bruce johnson
Moderator
  1. No matter what the illustration shows, it is easier to taper your thread back far enough that you have a tapered section in the eye when you have finished a proper thread. This makes the thread not much larger than the needle at that pint and pulls easier. Pretty much most of my handsewing is done with the smaller of the two sizes of needles TLF sells. I can't remember if the smaller is "O" or "OOO" off the top of my head. Push the awl in far enough that the needle pulls easily by hand and you will get faster and work will be easier. If you need to, stack small discs of leather on the awl blade to set the depth and bury the awl to that depth. It will also keep you from getting rat-butt marks from the awl chuck hitting your leather. That is a real term I learned from an esteemed maker in Texas. If you make a slit type hole with the right awl blade, each successive stitch will press and close up the previous hole more. Another advantage to angling the awl when you stab. Too low an angle or straight won't close up as well. If you are using pliers you are doing two things. One is you are way slower. The other is that you are putting little nicks on your needles that will abrade your thread as you pull the needles through. Another lesson I learned from my Irish harnessmaking visitor several years ago. He sewed 16 SPI with a regular awl and some 346 machine thread by eye to show me it could be done. Awesomeness would describe it.
  2. The knife is at least 100 years or better. CS Osborne changed addresses in 1906 from Newark NJ to Harrison NJ. Probably they had some old stock that still had the Newark marking after that for a while, but that is the timeline. The cross looks like a factory marking and not an owner's mark added later, but this probably not 100% for sure. They did do a size marking with "X" markings at one point. The single X was a 6-1/2" wide, the XX was 6-3/4, and the XXX was 7" wide. That is the subject of some mild debate but the old catalogs listed the X markings that way. Some people say the X was a quality mark - the more Xs, the better the knife. I don't think so. They did list a second quality knife of the same stylein the catalog for a bit less. That said, the X marked knives I have had were marked between the CSO trademark and the brass, but no reason to think they might not have got close with the makers stamp and put the X above on your particular knife. I like those CSO knives quite a bit. They are a good mix of fairly easy to profile and sharpen, but still hold their edge for a good while. I would taper that bevel back more than what it is. It looks pretty steep. It is going to take a few hours to do right, but will be worth it when you are done.
  3. At least half of my orders want the rope border. Unlike Jeff's, most of mine are not contained in bead or cut lines. Mine are beveled to stand up . I used to use the Tandy or Hidecrafter rope stamps. I wore out and bent a couple a year. A while back I got Barry King to make me two sizes as a custom order. Looks like Barry now has them as a stock item stamp now. Nothing against the Tandy and Hidecrafter ones because they made me a lot of money, but the ends bend up on them if you do many tipped impressions. I have a scan somewhere on the forum that I can't find right now comparing the impressions of the Tandy/Hidecrafter vs. Barry's and there is a difference. Here is a link to a thread a few years ago when I was still using the TLF/HC stamps - Rope stamping
  4. Several years ago I had the good fortune to have an older Irish harnessmaker spent the afternoon with me. The first thing he did was to take a shoeing rasp to my stitching horse to properly shape the ends for closer sewing. Then he took my awls and sorted through them. He picked about 5 out that were OK to his purposes, and went to sharpening. Muscle memory and all that, but about one minute each on the stones going through the grits. He raised a bur edge on the actute angles of the diamonds almost to where the taper leveled out. Stropped the bur off and then used that edge to cut leather as a test. Used them like a knife on a the edge of a piece of skirting. They sliced like a good knife. I just thought I knew how sharp they were supposed to be before that. THAT was a lesson learned. One bad awl he worked into a round point to use for oversewing with less chance of cutting the existing threads. The rest went to sharp points for a game of "awl darts". .
  5. :popcorn: Don't ya just really like a good ending.
