dkbutcher
Everything posted by dkbutcher
I'll try to answer to the best of my (very limited) knowledge... Dye is not paint, it is soaked into the leather and I would guess that is why most colors get dark when you put them on the leather. You can't do any sort of primer with dye because it is a dye and not paint... so why not use paint instead of dye? There are acrylic (I think) leather paints that you could use instead of dye or you can use paint in spots that you need it. Look at the firefighter helmet shields for examples. Someone might know of a way to make dyes pop out but I don't know how. If I was doing it I would use paint in the areas that you need the bright colors but then you would also need to work at getting it to look good with the other dyed areas. Dave
How To Account For Thickness Of Laptops, Phones, Etc?
dkbutcher replied to KelseyR89's topic in How Do I Do That?
The Al Stohlman answer is to put your stitches as far in as the leather being sewn is thick. Add up all of the thicknesses of the leather being sewn together and that is your starting point but I don't think it's a hard and fast rule but more of a guideline. If I understand what you are trying to make correctly then I would do the width like this: width of laptop+stitching allowance (roughly the thickness of the leather you are sewing)+ 1/2 of the thickness of the laptop (since you will have one half of the thickness in the top part and one half in the bottom part to make the full thickness)+the bending/fudge factor. I'm not good at the bending/fudge factor yet but I would say to overestimate rather than under since it is better to have a bit too much wiggle room vs. a case that your laptop won't fit into. One of the other reasons I suggest you go a bit big is because (I just discovered today) I seem to get some shrinkage after applying the dye and it has dried. So if you make it a perfect cut out fit and it shrinks even a little bit then you're out of luck. If I was doing it I would probably add about 3/8" on each side for 3/4" total added... maybe even round it up to an even inch. That would put you just a smidge above 16", right? Do a dry run with some paper and see how it goes. I don't know for certain if that would work, hopefully you'll get a more experienced person to chime in in the next few days P.S. This is my third try to make a slipcase for my tablet. The first one was just too narrow. The second one worked fine but I didn't check my math so it was about 1/8" sticking out the end (not a huge deal and it worked great but I had a friend with a tablet that was about 1/8" shorter so I gave it to her)... this one fits perfect (I checked my math four times ). -
You would need to account for the thickness of the laptop plus your stitch allowance (the distance from the outer edge of the piece and the inner part of the stitch line) and probably a fudge factor (at least that is what I have had to do) to make sure that it isn't too tight. I'm still trying to figure out how much fudge I need to feed my creations Dave -
or doing the non-drill method if you want a slightly more traditional look... http://youtu.be/lCFTDqQaEIc
I will take a stab at it but my knowledge is fairly limited. Carnauba wax comes from the carnauba palm and is the wax with the highest melting point (I think). It is used in car waxes and things like that. Carnauba cream is a product made by Fiebings and instead of being a solid or a paste it is the consistency of lotion (no clue what the other stuff is in it to make it like that). I love the stuff. It gives your leather a wonderful smell and a beautiful shine. It does darken things up a little bit so if that's an issue then you might want to stay clear. I don't know how much protection it provides but I would guess that it is similar to shoe polishes. I've never tried Aussie but I would guess ('guess' is the important thing to remember) that it might be sort of like Montana Pitch Blend (which I also use) or Obenauf's Heavy Duty LP (which I also use and love). I consider these to be a bit more robust than carnauba cream since they are designed for protecting leather under harsh conditions... but maybe carnauba cream does too. I just don't know but I use carnauba cream on just about everything that I do. It gives a nice rich shine to things without making them look like plastic.
I'm not really experienced enough to give you "good" advice but since nobody else seems to have chimed in yet I'll tell you what I do. As soon as I'm done cutting it out I give it a very light coat of neatsfoot oil on the grain side. I give it another light coating again on the grain side after I'm done tooling/dying it and it has dried out. If I'm using thicker leather I might oil it a bit more heavily and maybe a bit on the flesh side and then give it a good 12-24 hours for the oil to completely soak in as deep as possible. But normally I use 7-8 oz. or thinner leather so I just do the two light coats. Dave P.S. But I also like to finish it up with Carnauba creme when I'm done. That is almost always the final step in my normal process.
