Everything posted by Bob Blea
From the album: Northwest Style Floral Notebook
I love this shell design on the back. It traces it's history back a long time in saddle decoration. It was easily made with just a few tools, often only a single veiner was required. A saddle maker without much artistic skill could stamp a shell pattern on a saddle and get a really nice effect without taking a great deal of his time and effort. -
Note the places in the vine work where the vine splits off in two directions, leaving a teardrop area between the vine. This is one of the hallmarks of the Northwest style. -
This style is very similar to the Sheridan style, though the shading in the flower petals and leaves is handled a bit differently. The layout and flow of the design is different from Sheridan style too. I enjoy lacing so almost all of my notebooks are laced around the edges. It takes a lot of time, but I really like the effect.- 3 comments
- northwest style
- floral carved notebook
(and 1 more)
Try contacting Barry through his website. I know he does ship internationally, and he can probably tell you what the shipping costs are. He is very responsive and he (or someone in the shop) will get back to you quickly. Bob
Floral Award Bronc Halters
Bob Blea replied to Double U Leather's topic in Saddle & Tack Maker Gallery
Really nice! I can really appreciate how much of a challenge it is to tool flowers that are small like these. Yours turned out great. Bob -
I like them both. Don't see many saddles like that first one! Bob
Hello and welcome to the forum! I make quite a few notebooks and journals. I found it works best to fold the leather as soon as I finish carving/tooling the cover. The leather is still moist from casing at that point so it fold easily and will hold that fold once it dries. I then give it a good coating of neatsfoot oil. This restores some moisturizers to the leather and it is less stiff and more flexible. I make sure the spine area gets a good coating since it will do all the flexing over the lifetime of the notebook. Just make sure you use it sparingly. A little goes a long way. I haven't used Resolene as a finish, so I haven't had any experience with it flexing, but I know enough about it to agree with billymac above. I apply several thin coats of Wyosheen to my notebooks prior to antiquing. After antiquing, I have a spray on acrylic coating (similar to Resolene) but it's thin and just there to protect the antique and give some moisture and UV protection. If you thin down your Resolene (you should always use it thinned 50/50 with water) and put it on sparingly, it will probably flex OK. Hope this helps, Bob
- 4 replies
- leather journal
- leather notebook
(and 4 more)
Hello, You want to make sure you are striking with an even amount of force every time, and if the leather is too wet it will be hard to make even impressions. Do you have any pictures you could post as examples? Bob
I hope you didn't get too much of your leather damaged. Maybe you can find projects for the stained parts where you can dye them and hide the problem areas. Bob
With seats like that I'm sure you will get lots of attention. The seat looks great! Bob
No Longer A Leather Virgin!
Bob Blea replied to haervaerk's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Not bad work at all, you should be proud of your first attempt! Welcome to the forum. Bob -
The Utility leather sounds like Latigo, which does have a lot of oils added to it. I know you don't want to store latigo with veg tan because the oils (and the dyes) can bleed out into the veg tan, and I think that is what happened here. I haven't worked with latigo much and I don't make things out of it, so I can't say what risk there is in the oils getting on your customer's clothing. Hopefully someone more knowledgable on that issue than me could answer that. Bob
Craftool Pro Stamps/tandy Sale
Bob Blea replied to AllAroundRider's topic in Leatherwork Conversation
I've looked at the new stamps and they look good, I also have read a few comments here that they are pretty good. On sale they probably are a good buy, though when not on sale in general the Barry King tools are cheaper. If I were upgrading the first things I would get would be bevelers. They are the most important good tool you could have. Next would probably be the undershot bevelers or petal lifters, as they are pretty important to getting the Sheridan style leaves and flower petals. Also, I think my floral work got a lot better once I discovered what a center shader could do. Add to that a good veiner and you are probably all set for a lot of things. For knives, depends on how much you want to spend. I started with a tandy round knife a year later I bought a Leather Wranglers round knife and found out how unsharp my tandy one was. The Tandy knives, especially when on sale, might be a good place to start IF you can sharpen them properly. Hope this helps, Bob -
