Everything posted by TwinOaks
Holster Leather Question
TwinOaks replied to johnggrg's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I think the general consensus is that CT should NOT be used on the interior of the holster....for the reasons you read. You can certainly try sealing it, and I can't think of a reason you can't, but you also need to be aware that it will not carve or mold like veg-tan. That means that decorative carving or stamping will not look as good, and unless you're going after a simple "bikini" holster that has no molding or retention, it won't be very useful. -
Welcome to Leatherworker.net, best site on the entire internet! For starters, check out the Paul Burnett section here on Leatherworker: http://leatherworker.net/forum/index.php?showforum=214 That has a lot of the basics and should get you well on your way. As far as practice pieces.....pretty much any image on paper should be translatable to leather. Just pick an image and start 'drawing' with your knife. Unlike some forms of art, working with leather offers an opportunity to develop your own style, completely independent from anyone else's work. You'll know it's a good style to use when you see others emulating YOUR work.
About the best you can expect from any of the lacquers is a great finish and a good buzz. I've been using Deft (spray lacquer for wood) and have been very pleased with it. It dries very quickly, and smells just like Neat-lac (spray). If you haven't tried it yet, check out Leather Balm w/ Atom Wax. It gives a nice mellow finish w/o all the fumes. Or, if you like Resolene, mix up a little 50/50 Mop-n-Glo and water.
Be very careful w/ ccleaner, it's easy to do more harm than good. I'd say the easiest thing to do is use the add/remove programs function, but since I don't use Vista, I can't point you in the right place.
http://leatherworker.net/forum/index.php?app=core&module=search§ion=search&do=search&fromsearch=1 <--- The page of results when searching for gunbelts. specifically: http://leatherworker.net/forum/index.php?showtopic=27513&st=0&p=173160&hl=gunbelt&fromsearch=1entry173160 http://leatherworker.net/forum/index.php?showtopic=26463&st=0&p=166481&hl=gunbelt&fromsearch=1entry166481 http://leatherworker.net/forum/index.php?showtopic=24110&st=0&p=153363&hl=gunbelt&fromsearch=1entry153363 http://leatherworker.net/forum/index.php?showtopic=19914&st=0&p=128930&hl=gunbelt&fromsearch=1entry128930 http://leatherworker.net/forum/index.php?showtopic=3673&st=0&p=52329&hl=gunbelt&fromsearch=1entry52329 http://leatherworker.net/forum/index.php?showtopic=12993&st=0&p=20211&hl=gunbelt&fromsearch=1entry20211 http://leatherworker.net/forum/index.php?showtopic=12760&st=0&p=4239&hl=gunbelt&fromsearch=1entry4239 These were located by doing an advanced search, listing "gunbelt" as the search term, and specifying the hoster/sheath/etc. forum in the 'where to look' category.
Yeah, sorry, I was feeling a bit lazy and didn't post the link. Thanks for taking up the slack, abn. Aspanol, the edges are hidden with a wrapped edge, sometimes called a French edge, which is demonstrated in the tutorial I so woefully neglected to link.
Any color transfer could likely be inconsistent because the color change is a result of a chemical reaction. You might try cutting a line around the negative image (on the leather) to prevent the reaction from wicking through the leather fibers.
If you want the 'tassle' end follow Aggie's advice. You could also make an eye and braid the end back into the main body, or make what effectively is a butt splice. Here's a link that you might like. it shows the 4 strand braid on a snap with a terminal eye, you'll just have to click the tutorial for the dog lead. http://myriam.dakotabraiding.com/
Best Place To Have One Made?
TwinOaks replied to jayjay's topic in Gun Holsters, Rifle Slings and Knife Sheathes
What marks? -
!?!?!? No..... EXPERIMENT!!! Really, it isn't all that difficult. I just made a Ranger-ish belt for a friend, and had nothing more to go on than a few pics. I've got another on order with a few changes, too. Just be sure to leave enough tongue to go under the buckle, no matter which belt hole is being used.
Classic Mellow Glow
TwinOaks replied to Rossignol's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Tan Kote, Bag Kote, Leather Balm, Carnuba cream, and there's something else, but I can't remember what it is. These products will allow the character of the leather to show through very well. You can also use an acrylic finish, but it needs to wear a while to achieve the right "glow". Many of the acrylics will have a 'plastic' look and feel to them when first applied. -
Do a search on this website for "biker wallet", and then click on the "how do I do that" forum and look for the tutorial by Kevin King. He takes you step by step through the production process. The thread on the biker/trucker wallet includes a pattern similar to the one you have pictured.
Folded and heat creased if you have the equipment, time, and patience. Folded and stuck down with glue or the tape that KK recommends if you have too little of the latter two.
I'm having good results with Avast!, and Comodo. It's worth the free price of admission to surf over to Geekstogo.com and look at their suggestions. Our own Johanna does (or did) a bit over there too.
Welcome to Leatherworker.net! We've got tons of info here for your perusing pleasure, and we're pretty handy in the "Help" department too. We also love pictures. So.....get some ideas on what you want to create, and if you have any questions on it, we'll be glad to help you out.
Just outstanding work Kevin. You really set the bar high for anyone doing inlays and overlays. Keep up the fantastic work.
You should be able to remove it by using a Q-tip dipped in acetone or denatured alcohol. Damp, but not dripping, rub lightly. If you happen to have any Fiebing's Deglazer, that works well too.
B, being an ambassador has nothing to do with the quality of the leather work. Those of us who are ambassadors were asked to take the position to because we're all over the board, at all hours of the day, and make the efforts to greet each new member we can and help them learn to utilize this site. We, as a group, are the 'extra eyes' for the moderators because we spend so much time here. For me, I'm not an ambassador because I've learned a lot about leather, rather, I've learned so much because I'm an ambassador. Do I spend x amount of hours per day? No. I might not be on for several days at a time, or even as long as month. We all have lives in TRW, and it's understood that life comes first. When we do spend a lot of time here, we help out with 'the little things' around the site, and I must say, periods of severe insomnia come in handy. In regards to contributing to the site....I agree. We all love this site and from time to time there are donation requests when needed. The upkeep of the website, especially as it's grown (you should've seen it 3 years ago), does require money and was one of the deciding factors to having the ad banners at the top of the page. Contributions are still needed, and the staff appreciates all those who do so. If anyone is interested in making a contribution to the site, you can click on the little down arrow by your name (top right corner on the forum home page) for the pull down menu, then click on 'paid subscriptions', or go to your profile and look for the same There's also a "Donate" box just under the 'recent status updates' box on the right side of the screen. Thanks for bringing up the little reminder about what keeps this site online, M
That looks like a pretty simple design...any chance you could make it? carve out of wood maybe? Could be another skill to teach.
Yes, you could do it, but I don't think the results would be satisfactory using a sponge. You might try just dyeing it first, then once you have a nice even coat, applying a light coat of oil. The most even coat of dye I've personally achieved is with an airbrush......although, I must admit it was a pretty thorough coating when I knocked over a bottle of dye.
" A man will stand on the side of the road for a very long time waiting for a roasted chicken to fly in." I suggest checking with Jeff Mosby at GreyGhostGraphics, and Brenda at Lasergiftcreations.....dot com. Mine was $35 +tax and shipping, from Brenda. All our communications were by email, but I described what I wanted, she sent me a 'proof' image, I okayed it, and two days later I had my stamp. Superb service. From what I have read here, Jeff has a great reputation too, but I haven't had any dealings with him.
