zuludog
Everything posted by zuludog
Edge beveled size for various leather thicknesses
zuludog replied to Aventurine's topic in Leather Tools
There are a few Japanese/Chinese/Korean manufacturers of leatherworking tools that are good quality and reasonably priced, including Seiwa; Craft Sha; Oka; Kyoshin Elle; and Wuta ..... so yes, the set you have shown will do the job, probably with a bit of sanding & burnishing to obtain a smooth rounded edge. You could also get a rounded edge by using grooved edgers, but the Wuta set will do the job and are cheap enough, though you will almost certainly have to sharpen them as shown in my earlier reply Most leatherworking tools only come with a basic finish, to keep the price down to a reasonable level; it is only the expensive custom made tools that you can use straight out of the box Read FREDK's post carefully, he mentions a carrot SLICKER, not SLICER --- edge burnishers or slickers are usually of two designs; one is made from turned wood, has a few grooves, and is tapered; it is called the carrot type for obvious reasons to distinguish it from the other main type, which is flat and sometimes called the slipper type. See here, forget the small disc, that is intended to be used on a rotary tool such as a Dremel https://www.amazon.co.uk/Leather-Slicker-Multi-Size-Burnisher-Handworking/dp/B07H2HNZWN/ref=sr_1_11_sspa?crid=OO4SJTSY7E3H&dib=eyJ2IjoiMSJ9.0Kh9hbdzio5Td_BvaeF2Ft8zz9B1-KSBStQjdvbwQreaoIkL1f9CjcgnS0eE-t8-qZDtVdV6pdbpdnpire-nFe69ZiQQf7Sp3Qcv9BabGvlm_qfro5SZtBJIU8BhwhIFlz9CYwdQbELv7NHvYk_v0exCwvV-ZSTNvgEnmms-X0h9TMrHutFjauZo7AYMQjlJH-34Bkg61iLByisJTqLrOiMHhR2UCVe3rmnEAuF6jxH-3FCsHAt-qPm1Jg55lRibO1_ejKeCRasPQU_h8ZjufjfWTDhYttCt9HlvzuaDA8c.EuKn1Sq3bKaraeDoGRNBp1S-iAId8USKdcJwZClAmjs&dib_tag=se&keywords=leather%2Bedge%2Bburnishers&qid=1720803082&sprefix=%2Caps%2C103&sr=8-11-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&th=1 Hmmm .... please excuse this question, but I have to ask -- just how much experience do you have in leatherwork? .... as some of your questions here and in other Posts are quite basic I suggest you Search YouTube for categories such as beginners leather tools - each video will be slightly different, reflecting the choices of the individual worker, but watch a few and you'll get the general idea. There are also videos on techniques such as edge beveling & finishing, saddle stitch, skiving, sharpening, and so on. Watch videos on making the items you fancy, and also simple items such as key fobs & card holders, and you'll see what other people use and how they do things. (and make some yourself!) You'll quickly realise that most leatherwork uses the same sort of methods & tools whatever you're making, so watch as many as you have the stamina for and you'll pick up instant experience You need to make a few items, starting simply then building up, to get a feel for handling leather, cutting, stitching, edge finishing, and all the rest of it These channels are good, but there are many others - JH Leather; Corter Leather; Nigel Armitage; Leodis Leather Oh, and have fun! -
As mentioned by billybop, and no doubt others to come - Sometimes the manufacturers list the size of tiny blade inside an edge beveler, either in mm or fractions of an inch, but to make things easier they give them a size number ..... so far, so good The problem is that there is no common standard, each maker has their own system or standards ...... so, for example, a size 3 might be bigger or smaller than a size 3 from other makers. The only way to obtain a consistent grading or progression in sizes is to buy all of the same type of tool However, the general rule is that you use a smaller number size on thinner leather. Some makers, but not many, give suggestions for which number to use on which thickness, but you have to search their Websites Then there's the preference of each leather worker - some might like to remove a small amount of leather, some a lot, and so they will use different bevelers on the same piece of leather ..... and then you have the choice of a grooved or flat beveler Fun, isn't it?! Search YT for Choosing the size of leather edge bevelers, there are a few videos, though I haven't watched any My guess is that you are a beginner. All I can suggest is that you buy one or two of the smaller sizes of the simple, basic, cheap beveler for about $10 to $15 that you often see, and take it from there ..... watch videos on sharpening & using ..... and videos on things you'd like to make, so you'll see what sort of bevelers they use on what thickness of leather, they might even list them. You get a better idea of the size needed if the beveler is very sharp - the key to good leatherwork is to have razor sharp tools. Search YT for appropriate videos -- this is a good one -
Firstly, Welcome to the fun! Secondly, I don't do carving/tooling/stamping Generally speaking, the leather craft kits from Amazon aren't very good, and generally again, you'd be better off putting your money towards something better ----- on the other hand, if the price is very low you'll get a good selection for little money, so it might be worth a go just to try it and get started. And from the look of those kits some of the tools are reasonable enough, so even if you keep some and dump others the overall cost would still be reasonable. However, paradoxically, if that's the right word, you need some experience to decide ..... like I said, welcome to the fun I suggest you Search YouTube for 'beginners leather tools' and similar categories, there are several videos. Each one is similar but slightly different, reflecting the preference of the individual leather worker but watch a few and you'll get the general idea. Also watch YT videos on making the items you fancy, such as wallets, belts, knife sheaths, pouches, and you'll see what other people use and how they do things There are also videos on techniques such as saddle stitch, edge finishing, sharpening edge bevellers, and so on Get a shopping list together and build up your tool kit as you need it I only know a few suppliers in the USA - Weaver, Tandy, and Rocky Mountain Leather Supply, but I'm sure other people will add their suggestions.
