well, it depends - the OEM Singer medium-coarse needle plate is for needles up to #23 (22-23 is stamped on the OEM Singer 82234 needle plate). As Wiz said, the tiny spools do not hold much of the thick thread. I´m using mine for #22 needles with 138 thread but to any thicker. Keep in mind this is a repair machine and not really a machine for producing leather goods.
Cowboy CB3200 and its "performance"
Constabulary replied to TonyGreen3455's topic in Leather Sewing Machines
But this is a CB3200 and the one on Ebay that you linked in the other thread seems to be a CB3500 or similar so it is the little bit heavier type if I see this right. https://www.ebay.co.uk/itm/355819813297 I do not know the full details on these machines but as I said I would not worry too much. Just my 2 cents -
Singer 18-2 looking for information on a screw
Constabulary replied to Nico619's topic in Leather Sewing Machines
screws from other singer machines may fit as well. I´d check for Singer 16 or 31k screws but would compare the parts lists first.- 5 replies
- replacement
- parts
(and 3 more)
Singer 45K online - weak points and what to avoid?
can´t believe that no one bought it yet. If someone wonders who DCR is (I wanted to figure this) https://www.dcrindustrialsewingmachinery.co.uk/item/dcr-205sca-short-cylinder-arm-industrial-sewing-machine -
Please post a link to that statement. As you know nowadays a lot of unreflected BS is posted here and there in the WWW so knowing the source may help to figure things. On the other hand, with less than 2hrs a day I would not worry too much. Have you ever read anywhere from serious quality problems with these machines - beside user errors or not properly adjusted machines (well that both happens)? I have not. You even considered buying a vintage decades old Singer 45k with unknown millage (they could be worn out too) so I honestly would not worry to much about the newer Chinese made machines. But in the end you decide. -
Issue changing stitch length SInger 111W156
Constabulary replied to bnsmith's topic in Leather Sewing Machines
Does this help: -
singer 107w102 stitch spacing adjustment question
Constabulary replied to ddiuni's topic in Leather Sewing Machines
There is a Facebook group for 107w embroidery machines maybe they know more. https://www.facebook.com/groups/1981127628794141/?_rdr -
machine has no reverse. Turn around the material and sew over the last 2-3 stitches.
The machine is designed to make 1/2" throw - not 14mm. If you want to push it further than 1/2" you probably (I guess) have to replace internal parts that govern the needle bar - IF such parts are available at all. Don´t know if there was an embroidery or ZZ machine in this class with a 14mm throw. If it is not a parts problem you may look at the needle hook timing. Maybe this thread here helps: https://leatherworker.net/forum/topic/79721-timing-a-zig-zag-machine/ I have acquired a 107w102 recently but havent yet touched or tested it. -
its there see 2nd picture. Really - If I was in the UK I`d buy it in a heartbeat! Don´t let it go for that price! -
same as for the Juki 563 and so forth https://www.ebay.de/itm/222535571262 as it seems
looks like a 45K89 with jump foot and reverse (not sure reg. subclass though). The other one is not an Adler 205 it is a Chinese made machine similar to The cowboy CB 3500. https://www.tolindsewmach.com/cb3500.html I´m a vintage machine guy and love the 45Ks but the other one for sure is the better deal it has triple feed a larger hook and is the more modern machine (obviously). The price is a steal and I would not wait too long to buy it for that price. Rear foot is missing buy maybe its there but that IMO would not rule out buying it SOON! EDIT: Singer seems to be 45k89 as assumed - here is another one: https://www.ebay.co.uk/itm/355920387730? -
before you buy many different 328 needles I´d test one set first to see how thick you really can sew with the 328 needle and see if the needle holder does not hit the presser foot at max. material thickness.
where to start.... First of all what do you know about the 45K machine? Is it cylinder arm or flat bed? Jump foot for fixed foot? Has it reverse? Do you know what subclass it is? What does the seller know? Has he used it or is it a barn find in unknown condition? Can you test sew it? If yes buy needles & thread you want to use with the machine. Download read and print the manual (if possible) and take it with you (or PDF file on your phone) when test sewing the machine. The Adler most likely is a 205 and not 250. Same questions as above... (205 is a cylinder machine though) We don´t know the two offers so let us know what you know. Do you have pictures or a link to the offers? So we can try to figure if parts are missing or if anything is broke... What do you want to sew with it? What material and material thickness (all layers together)? -
remove the slotted axial end screw from the top shaft first. The hand wheel is attached to the shaft with 2 set screws. Remove them and if the hand wheel is not gummed with old oil (happens) you should be able to pull it off the shaft. If it does not move use a rubber hammer or piece of wood + hammer or a gear puller. If you don´t dare leave it where it is and use a speed reducer instead.
The specialty on the system 328 needles is that depending on their size they come with different shaft diameter. IIRC the 794 has 2.5mm no matter the needle size.
Needles breaking on Singer 15-91
Constabulary replied to lukeoliver1776's topic in Leather Sewing Machines
Are you probably pushing the leather materials and the needle hits the needle plate? Have you tried sewing something else w/o braking needles? Have you checked the needle hook timing? Maybe the hook tip is hitting the needle and is breaking it. -
AFAIK this type of top shaft and this type of hand wheel are no longer available new. You may find them used - somewhere - somewhen. I´d probably check on Ebay or with an "old school dealer" they sometimes have machines that they strip for parts. Dot know how much you have paid for the machine but the parts may cost more than you paid for the machine.
reg. skipped stitches - is the needle insert correctly with needle scarf toward hook tip? Maybe needle bar set a bit to high (check needle hook timing)? Hook tip probably a bit to far away from the needle? If you are looking for timing values or an English manual look for the Singer 31-18, the machine is very similar and has wheel feed too. Not sure how similar the wheel feed mechanistic is but that's the best crossover reference I think. Needle hook timing values are the same. EDIT: I have this manual: Singer 31-17,-18,-21 Instruction Manual.pdf
Pfaff 545 Identification and tension issues
Constabulary replied to Gryning's topic in Leather Sewing Machines
545 is the class the rest of the digits is a description of a sub class -
Singer 31-15 VS Brother LS2-B837?
Constabulary replied to Teradee's topic in Leather Sewing Machines
you own them both so you decide which one suits your needs best. But if it was me I´d keep the LS-2 . Why? Cause it is a triple feed machine with reverse. -
Mauser Spezial MH 2645 Tehnical/user manuel
Constabulary replied to ZlaPatofna's topic in Leather Sewing Machines
Not a super common machine here I´d say. Maybe there were used different motors at time so I would check with the manufacturer for that. or check this YT video -
Basically ALL sewing machines can sew leather it just depends on the leather. As you assumed, it could have been an edge binding machine for heavy materials. Large hand wheels were also used for slowing down the sewing speed. You have to raise the needle bar if you want to use a longer needle regarding tension - most likely your bobbin thread tension is way to high (see manual for that) or you have a way too soft upper tension spring (you may need a heavier beehive spring then) or you have a permanent upper tension release for what ever reason. F.I. knee rests against knee lift lever or if you have a foot lift pedal your foot rests on the pedal.... To figure out what the numbers on the plate mean see this thread - it may help: https://leatherworker.net/forum/topic/89283-an-introduction-to-the-pfaff-numbering-system/ Other than than check the 545 parts list there should be explanations of numbers as well. But keep in mind the plate only tells you how the machine was set up when it left the factory but not what change were done by owners or dealers afterwards (like setting is up for shorter needle). -
Have googled for it or checked the manufactures website? It took me seconds to find it.
