Everything posted by Big Sioux Saddlery
Can I make this brown harness black?
Big Sioux Saddlery replied to MelissaW's topic in How Do I Do That?
The harness appears to be made from burgundy latigo, which will likely be somewhat resistant to a good dye job. Latigo has waxes and oils added during the manufacturing process, and may have a finish coat, all of which will resist your attempts to change the color. To be sure, black dye, (and yes there is a "regular" Fiebings black dye, as well as an oil dye) will change the color, but you may not get good, complete coverage. Meaning there could be a tendency for the burgundy to show through the black, and a tendency for the black to rub off onto anything it touches for years to come. This can happen even with good quality black harness leather that has been drum dyed and finished at the tannery. In my experience, I have gotten more rub-off from the oil dyes than the regular Fiebings dyes. I know this goes against common opinion, but time and again, that's what I've seen in my shop. I usually opt NOT to spend the extra money on the oil dye if I have a choice between that and the regular dye. As a professional shop, I almost always turn away a job such as this, and advise the client that if they want to they can certainly try it on their own, but I am not optimistic as to a great outcome. I would be very displeased if I had specifically ordered a black harness and received one made from burgundy latigo, and I would strongly voice my displeasure to the company I purchased from. Best of luck to you whatever you decide to do. -
Can anyone identify this machine?
Big Sioux Saddlery replied to bikermutt07's topic in Leather Sewing Machines
I have seen attempts to sew harness on one of these machines. While they may have the capacity, the results are crude at best. I can't imagine trying to do fine work on one. Visibility is extremely limited by the large foot. I would save the $600 and put it toward a machine better suited for your needs. This is a flatbed machine. For heavy leatherwork, generally a cylinder arm is more useful. -
Anyone wanting to add a Singer 97*?
Big Sioux Saddlery replied to SARK9's topic in Leather Sewing Machines
THAT I would like to have seen. There is an original flour mill in Neligh, NE that was built in 1873 and still has all the original mill equipment. It is a museum now. Even though it is not leather related, it was fascinating for me to visit. I was especially intrigued by the leather belts still in place on the machinery. Made from what appeared to be perfect hides, no neck or shoulder wrinkles were visible anywhere, and the splices were nearly imperceptible. Only thing better would be finding an old harness factory still intact and original from the early 1900's. -
Saddle ID Mark Help Please
Big Sioux Saddlery replied to lilbrenda's topic in Saddle Identification, Restoration & Repair
I also have a saddle nearly identical to the OP's. Same tooling pattern, same buckstitching. Mine has the horn broken off. A customer brought it in and left it because it is not worth fixing. They are, in fact, made in Mexico, and are el cheapo saddles, not worth putting anything more than a new latigo on, because at least you can switch that to a different saddle. They are made from inferior materials, and when you look at how they are put together, it is scary that they are allowed to be sold and used. Sorry to be blunt, but I've seen hundreds of these throughout my years in business. -
There are harness parts that can hit the one inch mark pretty easily if one doesn't actively try NOT to. Tug ends and Breeching ends primarily. Although I've never made a bareback rigging, used on bucking horses in rodeos, I've been told they'll hit an inch also. Cantle bindings on a handmade saddle will definitely hit an inch, although we hand sew those.