  6. Actually your are going to have to sharpen that edger you now use too at some point. The techniques should be pretty much the same. As far as ordering a #2 and #3 and having to machine them to that size, it should have nothing to do with the size. The size designates the width, and every maker is a bit different with the same number sizes. One contemporary and a couple of old line makers are way different on their sizing number compared to others. Your #2 shoud cut a narrower edge than the #3. They should both be sharpened exactly the same way. Properly sharpened those Dixon tools will outlive your other one by years or generations. If you don't want to got through it, I'll buy them both as is without sharpening. On a side note, what is the Ebay seller you bought them from telling you? Are they reselling new tools with an Ebay store without adding any value over ordering from Abbey or Dixon straight up or was this a one time deal for them?
  7. They look just like the one I have for sale. As far as the tip profile, that is how they are. They may not come deadly sharp from the factory, so a replacement may not be any better. I don't know to what degree of sharpness Dixon goes with their new tools. Some of the old line companies did not put a final edge on cutting tools. I have not had a new Dixon so can't say. I have pulled old Osborne tools out of the paper that hand no real edge. Older guys have told me that was to put your own favored final edge profile on. I got a pretty old Dixon plough gauge knife last year with the blade having a profile somewhat but a square edge on the front - it is my most reached for user. Pretty much most tools you get are not going to be using-sharp out of the box. For new edgers, Bob Douglas and Barry Kings should be. I don't know about Ron's edgers since he sold the business. although we expect to get sharp ready to use tools when we buy them new, they mostly aren't. If they are, we are generally paying the price for the maker to do that. In some cases that doesn't mean the tool is bad - just that it takes a little time to finish it off and make it good. Sharpening up that edger might take 10 minutes. In the process you will get a feel for how hard that steel is and what you can expect out of the tool. Even the ones coming sharp will need to be worked on every so often.
  8. Been there a couple times. They have a big warehouse and kind of let you freely roam. I am pretty sure most of the hardware and tools are at San Dimas though. At least that is how it was started out for San Dimas. Lots of leather to look at and they are very hospitable. Realize that most of their business is telephone orders. The reps will be on the phone and might point you to an area, but usually are tied up enough they won't lead you through and go through the different options in every aisle. Kind of find something and they will break away to explain a particluar leather and be happy to do that.
  9. Does it look like the one I have attached? They make a flat bottom version and a hollow ground which has a rounded bottom. If it is the flat bottom then the sharpening is pretty straightforward. You sharpen them on a fine stone from the bottom until you get to a fine foil edge. Then strop if lightly from both sides to remove that foil edge. Biggest thing is to make sure you get all of the foil stropped off. For the round bottoms, do like Bill suggested and use a round base like a nail or screwdriver and wrap it with the wet-dry sandpaper. Make sure the radius matches the tool. If there are grit marks when you are finished then go to finer stone or wet-dry sandpaper and do it again until the grit marks are gone. You can strop the slot out with a thin piece of leather or the edge of a piece of cardboard from the back of writing pad works. I use green compound. I would not toss the Dixon's, I have a some Dixons I have kept and the steel is pretty good. The shorter toes are easier to do inside curves with. Pretty nice tools overall.
  10. Nice work, and I think it is fine here. This is the finished leather goods section of the marketplace. One other place I would suggest is to get listed through the home page on LW.net in the "Leatherwork Directory" where potential customers can also hook up with you and your work.
  11. I have played with one a bit, and know a guy with one. Here's a link to the wesite - MA III Series Clicker Press . I don't remember the size of the platen, but the bed is 12x9 and the head is smaller. I think I read somewhere that it translates into about 5 tons of pressure. They are pretty precision made and adjustable for die height. I saw one was demonstrated to use as an embossing press and used with letter stamps all lined too. They used to be around $1200 in memory ?? The website has a number to call for the US distributer.
