zuludog
Everything posted by zuludog
Have a look at www.buyleatheronline.com They have a wide range of leathers I have bought from them, and they are reliable
stupid question about using diamond chisels
zuludog replied to Alaisiagae's topic in How Do I Do That?
You could try just using the chisel as a pricking iron, then making the actual holes with an awl.....but that does mean using a sharp diamond/saddler's awl, something like an Osborne #42 or #43, which you would need to sharpen & polish before use There are plenty of YT videos on how to prepare & sharpen an awl blade -
Yes, Jo's videos are good, and an added bonus is that you get to hear a perfect Middle Class English accent If you ever want to upgrade from Tandy, have a look at Weaver Leather Supply and Rocky Mountain Leather Supplies I dye before I glue and make the stitch holes, whether it's just one side or both -
Averagely priced stitching chisels such as Tandy only come with a basic finish or sharpness, so they can be improved by polishing & sharpening the prongs yourself Make a small file by gluing some 600 grit wet & dry paper to a thin sliver of wood like a lollipop stick; or a piece of thin, stiff plastic; or a thin strip of aluminium. Than carefully polish all the prongs. This is a bit of a tedious job, but worth doing. This will remove the black coating, but that doesn't matter Lubricate the prongs before use by stroking them over beeswax When removing the chisels, hold down the leather by pressing down with a piece of wood right next to the prongs, to avoid distorting the leather and the holes I work on an old magazine. They are effectively free; and have just the right combination of resilience and support, but soft enough not to blunt the prongs. Just replace it when it's worn Mark the line of stitching with dividers. Place one tip against the edge of the leather, and the other onto the leather, with a gap of about 3 or 4mm Search on YouTube for using stitching chisels, there are several videos. Also for making pouches and wallets, you'll see how other people stitch thin leather. In fact as you watch YT videos on making any leather items you'll see the tools & techniques used Nigel Armitage has a series of videos on making pouches, starting with a simple 2 piece model, then building up to more complicated designs -
Belt length measurements and centering names on the back
zuludog replied to Maint1517's topic in How Do I Do That?
Nigel Armitage's Vimeo channel has several videos on making a belt, from preparing the pattern and making the measurements, right through to the finished item There are 100 videos on it at the moment, covering all aspects of leatherwork, with more being added all the time It's about £5/$6/6 euros per month -
Hello French Mich and welcome to the forum! I'm sure that both your English and your leatherwork are better than mine; nevertheless, you are welcome to such advice and knowledge that I have Years ago British crafts and industry were secretive and restrictive, but that has improved now. Have a look at these YouTube channels - Ian Atkinson, J H Leather, Nigel Armitage Nigel Armitage also has a Vimeo channel where he goes into more detail, but that is about £5/6 euros? per month. However it is very good, with about 100 videos on it, and he is adding more all the time
I've just seen that www.workshopheaven.com are selling a Quangsheng 30mm plane blade reduced from £14 to £6 It shouldn't be too difficult to turn it into a skiving knife or a Japanese style leather knife
Advice needed for working with Lin Cable (linen thread)
zuludog replied to NeilMott's topic in Sewing Leather
Ah yes, I'd forgotten about that, thanks for the reminder For years, before I became interested in leatherwork I repaired tents & rucsacs, and I just put the thread through the eye of the needle and that was that Soon after I became interested I went on a leatherworking course and was shown the usual method of threading a saddler's needle, piercing the thread, and locking it. I tried it for a while afterwards, but decided it was too fiddly, so I went back to just a simple pass through the eye As Toxo mentions, you can vary the length of working thread (is that the correct term? I'm sure you'll know what I mean) and the tail to make longer or shorter pulls through the work; and also spread out the wear on the thread caused by the eye. Waxed thread grips well, and fills the eye so the needle doesn't often slip off the thread of its own accord I don't tie a knot in the end of the thread; I just do a bit of backstitching or overstitching at the start. With linen thread it's held in place by friction, and with synthetic I heat seal the end of the thread after I've trimmed it -
Edge Finishing Problems
zuludog replied to DACLAP's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I used to use a Q tip/cotton bud to apply edge finish, but found it held too much and spread the Edge Kote too much. This was not helped by the fact that the thing started to disintegrate and flop around Now I use a pencil for thicker edges, say where 2 or 3 layers of 2 or 3mm leather are sewn together; they're cheap; you can vary the amount you pick up; and with a bit of practice you can control the application quite precisely For thinner edges like wallets I've seen people use a round awl, though I have yet to try it myself Those are for Edge Kote and similar dyes. For Gum Tragacanth and Tokonole I use the tip of my finger -
When you burnish the edges try not to press down too hard with the burnishing tool. Use fast strokes with only just enough downwards pressure to keep it in place and generate the heat -
