TonyV
Everything posted by TonyV
I second this motion. There are also a lot of Youtube vids that teach holster making from the very simple Slim Jim to extravagant carry rigs, tooled, reenforced, etc etc. Start reading and watching. When you have more questions, there are several on this forum that can help. But first, a suggestion. The basic steps, and basic tools of holster making are not a lot different than the basics of any other leather project. If you can make a simple wallet or belt, you can make a holster. A holster is not much more than a pouch, anyway. Go for it!
Shoulder holster for a Ruger speed 6
TonyV replied to Hags's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice desigh, I like it. Did you use rivets or chicago screws to attach the holster to the strap? -
It's all a matter of personal preference. First, a stiff gun belt helps distribute the weight of the gun all around the hips. Lighter, more flexible belts let the gun's weight hang all in one spot. Hard to wear all day. Modern belts are often heavier, and sometimes with a plastic stiffener between the lining and outer layer. This adds complexity and expense to the build. Unless you wear a gun and reloads all day, it's probably overkill for most people. If you're looking to build an authentic belt that's only being worn on occasion, think simplicity, quality and economy. Use a good quality veg tan about 9-10oz or thicker. Some people like a liner, some don't, but a 2-3 oz veg is what I might use if I did choose to line, which I only did once. The flesh side or rough out can help the belt from slipping around, but that doesn't require a liner, just use the flesh side of your strap for that purpose. I've seen several historical gun belts and they run the gamut of thickness, lined or not. I don't bother lining belts. In a holster, preference is still in play. If you line it, be certain it is veg, not chrome. Some people use a suede liner (again, be certain it is veg, not chrome. The mineral salts can contribute to corrosion of the gun) because it helps with retention. Some prefer a smooth liner to help a faster draw, and rely on a hammer loop retainer, which I feel is more authentic. I've built a few Slim Jim holsters, all unlined, open toe, loop thong to go over the hammer.
Blue grey dye
TonyV replied to rcon1991's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Manufacturers often use custom made colors. You might want to blend your own color to match. That color looks more gray than blue, so I would start with gray and tint with blue to suit. The only gray dyes I've found are in water-based dyes. RIT dye, generally a fabric dye, is a water-based dye that can be used on leather, and they have the widest range of colors that I'm aware of. -
Beautiful rig! Gore's oakleaf and acorn work is always top notch. The whiteness of the grips is simply because they are natural ivory. The whiteness is what made ivory grips and ivory piano keys so desirable. Yellowed ivory is old and dirty, aged and stained. If that's what you want, give them time and lots of use. Or, set these aside to save for special dress use and replace them with artificial grips that look like old ivory for range use.
The edit button is in the dropdown you'll find by clicking the 3 dots in the upper right hand corner of your post. Once edited, the Save and Cancel buttons are in the lower right, below the message frame.
Yeah, lettering is a challenge, especially at first. Spacing, centering, whether to use decorative cuts or not, stamps or freehand... A body could use up a couple good bellies practicing. Glad you're back in action. I'd wear that belt, but my name ain't Mullins
Check out the Patterns and Templates subforum here. Lots of sharing going on. Can't find what want? Ask. Just might find what you need.
Leather makes everything better!
ON Gutenberg.org there are a few books published in the 19th and early 20th centuries dealing with leather tanning. Some get quite scientific. You will find that the principles of tanning really haven't changed all that much over the centuries, mostly the equipment and techniques have been modernised. For example, tumbling drums might have been powered by water mill, men or mules 800 years ago, powered by steam 200 years ago, electricity 100 years ago, but the tumblers are very similar, built of wood 800 years ago, now built of metal. Dyeing was, of course, done with natural dyes like walnut and other vegetable dyes, vinegaroon, perhaps some mineral dyes, or painted with the paints and tints of the time. The paints used on a shield would likely be the same paints used on the scabbard. Dyeing would have been a very expensive option to one buying leather. Don't forget that oiling a piece of leather will darken it quite well, making a dye unnecessary in many cases. Gutenberg has old books on dyeing, as well. 'Dyes and Dyeing' by Viscount Exmouth Charles Pellew has a chapter devoted to leather staining and dyeing. Mentions acid dyeing for different colors.
