Everything posted by dikman
Appears to be in very good condition.
Newbie with questions
dikman replied to Tigdim's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Where I buy my leather they naturally also have belly. As it is cheaper I asked the chap about using it and he said while it might be ok for odds and ends he wouldn't recommend it for anything "important". It's thickness can vary and it can stretch in unwanted directions. I guess it could be ok for lining something where it can't be seen much? -
Constabulary, it's not just sewing machine gearboxes that have this problem of squeezing the grease out of the gears! Unless the gears run hot enough to melt the grease back into the gears (!) they tend to not be as lubricated as we might think. Your idea of a sticky oil is pretty good, chainsaw bar lube might also work ,it's designed to be sticky stuff and might be a bit thicker than the spray-on stuff for bike chains. Food for thought...
- 28 replies
- grease
- industrial sewing machine
(and 1 more)
Changing out a handwheel with a motor pulley
dikman replied to leecopp's topic in Leather Sewing Machines
Pulley choice came down to what I had handy - big pulleys tend to get expensive here! The one on the Pfaff is heavy enough to act as a flywheel!!! The "hand crank" I bought cheap, it is alloy and had a bit of bad corrosion at one point on the rim so I cleaned it up and gave it a coat of paint. Good enough for a hand crank. -
Constabulary, yes, if you like the "traditional" look on old machines then you definitely won't like this setup! Wiz, that, of course, is something to be aware of. Careful selection of the pulley is important, if they're pressed steel then not good, but cast pulleys can be smoothed over. In my case(s) they have substantial rims that are smooth. I do a lot of handwheeling and haven't had any issues. Matt, both machines have 550w servos with small 45mm pulleys and I haven't had any problems (and I tend to sew slow and creep the needle along!) -
Yep, I did this on two of my motorised machines (photos here) - It works well. -
True, my idea only works if you've already got a suitable machine, it would be false economy to buy a sewing machine just for pre-punching holes. If you have to buy something then a drill press makes more sense. -
I use one of my sewing machines for pre-punching the holes in my holsters. No thread, a 140 needle and I handwheel it, makes it easy to keep the holes straight! -
Not necessarily. I bought one 'cos it sounded like a good idea (being a newbie), tried it out but didn't really like it much - because I tend to sew slow there''s no real advantage in having it. For someone who sews fast, however, I can see where it could be quite useful. By all means try it out, who knows, it may suit your needs/sewing style.
In one case I used an existing pulley that I had in one of my spares boxes, the other one I happened to pick up a cheap old pulley at a junk yard. In both cases, though, I had to make sleeves to fit them on the shafts (Pfaff and Seiko machines). I forgot that I also fitted one to a Singer so that I could hand-crank it. Might not necessarily look pretty but it slows things right down and they're good for hand-wheeling too.
Building a speed reducer will help, also fit a 45mm pulley on the motor (every little bit helps!). Another possibility (instead of a speed reducer) is to replace the handwheel with a large pulley, I've done that on a couple of my machines and it works well at slowing things down.
Incidentally, I have an older Pfaff 335 that has a manual upper tension lever, i.e. even if the presser foot is lowered until I operate the tension lever the two tension discs stay apart. If I forget this and start sewing when there is minimal tension on the upper thread, guess what the result is? A massive bird's nest underneath which eventually jams the bobbin case!
rifle stock shell holder
dikman replied to JHayek's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Picks up jaw from floor......... -
" I admit I may have gotten carried away" What makes you think that? Very nice work. -
The W machines were made in the USA, at the Bridgeport plant, and the story goes that all their records were destroyed in a fire a long time ago. I've been unable to find any info regarding serial numbers on W machines so I figure the story is probably true.
Lining for Shotgun Case
dikman replied to rktaylor's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Does it come from synthetic sheep? -
Vinegaroon mix is brown?
dikman replied to dikman's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Thanks guys, I wondered whether adding more vinegar would make any difference. -
I made a vinegaroon mix several months ago. I decided to use it on a cartridge holder strap and when I poured it into a container it's gone a light muddy brown! I used it anyway and it worked fine on the leather, but I'm curious why it's changed colour in the container (plastic bottle). Anyone have any ideas?
No reason it wouldn't work, although it seems like overkill to me (why not paint wood to get the hammered finish?). If you were fitting a cylinder arm machine then it would minimise the cutting needed, but I wouldn't fancy making the cutout for a flat bed - unless you've got access to a CNC laser cutter! Even with the right tools steel still requires more work and effort to finish (which you probably already know).
Yep, they do have a tendency to act as a money sponge.
You don't have to remove the motor, but unless you're Hercules it makes it much easier (and safer) to get that dead weight off the table before trying to load it into a vehicle (I'm assuming here that you're by yourself, if you have a mate with you then that's different).
I've done this to several (different) tables, I take a set of socket spanners (metric and imperial), a couple of adjustable wrenches, assorted screwdrivers (flat and philips), assorted pliers, a pair of locking vice-grips and a cordless drill (probably not necessary but I take it anyway) - you never know what problems you might run into. Don't forget to take some old cloths as it can be a grubby job! Remove the head unit and turn the table upside down to remove the motor (heavy!!) and dismantle the legs if needed (I find it better to do this as it makes everything manageable).
Sounds like you need another machine , one designed to use a roller foot.
- 22 replies
