of the feed dog, or was it a separate part? I'm guessing it went on with the slot perpendicular to the needle travel? Thanks.
  19. Hi Art, Do you have a dog on your slot plate?
  20. The patent expires at the end of 2015, and searching for it has told me what I wanted to know about how it works. Cheryl, who is excellently responsive, said they are negotiating with an unspecified manufacturer to take over production of the needle guides. Thank you for those, much appreciated. Pictures of the part I'm thinking of would mean taking the needle plate off, so don't worry about it, I finally found the patent documents which have pictures. Cheers.
  21. I'm curious about how the lower needle guide on Ferdco machines works. Can anyone post a picture of it? Thanks.
  22. Of those, I like the look of #2 best, but search the forums for 'kwokhing' and have a look at the neat drop-down guides.
  23. I'm not sure where those are, or who dated them, but I have to say as a 15th century reenactor; if those are 15th century chairs I'll eat my hat That style of chair is an 18th century thing at the earliest, and I wouldn't be surprised if those were actually Victorian chairs that haven't aged terribly well. The last one might be late 16th century, but the aesthetic still looks wrong, and if it is I'd say the upholstery has been redone. If you want to see some pictures of medieval and renaissance chairs have a look here Larsdatter's chair page. Unfortunately leather wasn't a big feature of upholstery until the modern period.
  24. What sort of light plastic do you use? Thanks for sharing this technique.
  25. My guess would be that they're starting with a bit of animal that isn't flat. Those could well be - and I'm not kidding - bull scrotums or something similar.