  12. I am with Chuck, just let it warm up and the chunks will dissolve. I keep my oils on a shelf in my shop. In the winter the NF oil gets a little or a lot pasty or almost solid. The Feibings seems to set up less than the lower end brands. I either set the jug in front of the heater for awhile (lid loosened) or if it will pour then glop it out into my paint roller tray. I fan it with the paint stripping/glue drying gun on high until it melts. I use my NF oil pretty much outside temperature in the summer (around 90 in the afternoons) or warmed slightly in the cooler times of the year. It penetrates better for me that way. Setting the jug in the sun until it feels slightly warm is all I need. Too hot and you can scorch leather and say bad words. I use a fair amount of olive oil too. For all the reasons mentioned already plus it is less greasy feeling for products that will be handled. As far as cost, they are almost a tie for me. The olive oil costs me about $23/gal at the wholesale grocery outlet and I can buy Feibings NF from the local handy livestock supply/western clothing emporium last time for $24/gal. I can buy NF cheaper from him than ordering it and paying even nominal shipping with a mixed order. I can see the latest fashions and continue to eat crow about my prediction that the crystal fad would die out within a year. I think I said that in late 2002.
  13. Yes, with the tapered. It makes a big difference for me using anything over a 16 oz maul. Some of what I do are big pieces and I can't always reach the center if I rest my elbow and rock the maul. On my bigger baskets and block stamps I am faster and less fatigue to use heavier mauls and do one hit on the baskets or two hits on the blocks rocking the stamp one way and then the other. I can keep my elbow locked to my side and use my whole forearm with my wrist straight.
  14. You don't have to lift you arm or shoulder as high to hit the stamp level.
  15. I have gone through a few ways and this works the best for me. The backboard is a free standing display rack for beef jerky. I bent up the hooks for the pegboard and drilled a small hole in the bottom of green pill vials for the stamps. Originally I used clear plastic juice cups but the stamps and cup color kind of blended together. The green cups are an easier background to look against. The stamps sit at an angle and the heads easy to pick out. I have the sorted by type and so I can got through pretty quick to pick the ones I need. I have a small block wih holes I have on the stamping bench for the stamps pulled for a particular project. The mauls all hang right there, along with any handled tools like push bearders, creasers, or ticklers in use. The swivel knives hang on a pegboard gang hook and are all in one place. What I like about this set up is the flexibility. If I get a new stamp I can just drop into whatever cup it belongs to. I don't have to do the 'right shift/left shift" to make a spot in the organized one-to-a-hole rack I used to use. I can add a cup and break them down further is need be too. I try not have more than 10 to a cup anymore or 5 of the big blocks. The downside is that a certain maker's short stamps seem to be shaded by other stamps and are not standing right up there to see sometimes. I have been thinking about sorting those stamps into their own little corner of the world.
  16. Trox, Yes I will ship to Norway.
  17. Ferg, Yes you are right. I left out the word "easily" to change the height on that bottom roller. On this American a screwdriver or crescent wrench will do it pretty easily. The fork can bve adjusted for height on the others. They still have an upper limit, but can adjust down. Pretty much for most leathers, I leave them at the top limit. That lets me run lighter weight leathers through for edge skiving. and still have the flexibility to run thicker leathers through if I am doing skirt plugs or ground seat pieces. That is where backing off the spring tension helps to let that heavier leather go through. Still each of these machines are individuals and one might like to be more "high and tight" and the next one "low and loose". Sounds like you might need to throw a little heat to that jam nut and bolt. That is pretty much another set it and forget it deal for me too.
  18. Ferg, They can get pretty squirrely if the blade isn't all the way forward to the stop. It usually on the bracket for the bottom roller on the left side viewed from the working position. I have had one or two without a stop, but had enough experience to kind of place it without cranking the blade edge off the first turn of the handle. The leather can go under the blade, over the blade or just wad up if there is much gap. To adjust the splitting height on most, you have to adjust either side equally to be level for splitting. You want to change a split thickness, you get the wrench or screwdriver and adjust both sides again. Pretty much I use a splitter to be a splitter and skiver to be a skiver. I set the blade at an angle I like and don't change it much. I adjust the edge left on the skived piece ( some edge or feather edge) with the fence guide. For the blade "Just set it and forget it". Not an original phrase and yes, I have a Showtime rotissierre cooker too. If you are consistantly doing heavy leather then you might need to back off the tensioning spring screw on the bottom roller. On most there is a place in the frame casting that limits the height of the lower roller. They can only go so high. At least one of them has an adjustment to change the space between the top and bottom roller. The American I just got has a lever/handle to open up the rollers. There is a long bolt on that you can tighten or loosen to adjust the gap some. Nice feature I guess, but the Landis I just sold didn't have the adjustment and worked fine for several years. None of the others have had them either. On most of the 3-in-1s there was a little table on the end by the round cutter. It helped support the leather to make a vertical cut. Seems like they are broken or missing on a lot of them.