Some thread is ready waxed, and some isn't. AFAIK Tiger is waxed, but you must wax Fil au Chinois/Lin Cable yourself I'd have thought that 0,8mm or 332 thread is a bit thick for watch straps, but I suppose it depends if you want a chunky look or not. Yes I expect it would be difficult to thread a #004 needle with 332, so your choice would be to use a bigger needle like #002 or thinner thread, like 532 or even 632; and 0,6mm Tiger thread, which is a fairly standard diameter for leatherwork If you are using 332 it could be that it is too thick for the holes, and rubbing on the inside of the holes, causing it to fray. Synthetic thread is less susceptible to this For threading a needle you can taper the end of the thread - either cut it on a slant so there's just a narrow point to insert into the eye at first. Or lay the thread on your cutting mat and gently scrape the end 5mm or so of the thread with the tip of a knife to feather it. Then wax it again and work it into a point and thread the eye as usual Tiger thread is synthetic, so you trim the ends and heat them which shrinks and balls up the end of the thread so the cut ends more or less vanish, and the ball prevents the thread from undoing But linen thread is a natural fibre!. All that will happen if you heat it with a flame is that it will burn. The technique with linen thread is to backstitch 2 or 2 1/2 stitches and the friction keeps it in place - JH Leather shows this on several of her videos. In fact she seems to use linen thread for most of her work - FauC and others; watch her videos and you'll see how it's used Search YT for 'thread for leatherwork', there are several videos, including one by Ian Atkinson where he compares Tiger & FauC Incidentally I have used both the linen and synthetic 'Twist' thread from RMLS and they're both excellent. They are the Chinese Yue Fung thread sold under their own label If you have problems with colours, why not tell the supplier what you want and ask them for something that matches - after all, it is in their interest to help you -
Yes, make a mock - up from cardboard or thin card like breakfast cereal packets; tape/glue/staple the pieces together. This will show you - What the finished article will look like, and the sequence of construction Then you can make patterns/templates from flat card and fiddle about with these to make the best use of your leather
I have never used an oblong punch - I can'y afford one! But this is how I use round punches, I hope it is useful for you Make sure the punch is very sharp.....I punch over a corner of my bench, where the leg is.......for the support under the leather I punch into an old magazine......this is thick enough and solid enough not to bounce or yield, but is soft enough not to damage the cutting edge of the punch.......move the leather and/or the magazine so there is always a fresh part of the magazine under the punch, and it stays over the leg Decide where you want to punch and press down by hand......this will be just enough to make a small mark; or give the punch the lightest of taps.........remove the punch and double check the position is correct......then tap with light blows, becoming heavier till you've finished the hole This is similar to the way I cut a curve in leather - draw the line with a scratch awl, which acts as a guide.....then a very light cut with the knife........ then firmer and deeper cuts tiill you're through I hit the punch with a hide mallet, or you could use wood or nylon. I think that if you use a rubber mallet that might also cause a bounce......and when you do hit the punch you should hold it down very firmly onto the leather
Have a look at YouTube videos by J H Leather. She does most of her work with a 1/2 head knife I made a Japanese style leather knife from an old plane blade, so that's another possibility......as if you don't have enough to do
Welcome to the Forum! Have a look at Rocky Mountain Leather Supply
Have a look at these YouTube videos - Making a Moulded Leather Possibles Bag by Ian Atkinson How I Make a Large Wet Moulded Leather Possibles Belt Pouch by John Wellings - Variety Channel. There are probably other similar videos, just Search around on YT They clearly show that firstly you wet mould the leather; then trim the border or flange; then glue it in place; then make the holes through both the front and back with a stitching chisel or an awl; then sew it up I don't think you could pre - prick leather that is to be wet moulded because, as you have seen there would be too much distortion and the holes would no longer line up I would cut the moulded part to the approximate shape, then do the final trimming after the sewing as that would literally give you more margin for error Nigel Armitage has several videos on making pouches where he explains about pre - pricking, though these are with plain gussets, not wet moulded However his Vimeo channel does have a video on wet moulding. There are nearly 100 videos on all aspects of leatherwork, from the seemingly simple and basic like how to cut leather or place stitching chisels to more advanced projects, and he is constantly adding more. For £3/$4 per month you get first class information and instruction
Thanks for your reply After watching Nigel Armitage's review, and others, I've just ordered two Palosanto edge bevelers, size 1 & size 2 as these seem to be the most used; I can always order more if I wish to I could have ordered directly from www.palosantofactory.com but decided to order via Etsy UK as I thought this would be a more established route Estimated delivery time is about 4 weeks; we shall see We shall also see what the total cost is after shipping, taxes, and import duties. I expect HMRC (Her Majesty's Revenue and Customs) will be the same as in any other country - they will never miss a chance to get money off you I'll report the outcome in due course