Dwight is spot-on there. As long as you're not planning to bone in the fine details of the gun, a similar pistol will work. I used my Taurus 709S 9mm to make a purse holster pattern for my daughter's Sig P365 .380 before she even picked it up. I had to use some plastic wrap to give my pistol a bit more bulk, about 1/16 in all around, but it fit just fine when I gave it to her. As for revolvers, this method can work, too. Several years ago, before I picked back up the leathercraft habit, I bought a Bianchi holster that was made for a S&W 3in J-frame to use for my Ruger SP101 3 inch. It was a very tight fight and took some effort to work my revolver in, but now it fits like a glove.
I don't usually use half round cutters for strap ends, but they come in handy for cutting inside and outside corners, such as you might find on holsters and other items with lots of curves. They can be a PITA to keep sharp and honed, but when they are sharp, they are easy to use and make clean cuts. They've earned a spot in my toolbox. Hole punches can't cut outside corners, but they can do inside corners and the round ends of oblong cuts. I use well-honed wood chisels to finish the oblong cuts. I think quarter round punches would work best on strap ends.
The term 'ounces' relates to the old measuring method of leather in 'ounces per square foot', which worked fine in English speaking countries, really doesn't work well in most parts of the world these days. MM thickness is used in most of the world now, but 1/64 inch/ounce is still commonly used. No idea what part is in your pic. Possibly a damaged snap. Rivets, glue and sewing are used where you want permanent attachment in your project. Chicago screws are used for assemblies in which you want adjustability or replaceability in your project. They are like a rivet that screws together. Snaps, zippers and buckles are for frequent opening and closing. Start out learning to hand sew on small projects. It's a valuable skill to have. Even many machine-sewn projects can have hand sewn parts. Sewing machines can be very expensive and can be a separate hobby to themselves, but are often necessary if you have a lot of stitching to do or if you plan to make any money in leathercraft.
Sheath for curved knife?
TonyV replied to DaleksInc's topic in Gun Holsters, Rifle Slings and Knife Sheathes
There are different methods to fit the welt; 1-cut it out the shape you need. 2-wet form it. 3-Cut out darts (small triangle pieces) to allow the sharp angles to bend. Check this video. -
You would make a sheath for that knife about the same way you would make a sheath for any knife. Trace the shape and go from there. The blade would follow the shape of the channel inside the sheath. -
If it made economic sense to utilize the nearly 3 million feral camels in Oz I'm sure they would. I know that some of the culls are used for pet food, but they have to process the meat immediately. The processor has to actually be on site when the camels are shot, and they can only take a limited amount at a time. Not so easy when you have million hectare + stations to run, with very limited water and grazing available in that desert environment. The trailers, stockyards, fences and other equipment that are designed and plenty strong for cattle are just too small to manage camels, which are much larger than cows. It would require an entire new setup and more manpower to wrangle them successfully. Not to mention Ozzy laws and regulations. I agree it seems wasteful. I have had a camel steak and it was very tasty and tender. Camel leather is reputed to be both soft and strong and there are thousands of hides left in the desert to rot. Ah well, worms and buzzards gotta eat, too. And I have wished for camel leather on occasion myself.
Agreed, a great start. Leather has a very broad spectrum of interests. This forum covers most all of them with very knowledgeable people wjilling to help.
Quick Shine's MSDS sheet describes the product as an acrylic finish, "Opaque, white acrylic" Propylene Glycol and Tributoxylethyl phosphate are the listed hazards. Mop n Glo lists Diethylene Glycol monoethyl ether. Both are acrylic finishes, so if the odor is what drives your choice, pick which ever pleases you. I have no idea which would be the superior product on leather.
What am I missing... Or am I missing anything?
TonyV replied to LRBespokeGoods's topic in Floral and Sheridan Carving
You might need a bit more moisture, depending on what you mean by "little damp". We can't get a burnish with the stamps unless there is enough, but not too much, moisture inside the leather. There are many different methods to case the leather, a simple search of "casing leather" on youtube will give you plenty of options, but most of them agree, get it damp enough until it doesn't absorb the water quickly, and then wait long enough for the leather to begin looking like it's dry. Of course, too much moisture has its own set of problems, like mushy imprints and cuts, but judging from your statement, I would try more water and a bit more time to let it penetrate to the center. Trial and error will find the right moisture level and technique. -
Thanks for your hard work Johanna
Hacked? I would be more concerned about our data security than the appearance. Just my 2 bits.
She will be proud to use it. Great job. Erin go bragh
Very nice. Worthy of the finest handmade arrows and bow.
hmmmm... leather scented leather soap
