Everything posted by Turn n Burn
Well sounds like you know what you are doing Upcycling is always good too i cant bring myself to throw out such good steel either havnt looked into hss only used W1 and o1 so far
A Pin vice might be what you are looking for to lock the blade into. Also Look around industrial supply shops for drill rod have one close that sells 3' for about that in $ its annealed so you can just work if with files. I keep all broken and dicarded bits too but for $3 its worth knowing what and how to heat treat what you put the time into. Just temper carefully they are vary brittle. lost mine found its way out of its sheath and through my bag or i would show a pic. Thats my 3 bucks;)
I have been using Lepage low odour as i do most of my work when my son goes to bed and don't want the fumes in the house. I had some weldbond and used it when i ran out of Lepage and don't really like it takes to long and cracks sounding when flexed seems to hold but wouldn't want a customer hearing a piece cracking. Havnt seen weld wood red in Canada will keep my eye out for it.
You can make a dimmer switch wired to a plug and plug the solder iron in to it and control the heat that way also a cheap solder iron like wood burner has changeable tips i used the for wood burning until i got a pro unit.
Beer Koosie Prototype
Turn n Burn replied to jayjay's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
thats not a beer Otherwise great work -
Thanks guys thinking its time i branch out a bit figured out skulls pretty good flowers need some work love how the veiner works on leaves with a green highlight been enjoyable learning experience.
I use the re-curve blade for hair and feather cuts pierce with the point and pull back gives a thick to thin taper in the cut that is easy to control. For tight curves I use my swivel knife and cut the rest out with a scalpel or the re-curve blade.
Pig skin liner. 1/8" foam and a shoe lace rolled edge to lift it off a bit couldn't find felt in time so went this way
Looks like Im going to have to get a chain saw. Darn another tool to the collection
Need a little help with inspiration for this was going to stich it to plywood. Not so sure I like that idea anymore. I do like your idea of using a round or oval with bark on it but having a tough time finding one 24"or more in diameter which is what I will need for the length of this. Thought of using as an inlay but because of all the cuts thru the grain I dont thinkbit will weather well and I dont think it would where well so looking more at as a wall hanging. Any ideas or critic's welcome
Can I be added as well. Thanks
http://m.ebay.ca/itm/221258507166?nav=SEARCH m y mom just bought one of these machines wondering if anyanyone uses one like this and has any tips on using it. I will be making a base or stand for it probably out of steel
Depending on what you need reflective you could over lay some reflective tape or pieces from a vest I wonder how paint would hold up over time
- 8 replies
- reflective
- safety
(and 1 more)
Looks like JLS got in while I was typing the other is a mini lathe if you have a drill press thats my new burnisher my drill press is to big to bring inside
My drill press is one of my most used metal working toolsi use for leather. Drill, sand, run a flex shaft, and press for rivets although I havent tried that
Thanks again troy I didnt use blockout on everything just the light browns on the wing tips and just let it soke in good wiped areas I wanted to be lighter had a bit of water on hand to thin it out a bit to soak in and get a bit lighter shade accually worked really good dont think I would get the same results painting.
