SooperJake
Contributing Member
Everything posted by SooperJake
  1. Are you putting two slots in for the clip or one?
  2. That's really gorgeous!
  3. Nice rig...not sure how I missed it back in October. Few questions: How secure is that type of belt clip if you had to yank the shooter out in despiration? Also, was the Pro Water Stain Tan straight out of the bottle or diluted, and how was it applied? Thanks.
  4. Yes, Veg tanned. Thanks for the tips fellas
  5. The illistration that Shooter posted makes more sense in relation the original disertation. IWB "hybrid" style holsters with a yard of leather. One brand even has its own tv show, more or less.
  6. Mike, why not SHOW us what you mean? Would sure help me out. Thanks
  7. Post said link, please.
  8. I just finished an applique ( my first lacing project ) and I've ended up with some tiny scratched from the needle. The leather is vegetable tanned dyed with Angelus Jet Black. I've tried water and my thumb, and Bick 4, rubbing vigorously, to no avail. What's a good way to prevent this in the future, beside "not letting the needle touch the leather"? Should I have put clear coat down over the dye first?
  9. And paint it black.
  10. Are all these exotics from Roje', Dan?
  11. All of your work is pretty awesome!
  12. Welcome to the Cowboy Ranch!
  13. Nice work!. Chief, the two metal plates go on the money side of the magnet?
  14. Eric, is the paracord still working for you or have you switched to vacuum mesh material?
  15. How do you keep the bag from sealing up on itself and where is the vacuum port on the bag in relation to the dummy gun or holster?
  16. Beautiful work DBL!
  17. I hone all blades, including utility and exacto blades. Many folks don't sharpen for enough..meaning they never get the two planes of a cutting edge to meet. Magnification of the edge at various stages of sharpening is a great way to explain what is going on during the sharpening process. One of those lit magnifiers may be worth getting. A USB digital microsope is a really cool teaching aid. Ideally when you initially sharpen a cutting tool, a wire burr will form. This looks like a little flap of tin foil stuck to the edge and can be moved . When you get to this point you have "sharpened" the metal down to a very thin place along the edge, and it is critical that this foil or wire edge be stropped away, not broken off. Hand stropping takes time ( I use power on some things), and the closer you get to completion, the more apt the wire edge is to break. Once you get to the "magic point" where the two planes of the cutting edge meet, and the wire burr has been worn away by the stropping compound, you are getting a tool that is truly sharp. A cutting edge is really a kind of saw. The quality of the steel (grain structure) will determine how small you can make the "teeth" at the edge. If you could make an edge achieve a thickness of one molecule, why you'd have a really sharp tool. Edge holding ability comes from hardness and bevel angle. You sharpen the angle based on the use. Typically, a scalpel has a lower included cutting angle than an chisel. Microbeveling is a technique that tricks the tool into a higher degree of sharpenness with more resistence to folding under pressure. Mallet struck woodworking chisels can benefit from microbeveling, where the cutting edge may be 15° included, and the rest of the tool beveled at 20° or more. It's also a fast way to get a lower angle as you have less metal to remove at the edge. I'm new to use of the round knife, but for some cuts, like an exterior radius on a hide that is particularly firm of hand, I find it indispensable, as I rock around to make the cut. I like a honed utility blade for long straight cuts. Clean cut leather shines, literally.
  18. What, exactly, is "an operator friend"? Does that mean they work for the phone company?
  19. Nice work! The brass buckle kind of clashes. Black, maybe? The edges look stellar.
  20. Nice work Josh. +1 on the snap. Is that Feibing's medium brown?
  21. Nice work George! Is the horse leather more difficult to form? Does it have to be wetter?
  22. I like it. It bends some of the "rules", and there ain't nothing wrong with doing that from time to time. I get a reptilian feeling from the basket weave without a boarder around it. Neat.
  23. Mike, which brand of punch has these features you describe, please?
