Content Count
392 -
Calendar
Everything posted by wlg190861
I personally would use the waist an make wristbands or take and put 3 or four pieces together with 1 1/2" rings or what ever width the extra strap is an make some belts that way. They look nice Dan
I want to make adjustable purse/shoulder straps and was wondering if any of you could tell me what is the best piece of hardware to use and where to get them I would like to use 6/7 oz leather for the straps or suggestions welcome. I was thinking on the line of something like a Conway buckle style but a Conway I don't like for this application
I have been doing a little leatherwork for a few years now and at the present time I am making a purse. My question is, I have never used alum tanned leather an was wondering if this alum tanned leather 5/7 oz would work for adjustable purse straps and can it be cut with strap cutter or is it to flexible
Alternatives To Contact Cement Prior To Stitching
wlg190861 replied to jdm0515's topic in Sewing Leather
I just use super clue before sewing, just little dabs -
Need Help! Can't Solve Cowboy Stitching Issue...
wlg190861 replied to NoPleather's topic in Sewing Leather
I bought a cb4500 a few years ago a had that problem myself at the beginning. First, make sure your top thread is threaded right and not catching on anything. What I did and works for me is I tightened my bobbin almost All the way tight an the rest of my adjusting is done on top. I can sew from 2 oz to 20oz with no problem, any adjustments needed are done on top. -
Yes I use a sewing machine its a Cowboy 4500
I will try your second method, it sounds like a good system. Now all I need to figure out is getting the right size outer sole.
I want to make some moccasins an I would like to sew a sole to them. Has any one here done this, if so, what is the best leather for a sole or can you buy rubber soles, if so where ? Dan
Thank you all Dan
Yes I dye my latigo edges all the time
Thank Bob
I am thinking of buying this sewing machine next year an my question is can you sew a circle, by that I mean can you turn the pressor foot 360 degrees while sewing ? or only forward, reverse, left or right ?
Thanks for the pattern, cant wait to make one
I am hoping someone here could explain, What is pull-up leather, How is it tanned, Is it strong leather, what is it mainly used for ? Dan
For black belts I dip them in neatsfoot oil
I was just wondering if anyone has made a purse out of upholstery leather. I have a few patterns but don't want to cut the hide if this is to thin, 2/3 oz. Sounds like a stupid question but I don't know. What is the most common thickness of leather used in purse making ?
Thanks for the links Dan
tboyce Do you have or can you design some. I will pay you. Dan
I was wondering if anyone had leather mitten patterns. I tried to make a pair of my home pattern but didn't turn out. A coworker has a pair of leather snowmobile mittens. An I would like to find a pattern so I can make some. Thanks Dan
I would be very interested in receiving a pattern of the doc. bag
I use cb4500 will work great for all your needs
I printed a copy of you biker wallet. Very good lay out an directions. You are a very kindhearted person. Thank for your generosity Dan
By adding a welt to the seam, does that make the seam stronger or is that for looks ?
Go to your local ACE hardware store and, if not in stock they can order a 6' or 8' aluminum ruler. I use a 8' an it works great