Landis 1 thread looping on bottom
Big Sioux Saddlery replied to Alexis1234's topic in Leather Sewing Machines
I sewed on a Landis One exclusively for at least 15 years and still use one occasionally. Wiz's advice is pretty solid, as usual. One other thing that is important for this machine to do good and consistent work is for the bobbin to be wound tightly and very evenly. If you did not get a bobbin winder with the machine, you can drill a hole in the side of your bench, chuck the bobbin into a drill and insert the other end of the bobbin into the hole to wind the bobbin. I did this for many years before I found a bobbin winder. I also used a metal lathe when I had access to one for a couple years. Also, the tension plates could have a deep enough groove worn into them that they won't hold tension anymore. If this is the case, just the way the thread comes off the spool could cause enough resistance to mimic the tension from the plates and the machine sews good for a few inches, and then when the thread gets to a different spot on the spool and unwinds more easily, you lose tension and the loops show up on the bottom. As Cowboy Bob mentioned, pull the plates and check for a groove. -
I haven't yet. I get lots of requests from locals, but usually it's " Maybe I could work for you and you could teach me how to do this stuff." In other words, pay them to learn:-) I imagine someday, if I live long enough, I will have to think about what will happen to my business when I'm done and perhaps then think about taking an apprentice. I was hoping one of my three boys would take an interest, and although they have at different times all helped me in the shop, none of them wants to take over. But when I see someone struggling on this forum, especially someone who contributes as freely as you do, I'm not opposed to giving a little advice. And honestly, I'm not yet to the point (and maybe never will be) where I would be above spending a couple weeks with someone who could give ME some lessons. I don't think a person is ever too old or too wise to learn something new.
Removing the skirts from the saddle is an absolute necessity to do a reline. My normal process: Remove skirts. If they are very dirty, I might even do a pre-clean first as lots of dirt and grit will play hell on my groover. Using my patent leather groover, I cut the stitches from the top side. This doesn't ALWAYS work, but most of the time it does. Remove fleece and plugs from the skirts. Then, completely clean and very often, wet the skirts wet enough to block them back out and remove any curl. I will use weights to do that, and sometimes have to get kind of creative. I will apply some oil after the skirts have been flattened back out but before they are completely dry. I may apply another coat after they are dry, but at this point I don't want too much oil on them or it may migrate through and make gluing difficult. Then I cut and install new plugs, just as if I were building a new set of skirts. Install strings and lug straps OR re-sew skirt pockets to the skirts. Any repairs needed to the skirts themselves is generally done before gluing in the plugs. Sometimes an inskirt rigging needs major rebuilding. After the plugs are in place, I glue in the sheepskin, oversize, to allow for an even edge after sewing and trimming. Be very careful to sew in the old holes unless thee were already ripped through, in which case you'll have to make a new stitch line. On some restorations, the leather won't handle machine sewing in the old holes. I then either handsew or make a new stitch line, depending on clients preference. After stitched, I trim the plugs (they were left over size as well) and the sheepskin, and then finish the edges as I would on a new build. Then I bevel the fleece bag from the edges of the skirt, using my sheep shears and a roaching scissors to finish up. After that, I then apply one or more coats of oil, depending on how dry the skirts were to start with. Then reassemble. That is just a very superficial description of the process, and to do a thorough job, you'll have quite a few hours in it. A week would really be pushing it for me, because there is drying time for both skirts and plugs. Tow weeks makes me a lot more comfortable.
I do like Bruce does, using a patent leather tool to cut the stitches and then pull everything off. Really saves time picking stitches, although I've had some saddles where the thread was so rotten that it broke pulling the back off and there was still thread left in the holes. I feel that part of a reline job includes replacing the plugs. At least 9 out of 10 saddles that I get for relining, the skirts need re-blocking because they're all curled under. You can't do a decent job on these w/out replacing the plugs. At the top of my list of pet peeves is a sloppy relining job, and I see plenty of them come through. The skirts should look like new when you're done; re-blocked, edges perfect and even just like if you were building new, stitches back in the old holes if at all possible, completely cleaned and oiled, new strings and lug straps if it has them. I do use an electric sheep shears to trim the wool, but only after the new fleece has been stitched on, to bevel the wool back from the skirt edges. As referenced above, you do not merely trim the old fleece off, you have to remove whatever backing it's attached to, whether it's fabric or hide. I charge $350 for a reline, and honestly I probably need to go up. When a customer tells me that so and so does it for $200, I ask, ok, what does that include?? and then proceed to explain everything that's involved in doing the job properly. I've seen lots of those $200 jobs; there's one in the shop right now and I have that saddle where nobody can see it, because I don't want anyone thinking I did it! Since you already bid the job, you can do as little or as much as you are happy with, but one thing is for sure, if you do it right, you might not be happy with the money, but you'll be happy with the job and you WON'T underbid one again! Good luck Wiz.
