Everything posted by amuckart
I don't know what the market is like where you are, but to put your budget in context, but here in New Zealand I bought a Pfaff 441 for NZ$250, and a Seiko STH-8BLD2 for NZ$300, both with motors etc. I had to replace the motors on the Seiko because it was set up for upholstery work and was much too fast for what I wanted but a new servo motor was $150.
What's your definition of "medium weight"? 6oz or 18oz? It's handy to be as specific as possible because my definition of "medium weight" coming at this from a different area of leatherwork might be very different to yours. In my book, 24oz is "medium" but if you're doing garment weight stuff then I suspect your definition of "medium" is a lot less than that. Are you particularly set on a Juki machine? They're good, but you pay a premium for that brand. There are older models of machine that will sew garment weight leathers really well that you can probably get for a lot less than $1000. That money might be enough to get you a second hand Seiko TE/TF-6, which are cylinder arm roller foot machines designed for lightweight leather sewing. The TF-6 is a left handed machine, meaning it's arm points to the right instead of to the left like a normal machine and the presser foot and feed are on the inside of the arm. This gives excellent visibility of the seam lines. Both can have a flat table attached. The TE/TF-6 are modern clones of the Singer 16 and 17 class machines. Another machine that's popular amongst people sewing things like boot tops and shoes is the Singer 31-15, which is a flat-bed roller foot machine. It's a straight-stitch only, and has no reverse, but there are modern versions that do. The Pfaff 441 (not to be confused with the Juki 441) is another flat bed roller foot machine for leather that can be had second hand. There's a post-bed version too, but I can't remember the model number. For someone working outside of a factory setting without maintenance staff, the advantage of machines like these compared to more modern self-lubricating direct-drive ones is that they are much simpler and far easier to service and unless you need really high production speeds they will probably serve you just as well. My recommendation would be to look at the advertisements on this site and talk to Techsew, Toledo Industrial, etc. about what you need and see if they have a machine that will do what you want inside your budget. I've also heard very good things about Melanie Machine Co. in Ohio.
I didn't, but google found it quickly enough. Thank you for the pointer. It looks like a rework of the Juki engineers' manual.
- 19 replies
When you say "lambskin" do you mean wool on, or thin lamb leather? The sort of machine you need to sew garment weight leather and the sort of machine you need to sew thicker leather are quite different. I think that for lighter weight leathers a roller foot machine (ideally with a roller feed) is a good idea. A post or cylinder bed machine will allow you to sew complex 3D shapes as well as flat things. For heavier leathers, you'll want a walking foot machine. For medium weight work a Seiko STH-8 or Consew 206 (both clones of the Singer 111) is a good bet. They're common, easy to get feet and parts for, and reliable. I don't know if they can be adapted to sew thin soft leathers like lambskin though.
Mostly, but not 100%. Interestingly adjusting it in accordance with Steve's video did not work. I don't know why, I thought Cobra and Cowboy machines were mechanically identical. The video gave me what I needed to stare at the mechanism while cycling the machine which let me work out what bits did what. Along with the engineering manual I've got the machine sewing cleanly forward and backwards into the same holes but the stitch length is out by about -10-15% across the board. At 11mm I get just under 10mm stitches, and it stops feeding by a needle width at about the 3-4mm setting. I think I know why this is but I need to play with it some more to be sure. The correct point for zero on my machine is the centre of the adjustment bar.
- 19 replies
Tips For Your 441 Sewing Machines (Courtesy Of Cobra Steve)
amuckart replied to Johanna's topic in Leather Sewing Machines
I think this video of Cobra Steve going over the whole machine with all its adjustments makes a useful addition to this thread:- 22 replies
- cobra
- artisan toro
(and 6 more)
I was wrong. I found Cobra Steve's video and it showed me most of what I needed. Thanks for the pointer Constabulary!
- 19 replies
What Order Should Adjustments To A New 441 Be Made In?
