And now, for something completely different...
bruce johnson replied to TomE's topic in Saddle and Tack Accessory Items
Looking good! -
Modifying standard tools to Sheridan tools?
bruce johnson replied to mhein68's topic in Floral and Sheridan Carving
Yes, he is. He shows up on my Facebook feed occasionally. Just looked and he posted something 10 days ago. I don't know if his phone number is the same anymore or if he does emails. We used to talk a lot, but haven't talked for a couple years. -
Is your test piece the same leather and thickness as your project pieces? If so it's odd that the test piece sews that much differently than the project. Needle size and thread size appropriate? Same bobbin on the test piece and project? Thread path not binding on top and thread coming off the top spool cleanly? These are what I check first on our machines. Otherwise I'd be on the phone Monday with Vince and have him talk you through it.
Welcome back Bill! Glad to see you are still active in leather
If the red is the plastic coat dip it should peel right off.
Here’s a couple things to think about. I heard of one person last year who called Tippmann’s directly. They either had one on hand or coming in for refurbishing and the price was good with the warranty they give after refurbishing. It would be worth checking with them. As far as buying online from a private party, be VERY cautious! It seems like the Boss is one of the most common things that scammers list. Good price, story of “found in a storage unit” or “bought last year and hardly used it” . Super cheap pricing and never comes through. If you do find one, do not pay by any method that doesn’t give rock solid buyer protection.
Ron has never been a member of this group. Pretty much his writing and advice was all in the old IILG email group and they rejected a forum format in favor of remaining an email list group. (one of the reasons for the formation of this group however many years ago). I am pretty sure the IILG information and archives have all been lost when that group disbanded. Ron is still alive although I have not talked to him for a couple years. -
Probably the biggest modifications are these: - flower centers - grind a bevel around the outside edge where those radiating lines are. - Thumbprints - narrow up pear shaders into elongated shapes with straighter sides - Veiners - Thin them down from the back edge to make the impression thinner and more refined - Cams can have the corners ground and made into crowners - Bevelers - steeper angles to enable beveling stem work without mashing down adjacent lines. Typical bevelers are about 15 degrees, Sheridan bevelers are around 30 degrees and steep Sheridan bevelers can go 40-43 degrees. - undershots/lifters - can be made from shaders with some serious grind work. - Flower center bevelers can be made from vertical line shaders, shape them like a thumbprint, then grind one end to be slightly concave for a center beveler - Leaf liners can be made from vertical line shaders too. Grind them pretty much like you'd make a thumbprint then grind a flat angle on one end. Then make another with the opposing angle Most of us tried it 20+ years ago, we had to. Back then the sources were pretty tight - Don King and Bill Woodruff were the major players, Barry King was just getting going, Walt Fay was making some. You pretty much had to go to Sheridan to buy them early on. The stamps were limited in number and demand was there. Don, Walt, and Bill are gone (and those original stamps have had a 5-15 fold increase in price now). Barry King has a ton of options now, Clay Miller makes them, Horse Shoe Brand and Richard Brooks have recently stopped making stamps but made them. William Klutts is making some again. Wayne Jueschke makes really nice flower centers. Craftool Pro from Tandy has had a couple runs at Sheridan stamps. I am forgetting some makers here, and not intentionally. It is fun to make your own, but if you want to skip the learning curve and time spent on them, these options are there to buy them ready to go. -
What tool as far as you know doesn't exist but you wish it did?
bruce johnson replied to x546JP's topic in Leather Tools
Kind of interesting. I bought an early Boss 24 or 25 years ago. I loved the winder that fits a hand drill. Ordered a couple more winders as spares. I tension the thread between two fingers and can go back and forth to level wind bobbins like an old bait casting reel. I tried the bobbin winder on my 205-64 and Ferdco 2000 and still liked my hand wounds better. same on the 1245. My wife has a Cobra 26 and I wind all her bobbins by hand drill. Would not go back. Everyone is different but that’s just me. -
Old round punches - yard sale finds - need some TLC
bruce johnson replied to Sprocket's topic in Sharpen it!