I have offered (or rather I have been persuaded !) to start introduction to leatherwork sessions at a local community centre. I don't know what sort of interest there will be, but I suspect only a few people I'd thought of starting with an outline of tools & techniques, followed by a couple of simple projects; a key ring & a card holder; spread over several sessions, depending on how quickly people pick it up. Any comments and advice would be appreciated
Foam will hold and absorb some of the paint but it is not so soft that it will spread and be difficult to control Search Amazon, where they sell foam swabs intended for cleaning computer keyboards. You could use a cotton bud, but they do spread a bit
- 7 replies
- how do i do that
- how to
- (and 4 more)
I have seen Nigel Armitage use a pencil to apply edge paint on some of his videos; if it's good enough for Nigel ......
- 7 replies
- how do i do that
- how to
- (and 4 more)
Don't let it get on the surface in the first place! Apply it carefully with a small foam swab or the tip of a pencil and wipe it off immediately if it spreads. Don't load them with too much and take your time.
- 7 replies
- how do i do that
- how to
- (and 4 more)
The key to good leatherwork is to have razor sharp tools, Once you get a sharp edge keeping it like that is relatively easy - little and often is the rule, and most of the time just a strop or occasionally very fine abrasive paper or a stone is all you need. For my bevellers I use a strop with green chromium dioxide compound and paper varying from 1200 to 5,000 grit There are several videos on sharpening edge bevellers, with variations on a theme, but watch a few and you'll get the idea. This is a good and simple one
Yes, that's another thing I did, getting the correct angle of attack aka the angle of incidence, as they say in the aircraft industry Get something like 2 or 3 mm veg tan leather, cut a straight edge then start bevelling --- at first lay the beveller down so it's quite flat and won't cut at all; then repeat again & again, raising the handle each time to make a steeper & steeper angle until it jams & judders, and can't be pushed any more Somewhere in between you'll find the best angle. Cut back the leather 5 or 10mm to obtain a fresh cut edge as required It is noticeable that each of the type of bevellers I used need a different angle
When I started doing leather work I got the cheap basic edge beveller that I see Tandy still sell for $9-99, and it works well enough, but I spent some time getting it really sharp Then I got a set of Craftool Pro, with the black rubber handles, in Tandy UK's closing down sale They do the job, but I need to be careful on using the correct angle or they tend to jam When I retired I treated myself to a set of Palosanto bevellers as they're supposed to be the best. They do a good job, but so they should for the price. ...... are they worth the money? Hmmmm... maybe not. Although I haven't used them I would think about a good mid priced item like Barry King; or a similar style to Palosanto such as Kemovan, George Barnsley, or Tandy's Round Edge Beveller SKU 86001 for $49-99 . I find that I keep going back to the cheap basic beveller Whatever you choose get a range of sizes to match the thickness of the leather, and keep them very sharp, there are several YT Videos about sharpening. Also the type of leather affects how easy it is to edge bevel, with softer & thinner leather being more difficult than stiffer & thicker There are videos about edge bevelling, or as you watch videos of items being made you'll see how other people do things
Have a look at YouTube videos by JH Leather, she is an excellent leatherworker, and her favourite type of knife appears to be a head knife, aka a half round knife. She uses a few different makes, including Barnsley. She has videos on skiving and other techniques, and as she makes various items you see how well she uses a head knife, for both cutting & skiving.