I would love to know how you do this too. I've marvelled at the quality of stamping I've seen on some swells, especially when they use tools like the crazy legs that I have trouble doing on a flat square surface. I would love to know if there are some tricks to this. Bob
Wayne Jueschke in Elko, NV makes excellent geometrics, though most are probably are not going to be under your $80.00 limit. He doesn't have a website by you can request a catalog by calling (775) 738-4885. Bob
That stamp is commonly called a 'tri weave'. There was a discussion on here a long time ago about it. Took a little searching but I found them again. http://leatherworker.net/forum/index.php?showtopic=4459&hl=%20tri%20%20weave%20%20stamp&st=0 and http://leatherworker.net/forum/index.php?showtopic=24009&hl=+tri%20+weave%20+stamp#entry152869 I don't recognize the stamp you have but it looks like a good one. They are definitely one that takes skill to run well. i have one and it is a craftool, but it actually works pretty well. You will want to check yours to make sure it is symetrical. Sometimes the lengths of the sides are not always the same so if you turn the tool it will give you a different impression and things won't line up. Try stamping it in cased leather, then turn the tool 120 degrees and stamp in the same place. If the impression doesn't line up the second time (at least around the edges, the center doesn't matter much) then the shape of the tool will be a problem. If that doesn't line up, it's not the end of the world. You just need to know to keep the tool always oriented the same way when stamping. The threads I linked to have some info on using this stamp and problems with them, maybe they can give you some help too. Unfortunately it's one of those geometrics that takes a LOT of practice. Hope this helps, Bob
Dying - Resist Techniques Fiebings Dye (Not The Oil Line)
Bob Blea replied to Tenleytown DC's topic in How Do I Do That?
You should be able to find Woodland Scenics liquid latex (or other brands) at any hobby store that has model railroad supplies. I have also found it at Hobby Lobby and at art supply stores. It's commonly used to make latex molds. -
2Nd Photo Album Done
Bob Blea replied to Double U Leather's topic in Books, Journals and Photo Albums
Fantastic work as always! I always look forward to seeing your posts here. Bob -
My New Round Knife From Leather Wranglers
Bob Blea replied to Cyberthrasher's topic in Leather Tools
That's a fantastic knife, I know it will work well for YEARS! I bought one from Paul last year and love it! Bob -
Nice idea, thanks for the tip. Bob
Hello Spartan, Tandy used to make these backgrounders, but they were discontinued about two years ago when they eliminated many of the old figure carving tools. They will probably be hard to find used since they probably didn't sell that many (you don't see them used very often anyway.) Check ebay tool auctions, and also there is a site dedicated to selling used leather stamping tools, www.usedleathertools.com. I just looked there and didn't see any of these listed. For new ones, I know Robert Beard makes them but he will have a long lead time. Clay Miller could probably make them if he doesn't already. Other than that I'm not sure where you would get them. By the way, I see I forgot to mention what the customer ended up choosing. Turned out he liked the effect of the large figure beveler. Bob
Sunflower Photo Album
Fantastic work, especially for you first time around with a sunflower. I had seen several notebooks and saddles with sunflowers on them over the past couple of years and every time I think I should try making something with a sunflower. Yours turned out great! I see what you mean about the seeder too. I hadn't considered that little problem! Bob -
I think it's looking good! Bob
Great info, as I've been thinking of sending along a conditioner as well. One (dumb) question: Where do you get virgin beeswax, other than asking around the bee hive? Bob
So I've been meaning to follow up on this and post the solution I eventually came to. It was a much more elegant solution that trying to tap out the hole in the concho. I realized that part of why this didn't look good was because the snap itself had a small ridge on the back that make it look like it was standing away from the leather. Add that to the overall height of the snap and it really stands out and makes the strap stay well away from the notebook. My solution was to use two layers of leather for the strap. The inner one is about the thickness of the body of the snap and I punched a large enough hole so the snap could fit down in it. I also used a thicker piece of leather for the outer strap so the screw would sit properly. The first picture shows all the parts and the other show the assembled product. I haven't glued the strap together yet, I was just test fitting everything. Thanks again for your help.