amuckart replied to amuckart's topic in Leather Sewing Machines
This great video from Cobra Steve answers the question- 1 reply
- 441
- adjustments
(and 1 more)
None taken. It was a calculated risk, and one I'm happy with. I'm not a professional who needs the machine for production work and I fix machines for fun so sinking time into getting it sorted isn't an issue.As it was I got the machine with a full set of feet & plates, for less than half what it would have cost me to import a machine from the USA. That's thousands of NZ$. For that money I'm willing to spend some time sorting it out and deal with a certain amount of mucking around with the local importer. I'm setting the machine up from scratch so I'm a bit beyond the basic tension and stitch length stuff :-)
- 19 replies
The machine has never been properly adjusted. I got it straight from China, and mostly got it going back when I got it, then I got sick and couldn't work on it for ages. I'm getting back to it now and starting from scratch because it was never quite right. There should be one correct position, irrespective of the way the particular machine is setup otherwise the max stitch length in forward/reverse won't be correct. Having stared at this for a while now I'm going with the centre of the bar, not the top. Too late, but thanks anyway I think there are a couple of reasons the question might not have been answered yet. It's not a trivial set of adjustments to make, and it's part of the setup that resellers do when they get the machines from China to make sure they're working just right when they go out the door, and that's a major part of their value-add proposition. That's pretty much right, but the wedge is rounded and not terribly accurate. I've run with the "screw the adjustment in as far as it'll go and that's zero" approach, which seems to be working for now.
- 19 replies
I've searched the forum and can't find an answer to this. My 441 isn't sewing as well as I want so I'm going back to basics and trying to tune it up from scratch. What I need to know is what order to approach the adjustments in. There are multiple adjustments in the engineer's manual that say they affect the stitch length relative to the markings on the machine or that they make the forward and reverse stitches different lengths. The problem I'm running into is that I seem to get into an endless cycle of setting one according to the manual, then adjusting something else and making it wrong again. Is there a specific order that adjustments should be done in to stop this happening? Thanks.
- 1 reply
- 441
- adjustments
(and 1 more)
I'm trying to get my 441 clone to have an accurate stitch length and sew in the same holes backwards and forwards. It only does this for some lengths. I understand how to make the adjustment, but I'm curious as to what the correct position for the stitch length lever is at the zero point. Should the middle of the lever align with the mark, or should the top of the lever? The lever is pretty chunky and imprecise but I'd like to be able to accurately set a specific stitch length so I can pattern things so the stitches end up exactly at the corners. This also applies to the max stitch length end, what part of the bar should align with the 11mm mark? Is this correct Or this: Thanks.
- 19 replies
I can't speak for Tor, but that's what I was asking about. The Ferdco machines had this part and they are described in the patents which I squirrelled out a while ago and listed in this post http://leatherworker.net/forum/index.php?showtopic=41581&p=259182 The patents were filed in 1993 and have lapsed, so my hope is that the other clone manufacturers will now start making and supplying these parts. Thanks.
Juki Tsc 441 Manual And Part List Download
amuckart replied to Trox's topic in Leather Sewing Machines
I would also love to get a copy of this manual. Thank you. -
Can you clarify what you mean by needle guide, is it a part under the needle plate that replaces the feed dog like in the Ferdco patents? If it is, where did you get it? Thanks.
Buying Keestar Sewing Machine 441 Directly From China..
amuckart replied to korokan's topic in Leather Sewing Machines
Watch this video and see how many different machines get used for different operations https://www.youtube.com/watch?v=HkvFBF4xT3o -
Hi Korokan, I think it's worth saying up-front that it's really great that you're asking these questions. Industrial machinery is a whole different world with different rules that aren't obvious until you've been there and seen them. That's because what the factory is doing is wholesaling industrial machinery and industrial machinery shipped wholesale comes with a completely different set of expectations than single-machine retail. You wouldn't by a CNC bridge mill from alibaba and expect it to unbox it and just have it work. You'd expect to have to install it, level it, set it up, calibrate it, integrate it with your design workflow etc. etc. etc. Industrial sewing machines are just like that, except that most people don't have expectations of CNC mills that come from having a small domestic model that they can take out of the box and have Just Work (not that that wouldn't be awesome, mind you!). The other thing about industrial sewing machines is that by and large they get set up to do one thing, and they do that one thing day in day out until they're completely worn out. Factories that need more than one type of seam sewn that requires a different weight or colour of thread, or a different length stitch, will buy a separate machine to do each thing, because doing that is cheaper than interrupting workflow to reconfigure a machine. You can see this in the depressing videos of Chinese jeans factories. That's where small single-maker shops are different, for someone producing bespoke goods in limited numbers an extra machine represents a significant outlay, and if you've only got one machine operator, the time lost reconfiguring the machine is comparatively small. Even so, most folks will have two or three industrial machines of different types for different work. Factories that employ tens or hundreds of these machines have in-house mechanics whose full time job is looking after them. They guy who starts the narration of this great video about Puritan machines does nothing but service them for the shoe factory that uses them. Puritan machines haven't been made new for years now. The dealers do ask for samples, and do do extensive testing of the machines before they order lots of them and put their brand on them and part of their process with that is working out how much work they need to put in to set the machine up and get it sewing properly for the work the customer wants to do with it, whether they can get the factory to manufacture the right sort of feet and plates and so on, and what the quality control coming out of the factory is like (it varies hugely from factory to factory). Something that isn't obvious at all to folks who learn about 441 machines from this forum is that they were never designed as heavy leather stitchers. They're designed for heavy textile work, sewing things like cargo parachutes and harnesses. There are even ones that are specifically set up to sew cloth polishing wheels. They were first set up to sew leather by Ferdco, and the guy who founded that company patented some of the modifications that are required. That was about 20 years ago. To set up a 441 to sew leather you have to swap out the feed dogs, needle plate and presser feet, you also have to set it up for thick thread, make sure you're using properly aligned leather point needles, and power it with a low-speed high-torque motor. I hope that helps a bit. -
Yes, that's exactly what I mean. Out of the box it had been assembled, but that's it. It wasn't timed and the feed was out of sync. -
Your No.6 will do pretty much anything in leather that a Cobra 4 will do unless you're running into the limits of the throat depth (in which case a Campbell Randall will be worse) or you need to sew right up at the edge of funny shaped things that can only be done on a cylinder arm machine. I had a No.6 and I regret letting it go.