I like Japanese Leather Knives, also known as a Japanese Skiving Knife; I use them for both cutting and skiving. They're not so easy to find in Britain since Etsy have a ban on selling any kind of knives in the UK, but Crafts By Little Bear have a few mid priced ones that will do the job You can find the JLK listed by Tom E for about £10 and it's surprisingly good for the money, but it needs a lot of work & sharpening to get it into a decent state You will need to get them very sharp - a diamond stone and fine abrasive paper are easy to start with, and The Scary Sharp System from Workshop Heaven is good. A full system is expensive, but the sample pack is only about £10 and will be good enough for these small knives, just find your own sheet of glass or porcelain tile Also make your own strop, there are loads of YT videos and green chromium dioxide compound is as good as any Play around with the Search Box on YouTube for JLKs, skiving, sharpening, making a strop and so on; follow the suggestions, watch a few, and you'll get the idea . This is a start -
AFAIK Rocky Mountain's own brand linen & synthetic thread is Yue Fung, under their own name, and it's good stuff I've tried Ritza thread and I too don't see why it's supposed to be so good The threads I've settled on are Artisan Leather's own brand braided polyester - Chinese from a UK supplier - and Yue Fung
Ah, we're definitely going Off Topic and rambling here, but during the decline of the Roman Empire they had the choice of bringing wheat for bread or animals for the Circus from Egypt as there were only a few boats available - they chose animals
Fortunately I have already stocked up, and anyway I drink more coffee than tea If any Americans or others are wondering about the importance of tea to the British Way of Life -- a couple of years ago there was a terrorist bomb threat in London, and the police were going door to door to clear people from rooms & buildings that faced onto the street When they got to a cafe the customers refused to leave as 'we haven't finished our tea yet'
Thanks Meanwhile I've been Searching supplier's websites, and in the UK at least, Identity Leathercraft, Metropolitan Leather, and others have alternative edge finishing gums, and gum tragacanth of course. Although I haven't tried these they are reputable suppliers, and the alternatives should be OK
Do we know the current situation with Tokonole? I've heard there is a shortage It's out of stock with a couple of UK suppliers, but still listed on several Etsy UK suppliers, but of course that doesn't mean you'll get it if you order it
Knife making looks like it is a popular hobby in the USA, and I also think there are a few knife makers on here. I'm sure that if you made a request on this forum or a knife making forum someone would make a head knife for you I have a Barnsley head knife, it is made from sheet steel about 1,5 to 2,0 mm thick. Barnsley probably stamp out the shape but it shouldn't be too difficult for an experienced maker to cut it out. Then just make a long gently sloping bevel. The handle is simply turned with a brass tube ferrule.
I see you live in the USA, so I thought you might be interested in this. I think it's more expensive than those from Barnsley or Osborne, but I know that RMLS is a reputable supplier Rocky Mountain - Half Round/Head Knife - Sharp! (rmleathersupply.com) You might also consider a Japanese Leather Knife, I use one for straight cuts and skiving. They are easy to sharpen, and as with most leather tools prices range from cheap to expensive. If you're not familiar with it, Search YouTube
It is a head knife, so called as the side view looks like a bird's head. Watch YouTube videos by JH Leather, she uses one for most of her work www.georgebarnsleyandsons.co.uk usually have one, but don't appear to at the moment. In fact they seem to be reorganising their range of knives as it looks like they are selling off a lot of old stock at reduced prices Osborne also offer a head knife, but you'll have to do your own Search Generally, although these knives are not very cheap they are reasonably priced for the quality you get. They are an alternative to the more common round knife, which has two points, as they are usually cheaper, and the single point makes them easier to use. Typical price for them is about £40, say $45
Veg-Tan bellies: what to do with them.
zuludog replied to DieselTech's topic in Leatherwork Conversation
One time I bought a couple of bellies in a sale that were fairly thick, about 3mm in the middle and 5mm at the ends I made axe covers and chest protectors for spoon carving, with an extra thickness glued onto the centre of the chest protector. -
Leather bucket used by English firefighters in the past.
zuludog replied to SUP's topic in Leather History
Diverting slightly -- I have visited Fort George in NE Scotland, find it on t'Net This was built in the 1700s, and is still an active military base, though this is reduced, and a large part of the fort is now a museum The gunpowder store, now part of the museum was once lit by candles, as a naked flame was the only source of illumination at the time. The candles are placed in a small windowed enclosure that juts out into the magazine, and is sealed on the magazine side. Access and ventilation is made from outside the magazine, on the other side of the wall For similar reasons, the tools and equipment used were made from wood, copper, and brass -
Also, in the days of gunpowder, knocking and scraping a leather bucket wouldn't cause a spark This was still a consideration during WW2, when troops manning gun positions would change out of their usual nailed/studded boots into boots with plain leather soles for working in the magazines and handling ammunition -
As chuck123wapati has commented, you know your work is good enough when people ask you to make things ....... and from there it shouldn't be too difficult to ask around and sell a few items to help recover the costs of your hobby and bring in extra income....... but turning it into anything like full time employment and income would be much harder ...... and without meaning to be harsh, if you need to ask if you're ready, then you're not.
Stitching Holes on gussets and front/back don't match.
zuludog replied to PlanoMike's topic in Sewing Leather
I can't help you, but this might
