Everything posted by fredk
That is a thing of real beauty there I guess the symbol is a ranch brand? How is it read?
Most excellent What weight, or thickness, of leather did you use? And did you use a wire around the edge of the brim to make it hold its shape?
A comfortable knife, easy on the turn and no wobble, but its the blades that matter really edit; here is the review YinTX refers to;
This Art Form Is Going Straight To Hell
fredk replied to Reegesc's topic in Leatherwork Conversation
In my area some women have turned 'scrapbooking' into a paying hobby. Folk bring them their cuttings, old cards, old letters etc and they put it all together into what we used to call in child fostering a 'memories book' -
I have two. One from Le Prevo, cost about £10 its ok. Another I got from China via ebay, it cost me under £5, and I think its better than the other. No play in it and it seems to turn smoother.
My 60mm is a Fiskars, like this one; Push the orange thing on the top and it pushes the blade out to the cutting position, it also makes the orange button on the side pop out. Press that button and the blade snaps back in to the safe position I'm not sure what make my 28mm is now, its got no name on it. I thought it was an Olfa. I've had it for several years now. Its got a head on I can set at any angle, in line with the handle. I store it so its in-line and set the head/blade at about 30 to 45 degrees for cutting I cannot compare the two as I've only ever owned these ones
Must be a difference in knife model. On mine, 60mm & 28mm, the blade guard remains fixed and the blade is moved out to the cutting position. I no longer have the 45mm, I passed it on. Looking at the 28mm again, I reckon I can cut away some of the blade guard to make it more useful.
Proops sells through ebay as well. Though I'd hardly describe what they sell are 'man-toys' ~ they sell tools, tools for making things https://www.ebay.co.uk/sch/Business-Office-Industrial/12576/m.html?ssPageName=STRK%3AMEFSXS%3AMESOI&_ssn=spoorp&_sop=15 I second the use of a rotary blade knife. Invest in a 60mm diameter blade one by Fiskars or Olfa. Not only are their blades superior but the knives themselves are more ergonomic. Plus, I've found, the best of these knives slide the blade down to the working position, from its safe position. The 28mm and 45mm knife blades don't clear the handle by more than about 1mm, not enough to cut through 1mm leather. The 60mm comes down further.
Does anyone know the correct name for this?
fredk replied to ThoughtFission's topic in Leatherwork Conversation
That looks like a bespoke piece but I reckon a ball-head from a camera tripod could do the job. Use a heavy weight duty one from the likes of Manfrotto -
ooops, sorry, I was talking about placing ready-rivets, not brass rivets which need a setter.
1. You must be using really thin leather. I can cut as thin as 1mm with my strap cutter 2. plan ahead. cut a wide piece of leather, enough for several straps. turn this over and glue to the main hide. then use a strap cutter to cut the double thickness in strap widths as needed. using a fresh sharp blade you'll get a nice clean cut edge which won't need any sanding
a wee tip idea for placing those rivets into hard to reach places, 1. cut a length of thin card, thinner than cereal box card, but that would do 2. a few mm from the end poke a small hole, small enough to hold a rivet step fast. don't punch the hole, you need the card that forms a rough ring around a poked hole 3. use that assembly to take the rivet to its hole in the leather and push it thru that hole 4. when its in place snap on the head. most rivet heads snap on tight 5. either then or slightly later, give that card strip a good hard tug to rip that few mm at the end, allowing it to come free of the rivet. if you use thicker card, partly cut thru the card from the hole to the end of the strip to help it rip away 6. smash down the head of the rivet, using your favourite hard long anvil as backing I have a couple of lengths of 3mm steel bar and an odd shaped bit of 6mm steel plate as insert anvils.
Beginning Sewer looking for general advice
fredk replied to MtlBiker's topic in Leather Sewing Machines
We have a specific section on Leather sewing machines and sewing leather. Either re-post your queries there or get a Moderator to move it there https://leatherworker.net/forum/forum/50-leather-sewing-machines/ -
If that doesn't turn out I bought a set of these, I use them with my press. 7 sizes from 20mm to 50mm, going in 5mm steps, includes a 40mm https://www.ebay.co.uk/itm/7Pcs-DIY-Leather-Punchers-Craft-Cutter-Mold-Die-Round-Hole-Punching-Tools-Kit/353080017082
I'm confused about the purpose of some of these products
fredk replied to Chris623's topic in Getting Started
I've no experience of Edge Kote. Edge paint is as thick as non-drip paint. You put it on with a spatula or one of these roller type jobbies I've never had a problem of it peeling. Perhaps its the way I put it on? I do only really use it on pre-dyed chrome tan. I get a colour to match. eg I have a load of lavender coloured leather so I got some edge paint to match as neither the raw edge no black looks good on it -
This is true. You and I would have a meter and know how to use it but I'm reckoning the OP doesn't have one and gave the basic search instructions
Yes. For that reason I only use for edging the same colour as the front & back You can get 'edge paint' which is thick and doesn't bleed down off the edge -
Obviously you have a power supply lead grounding somewhere. Un-plug the machine from the power supply socket. Then start by taking the plug apart and going over the power lead to see if there is a bare wire or a break in the power lead. Go over it carefully, inch by inch, look closely, bending the power lead back and forth, work along it. If you see nothing there, check the switch unit in the machine for a bare or broken broken power lead, then check from the switch to the motor. Remember; always keep the machine un-plugged from the mains power supply whilst checking the power leads
Try mixing up a strong solution of pure lemon juice and water and soaking the piece in it for a few days then hang up in an airy place to dry.
a. We are all constantly learning b. Its good to aim for perfection but never worry, none of us has ever achieved that (well, I do all the time, ) We just have to accept that our efforts will fall short but at least we tried! c. By pushing the envelope we learn new things and new ways and discover what we can or cannot do. Its better to try and fail than to sit back and think 'I can't do that' d. It won't be long till you try again. Its like that old silly saying about falling off a bicycle/horse, get right back on it and try again, and again. . . . -
Which camouflage stamps and which backgrounder have you? Which are you going to use? The numbers on the handles would do for info. Is your plan to use the camo along the border above and below the 'makers' stamp area? I'm just trying to get a picture (in my head) of your design.
Mycelium is the fibrous part of certain fungi. It sounds like this stuff makes a sort of suede felt in composition