Help-Drawing Your Own Patterns
dkbutcher replied to BarABarLeatherworks's topic in Patterns and Templates
I'm still very new to this and still trying to work out the design side of things. But... I have started using Inkscape and love it! Usually I scribble something down on paper, then try to work things out onto graph paper, then I'll make it based on my graph paper drawings. If the design works really well and I like it then I make another one but put it together with minimal glue and stitched enough so that it will stay together and I can verify that it's going to fit (really I only need to do this to things that I'm wet forming otherwise I can just skip making another one and start putting it into Inkscape) and then take it apart. Putting it together and taking it apart has the advantage of showing me where stitch lines ended up, snaps were installed, and tooling area boundaries are located. Then I make my template: I then make an Inkscape project and add everything into, including dots for approximate locations for some of the things I mentioned. I will write some notes on the template plus information about what it is and what weight leather I used. Then I save it as a pdf, print out a copy, take a bunch of painters tape loops and put them on the back of the template (I don't cut the template out... I just stick the entire sheet to the leather) and then tape it directly to the leather in the location of the hide that I plan on using. I cut the pattern out using a straight edge on straight lines as much as possible... I cut through the paper and the leather at the same time. Once I'm done "tracing" through the paper and leather then it is all cut out. I've been very happy with that method but I will be getting some acrylic templates from Joyce in the future, mostly for things with curves. This has worked well for me so far (I just started doing this a few weeks ago) and it has the added bonus of print>tape>cut>done and you can do it as many times as you can print out your design Dave -
That's what I would guess too. I'm a big fan of Resolene followed by something waxy (Carnauba creme or Obenaufs or something like that). I have had good luck with the advice you get from a lot of folks here who say to dilute the Resolene 50/50 with water, brush on a light coat and keep doing the brushing motion to remove any bubbles or even it out, let it dry (I actually keep lightly brushing until it is almost dry), and do another coat or two. I'm still a newbie myself but that has worked for everything I've done and I like the look I get from the Resolene. Some people, however, don't like the shiny look and prefer to use other things that don't give you the gloss but I don't know anything about those other options. Others will mention that you can get the same thing as Resolene with diluted Mop-n-Glo but I haven't tried that yet. Dave
What I was saying is that if you don't like the finish you get from resolene then go ahead and replace it with something else. But I like resolene and it seems to be one of the better finishes for water/moisture resistance and protecting the leather (and keeping any excess dye from getting on the user). If you don't like it then try something else
I'm still learning but I would add in 2.5 Buff, buff, and more buff and then I do resolene before carnauba cream I would keep the resolene unless it is giving you a finish appearance that you don't like... if so then you should find something to replace it. Now the people that really know what they are doing can answer Dave
I bought one of these from Goldstar Tools. To be honest, the biggest selling point was $19.95 for additional sets. All of the other presses seem to charge more for their sets than Goldstar charges for their entire setter. I don't mind spending $20 for another set but 4x that... not so much. It's not perfect, not a thing of beauty, but it works and it does the job. It has been money well spent just to preserve my sanity (snaps have been the bane of my existence) Dave
Thanks for posting this! I've sent an email and hope to attend the next meeting. I'm not close to much of anything but Okeechobee might be the closest for me. Tampa/Orlando/Okeechobee would all be about the same but Okeechobee wins because... it's not Tampa or Orlando (and the traffic that comes along with that). Dave
Book Cover
dkbutcher replied to Greenbarn's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I really wish you hadn't done that... because now I feel the need to do something like this too! (haha) I love NW coast native art! It looks really nice. Is the art done separately and glued on (that is sort of what it looks like but I may not be seeing it correctly)? Very good job. Dave -
In my (still very limited) experience you have to be careful getting a consistent amount of neatsfoot oil or you increase the chances of this happening too. The flesh side will really soak it up and will also make you want to put on more so that all of it has been oiled. This can lead to putting more in one place that another and more on one piece than another. If you don't have an airbrush to apply it with (I don't) then you have to be careful and/or just apply it to the skin side. I love neatsfoot oil and love that I can use it as a super light colored dye without using dye. But I have also learned to be careful to only apply it on the skin side on thinner leathers and be extra careful when applying it to the flesh side on thicker leather. It sounds a bit like, at least in this case, you will abandon neatsfoot oil but in other projects where you might want to use it this might be good to think about. Dave
Temporary Gluing Leather For Stitching
dkbutcher replied to superpacker's topic in How Do I Do That?