Have a look round a car accessory store at soft faced hammers. They often have alternative or interchangeable faces, such as the Thor, which you can get with copper or hide faces and a range of weights Search YouTube for soft faced hammers and dead blow hammers, there are several videos
Thanks to the Lockdown I've been saving money. I filled the petrol tank in March and it's still only 3/4 full as the only places I drive to are a couple of local supermarkets. Events, museums, and other venues are cancelled and closed. Shops and pubs have re-opened but it's a fairly joyless experience, wandering around with your face mask on or sitting inside your plastic cubicle nursing a pint, which is not what pubs & bars are about, so I've only been once, and won't go again till we're back to something like normality. Alright, that's the background, now for the important bit I have a set of Tandy Craftool Pro edge bevellers, the ones with the black rubber handles, that I got when the Manchester store had them on offer. They do the job, but I've never been too happy with them, so I was thinking of getting something better. These would probably be Palosanto, just the middle sizes to start with, #1 & #2, then others if I need them. I would be importing them from Korea; does anyone know how deliveries are at the moment, please? Or any other comments
My Dad was a carpenter, and I was brought up on oil stones. I inherited his tools, including the oil stones, and added another couple at some time. So now I have a range from coarse to very fine I follow the fine stone with a strop - 2 mm veg tan on wood, flesh side up, with Veritas green stropping compound I've tried Japanese water stones and diamond stones, but I don't like them To a greater or lesser extent knife makers only provide a cutting edge that is basic to adequate, and you are expected to do the final sharpening and polishing yourself. That's one of the reasons that top class knives that are ready to use straight out of the box are so expensive; they've done that for you; but it takes time and effort, and so adds to the cost. However, once you've got your knife into a fit state you usually only need a strop to keep it there, or perhaps occasionally a fine stone There are lots of videos on YouTube about sharpening knives, including round & head knives. I like the one by JH Leather If you use a utility or craft knife with replaceable blades, even new blades re better when they've been stropped
Ah! If you want to hang them on a wall, why use a cover at all? Drill the ends of the handles and hang them on a nail or a hook. fit a short loop of cord if you need to Or a pouch - cum - holster that you fix to the wall, and just drop the skiver into it
What size Tiger thread do I need for this chisel?
zuludog replied to brainmonster's topic in Getting Started
I'm with HADRADA on this Nigel Armitage has several YT videos on stitching chisels, and on his recommendation I chose Seiwa as shown by Hadrada, and I'm happy enough with them Obviously a top class tool such as Crimson Hide would be better, but they are very expensive, and the Seiwa work well enough if you're careful about placing them, and polish the prongs Wider spaced prongs are easier to use and sew with, so start with the distance between the prongs of 3 to 4mm, and only get closer spaced chisels after you've gained some experience, and if you decide you need to. 0,6mm dia synthetic thread will be OK for most stitching. 18/3 or 432 linen thread is about the same diameter Go to the 'Sewing Leather' section of this forum. The first Thread is all about stitching chisels, and there is a lot of good advice on there EDIT - I've just re - read your post and I see you've already bought a chisel with 2mm spacing, which is very narrow, and I think you may well have difficulty sewing with it. If you go ahead I would use thinner thread such as 0,4mm synthetic, or, as Hadrada stated, 632 linen I would get chisels with 4mm spacing - a 2 and a 4 or 6 prong - and 0,6mm thread, and get used to those first -
Hello Landfield, and welcome to the Forum The pouch is a good start Search YouTube for 'Nigel Armitage - pouches' He has made a series of videos, starting with a simple flat pouch and working up to more complex designs. Also JH Leather; she does most of her sewing with an awl Try using an old magazine as a base for making holes. It is strong enough to support the leather, but soft and yielding enough not to damage awls & stitching chisels -- and it's effectively free. Just replace it when it gets worn
The usual way of making a strop is to glue leather to a piece of wood - Search YouTube for 'making a leather strop', there are several videos. The rubber cement or the white glue would be OK Have the leather bigger than the wood, then trim it when the glue's dried Have the flesh side of the leather showing; place it on a bench with the wood uppermost; put a couple of pans of water on top and leave it overnight to set FREDK's advice on soaking the leather first is good Treat yourself to some proper stropping/honing compound, like Veritas green compound. A bar isn't that expensive, and it will last for ages
French Edge Skiver - is this going to be a problem?
zuludog replied to Alaisiagae's topic in Leather Tools
Even new blades for utility & craft knives will work better if you strop them first You can also re-sharpen them on a fine stone or fine grit paper, followed by stropping You can get skiving knives with replaceable blades, I think 'Safety Skiver' is one make. But Search YouTube for 'Japanese leather skiving knife' You'll see that it can be used for both cutting and skiving leather. They are easy to sharpen, on a fine stone or fine abrasive paper, then a strop; you'll find that on YT as well
