blue62
Everything posted by blue62
  1. Use a liner and put the snap base in before you put the liner on.
  2. Latigo works much better for lining tack, seems to last longer than chrome tan, as far as thickness goes make you outer layer a shade thinner, for example if you want a finished piece at 14oz, use a 7oz veg and a 7oz latigo liner.
  3. No, I haven't used one, or bought a splitter at all, I've been keeping a eye out for a band knife though, .
  4. blue62
    Dashboard
    Cowboy 4500, used 207 thread
  5. blue62
    Dashboard
    Buggy dash, padded and covered in patent leather.
  6. Follow Josh's instructions and you should do just fine.
  7. One of the fustrating things of relining skirts is when you cut the single row of stitches that hold the woolskins and plugs to the skirts and find the glue that was supposed to hold the plugs in place has broken down over the years, and now the plugs are laying on your bench, it takes some extra time to reglue them and properly get them back in place. So, When I build my skirts I use two rows of stitching, the inner row holds the plugs in place, and the outer row holds the woolskins. Just thought I'd share something that may make someone's job easier in the future.
  8. I like 2 layers of 6/7 herman oak. If your interested in western holsters slickbald's pattern pack is the best $25 you could spend, it comes with very well written instructions that can be applied to alot of different things.
  9. One of the bigger reasons for no liner is cost, to line takes twice the material and adds labor. At least from a production standpoint.
  10. The other plus tax veg liner made from the same thickness as the front is it makes for a nice rigid holster that holds it's shape, kinda like how plywood gets its strength.
  11. +1 on the veg liner, mine are the same stuff the fronts are cut from, usually 4/5oz for pancakes.
  12. Use two coats on each piece, let first dry completely, let second dry to where your finger will barely stick to it, then put together and apply some pressure, such as hammering if your project allows.
  13. Big box, fold stirrups into woolskin, use cheap pillows for cushion, wrap horn with scrap wool skin.
  14. Good looking rig, for cas I'd leave the bullet loops off, so there would be room for a shotgun slide with a couple loops for a on the clock reload.
  15. They are the same needles as a 441 clone, schmetz has sizes marked a couple of different ways on there packages https://www.schmetzneedles.com/item/794-S-Needle-System-SPECIAL-ORDER-100274
  16. 277 top and bottom, get a few different sizes of needles, I think they use the same needle class as a 441 clone, I use sizes 22, 23, 24, 25 and 26, depending on the thickness of the material and how the stitching needs to look.
  17. Anything over 6 oz would sew ok in a cowboy 4500, anything less the consew 206 or a class 26 cobra would work well,
  18. Finished up a cowboy action competition rig, 7 1/2" Ruger vaqueros. Outside and the liner are 6/7 Hermann oak, Jeremiah watt buckle, saddle tan fiebings dye, finished with tankote
  19. Not a bad looking knife, the ring works well for people with hand issues, don't have to worry as much about dropping it, what did you use for a bearing under the saddle? What kind of blade is in it?
  20. Looks good, also if you run a overstitch wheel over the stitching it will even out and help set the stitches.
  21. Did you welt the seam to protect the stitching as the knife slides in and out?
