JerseyFirefighter
Everything posted by JerseyFirefighter
The most I have seen is full thickness (14-16oz) natural saddle skirting with just a small portion of the butt area reaching 20oz and over. I would be impressed if there is someone out there that can produce a full 20oz thick side. Definitely seems like that would be an oddity that comes through the tannery every now and then, or else maybe a bit more common but they split it down because no one ever needs a single piece that thick.
Brass Line 24 Snaps. A losing venture?
JerseyFirefighter replied to JerseyFirefighter's topic in Hardware and Accessories
I typically purchase 500-750 at a time just so I don't have to store the excess hardware of larger buys. With my issue I wouldnt buy any more than a hundred or two at a time until I can find a more superior snap. -
I have used both a craftool press pro with die and the more economical hand setter and anvil. I have had zero issues with any other finish I use. The solid brass seem to be the only one showing issues from time to time. Yes, the post. -
It may come down to using brass plated instead of solid brass. Thanks for the confirmation that I am not the only one. I know of other guys doing similar work experiencing the same issue. Just a shame there wasn't a better alternative/more stout brass snap to use. -
Hello there! I was curious about the forums input regarding brass snaps failing. I set a hundred plus snaps a month, and it seems like the only issues with snaps failing are predominately brass. I know it is a much softer metal in regards to other offerings, but I was wondering if anyone else has the same issues. I check every piece of hardware set. Brass posts are prone to the peen splitting in my experience. We make sure there is a nicely finished post so the I know the metal is not failing due to how it is set. I have tried setting on a standard snap anvil and I have set them on a press and die. As far as manufacturers, I have used weaver leather and even paid 4x the amount for a hundred pack on buckleguy with the same result. These snaps are used as retention pieces that has minimal pull/resistance and yet the failure rate is highly skewed towards brass. Any insight or suggestion as to a more robust line 24 snap in brass would be greatly appreciated. Thank you!
Looking for camera strap hardware
JerseyFirefighter replied to JerseyFirefighter's topic in Suppliers
I think these will do. Thanks Jake! -
I was looking into making a double shoulder camera strap and was curious if anyone had insight towards these quick release shackles. I'd prefer to find square vs round, but it seems the majority of offerings are either from Alibaba, or $25-30 for marine grade hardware used on boats. I'm figuring to make the strap these attach to to be about 3/4"w . I wouldnt mind buying in bulk because I can always make some more in the future and sell them as stock items. Thank you in advance for any assistance.
Why anyone is answering in this thread is beyond me. Unless i'm reading this completely wrong, you're frustrated as it seems with all caps in your title, and then proceed to rant that no one is giving you free business advice, particularly questions where the answers can be wildly subjective and dependent on the market for products. The whole post seems rather childish and entitled. You even take a jab at others on here for not answering your questions to your level of satisfaction. The search function is in the top right. As others have pointed out there are a number of threads covering all three of your questions. Happy hunting.
I dont have any specific stats to cite from, but at least through my own observation, the double cap is mushrooming itself against another piece of metal with a wide surface are as opposed to a jiffy rivet mushrooming itself against the leather alone. That said, I use copper rivets for my connector points for straps, and double caps where the shear/stress forces are minimal by comparison.
i like the addition of the belt swivel. I never particularly cared for the unfinished look of jiffy rivets over a double cap rivet, but also for a cosmetic perspective, the peen/ridges of the jiffy rivet may chew up the surface of the back of the radio over time. All in all good work!
Keeping an eye out to see what else you have coming.
Very nice Memphis! Congrats on the holster design. As you had mentioned, patterns for radio holsters don't really exist. It's a badge of achievement in my opinion (through much trial and error) to make one you are satisfied with. A proud Dad making his daughter something to use on the job seems that much more satisfying.
- 12 replies
- firefighter
- fire services
(and 1 more)
Mine came with a thread post top center and a lube pot before it gets threaded to the first tension disc. As far as it differs from my Cobra, there is much of a difference. Surprisingly, I enjoy sewing more with the ferdco than the cobra.. I chalk it up to ive been using it for years and the cobra is newer, so I feel like im just used to its quirks.
Aside from sharp bends and too thick of leather at the buckle turn-back, I would say the leather is very dry. which it turn makes it more susceptible to cracks. Was the belt oiled after dyeing?
Looks good. The shield for you or for a coworker?
J.H. Leather on Youtube has a tutorial on making padded dog collars. She said she uses Plastazote as a padding foam.
- 29 replies
- foam padding for leather
- closed foam padding
- (and 6 more)
Thoroughbred VS. Wicket & Craig
JerseyFirefighter replied to GoldenAge's topic in Leatherwork Conversation
They offer struck through services if you buy 50 sides and get your own "run" as they will be dyed to your specs. Nothing against W&C, but I found their bridle and latigo (besides not being struck through) has a much different appearance and feel over thoroughbred. Thoroughbred does have limitations of stock at times so you should plan your material needs ahead of time. I was also ordering with them around the time they had their dedicated salesman like W&C has a few, and I find ordering a bit easier now with thoroughbred you are always speaking with either Jeff or Brian anyway. -
Removing leather from a clicker press die
JerseyFirefighter replied to Lfrog's topic in Leather Machinery
I know since the dies are already made it might be difficult to incorporate, however Texas Custom Dies add a foam mold to the inside of most of a lot of their dies. The blade of the die cuts the leather, the foam compresses and then pushes the leather out do it does not get stuck in the die. -
Auto correct can sometimes be my best friend and worst enemy. That said I should proofread much more than I do.
They're firefighter radio straps set aside after being edge died. The floor is an epoxy pour. I had it done by a specialist out of Baltimore, DSD Paintings.
I've added a few more benches since we moved early this year. Still trying to figure out bulk leather storage when I get a restock. All in all production has increased since we're not moving things to get to other things. Hopefully the new bar (in the current back left uninhabited corner deemed "Taps and Straps" will start early 2020.
Cuz taxes didn't suck enough ...
JerseyFirefighter replied to JLSleather's topic in Marketing and Advertising
https://www.taxjar.com is a way of handling the growing complexity of the tax codes countrywide. It is however a shame that companies like this or turbo tax can thrive on an ever increasing complex tax code so that the layman is forced to sub out services. -
Wickett & Craig . . . does it normally take this long?
JerseyFirefighter replied to Chakotay's topic in Suppliers
2 weeks from W&C doesnt seem to bad. I recall that I waited that long if not longer for the few times I have ordered from them. My supplier is hit or miss when it comes to my materials that are in stock. I've learned to order at least a month ahead of time. If you want that tannery/distributors leather.. it takes what it takes. That said, asking what the turnaround time was during ordering would have saved a lot of headache.