First off if the edges are irregular you need to square that up. Open side down on abrasive paper until you get a flat edge all the way around. Then when you hit the edge to the belt you need to already be rotating the punch in your hand. Same for removing it from contact with the belt. My angle is slightly higher than the coning of the punch to make a slight secondary bevel. Anytime you leave the punch sitting against the belt without rotating it you can create a flat spot at worst and thin spot at almost worst. Watch how the edge develops. Magnification is your friend to see closeup and get an even edge thickness. (Optiviser with a #5 plate is my usual choice for punches, #10 for finer work) As the flat edge gets thinner and thinner you should be going to finer and finer grits to refine the edge and remove grit marks from the outside edge. The final abrasive should complete the bevel and make a fine burr on the inside of the edge. I use a diamond file to remove that burr. I polish on a sisal wheel with black and then green compound, sometimes go on to purple. Wipe the burr off the inside again and polish some more until the burr fragments are gone. -
At this point until I retire (1 years and 13 days) I sharpen anything bought from me for the cost of return shipping but don't take in much outside sharpening. That said, if you just can't find anyone close then let me know and you can send them to me to sharpen up for you. -
Unless your 1x30 is variable speed there is a good chance it won’t be easy to do them on it. I sharpen these type punches on a variable speed belt grinder on really low speed in a slack belt section. Hit the edge already rotating the punch and never let it sit. I work the burr off the inside with a tapered diamond file. Go through the grits and then polish with a few compounds to remove grit lines and get to my final edge. -
Tippman Aerostitch - More Help
bruce johnson replied to MagnusWyvern's topic in Leather Sewing Machines
I would Call Tippmann tomorrow. They can either tell you and may be able to send a manual. -
Mauls I have had - CS Osborne rawhide, Maul Master I, MaulMaster II, No names, Imports, Barry King, Bearman, Clay Miller, Bob Beard (yes he made them back in the day), Don King, handmades, and Wayne Jueschke. Mauls I sell - Wayne Jueschke. I am just going to concentrate on the Jueschke mauls. The handle - stacked leather and good ergonomic shape for me, stays in place in my hand doesn't transmit vibration. It is long enough to give a nice rebound action in your hand if you do the crosshand rocking wrist style of hitting. Head material - grippy without being rubbery or bouncy. Quiet when you hit the stamp. Bench is solid with a 3" thick rock and you just don't hear much. Weight - weight is toward the head, not neutral. That deadfall effect makes tooling much easier and in the case of walking stamps - faster. You are not "hammering", the maul weight does most of the work They can weigh the same as other mauls but have a heavier effect due to that head weighted balance. Durability - likely among the longest lasting. These are a few of the mauls in our shop - two Jueschkes on the right are around 18 years old, used for high volume work, the one of the left is maybe 6 years old - one of the first 12 mauls when he started making that size. Price - probably the highest initial price non-custom leather handle mauls available Value - That 1# maul in the center has conservatively 300,000 strikes (likely more). Cost per strike is around 0.0003$/strike. Still no flaking, chips, or surface wear to the head, handle is good and nothing loose. My experience....
Leather bag business asset sale, Selling it all for cheap!
bruce johnson replied to BibiBielat's topic in Old/Sold
Unsolicited testimony - If anybody has any doubts, I have bought some things from them. I can vouch that they are legitimate and easy to deal with. It is all what they say it is. -
Fred, some people mount small motors or hand cranks on the bobbin winders that are designed to ride against the belt of the machine. My Boss came with a metal stem split on the end and goes in a drill to wind bobbins. Easy to use and 20 plus years later I have still never used the built in bobbin winder on a machine. -
Not the easiest to explain. I’ve seen some video clips and pictorials but none I can lay a hand on right now. Basically here goes. The cantle is shaped and trimmed. The “bumps”are usually made with a filler like sash cord. Holes are spaced and punched through the three layers. The sash cord is whipped through the holes and around the back edge of the cantle. The cantle binding is fit up on top and pulled over. The binding has to be cased or tempered up right to be molded over the sash cord once it is stitched down. Rawhide can be fickle to work with to get the moisture just right. Mold with sticks, rods, whatever to get that definition of the cord underneath. Slits are then cut through the 5 layers for the lacing between the sash cord bumps. The lace is tacked underneath at one end and whipped through the slits and pulled down tight. This is another no fun part of it and wear gloves. Tack the other end.
