Everything posted by fredk
Try letting them soak in lemon juice for a few hours
Its possibly a black lacquer and normal paint stripper wont work on it. You could try a soaking in lacquer (cellulose) thinners, otherwise its a case of sanding it off with a very rough grade of grit. When replacing it I would use Hammerite Paint. As Hammerite is fairly thick you could just paint it over the old paint and the patches wont show. Hammerite comes in many colours so you can also choose one you like
Pink?
fredk replied to toxo's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
yes -
Pink?
I found Fiebings Oxblood came up pink -
It seems we favour pliers I use these very long ones for where I can't get my fingers. i.e. inside dice cups, these pliers are used to pull the needle through. I have two other pairs but they just not as long but very nearly Its not often I can't pull a needle through but when I can't I use these pliers. They are also used when I'm putting flat lace on the lacing needle, they are used to press the lace down onto the prongs without damaging the prongs A piece of cork used when I'm making a hole with an awl. Its used to back up and support the leather so the awl goes into it, not my fingers (!) Small pieces of cork with mapping pins. I use these to hold parts together whilst I sew them up I wouldn't be without my anvil. Used as its supposed to be for hammering and shaping things, eg setting ready-rivets but its also a good weight to put on pieces glued up
I think; The general public doesn't know all this. The newspapers reported, correctly or not, of peoples card details being stolen, the public read this and believed it. The fitting of RFID blocking material is like a comfort blanket to the public There was a similar 'scare' when we used the paper and roller system. Where the card was put in a hand operated machine, a paper receipt put on top. A roller was run over them and the card details were impressed into them, then we signed the receipt. The 'scare' was the shop was making two copies and the second was put thru with the first for payment; you were paying twice.
I've found that even mass produced knives that are supposedly exactly the same can have small differences which affect their fit in a sheath
I made a batch of Bee's Wax, Paraffin Wax and Rosin. Inspired by this discussion started in 2011 and woken up last December ; As usual I made too much I have 3 lots of five T-light size pieces to give away. They were made this size so they would fit in this thread waxer (not included) I also have 3 bigger sized ones and 2 even bigger. The really big ones are in a small pie dish, the smaller are in bun dishes This stuff is seriously sticky. I had to destroy the T-light holders to get the wax blocks out If anyone wants a share of these PM me Its all Free, including UK postage
I finally got making a batch of this
Dyeing whilst the leather is damp helps the dye spread though the leather evenly I would wrap a piece of sponge in a cloth and use that to apply the dye. Do a certain area all at one time, eg all of the brim, both sides, then the crown and then the crown shaper Keep a 'wet' edge. Say, on the brim start at the front centre, doing a bit on the left side, then on the right side, go back and do more on the left side, then more on the right until you meet up around the centre back
7 monthly report. 26th April 2024 Pieces treated and kept on the top of the dash in the south facing windscreen (windshield?) of a car #1; Baby Oil; Colour = Dark, Flex = Stiff 7/10, Smell = No Smell, Other (fungus, deterioration ) = 0 #2; Cooking Oil (rape seed); Colour = Dark, Flex = Stiff 7/10 , Smell = very slightly 'leather', Other = 0 #3; Lard (pork fats);Colour = Light, lighter than Control #1, Flex = Moderately stiff 5/10, Smell = A hint of oil, Other = surface feels a bit 'greasy' #4; NFO Compound; Colour = Dark, Flex is good, 4/10, Smell = neutral, Other = 0 #5; Olive Oil; Colour = Dark, Flex is good 3/10 Smell = very slightly of oil, Other = 0 #6; 3-in-1 Oil; Colour = Dark, Flex is stiff 9/10. Smell = Slight smell of leather and a hint of oil, Other = 0 #7; Vaseline; Colour = Light, lighter than Control #1, Flex is stiff 6/10,, Smell = faintly of 'leather' Other; Surface feels very greasy #8; Control #1; kept with #1 to #7; Flex has stiffened, Colour = mottled light and slightly darish, Flex = Stiff 7/10, Smell = Neutral, Other = 0 - Thats all for now I'll be back soon with a report on the pieces kept outside, in rain, sunshine and wind
I don't 'click' on unknowns Looks like you just glue them in
That narrows it down to about 30 possible places in 7 miles I think we were using the same chap though ebay. I was in touch with him and he was going to make some plates for me. Shortly after the Russian attack he was taken off ebay, as many more in Russia and then his website and email were taken off the system. I tried a few times to contact him but with no success.
I don't see photos of them, only odd attachments
I finally got around to making some pouches for my stitching chisels. They've been in a small box in my tool box, all mixed together. Now I won't have to waste time sorting them out each time I need them. Nowt fancy, just some scrap upholstery grade leather, cut into strips, folded over and glued along the edges and a resin snap added to keep them closed. I'll have one more to do soon as I've ordered 5mm chisels
All dealings with anyone in Russia are banned. Their websites have been taken down on Western servers. I. too, bought some embossing plates, it may have been the same chap
If you have a small motor-tool like a Dremel, with reverse; try using a small drill bit in reverse. The drill bit won't drill but it may grip enough to grip the screw and unscrew it
Using a creaser along an edge; I go very lightly at first to get a good line, then progressively press harder on each pass. It may take me as many as 6 passes to fully complete a crease. It doesn't take very long. Any tough spots are dealt with Using an edger; If I run into a tough spot I turn the leather round and come at it from the opposite direction. This usually deals with it, If not I by-pass it and trim it with a scalpel
