Everything posted by rktaylor
I finally have some adapters for this press. I decided against modifying the press and chose to modify the attachments. I bought a Little Wonder 104 rivet set and anvils. I had an adapter made for the anvils. I had the rivet set turned down to fit the press. I also had a Tandy mini punch set that I never use. I had the handle modified to the press. Overall it works pretty good, but the stroke seems a little short. Randy
Anybody headed to Wichita Falls for the Boot and Saddle Show? I'm finishing a saddle to take and will post some pictures soon. Randy
Leatherman sheath
rktaylor replied to Stetson912's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Well done. Randy -
My recent builds have been with Timberline, Double L, and Swanke. I've been happy with all of them, but there are differences in cost and quality. Depends on what you want. Randy
Halter/Bridle combination
rktaylor replied to BlackDragon's topic in Saddle and Tack Accessory Items
Nice work. Randy -
Jerk Steiner Saddle
rktaylor replied to rktaylor's topic in Saddle Identification, Restoration & Repair
@bjr, Thanks for the stories. I sold that saddle about a year ago to a guy in Wyoming. I seem to recall that he knew Mr. Steiner, but I can't find any communication to confirm that. He was sure pleased to get it. Randy -
The top is 3/8" and the bottom is 13/16" (seems odd but I measured it). Stimpson steered me to another company (I don't recall the name) that made dies for 104 rivets. I'll see if I can find the name. It would be nice if Weaver parts fit it. I haven't tried to find the specs on their dies. I'm just kicking tires now as I don't have a huge need. But, if I wouldn't mind using it without a big investment. Thanks for the tips. Randy
Thanks for the comments. I have a local machinist who works for beer so the adapters should be easy (at least for me). I currently don't have dies, so I was wondering if anyone has made a similar adaptation. The Weaver dies seem affordable, but I haven't priced others. I want to make use of the tool, but I don't know much about it and want to invest wisely. Randy
I recently acquired a Stimpson 405. The driver and anvil are for grommets. Has anyone adapted one of these rivets or snaps? How about converting to another brand like Weaver? Thanks, Randy
Thanks for all the tips. I know 3 stitches are a lot and I don't have this problem all the time. I think some of the issue is thread. I have thread from different suppliers and its certainly different. Regardless, I have started back stitching 2 and then going forward. Randy
Thanks. I've never been able to 'eyeball' the second or third stitch very well. Using a stitch wheel is a great suggestion. Randy
My bottom stitches aren't clean when I start. I make one forward stitch, back stitch, then go forward to finish. I have a Cobra 4. The pictures are of the bottom and top. Any thoughts? Thanks, Randy
I love my Robert Beard pear shaders. Randy
Screws ripped out of saddle tree
rktaylor replied to Mendosa's topic in Saddle Identification, Restoration & Repair
At some point I'm going to start worrying about the bar. Once you drill and patch enough holes, there's not going to be much original wood. You could patch the holes with dowel as suggested, then drill new holes also as suggested. Pictures would help. Randy -
Looking for silver hardware for breast collar
rktaylor replied to DS-Leather's topic in Saddle and Tack Accessory Items
Hansen Western Gear has some options. I've been pleased with their buckles and conchos, but haven't bought anything like this from them. https://hansenwesterngear.com/ Randy -
Matching border stamps and basket or geometric stamps.
rktaylor replied to bruce johnson's topic in Stamping
I think that is a good starting point. Chuck is right about finding things visually appealing. Some things just look better and some just don't seem right. This is my 'medium' basket weave stamp and my 2 favorite border stamps. Randy -
I couldn't find the picture I wanted, but this is from a similar saddle. These stirrup leathers wrap around the bars, but they have the roller buckles I described. You will need to be careful about creating too much bulk under the seat hockey, so think about how the stirrup leathers and fenders are going to fit. Randy
Yes. Your books are likely showing stirrup leathers wrapped around the tree. These smaller saddles typically aren't made like that. The stirrup leathers go through the dees and usually have a roller buckle for adjustment. I'll try to find a picture. Good job putting the tree back together. Brings back some not so fond memories. Randy
The Stohlman book would also be my first recommendation. While I find that I use Harry Adams' book more often, the Stohlman book covers more methods. I hope you continue to share your progress. Randy
While I believe you will learn by working on that saddle, a lot of what you do won't transfer to full size saddles. For example the riggings and stirrup leathers aren't going to scale up readily. If you don't have a use for it, I wouldn't invest a lot of time or money. I undertook a similar rebuild quite a few years ago, but a friend wanted it for his grandkids. Good luck on the journey. It will be rewarding. Randy
I have used dye on a few saddles. If you want to dye the entire saddle, I agree with @bland and @Goldshot Ron to use drum dyed leather from the tannery. I have used Pro dye for the background on tooled areas. I am not familiar with the acrylic dyes. I would not use anything to seal it as you will want to oil it in the future. I hope this helps. Randy
Jim, I called the buyer this morning and as expected it hasn't seen much use. This was a 'one off' project for me so I can't offer much advice. @Goldshot Ronshared his pack saddle instructions after I was done. They are now in my 'instructions folder' for future reference. He might share them with you. Let me know how it goes. Randy
Dye Rubbing Off
rktaylor replied to rktaylor's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
It wasn't sweat. I don't think it was sealed. I applied neat lac with a piece of shearling and since dye came off. I'll add another coat and put it back to use. I also think I'll stick with plain liners in the future. Randy -
I have been using Gum Tragacanth and Tokonole for the past few months. Both are working fine, but I prefer Tokonole. That might change with more use, but it is my go-to at this time. Thanks for all the tips. Randy
- 13 replies
- burnishing
- edge
(and 1 more)