Definitely makes a difference. One supplier's 277 is NOT necessarily the same size as another's 277. I am currently using 2 spools of white 277 from different suppliers. One is noticeably thicker than the other. Both are from reputable suppliers, but I can't run the lighter weight 277 on the top side of my Cowboy 4500, so I use it for winding bobbins. It doesn't cause an issue there. Even the same brand but different colors does make a difference. In my experience it's the colored threads that are more likely to cause issues, white being the least likely. Brown seems to be the worst out of the three colors I use: white, black, brown.
Randy, I know what a big decision buying your first machine is! I would not even consider anything with less than 3/4" lift for what you want to do. You will max out a machine with 1/2" pretty easily, and end up modifying (taking shortcuts) to reduce thickness of things you need to sew. As far as machines, there are lots of good choices. There is certainly something to be said for buying a new one for a reputable dealer, and the new "clones" are pretty user friendly. Having said that, they will never sew as tight a stitch as the old time harness/saddle stitchers (that is including the rebuilt Campbell machines.) I know I will get some arguments from that statement, but the new closed eye needle machines do not have a true thread lock on them to pull a super tight stitch. I do have a Cowboy 4500, and love a lot of things about it, but no machine has everything! If you do buy new, go with the 16" arm, you will not regret it for saddle and tack work. That may be the biggest improvement over the old machines. I have an edge guide for the 4500, but have hardly ever used it. In fact about the only time I ever use an edge guide is sewing harness tugs or rounds, and I don't do either of those on that machine. You will want to use a 346 thread on most saddle skirts, and all the heavy machines handle it just fine. Needle size is pretty important relative to thread size. My 4500 allows for very little "cheating". Meaning that very rarely can I drop a needle size while using a heavier thread than is intended for that needle. My reason for doing that would be to leave a smaller hole, with the thread filling the holes better. Closed eye needle machines typically leave a bigger, less attractive hole than hook and awl stitchers. But I would advise venturing into the used market for hook and awl stitchers only for the very mechanically inclined individuals:-) Good luck to you, there are more choices out there than ever before, at least since anyone alive today can remember.
Certainly!
You have a good attitude and seem willing to put in the hard work and pay your dues to get to where you want to be. I wish you the best of luck on your journey. Folks like you make it worth our time to teach what we know!
I think the hourly labor rate of $50 that Bob was referring to is a wage PLUS overhead expense of the shop. A full time, professional leather shop charging $50/hour is NOT going to be rolling in money, and I guarantee if the same shop is only charging $27/hour for labor, they are not going to be in business for long, or will have no opportunity to grow or expand the business. A guy doing this as a hobby with a few tools, doing most of the work by hand, and no desire to build a business or do this for a living, will make a little extra spending money at $27 an hour, if he's lucky.
I do realize that but don't care if I sell it or not. I just thought I'd offer it to you if it was what you were looking for. I stock between 50 and 100 sides at any given time, but I don't typically sell leather unless it's in a finished product. Eventually, it all gets used. I do hope you find what you are looking for.
This thread brings up a memory of a guy that came in a couple years ago with a knife he "Just couldn't find a sheath for". After about a half hour of discussion about how he wanted it made, and how unique his knife was and how he just had to carry it all the time, he asked how much I thought it would be. I don't remember exactly what I told him, under a hundred but more than fifty, he was astonished that it would be that much. Years ago, I would have done one of two things, depending on what mood I was in on that given day. I would have either lowered my price until he was happy (and it doesn't take much of that before you start to hate your job) or I would have gotten pissed off and told him to leave. But, the years have taught me a few things, so I asked him calmly what HE thought it should be worth. He said "Well, I'd think $25 would be plenty." I proceeded to explain to him the time involved in pattern development before construction even begins, and that the time to make up the pattern and possibly a mock up would exceed $25. This guy wasn't poor either. Like I've said for years, at least half my job is customer education. The guy left (didn't want to spend more than $25 on a sheath for this one-of-a-kind super-special knife) and I was fine with it. My only mistake was that I didn't ask him right off the bat what he wanted to spend. Anyway, the quality of your work warrants you asking a fair price for your time and materials. As mentioned above, you do very clean and professional looking work. I wouldn't make it for $50. But, whatever price you are happy with is the right price I guess. Best of luck to you, and very nice job on your sheaths!
