Everything posted by Bob Blea
First Time Leather Worker - First Holster
Bob Blea replied to katsass's topic in Leatherwork Conversation
Thank you for taking the time to put this tutorial together! Bob -
Hello, I had a potential customer ask me about different matting effects I could do to cover a large area on a notebook. The whole back will probably end up being matted with no other carving. I made up a set of samples of my matting tools on a piece of scrap and sent it to him to see what he likes. I realized that this certainly can't be all the matting options out there, probably not even a good start. So here is what I know how to do, how about the rest of you. Any neat matting effects you would like to share? Any unique ways of using tools that were not intended for a matting effect, like the pear shader below? The tools used here are (left to right) a Beard pebbler, Beard checkered matter, Two modern Craftool Byrnes matters (big and small), a modern Craftool (medium) pear shader, a vintage Craftool (large) figure beveler, a vintage Craftool backgrounder, and two Craftools that I'm not sure what they were called. The one on the far right may have been intended as a small flower center. If you have any neat ways of matting large areas, please share some pictures! Bob
Hello, If the leather you are using is a veg tan type you can burnish the edge. There is a good tutorial on doing that pinned at the beginning of this forum. Otherwise, a laced edge would probably look good. Bob
Try contacting Robert Beard at Pro Tools. He just made a pretty realistic set for me. I'd post a picture but don't have one available at the moment. Bob
I'm with you on the zippers! I've only tried it once with a small one on some scrap and it came out horrible. I need to practice more but I don't have much enthusiasm to start a project requiring one! Really anything that requires hand sewing is scary to me, it doesn't come out very well. I just need to practice a lot more on that too. Bob
I really enjoy the carving process. I used to get somewhat nervous about finishing, but I don't worry too much about ruining a project at that point. The part I look forward to least is the actual assembly and construction. I don't have as much confidence when it comes to hand sewing or building big projects, so the final assembly isn't my favorite. Also, it lacks the creativity that the carving stage does, so it doesn't appeal to me as much. Bob
2 Pocket Card Case
Bob Blea replied to hunio's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks good. I like the way the closing flap works. It looks very professional. -
Hello, I wouldn't call it tiny but I mainly use a small beveler from Barry King in Sheridan, WY. It's about an 1/8th of an inch wide and I don't call it tiny because I still run into places where I wish I had a smaller one! Barry now makes one that is half this size and usually once a week I kick myself for not buying one at the Sheridan show in May. Barry also makes belevers that have curved faces so they are easier to bevel tight curved lines that may help you. Barry King tools are pretty reasonably priced, but if you think this is going to be a one time thing and don't want to spend the money, you could in theory grind a nail at a 30-45 degree angle and have a reasonable smooth beveler. You would probably want to round the edges to make it easier to walk, but it could be done. Bob
Hi Rory, When I first started out in leatherwork I had the Leatherwork Manual too. It's a great book and I still refer to it from time to time. I wanted to make one of these key cases but didn't know where to find key attachment. Now I know, thanks for sharing that. I like how it turned out. The inside looks like suede, did you dye the flesh side of the leather to get that look? I recently ran into the same lacing problem you are describing, but didn't have a good solution for it. We were re-lacing an old gun belt and holster that is a family heirloom for an Aunt of mine. When it was made, it wasn't lined but it was double loop laced it's entire length. So, when it comes to splicing in a new piece of lace, you can't hide the splice inside the lining. We ended up placing it under the lacing on the edge of the belt and it looks fine from the front but it left a break in the lacing pattern on the back. We had similar problems ending the lace. There must be a good way to do it, but I didn't come up with one. I would like to know too if there is a good way to do this. For this sort of project I would just add a pigskin lining. I have lots of it and could probably do it with scraps on hand. Barring that, is the kep drop mounted on a piece of veg tan leather? You could start and finish your lacing at the bottom of that piece so there would be a place to hide the ends. you would just need to start with enough lace to get all around the project with one piece. Bob
Very nice work as always! I like what you did on the spine. Bob
Painting Leather
Bob Blea replied to Curley Fryes's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I've always painted them dry. You could probably still paint the leather if it was only a bit damp, but the colors might bleed since water will thin acrylics. -
Really nice effect lightingale! I've got to try this on one of my notebooks! Bob
My First Piece Of Jewelry
Bob Blea replied to immiketoo's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks good! How did you color the leaves to get the nice fall colors? Bob -
Background And Bevels Just Don't Stay Down
Bob Blea replied to c2369zulu's topic in Leatherwork Conversation
Looks like you may be carving your leather too wet. Also, are you re-wetting the leather a lot during carving, or maybe soaking it as you form it after carving? Bob -
Purchased Some Bk Tools, What Should I Get Next?
Bob Blea replied to Vianeth's topic in Floral and Sheridan Carving
After you get the items listed above (particularly the center shader and leaf liner!) you might want to think about getting quality flower center stamps. If your craftool ones are the older ones that leave a good impression this probably isn't very important. In my case, the ones I've bought from Barry King are far better than what I had and they are now pretty much all I ever use for flower centers. I also agree with having a few different sizes of veiners and thumprints. They come in handy. Bob -
New Wallet Horse And Oak
Bob Blea replied to volpert's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Really nice carving! I really like the horse, and your leaves came out good too. Bob -
Looks great Hunio. We just recently started seeing that type of ring binder here in the US. I bought one this summer because I realized I could make a really nice cover for that kind of notebook. I really like how yours turned out. I will have to get on making a floral carved version for me! Bob
Tote Bag
Bob Blea replied to Crystal's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Really very very nice. Bob -
Various Types Of Sealer That Won't Rub Off On Flesh/clothes
Bob Blea replied to Casm's topic in How Do I Do That?
Thanks, I thought it was cut with water but couldn't remember and could find a link to the original post. I'm playing with finishes too right now so this helps. Bob -
Thanks for posting Pete! I'll give this a try. Bob
Not a dumb question at all. Mop n glo turns out to be an acrylic sealer and some members here use it as a final seal (in place of resolene I think.) I have never used it myself but it's cheaper than resolene. I don't remember if it needs to be cut with water or if you use it full strength, but if you search around in the finish forum you will probably find references to it. I tried searching for the term 'mop-n-glo' but couldn't find posts on it. You might try searching on acrylic finishes and see what comes up. Hope this helps, Bob