- 18 replies
- cobra
- campbell bosworth
(and 1 more)
I bought a machine direct from China. It was a Hightex brand, which is what Cowboy machines are called outside of the US. The short version is this: If you are buying this for use in a business, buy one from a local well-respected shop who will set it up and support & service it. Buying direct from China is a Bad Idea if you need the machine up, running, and making money in a specific timeframe. For me, as a reasonably mechanically competent amateur who has torn down and re-built other machines, it was worthwhile. The cost was around half of what it would have cost me to get a machine from Cowboy or Cobra shipped to New Zealand, but if I were in the USA it is not something I would consider. I bought via a reseller here, so as a private individual not a business I had the benefit of NZ's strong consumer protection laws if it went wrong, but even so It was almost 5 months before I had all the parts I needed. Because of screw-ups with the shipping I didn't get the correct motor and speed reducer with the machine and it took ages for them to arrive. It took me a full day to clean the shipping grease off, assemble the stand and table and get the machine mounted and oiled. There were no instructions at all, and the assembly of the table was non-obvious (which is to say that the holes drilled in it matched neither the machine nor the stand, and I ended up building a new table). After that it took me many hours to get the machine timed, feeding properly, sewing in the same holes in reverse that it did forwards, and so on. I was lucky, my machine wasn't missing any bits, came with all the feet I needed, and didn't require a total teardown and rebuild like the Hightex 441 another NZer on this forum bought. Even without any major things going wrong with my machine mechanically, I would have been completely screwed without the Juki 441 engineer's manual. Even with that it was tricky getting the machine set up because the timing marks the Juki manual references don't exist on my machine. If you're comfortable with tearing down and re-building walking foot sewing machines and you know how to time them from scratch and you have the time and tools to do so, then getting a machine direct from China can work, but it's a gamble. You can't count on getting any kind of support from the factory, and as Wiz has pointed out getting the additional harness feet is expensive and they aren't guaranteed to fit the specific machine you end up with. -
American Straight Needle Parts Needed
amuckart replied to catskin's topic in Leather Sewing Machines
Bob Kovar at Toledo Industrial probably has, or knows where to find, what you need. -
Downloadable Manual For Pearson No.6
G'day, I'm glad you found the manual useful. Yes I think you did buy some post beds from me. I hope they worked out Ok for you. You can get 331LR needles in size 230 only, from Sewing Supplies in Auckland. I dealt with them by email and they were always really great. Do you have photos of your machine? -
Issue With Consistent Stitch On Cobra Class 18. Help!
amuckart replied to Boa's topic in Leather Sewing Machines
Is it the top thread pulling the bottom thread up, or the bottom thread pulling the top thread down? If your thread path is Ok, and your tension on the top is working Ok, it might be the bobbin winder or bottom tension. If your bobbin thread isn't wound absolutely consistently you could be having issues where the tension is 'spiking' due to uneven wind. -
Yep, I'm coming to realise that the threads in this machine are a bit special. That really surprises me because I figured that at the point where you're cloning a machine it would just be easier to use a common thread standard instead of having to replicate whatever weird ones the original manufacturer used. For that matter I'm a bit surprised that a late 20th century machine still uses all those weird threads. I've got a parts list for the TSC-441 and it's a mix of metric and imperial and god knows what.
- 11 replies
- 441 clone
- cowboy 4500
(and 1 more)