Well, I've got some dark brown but I'd say it's about 4/5oz and not 3/4. I did not buy it directly from W & C; I bought it off a guy that SAID it was W & C though. I haven't used any of it, but it seems like nice enough leather. I have had some heavier W & C dark brown, and it had a little different type of finish than this leather has. If you are interested, I guess I could sell you some. If you want a picture, I could get one for you. Busy days here these days and I don't set by the computer all day so it sometimes takes a bit for me to get back to people. If you want to "click now" and have it in three days, I'm probably not your guy (gal actually).
Well, I'd might be interested but the kicker is going to be "when does she want it?" I have access to a laser and a gal that knows how to use it. But, I'm booked a long way out, and since confirmation usually happens in the spring, I'm assuming we're talking a short time frame.
I've always done it "up". When I see it the other way I always think it looks backwards although in your example it doesn't look as bad as most I see.
Just based on the style of your saddle, I'm guessing it to be an early '70's model. Around here, you'd be hard pressed to get more than a couple hundred bucks for it. It's a style that once it went out of style, you couldn't hardly give them away. I have a very similar BA saddle that someone donated last fall. It needs a little repair, and I'm not even sure if I could get the cost of repair out of it. Horseback riding today has become very specialized and people want saddles that are specific to their chosen discipline. This type of saddle doesn't fit any of our modern-day disciplines. Someone might buy it for an extra saddle to have around when their city cousins come to visit and ride, but it's not going to be a high dollar saddle, even if in good using condition. That's just my opinion, based on what I see around my part of the country. Best of luck to you.
First of all Carol, don't beat yourself up too badly. While I'm not a fan of olive oil (I use neatsfoot oil), no matter what you would have put on the saddle, it would have darkened it. Oftentimes, the leather itself dictates how dark it will get after oiling. Some leathers will darken more than others with the same amounts of oil used. There is no way that I know of, and I've been doing this nearly my entire life, and the last 25 of it as a business, that you can apply anything to leather to recondition it when it has been left dry for years that will soften and recondition without darkening. Lexol has shown me nothing on a really dried out saddle. I tried it many years ago and was unimpressed. I bought some a couple years ago for a couple saddles I really wanted to stay light, and was equally unimpressed. The reconditioning process takes many light applications over a period of time, even weeks. More light oilings will darken a little less than a few (or one) heavy application. I will use water also at different points in the process to first clean the leather, and later possibly to try to even out and get the oil dispersed more evenly. It is a long and time consuming process. Time may lessen the darkening effect somewhat and restore the color back to a more mellow tone as the oil continues to migrate throughout the leather fibers, although it will never be "light" again. A finish coat also helps the color, and can make the leather look not quite so black. On the restorations I often use Urad as a final step. It adds a nice gloss, but is not permanent so won't interfere with later oilings/conditonings. A little of the Urad goes a long way.
How to hand stitch sheepskin to saddle skirting
Big Sioux Saddlery replied to damsaddler13's topic in Saddle Construction
Never heard of that but what a great idea. Occasionally, I'll get a reline on an old saddle where if I sewed the skirts on a machine, I'd run the risk of tearing out between the holes. I dread these jobs. They are usually vintage saddle restorations and have a lot of sentimental value to their owners. I will try this next time. Thanks Toot!! Gotta ask Colonel, if sewing a set of skirts for the first time, why not just sew them on the Adler instead of pre-punching holes and then sewing by hand?- 11 replies
- handstitch
- sheepskin
(and 1 more)