I'm still taking leatherworking baby steps... but I'm pretty sure that the temporary refers to keeping the two parts together until you can get them even more permanently together with the stitching. All of the other suggestions were cements and definitely not temporary that could be more easily pulled back apart than the Leather Weld. They are all doing the same thing as the Leather Weld. -
I'm from about 3 hours south of G-ville but would definitely make the trip up if the event was big enough Dave
You just gave me one of those "Why didn't I think of that?" moments! Thanks for posting this Dave
I have a Goods Japan #3 and recently ordered a Barry King #2. The GJ works ok but the BK is like butter If I had to do it over again I would definitely get only Barry King edge bevelers. Dave
- 12 replies
Very Simple Sheaths
dkbutcher replied to dkbutcher's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thanks a bunch! It is pretty rare that you have something that is really needed (I need a sheath for both), really simple to do, and you really like the finished product. Usually at least one of the three is not there Dave -
Here are a couple of extremely simple sheaths that I did with some scraps from other projects. You can't get much simpler than these but they are my first stitching efforts and I have learned a lot already. At this point I can tell that my awl work needs a lot of improvement and it will hopefully do that once I build my stitching pony. Both pieces are 2-3 oz. leather with mahogany dye and sewn with brown 277 poly thread. My first was for a small Swedish pocket knife. The original sheath that it came in was exactly like this. I decided to not color the edges just to see how it looks and I kind of like it on this piece. The rounded end got a bit knackered up and close to the stitching. The second is just a larger version of the sheath for my Parker shavette. This one went a little bit better but I screwed up my groove/spacing a little around the end, I didn't sew to the last spot on one end, and I keep making the end hole too big for a single pass of thread (vs. making the hole a little larger for the previous two which will have the back stitched double). This was also the first one that I glued together and I made a bit of a mess which helped my edges get a bit on the ugly side. All in all these were very fun and rewarding easy projects Dave
Welcome from Polk county (almost down in Highlands near Sebring) Dave
Nice, that looks perfect! I'll need to remember this one Thanks, Dave
It looks to me like everyone in this discussion is arriving at the same place by different routes. Dave
Well... I've been fonted and here is my pressing. I did each of these by hand just pushing the type into the cased leather. I wanted to do each separate so that I could jumble the letters. I bought a set of Stymie bold 24 pt and Stymie bold 18 pt. I can definitely tell that I will want some larger sizes so I'll be looking around for more. This is just post stamped and still wet. It'll be interesting to see how it looks after I put some dye on it and some finishing. All in all I like it! Dave
I am definitely not an authority but what came to mind was the fisherman's knot (either a double or a triple). If you tie it fairly tight then it would definitely hold but over time it will eventually loosen. But... when it is loose you can always retie it and tighten it up again. http://www.animatedknots.com/doublefishermans/ I had never heard of the barrel knot before the earlier post so I looked it up and found this: http://www.free-macrame-patterns.com/barrel-knot.html It would probably be a good idea if you are going to do more items like this to look into macrame since there will probably be a lot of overlap. Enjoy, Dave