  19. Ferg, Nope no manuals for one in my shop either. I couldn't say for sure, but they may have used this frame casting as a "universal" at some point and bolted the welt roller on as an option. The American and Landis ones are fairly intuitive to figure out the adjustments. Yours look like the blade angle adjustment is done with eccentrics. I have a Progressive that I am playing with, and that is a whole nuther cat. I think I like it, but it is way different.
  20. I have a Ferdco and bought the bundled set when I bought it, and then got more. I use the stirrup plate quite a lot. It makes sewing gussets into casework much easier, especially sewing into and out of 90 degree corners. You swear a lot less than with the flat plate or holster plate. I use the left toe foot when I am sewing with a guide. I use the right toe foot whan I am sewing something with spots already set. I use the buckle feet a bit for getting close to hardware, and the holster plate gives me some clearance to tip a center bar buckle back out of the way some. I also use the right toe foot sometimes sewing next to raised area like on bucking rolls or leather covered wood picture frames. Sometimes on repair work that is a pretty narrow lip to sew, the right toe foot was off the leather. Ferdco makes a case and boot foot that is in line with the center presser foot and I bought that later - very handy. The only foot set up I haven't used much is the blanket foot. Just don't sew canvas or heavy fabric. As far as the slotted plates and bottom feeddogs, mine doesn't have them. My Adler did, but I never had near the accessories for it I do for this one anyway. I have a lube pot and use it for heavy or fast sewing. I don't use it all the time, but If I know I am going to be high speed sewing reins my needle will smoke if I don't. Same deal for slower sewing on repair work on harder leather. I use lexol in mine or some thread lube a guy gave me. I don't run the thread through the rubber gasket wipers though. No particular reason other than it takes time to thread it through. I run the thread out the hole in the top and before the thread guide loop. Between the hole and the thread loop, I stick a 1-1/2" cube piece of dry cellulose sponge with a slit partway through it for the thread. It stays in place there and wipes the excess off the thread. When it saturates the excess runs back into the hole or runs back down the thread. Every so often I might squeeze the excess back into the pot also or when I am done.
  21. Dan, I am pretty sure that is what the turnbacks are. A guy might try it on one and see. I don't think you could just fold a good one back and not break it. Heat it up and you could mess with the temper.
  22. These are some examples that I recently got in. In the top view the upper one is a round bottom edger, the middle one is a turnback, and the bottom one is a CS OSborne round bottom French type edger that will also work. It is pretty similar to a Vizzard edger, but the purist will say that only Gomph made a true Vizzard edger. It will have the toes taken back some to make the tight turns easier.
  23. For new ones Bob Douglas (sold by Sheridan Leather Outfitters), Barry King, and Jeremiah Watt all sell them. For old ones like Gomph, HF Osborne, or CS Osborne Sheridan Leather Outfitters usually has some and I currently have some round bottoms. Most of the time the turnback and vizzards I get are sold to want-list customers.
  24. When you get to tight turns you need an edger with the cutting edge out in front. Some examples are a round bottom edger, turnback edger, or vizzard edger. I use whichever is handiest.
  25. If they are only getting 10% to sell it, but $10-$30 a month to rent shelf space then they really have no incentive to sell it. The longer it sits, the more they make. The only way this would work is high dollar things that don't take up much space and sell themselves within a month.