My personal favorites are Gomph round back edgers.
I’m with Mike also. Slightly damp is much easiest and smoothest if you have a sharp edger. Dull edgers tear, push, and chatter. As far as what type edger - I doubt that very many people have used as many different edgers than me. Each has an advantage - might be lower price, ability to hold an edge, cuts a flat or rounded profile, easily obtainable, pretty or matching handle, or what ever. My number one criteria is ease of sharpening. Doesn’t matter how sharp they come new, they need to be maintained. Sharpening might be on optional skill if you cut with a utility knife, but there are no disposable edgers I am aware of. I want the top and bottom of that cutting edge to be easily accessible to sharpen.
LOL, only 63 years young. These catalogs mostly came with old sets or bought on EBay
My Mast press takes 3/8 dies. The Weaver Little Wonder hand presses I have sitting here take 3/8 dies also they should be pretty available. It looks like Weaver is only selling their Master Tools foot press now. Another source for dies is Beilers in Ronks, PA. They still sell foot presses similar to yours, Amish business with no website but they send out catalogs.
- 4 replies
- mast harness hardware
- foot press
(and 3 more)
Exactly right! When they grab and throw a tool it is exciting. I reverse the buffers on the cradles so they rotate away from me on the top. I work off the top of the wheel where I have better visibility of the edge and maintain a more consistent angle. I have arrow stickers on the top of every buffer showing the direction of rotation to keep it in mind. When I had a helper the arrows reminded him these are opposite of most shops. I don't throw tools like I used to for sure. when I do it is thrown away from me and not into my lower body like it was before I reversed them all. The wheels I had the most problems with grabbing a tool are the airway pleated wheels. The chrome detailers, refurbishers, abrasive dealers all told me how great they are - longer life, hold compound better, run cooler, etc. Buy them, guarantee you will like them they said. I bought a decent assortment of airways and I was throwing tools like a monkey throws poop. Those pleats were like hands grabbing the back edge of a knife or even a shank on a handled tool like a creaser. My shop helper found jobs in the other shop areas. I figured I was in the learning curve and mucked ahead. After a week I was not much better - gave up and took them all off.
I've done a bunch with hair-on. I have used them for bags and pillows some. You just have to know you can walk on these for years and no hair slips. Put it on the back of a bag and a ladies purse will be bare in the 3-4 months from rubbing against them. I don't know why that difference!. I mostly used them for inlays on rope cans and bags, notebooks, restaurant menus and wine lists, and bigger things. I did a few hundred contract belts with hide inlays too. I like working with hair-on a lot but It can be messy. Pattern cut from the flesh side. Pay attention to the lay of the hair and how it will be oriented on your work.
Seems like a good time to bring out the OSHA-like safety poster I made up several years ago for the door to my tool working shop. It is laminated and still there for a daily reminder.
The Rocky Mountain Leather Trade Show is coming right up on May 17-19. Classes start earlier in the week and continue through the show. This is the biggest leather trade show and continues to grow. Last year there was a last minute change of venue and some learning curve there but the Leather Crafters Journal has smoothed out the bumps and this year's class selection and vender layout looks to be great! Classes, informal BSing and socializing with a world wide attendance, the Leather Debut Show of judged entries will knock your socks off, and lots of venders. I am starting to pack tools today and we have the same location as last year - first hallway near the entrance. Lots of people in this group use a screen name but if you are there, please stop by and introduce yourself! Free stickers and the famous 6 inch Bruce Johnson Leather Tools rulers are free as well, plus a regionally famous candy dish. Oh yeah, we will also have a good selection of refurbished and new leather tools. Here is a link to the exhibitor list and map - https://leathercraftersjournal.com/rocky-mountain-leather-trade-show/exhibitors/ Hope to see you there! - Bruce and Rundi
